VE4532-681M
VE4532-681M
    VOLUMESOURCE(千代源)
    SMD,4.5x4mm
    功率电感 680µH ±20% 7.26Ω IND_4.5X4MM_SM
VE4532-681M 数据手册
Wire Wound SMD Power Inductors—VE Series Applications: ●Power supply for VTRs. LCD televisions. ●Notebook PCs, Portable communication equipment. ●DC/DC converters, etc. Features : Product Identification : ●Silver Plated Type, Low cost designed. ●Available on tape and reel for auto surface mounting. VE 5845–100 M (1) (2) (3) (4) (1) Product symbol. (2)Dimensions code. (3)Inductance: “100”for 10uH. (4)Tolerance: K:±10%;M:±20%;N:±30%. Marking Dimensions in (mm) Item VE3521 VE4532 VE5830 VE5845 VE7835 VE7850 VE1040 VE1054 A 3.5±0.3 4.5±0.3 5.8±0.3 5.8±0.3 7.8±0.3 7.8±0.3 10.0±0.3 10.0±0.3 B 3.0±0.3 4.0±0.3 5.2±0.3 5.2±0.3 7.0±0.3 7.0±0.3 9.0±0.3 9.0±0.3 C 2.1±0.3 3.2±0.3 3.0±0.3 4.5±0.3 3.5±0.3 5.0±0.3 4.0±0.3 5.4±0.4 H 3.5 4.5 5.5 5.5 7.5 7.5 9.5 9.5 I 1.6 1.75 2.15 2.15 3.0 3.0 3.75 3.75 Characteristics : ●Saturation Current(Isat):The current when the inductance Becomes 20% lower than is initial value.(Ta=20℃). ●Temperature Rise Current(Irms):The current when the temperature of coil increases up to max.Δ T=40℃.(Ta=20℃) ●Operating temperature : -30℃~+105℃. ●Storage temperature range (packaging conditions): -5℃~+30℃ and RH 70% (Max.) Test equipments : ●L&Q: HP 4285A or HP 4284A,VR116/VR7210. ●DCR: Milli-ohm meter,VR131. ●Electrical specifications at 25℃. J 0.8 1.5 1.7 1.7 2.0 2.0 2.5 2.5 Electrical Characteristics VE3521 Series DCR(Ω ) Isat(A) Irms(A) Part No. L( uH ) Test Frequency Max. Typ. Max. Typ. Max. Typ. VE3521-1R0M 1.0±20% 100kHz/0.25V 45m 30m 3.30 4.10 2.60 3.10 1R0 VE3521-1R2M 1.2±20% 100kHz/0.25V 50m 32m 3.00 3.70 2.50 3.00 1R2 VE3521-1R5M 1.5±20% 100kHz/0.25V 55m 44m 2.70 3.40 2.15 2.60 1R5 VE3521-1R8M 1.8±20% 100kHz/0.25V 70m 49m 2.50 3.20 2.00 2.50 1R8 VE3521-2R2M 2.2±20% 100kHz/0.25V 85m 59m 2.30 2.80 1.80 2.20 2R2 VE3521-2R7M 2.7±20% 100kHz/0.25V 100m 65m 2.20 2.70 1.55 1.90 2R7 VE3521-3R3M 3.3±20% 100kHz/0.25V 120m 96m 1.95 2.40 1.45 1.80 3R3 VE3521-3R9M 3.9±20% 100kHz/0.25V 125m 110m 1.85 2.30 1.40 1.60 3R9 VE3521-4R7M 4.7±20% 100kHz/0.25V 135m 120m 1.60 2.00 1.30 1.50 4R7 VE3521-5R6M 5.6±20% 100kHz/0.25V 165m 140m 1.55 1.90 1.25 1.40 5R6 VE3521-6R8M 6.8±20% 100kHz/0.25V 0.20 0.17 1.40 1.75 1.20 1.38 6R8 