DTC143ZE
DTC143ZE
    CBI(创基)
    SOT-523-3
    SOT523 100 150mW
DTC143ZE 数据手册
Digital Transistors (Built-in Resistors) ·Equivalent Circuit DIGITAL TRANSISTOR (NPN) FEATURES  Built-in bias resistors enable the configuration of an inverter circuit without connecting external input resistors(see equivalent circuit)  The bias resistors consist of thin-film resistors with complete isolation to allow negative biasing of the input.They also have the advantage of almost completely eliminating parasitic effects  Only the on/off conditions need to be set for operation, making device design easy PIN CONNENCTIONS and MARKING ORDERING INFORMATION Part Number MARKING Package Packing Method Pack Quantity DTC143ZE E23 SOT-523 Reel 3000pcs/Reel DTC143ZUA E23 SOT-323 Reel 3000pcs/Reel DTC143ZKA E23 SOT-23-3L Reel 3000pcs/Reel DTC143ZCA E23 SOT-23 Reel 3000pcs/Reel 1 of 7 Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd. MAXIMUM RATINGS(Ta=25℃ unless otherwise noted) Symbol Limits(DTC143Z□) Parameter VCC Supply Voltage VIN Input Voltage IO Output Current PD Power Dissipation M 100 E 150 Operation Junction and Storage Temperature Range TJ,Tstg UA CA KA Unit SA 50 V -5~+30 V 100 mA 200 200 200 300 mW ℃ -55~+150 ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified) Parameter Input voltage Output voltage Input current Symbol Conditions VI(off) VCC=5V,IO=100µA VI(on) VO=0.3V ,IO=5mA VO(on) IO/II=5mA/0.25mA II Min Typ Max 0.5 V 1.3 V 0.3 V VI=5V 1.8 mA VCC=50V,VI=0 0.5 μA kΩ 0.1 Output current IO(off) DC current gain GI Input resistance R1 3.29 4.7 6.11 Resistance ratio R2/R1 8 10 12 Transition frequency fT Unit VO=5V,IO=10mA VO=10V ,IO=5mA,f=100MHz 80 250 2 of 7 Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd. MHz I Typical Characteristics REVERSE VOLTAGE VR (V) AMBIENT TEMPERATURE Ta (℃) 3 of 7 Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd. PACKAGE OUTLINE Plastic surface mounted package; 3 leads SOT-523 4 of 7 Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd. PACKAGE OUTLINE Plastic surface mounted package; 3 leads SOT-323 5 of 7 Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd. 6 of 7 Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd. PACKAGE OUTLINE Plastic surface mounted package; 3 leads SOT-23 7 of 7 Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd.
DTC143ZE 价格&库存
很抱歉,暂时无法提供与“DTC143ZE”相匹配的价格&库存,您可以联系我们找货
DTC143ZE
    • 10+0.08000
    • 50+0.07400
    • 200+0.06900
    • 600+0.06400
    • 1500+0.06000
    • 3000+0.05750
    DTC143ZE
    • 20+0.19980
    • 100+0.12390
    • 800+0.08190
    • 3000+0.05840
    • 6000+0.05550
    • 30000+0.05150
    库存:5809
    DTC143ZE
    • 50+0.12906
    • 500+0.10228
    • 3000+0.08241
    • 6000+0.07344
    • 24000+0.06567
    • 51000+0.06156
    库存:27352
    DTC143ZE
    • 1+0.26950
    • 200+0.08998
    • 1500+0.05621
    • 3000+0.04466
    库存:5809
