1.5KE SERIES
1500 WattsTransient Voltage Suppressor Diodes
DO-27
Features
Plastic package has Underwriters Laboratory
Flammability Classification 94V-0
1500W surge capability at 10 x 1000 us
waveform
Excellent clamping capability
Low Dynamic impedance
Fast response time: Typically less than 1.0ps
from 0 volts to VBR for unidirectional and 5.0 ns
for bidirectional
Typical IR less than 1uA above 10V
High temperature soldering guaranteed:
o
260 C / 10 seconds / .375”,(9.5mm) lead length
/ 5lbs.,(2.3kg) tension
1.0 (25.4)
MIN.
.042 (1.10)
DIA.
.037 (0.90)
.375 (9.5)
.335 (8.5)
.210 (5.3)
.190 (4.8)
DIA.
1.0 (25.4)
MIN.
Mechanical Data
Case: Molded plastic
Polarity: Color band denotes cathode except
bipolar
Dimensions in inches and (millimeters)
Maximum Ratings and Electrical Characteristics
Rating at 25 oC ambient temperature unless otherwise specified.
Single phase, half wave, 60 Hz, resistive or inductive load.
For capacitive load, derate current by 20%
Type Number
o
Peak Power Dissipation at TA=25 C, Tp=1ms (Note 1)
Steady State Power Dissipation at TL=75 oC
Lead Lengths .375”, 9.5mm (Note 2)
Peak Forward Surge Current, 8.3 ms Single Half
Sine-wave Superimposed on Rated Load
(JEDEC method) (Note 3)
Maximum Instantaneous Forward Voltage at 50.0A for
Unidirectional Only (Note 4)
Symbol
PPK
Value
Minimum1500
Units
Watts
PD
6.5
Watts
IFSM
200
Amps
VF
3.5 / 5.0
Volts
Operating and Storage Temperature Range
TJ, TSTG
-55 to + 175
Notes:
1. Non-repetitive Current Pulse Per Fig. 3 and Derated above TA=25oC Per Fig. 2.
2. Mounted on Copper Pad Area of 0.6 x 0.6” (16 x 16 mm) Per Fig. 4.
3. 8.3ms Single Half Sine-wave or Equivalent Square Wave, Duty Cycle=4 Pulses Per Minutes
Maximum.
4. VF=3.5V for Devices of VBR ≤ 200V and VF=5.0V Max. for Devices VBR>200V.
o
C
Devices for Bipolar Applications
1. For Bidirectional Use C or CA Suffix for Types 1.5KE6.8 through Types 1.5KE440.
2. Electrical Characteristics Apply in Both Directions.
Revision:20170701-P1
ht t p : //
www.lgesem i .c o m
mail:lge@lgesemi.com
1.5KE SERIES
ELECTRICAL CHARACTERISTICS (TA=25OC unless otherwise noted)
1.5KE SERIES
Uni-polar
1.5KE6.8
1.5KE6.8A
1.5KE7.5
1.5KE7.5
1.5KE8.2
1.5KE8.2A
1.5KE9.1
1.5KE9.1A
1.5KE10
1.5KE10A
1.5KE11
1.5KE11A
1.5KE12
1.5KE12A
1.5KE13
1.5KE13A
1.5KE15
1.5KE15A
1.5KE16
1.5KE16A
1.5KE18
1.5KE18A
1.5KE20
1.5KE20A
1.5KE22
1.5KE22A
1.5KE24
1.5KE24A
1.5KE27
1.5KE27A
1.5KE30
1.5KE30A
1.5KE33
1.5KE33A
1.5KE36
1.5KE36A
1.5KE39
1.5KE39A
1.5KE43
1.5KE43A
1.5KE47
1.5KE47A
1.5KE51
1.5KE51A
1.5KE56
1.5KE56A
1.5KE62
1.5KE62A
1.5KE68
1.5KE68A
1.5KE75
1.5KE75A
1.5KE82
1.5KE82A
1.5KE91
1.5KE91A
1.5KE100
1.5KE100A
Bi-polar
1.5KE6.8C
1.5KE6.8CA
1.5KE7.5C
1.5KE7.5CA
1.5KE8.2C
1.5KE8.2CA
1.5KE9.1C
1.5KE9.1CA
1.5KE10C
1.5KE10CA
1.5KE11C
1.5KE11CA
1.5KE12C
1.5KE12CA
1.5KE13C
1.5KE13CA
1.5KE15C
1.5KE15CA
1.5KE16C
1.5KE16CA
1.5KE18C
1.5KE18CA
1.5KE20C
1.5KE20CA
1.5KE22C
1.5KE22CA
1.5KE24C
1.5KE24CA
1.5KE27C
1.5KE27CA
1.5KE30C
1.5KE30CA
1.5KE33C
1.5KE33CA
1.5KE36C
1.5KE36CA
1.5KE39C
1.5KE39CA