VE3521-8R2M 8.2±20% 100kHz/0.25V 0.25 0.19 1.20 1.45 1.15 1.35 8R2 VE3521-100M 10±20% 1kHz/0.25V 0.32 0.24 1.05 1.30 1.10 1.30 100 VE3521-120M 12±20% 1kHz/0.25V 0.35 0.27 1.00 1.25 0.90 1.05 120 VE3521-150M 15±20% 1kHz/0.25V 0.46 0.37 0.90 1.15 0.75 0.90 150 VE3521-180M 18±20% 1kHz/0.25V 0.52 0.40 0.80 1.00 0.70 0.85 180 VE3521-220K 22±10% 1kHz/0.25V 0.65 0.57 0.75 0.95 0.56 0.66 220 VE3521-270K 27±10% 1kHz/0.25V 0.75 0.66 0.70 0.85 0.53 0.63 270 VE3521-330K 33±10% 1kHz/0.25V 0.92 0.76 0.60 0.75 0.52 0.62 330 VE3521-390K 39±10% 1kHz/0.25V 1.12 0.97 0.55 0.72 0.43 0.52 390 VE3521-470K 47±10% 1kHz/0.25V 1.27 1.10 0.50 0.65 0.40 0.47 470 VE3521-560K 56±10% 1kHz/0.25V 1.50 1.30 0.45 0.58 0.35 0.43 560 VE3521-680K 68±10% 1kHz/0.25V 2.00 1.52 0.40 0.50 0.33 0.40 680 VE3521-820K 82±10% 1kHz/0.25V 2.15 1.83 0.35 0.47 0.30 0.37 820 VE3521-101K 100±10% 1kHz/0.25V 2.80 2.46 0.34 0.42 0.28 0.33 101 VE3521-121K 120±10% 1kHz/0.25V 3.40 2.74 0.33 0.41 0.26 0.31 121 VE3521-151K 150±10% 1kHz/0.25V 4.20 3.12 0.28 0.35 0.23 0.28 151 VE3521-181K 180±10% 1kHz/0.25V 4.50 3.58 0.27 0.34 0.21 0.25 181 VE3521-221K 220±10% 1kHz/0.25V 5.70 5.05 0.25 0.31 0.19 0.23 221 VE3521-271K 270±10% 1kHz/0.25V 8.50 5.92 0.22 0.27 0.17 0.20 271 VE3521-331K 330±10% 1kHz/0.25V 9.50 6.96 0.19 0.24 0.15 0.18 331 Typical Performance curves: VE3521 Inductauce vs DC Current Curve VE3521 Temperature rise vs DC Current Curve Marking Electrical Characteristics VE4532 Series DCR(Ω ) Isat(A) Irms(A) Part No. L( uH ) Test Frequency Max. Typ. Max. Typ. Max. Typ. VE4532-1R0M 1.0±20% 100kHz/0.25V 26m 17m 3.85 4.80 3.40 4.20 1R0 VE4532-1R5M 1.5±20% 100kHz/0.25V 35m 23m 3.44 4.30 3.00 3.70 1R5 VE4532-2R2M 2.2±20% 100kHz/0.25V 42m 28m 2.80 3.50 2.75 3.40 2R2 VE4532-2R7M 2.7±20% 100kHz/0.25V 48m 32m 2.75 3.45 2.45 3.15 2R7 VE4532-3R3M 3.3±20% 100kHz/0.25V 60m 40m 2.48 3.10 2.35 2.85 3R3 VE4532-3R9M 3.9±20% 100kHz/0.25V 65m 43m 2.32 2.90 2.00 2.60 3R9 VE4532-4R7M 4.7±20% 100kHz/0.25V 76m 56m 2.00 2.50 1.98 2.40 4R7 VE4532-5R6M 5.6±20% 100kHz/0.25V 103m 76m 1.96 2.45 1.80 2.20 5R6 VE4532-6R8M 6.8±20% 100kHz/0.25V 119m 88m 1.60 2.00 1.62 2.00 6R8 VE4532-8R2M 8.2±20% 100kHz/0.25V 134m 99m 1.52 1.90 1.42 1.82 8R2 VE4532-100M 10±20% 1kHz/0.25V 0.14 0.11 1.44 1.80 1.38 1.62 100 VE4532-120M 12±20% 1kHz/0.25V 