KBJ15005 THRU KBJ1510
SINGLE PHASE 15.0 AMP BRIDGE RECTIFIERS
VOLTAGE RANGE
50 to 1000 Volts
CURRENT
15.0 Amperes
KBJ
4.6 +0.2
30.0+0.3
FEATURES
3.6 +0.2
3.2 +0.2
* Ideal for printed circuit board
3.5 +0.2
* Low forward voltage
20.0+0.3
* Low leakage current
* Mounting position: Any
2.5 +0.2
_
5
11.0+ 0.2
4+0.2
2.2 +0.2
17.5+0.5
1.0+0.1
0.7+0.1
2.7 +0.2
10 +0.2
7.5+0.2 7.5+0.2
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Rating 25 C ambient temperature uniess otherwies specified.
Single phase half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
TYPE NUMBER
KBJ15005 KBJ1501 KBJ1502 KBJ1504 KBJ1506 KBJ1508
8 KBJ1510 UNITS
8
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Current @Tc=100 C
Peak Forward Surge Current, 8.3 ms single half sine-wave
50
35
50
100
70
100
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
V
V
V
15.0
A
superimposed on rated load (JEDEC method)
Maximum Forward Voltage Drop per Bridge Element at 7.5A D.C.
Maximum DC Reverse Current
Ta=25 C
240
1.05
10
A
V
A
at Rated DC Blocking Voltage
Typical Junction Capacitance (Note 1)
Typical Thermal Resistance RqJC (Note 2)
Operating Temperature Range, TJ
Storage Temperature Range, TSTG
500
60
0.8
A
PF
C/W
Ta=125 C
-55
-55
+150
+150
C
C
NOTES:
1. Measured at 1.0MHz and applied reverse voltage of 4.0V DC.
2. Thermal Resistance from Junction to Case with device mounted on 300mm x 300mm x 1.6mm Cu Plate Heatsink.
REV 1.0 2019 JAN
PAGE:1/2
RATING AND CHARACTERISTIC CURVES (KBJ15005 THRU KBJ1510)
FIG.2-MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
AVERAGE FORWARD CURRENT,(A)
15
12
9
Single Phase
6
Half Wave 60Hz
Resistive Or Inductive Load
3
60
80
100
120 140
160
PEAK FORWARD SURGE CURRENT,(A)
FIG.1-TYPICAL FORWARD CURRENT
DERATING CURVE
250
240
200
150
Sine Wave
JEDEC method
50
CASE TEMPERATURE,( C)
8.3ms Single Half
Tj=25 C
100
50
10
5
100
FIG.3-TYPICAL FORWARD
FIG.4-TYPICAL REVERSE
CHARACTERISTICS
CHARACTERISTICS
50
50
10
10
REVERSE LEAKAGE CURRENT, ( A)
INSTANTANEOUS FORWARD CURRENT,(A)
NUMBER OF CYCLES AT 60Hz
3.0
1.0
Tj=25 C
Pulse Width 300us
1% Duty Cycle
0.1
3.0
Tj=100 C
1.0
0.1
Tj=25 C
.01
.4
.6
.8
1.0
FORWARD VOLTAGE,(V)
1.2
1.4
.01
60
80
100 120 140
PERCENT OF RATED PEAK REVERSE VOLTAGE, (%)
REV 1.0 2019 JAN
PAGE:2/2
很抱歉,暂时无法提供与“KBJ1510”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.38884
- 10+2.82093
- 30+2.57887