1.5KE43C
1.5KE43CA
1.5KE47C
1.5KE47CA
1.5KE51C
1.5KE51CA
1.5KE56C
1.5KE56CA
1.5KE62C
1.5KE62CA
1.5KE62C
1.5KE62CA
1.5KE75C
1.5KE75CA
1.5KE82C
1.5KE82CA
1.5KE91C
1.5KE91CA
1.5KE100C
1.5KE100CA
Breakdown voltage VBR @ IT
Min (V)
Max (V)
6.12
6.46
6.75
7.13
7.38
7.79
8.19
8.65
9.00
9.50
9.90
10.45
10.80
11.40
11.70
12.35
13.50
14.25
14.40
15.20
16.20
17.10
18.00
19.00
19.80
20.90
21.60
22.80
24.30
25.65
27.00
28.50
29.70
31.35
32.40
34.20
35.10
37.05
38.70
40.85
42.30
44.65
45.90
48.45
50.40
53.20
55.80
58.90
61.20
64.60
67.50
71.25
73.80
77.90
81.90
86.45
90.00
95.00
7.48
7.14
8.25
7.88
9.02
8.61
10.01
9.56
11.00
10.50
12.10
11.55
13.20
12.60
14.30
13.65
16.50
15.75
17.60
16.80
19.80
18.90
22.00
21.00
24.20
23.10
26.40
25.20
29.70
28.35
33.00
31.50
36.30
34.65
39.60
37.80
42.90
40.95
47.30
45.15
51.70
49.35
56.10
53.55
61.60
58.80
68.20
65.10
74.80
71.40
82.50
78.75
90.20
86.10
100.10
95.55
110.00
105.0
ht t p : //
IT (mA)
10
10
10
10
10
10
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
Maximum
Reverse
Leakage
IR(uA)
@VRWM
1000
1000
500
500
200
200
50
50
10
10
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
Maximum
Working
Reverse
PeakRevers
Surge
e Voltage
Current
VRWM
Ipp(A)
@10x1000us
(Volts)
sinewave
5.5
139
5.8
143
6.1
128
6.4
133
6.6
120
7.0
124
7.4
109
7.8
112
8.1
100
8.6
103
8.9
92.6
9.4
96.2
9.7
86.7
10.2
89.8
10.5
78.9
11.1
82.4
12.1
68.2
12.8
70.8
12.9
63.8
13.6
66.7
14.5
56.6
15.3
59.5
16.2
51.5
17.1
54.2
17.8
47.0
18.8
49.0
19.4
43.2
20.5
45.2
21.8
38.4
23.1
40.0
24.3
34.5
25.6
36.2
26.8
31.4
28.2
32.8
29.1
28.8
30.8
30.1
31.6
26.6
33.3
27.8
34.8
24.2
36.8
25.3
38.1
22.1
40.2
23.1
41.3
20.4
43.6
21.4
45.4
18.6
47.8
19.5
50.2
16.9
53.0
17.6
55.1
15.3
58.1
16.3
60.7
13.9
64.1
14.6
66.4
12.7
70.1
13.3
73.7
11.5
77.8
12.0
81.0
10.4
85.5
10.9
www.lgesem i .c o m
Maximum
Clamping
Voltage
Vc (Volts)
@Ipp
10.8
10.5
11.7
11.3
12.5
12.1
13.8
13.4
15.0
14.5
16.2
15.6
17.3
16.7
19.0
18.2
22.0
21.2
23.5
22.5
26.5
25.2
29.1
27.7
31.9
30.6
34.7
33.2
39.1
37.5
43.5
41.4
47.7
45.7
52.0
49.9
56.4
53.9
61.9
59.3
67.8
64.8
73.5
70.1
80.5
77.0
89.0
85.0
98.0
92.0
108
103
118
113
131
125
144
137
1.5KE SERIES
1.5KE SERIES
Uni-polar
1.5KE110
1.5KE110A
1.5KE120
1.5KE120A
1.5KE130
1.5KE130A
1.5KE150
1.5KE150A
1.5KE160
1.5KE160A
1.5KE170
1.5KE170A
1.5KE180
1.5KE180A
1.5KE200
1.5KE200A
1.5KE220
1.5KE220A
1.5KE250
1.5KE250A
1.5KE300
1.5KE300A
1.5KE350
1.5KE350A
1.5KE380
1.5KE380A
1.5KE400
1.5KE400A
1.5KE440
1.5KE440A
1.5KE500
1.5KE500A
1.5KE520
1.5KE520A
1.5KE550
1.5KE550A
1.5KE600
1.5KE600A
Note:
Bi-polar
1.5KE110C
1.5KE110CA
1.5KE120C
1.5KE120CA
1.5KE130C
1.5KE130CA
1.5KE150C
1.5KE150CA
1.5KE160C
1.5KE160CA
1.5KE170C
1.5KE170CA
1.5KE180C
1.5KE180CA
1.5KE200C
1.5KE200CA
1.5KE220C
1.5KE220CA
1.5KE250C
1.5KE250CA
1.5KE300C
1.5KE300CA
1.5KE350C
1.5KE350CA
1.5KE380C
1.5KE380CA
1.5KE400C
1.5KE400CA
1.5KE440C
1.5KE440CA
1.5KE500C
1.5KE500CA
1.5KE520C
1.5KE520CA
1.5KE550C
1.5KE550CA
1.5KE600C
1.5KE600CA
Min (V)
99.00
104.5
108.0
114.0
117.0
123.5
135.0
142.5