0.19 0.15 1.24 1.55 1.30 1.50 120 VE4532-150M 15±20% 1kHz/0.25V 0.21 0.17 1.12 1.40 1.18 1.42 150 VE4532-180M 18±20% 1kHz/0.25V 0.27 0.22 1.00 1.25 1.05 1.30 180 VE4532-220M 22±20% 1kHz/0.25V 0.31 0.25 0.96 1.20 0.98 1.20 220 VE4532-270M 27±20% 1kHz/0.25V 0.36 0.29 0.84 1.05 0.85 1.05 270 VE4532-330K 33±10% 1kHz/0.25V 0.42 0.34 0.76 0.95 0.82 1.00 330 VE4532-390K 39±10% 1kHz/0.25V 0.48 0.39 0.74 0.92 0.78 0.92 390 VE4532-470M 47±20% 1kHz/0.25V 0.56 0.45 0.68 0.85 0.74 0.90 470 VE4532-560K 56±10% 1kHz/0.25V 0.81 0.65 0.63 0.78 0.65 0.80 560 VE4532-680K 68±10% 1kHz/0.25V 0.92 0.74 0.50 0.62 0.58 0.70 680 VE4532-820K 82±10% 1kHz/0.25V 1.06 0.85 0.46 0.58 0.55 0.65 820 VE4532-101K 100±10% 1kHz/0.25V 1.18 0.95 0.45 0.57 0.52 0.62 101 VE4532-121K 120±10% 1kHz/0.25V 1.31 1.05 0.44 0.56 0.46 0.56 121 VE4532-151K 150±10% 1kHz/0.25V 1.97 1.58 0.37 0.46 0.38 0.47 151 VE4532-181K 180±10% 1kHz/0.25V 2.55 2.04 0.30 0.38 0.33 0.42 181 VE4532-221K 220±10% 1kHz/0.25V 2.90 2.32 0.29 0.37 0.32 0.39 221 VE4532-271K 270±10% 1kHz/0.25V 3.31 2.65 0.27 0.34 0.30 0.37 271 VE4532-331K 330±10% 1kHz/0.25V 6.92 5.54 0.24 0.30 0.20 0.24 331 VE4532-681M 680±20% 1kHz/0.25V 8.24 7.26 0.17 0.20 0.18 0.19 681 Typical Performance curves: VE4532 Inductauce vs DC Current Curve VE4532 Temperature rise vs DC Current Curve Marking Electrical Characteristics VE5830 Series DCR(Ω ) Isat(A) Irms(A) Part No. L( uH ) Test Frequency Max. Typ. Max. Typ. Max. Typ. VE5830-1R0M 1.0±20% 100kHz/0.25V 18m 13m 6.70 8.40 5.10 6.50 1R0 VE5830-1R2M 1.2±20% 100kHz/0.25V 22m 16m 6.00 7.50 4.10 5.40 1R2 VE5830-1R5M 1.5±20% 100kHz/0.25V 26m 19m 5.60 7.00 4.05 5.10 1R5 VE5830-1R8M 1.8±20% 100kHz/0.25V 28m 21m 5.60 7.00 4.00 5.00 1R8 VE5830-2R2M 2.2±20% 100kHz/0.25V 30m 26m 4.40 5.50 3.70 4.70 2R2 VE5830-2R7M 2.7±20% 100kHz/0.25V 40m 31m 4.25 5.30 3.30 4.20 2R7 VE5830-3R3M 3.3±20% 100kHz/0.25V 50m 35m 4.00 5.00 3.10 3.90 3R3 VE5830-3R9M 3.9±20% 100kHz/0.25V 60m 38m 3.60 4.50 3.00 3.70 3R9 VE5830-4R7M 4.7±20% 100kHz/0.25V 70m 51m 3.15 4.20 2.15 2.50 4R7 VE5830-5R6M 5.6±20% 100kHz/0.25V 80m 60m 2.88 3.60 2.05 2.45 5R6 VE5830-6R8M 6.8±20% 100kHz/0.25V 90m 65m 2.75 3.40 1.98 2.38 6R8 VE5830-8R2M 8.2±20% 100kHz/0.25V 100m 70m 2.65 3.30 1.58 1.90 8R2 VE5830-100M 10±20% 1kHz/0.25V 0.13 0.10 2.15 2.70 1.38 1.65 100 VE5830-120M 12±20% 1kHz/0.25V 0.16 0.12 2.00 2.50 1.30 1.62 120 VE5830-150M 15±20% 1kHz/0.25V 0.19 0.15 1.85 2.30 1.20 1.50 150 VE5830-180M 18±20% 1kHz/0.25V 0.21 0.17 1.68 2.10 1.17 1.40 180 VE5830-220K 22±10% 1kHz/0.25V 0.28 0.19 1.45 1.80 1.05 1.30 220 VE5830-270K 27±10% 1kHz/0.25V 0.32 0.24 1.35 1.70 0.90 1.10 270 VE5830-330K 33±10% 1kHz/0.25V 0.38 0.28 1.20 1.50 0.88 1.08 330 VE5830-390K 39±10% 1kHz/0.25V 0.42 0.32 1.10 1.40 0.80 1.00 390 VE5830-470K 47±10% 1kHz/0.25V 0.52 0.40 1.05 1.35 0.75 0.90 470 VE5830-560K 56±10% 1kHz/0.25V 0.56 0.47 0.95 1.20 0.70 0.88 560 VE5830-680K 68±10% 1kHz/0.25V 0.68 0.56 0.88 1.10 0.69 0.85 680 VE5830-820K 82±10% 1kHz/0.25V 0.82 0.64 0.80 1.00 0.57 0.72 820 VE5830-101K 100±10% 1kHz/0.25V 1.10 0.88 0.75 0.95 0.46 0.65 101 VE5830-121K 120±10% 1kHz/0.25V 1.20 1.02 0.68 0.85 0.48 0.59 121 VE5830-151K 150±10% 1kHz/0.25V 1.50 1.34 0.64 0.80 0.43 0.53 151 VE5830-181K 180±10% 1kHz/0.25V 1.80 1.45 0.56 0.70 0.42 0.50 181 VE5830-221K 220±10% 1kHz/0.25V 2.00 1.64 0.48 0.60 0.36 0.44 221 VE5830-271K 270±10% 1kHz/0.25V 2.90 2.32 0.44 0.55 0.31 0.38 271 VE5830-331K 330±10% 1kHz/0.25V 3.30 2.67 0.40 0.50 0.28 0.34 331 VE5830-391K 390±10% 1kHz/0.25V 3.70 3.01 0.38 0.48 0.26 0.32 391 VE5830-471K 470±10% 1kHz/0.25V 4.90 3.74 0.36 0.45 0.24 0.28 471 Typical Performance curves: VE5830 Inductauce vs DC Current Curve VE5830 Temperature rise vs DC Current Curve Marking Electrical Characteristics VE5845 Series Part No. L( uH ) DCR(Ω ) Isat(A) Irms(A) Test Frequency Max. Typ. Max. Typ. Max. Typ. Marking VE5845-1R0M 1.0±20% 100kHz/0.25V 12m 8.0m 3.52 4.40 4.40 5.50 1R0 VE5845-2R2M 2.2±20% 100kHz/0.25V 20m 15m 3.08 3.85 3.80 4.80 2R2 VE5845-3R3M 3.3±20% 100kHz/0.25V 30m 23m 2.88 3.60 3.60 4.50 3R3 VE5845-4R7M 4.7±20% 100kHz/0.25V 40m 32m 2.56 3.20 3.20 4.00 4R7 VE5845-6R8M 6.8±20% 100kHz/0.25V 50m 38m 1.80 2.25 2.20 2.80 6R8 VE5845-100M 10±20% 1kHz/0.25V 100m 60m 1.60 2.00 2.00 2.60 100 VE5845-120M 12±20% 1kHz/0.25V 120m 69m 1.44 1.80 1.80 2.20 120 VE5845-150M 15±20% 1kHz/0.25V 140m 81m 1.28 1.60 1.60 2.00 150 VE5845-180M 18±20% 1kHz/0.25V 150m 90m 1.16 1.45 1.56 1.90 180 VE5845-220M 22±20% 1kHz/0.25V 0.18 0.11 1.12 1.40 1.37 1.70 220 VE5845-270M 27±20% 1kHz/0.25V 0.20 0.13 1.04 1.30 1.20 1.50 270 VE5845-330K 33±10% 1kHz/0.25V 