144.0
152.0
153.0
161.5
162.0
171.0
180.0
190.0
198.0
209.0
225.0
237.5
270.0
285.0
315.0
332.5
342.0
361.0
360.0
380.0
396.0
418.0
450.0
475.0
468.0
494.0
495.0
522.5
540.0
570.0
Max (V)
121.0
115.5
132.0
126.0
143.0
136.5
165.0
157.5
176.0
168.0
187.0
178.5
198.0
189.0
220.0
210.0
242.0
231.0
275.0
262.5
330.0
315.0
385.0
367.5
418.0
399.0
440.0
420.0
484.0
462.0
550.0
525.0
572.0
546.0
605.0
577.5
660.0
630.0
IT (mA)
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
Maximum
Reverse
Leakage
IR(uA)
@VRWM
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
Maximum
Working
Maximum
Reverse
PeakRevers
Clamping
Surge
e Voltage
Voltage
Current
VRWM
Vc (Volts)
Ipp(A)
@Ipp
@10x1000us
(Volts)
sinewave
89.2
9.49
158
94.0
9.87
152
97.2
8.67
173
102
9.09
165
105
8.02
187
111
8.38
179
121
6.98
215
128
7.25
207
130
6.52
230
136
6.85
219
138
6.15
244
145
6.41
234
146
5.81
258
154
6.10
246
162
5.23
287
171
5.47
274
175
4.36
344
185
4.57
328
202
4.17
360
214
4.36
344
243
3.49
430
256
3.62
414
284
2.98
504
299
3.11
482
309
2.74
547
325
2.86
524
325
2.60
576
342
2.72
552
357
2.37
634
376
2.47
607
406
2.08
720
428
2.17
690
422
2.00
749
445
2.09
718
447
1.89
792
470
1.98
759
487
1.74
864
513
1.81
828
1. Suffix 'A ' denotes 5% tolerance device. Without 'A' denotes 10% tolerance device.
2. Add suffix 'C 'or ' CA ' after part number to specify Bi-directional devices.
3. For Bi-Directional devices having VR of 10 volts and under, the IR limit is double .
4. For Uni-directional devices VF max=3.5v at IF=25 A 300us square wave pulse.
ht t p : //
www.lgesem i .c o m
1.5KE SERIES
RATINGS AND CHARACTERISTIC CURVES (1.5KE SERIES)
FIG.1- PEAK PULSE POWER RATING CURVE
FIG.2- PULSE DERATING CURVE
10
1
0.1
0.1 s
1.0 s
10 s
100 s
1.0ms
10ms
100
DERATING IN PERCENTAGE. %
NON-REPETITIVE
PULSE WAVEFORM
SHOWN in FIG. 3
TA=250C
PEAK PULSE POWER (PPP) or CURRENT (IPPM)
Pppm, PEAK PULSE POWER, KW
100
75
L=0.375"(9.5mm)
LEAD LENGTHS
50
PULSE
Without heat sink
25
0.8 X 0.8 X .040"
(20 X 20 X 1mm.)
COPPER HEAT SINKS
FIG.3- CLAMPING POWER PULSE WAVEFORM
PULSE WIDTH (td) is DEFINED
as the POINT WHERE the PEAK
CURRENT DECAYS
to 50% of lPPM
HALF VALUE- lPPM
2
10/1000msec. WAVEFORM
as DEFINED by R.E.A.
50
td
2.0
3.0
t, TIME, ms
CJ, JUNCTION CAPACITANCE. (pF)
10000
PEAK FORWARD SURGE CURRENT. (A)
PEAK PULSE CURRENT - %
100
75
100
125
150
175
200
O
150
PEAK VALUE
lPPM
50
TA, AMBIENT TEMPERATURE. ( C)
td. PULSE WIDTH, sec.
tr=10msec.
With heat sink
4.0
200
FIG.4- MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
8.3ms Single Half Sine Wave
JEDEC Method
UNIDIRECTIONAL ONLY
100
10
1
10
100
NUMBER OF CYCLES AT 60Hz
FIG.5- TYPICAL JUNCTION CAPACITANCE
UNIDIRECTIONAL
UNIDIRECTIONAL
BIDIRECTIONA
VR=0
1000
Tj = 25 C
f=1.0MHz
Vsig=50mVp-p
O
100
VR-RATED
STAND-OFF
VOLTAGE
10
1
10
100
200
V(BR), BREAKDOWN VOLTAGE. VOLTS
ht t p : //
www.lgesem i .c o m
很抱歉,暂时无法提供与“1.5KE200A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.20791
- 50+0.96627
- 150+0.86275
- 1250+0.65056
- 2500+0.59312
- 5000+0.55852