0.23 0.15 1.00 1.20 1.15 1.40 330 VE5845-390K 39±10% 1kHz/0.25V 0.32 0.21 0.85 1.05 1.10 1.35 390 VE5845-470K 47±10% 1kHz/0.25V 0.37 0.24 0.80 1.00 1.05 1.30 470 VE5845-560K 56±10% 1kHz/0.25V 0.42 0.27 0.72 0.90 0.95 1.20 560 VE5845-680K 68±10% 1kHz/0.25V 0.46 0.31 0.68 0.85 0.90 1.10 680 VE5845-820K 82±10% 1kHz/0.25V 0.60 0.40 0.64 0.80 0.80 1.00 820 VE5845-101K 100±10% 1kHz/0.25V 0.70 0.45 0.56 0.70 0.75 0.90 101 VE5845-121K 120±10% 1kHz/0.25V 0.93 0.52 0.52 0.65 0.70 0.85 121 VE5845-151K 150±10% 1kHz/0.25V 1.10 0.75 0.44 0.55 0.62 0.80 151 VE5845-181K 180±10% 1kHz/0.25V 1.38 0.90 0.40 0.50 0.58 0.75 181 VE5845-221K 220±10% 1kHz/0.25V 1.57 1.05 0.36 0.45 0.55 0.70 221 VE5845-271K 270±10% 1kHz/0.25V 1.65 1.25 0.33 0.41 0.50 0.65 271 VE5845-331K 330±10% 1kHz/0.25V 1.80 1.43 0.30 0.38 0.45 0.60 331 VE5845-471K 470±10% 1kHz/0.25V 2.90 2.25 0.12 0.15 0.2 0.25 471 Typical Performance curves: VE5845 Inductauce vs DC Current Curve VE5845 Temperature rise vs DC Current Curve Electrical Characteristics VE7835 Series Part No. L( uH ) Test Frequency DCR(Ω ) Isat(A) Irms(A) Max. Typ. Max. Typ. Max. Typ. Marking VE7835-100K 10±10% 1kHz/0.25V 80m 45m 2.40 3.00 2.40 3.00 100 VE7835-120K 12±10% 1kHz/0.25V 90m 55m 2.15 2.70 2.35 2.80 120 VE7835-150K 15±10% 1kHz/0.25V 100m 71m 1.92 2.40 1.95 2.40 150 VE7835-180K 18±10% 1kHz/0.25V 110m 83m 1.85 2.30 1.80 2.25 180 VE7835-220K 22±10% 1kHz/0.25V 130m 94m 1.60 2.00 1.70 2.15 220 VE7835-270K 27±10% 1kHz/0.25V 0.15 0.12 1.52 1.90 1.45 1.80 270 VE7835-330K 33±10% 1kHz/0.25V 0.19 0.16 1.28 1.60 1.40 1.70 330 VE7835-390K 39±10% 1kHz/0.25V 0.22 0.18 1.24 1.55 1.30 1.60 390 VE7835-470K 47±10% 1kHz/0.25V 0.25 0.21 1.12 1.40 1.25 1.55 470 VE7835-560K 56±10% 1kHz/0.25V 0.28 0.24 1.08 1.35 1.00 1.25 560 VE7835-680K 68±10% 1kHz/0.25V 0.33 0.31 0.92 1.15 0.95 1.20 680 VE7835-820K 82±10% 1kHz/0.25V 0.46 0.38 0.84 1.05 0.90 1.10 820 VE7835-101K 100±10% 1kHz/0.25V 0.48 0.41 0.78 0.98 0.88 1.08 101 VE7835-121K 120±10% 1kHz/0.25V 0.54 0.46 0.72 0.90 0.85 1.05 121 VE7835-151K 150±10% 1kHz/0.25V 0.76 0.63 0.60 0.75 0.75 0.90 151 VE7835-181K 180±10% 1kHz/0.25V 1.02 0.83 0.56 0.70 0.62 0.75 181 VE7835-221K 220±10% 1kHz/0.25V 1.20 0.98 0.52 0.65 0.58 0.70 221 VE7835-271K 270±10% 1kHz/0.25V 1.31 1.08 0.48 0.60 0.52 0.65 271 VE7835-331K 330±10% 1kHz/0.25V 1.50 1.26 0.44 0.55 0.51 0.62 331 Typical Performance curves: VE7835 Inductauce vs DC Current Curve VE7835 Temperature rise vs DC Current Curve Electrical Characteristics VE7850 Series Part No. L( uH ) Test Frequency DCR(Ω ) Isat(A) Irms(A) Max. Typ. Max. Typ. Max. Typ. Marking VE7850-100K 10±10% 1kHz/0.25V 70m 33m 2.88 3.60 3.20 3.80 100 VE7850-120K 12±10% 1kHz/0.25V 80m 46m 2.56 3.20 2.60 3.20 120 VE7850-150K 15±10% 1kHz/0.25V 90m 53m 2.25 2.80 2.55 3.10 150 VE7850-180K 18±10% 1kHz/0.25V 100m 59m 2.08 2.60 2.25 2.80 180 VE7850-220K 22±10% 1kHz/0.25V 110m 70m 1.95 2.40 2.10 2.60 220 VE7850-270K 27±10% 1kHz/0.25V 120m 87m 1.75 2.20 1.98 2.40 270 VE7850-330K 33±10% 1kHz/0.25V 0.13 0.10 1.52 1.90 1.82 2.25 330 VE7850-390K 39±10% 1kHz/0.25V 0.16 0.12 1.44 1.80 1.62 2.00 390 VE7850-470K 47±10% 1kHz/0.25V 0.18 0.14 1.28 1.60 1.50 1.90 470 VE7850-560K 56±10% 1kHz/0.25V 0.24 0.17 1.20 1.50 1.43 1.80 560 VE7850-680K 68±10% 1kHz/0.25V 0.28 0.20 1.12 1.40 1.30 1.60 680 VE7850-820K 82±10% 1kHz/0.25V 0.37 0.23 1.04 1.30 1.23 1.50 820 VE7850-101K 100±10% 1kHz/0.25V 0.43 0.28 0.92 1.15 1.08 1.32 101 VE7850-121K 120±10% 1kHz/0.25V 0.47 0.35 0.80 1.00 0.99 1.20 121 VE7850-151K 150±10% 1kHz/0.25V 0.64 0.40 0.72 0.90 0.90 1.10 151 VE7850-181K 180±10% 1kHz/0.25V 0.71 0.53 0.68 0.85 0.76 0.94 181 VE7850-221K 220±10% 1kHz/0.25V 0.96 0.61 0.64 0.80 0.70 0.85 221 VE7850-271K 270±10% 1kHz/0.25V 1.11 0.72 0.56 0.70 0.65 0.80 271 VE7850-331K 330±10% 1kHz/0.25V 1.26 0.95 0.52 0.65 0.58 0.70 331 VE7850-391K 390±10% 1kHz/0.25V 1.77 1.28 0.44 0.55 0.49 0.60 391 VE7850-471K 470±10% 1kHz/0.25V 1.96 1.46 0.40 0.50 0.47 0.58 471 Typical Performance curves: VE7850 Inductauce vs DC Current Curve VE7850 Temperature rise vs DC Current Curve Electrical Characteristics VE1040 Series Part No. L( uH ) DCR(Ω ) Isat(A) Irms(A) Test Frequency Max. Typ. Max. Typ. Max. Typ. Marking VE1040-100M 10±20% 1kHz/0.25V 53m 30m 2.90 3.60 3.50 4.30 100 VE1040-120M 12±20% 1kHz/0.25V 61m 37m 2.55 3.20 2.90 3.60 120 VE1040-150M 15±20% 1kHz/0.25V 70m 44m 2.40 3.00 2.80 3.48 150 VE1040-180M 18±20% 1kHz/0.25V 81m 52m 2.10 2.60 2.58 3.20 180 VE1040-220M 22±20% 1kHz/0.25V 90m 66m 1.90 2.40 2.40 2.98 220 VE1040-270M 27±20% 1kHz/0.25V 100m 84m 1.65 2.10 2.00 2.55 270 VE1040-330M 33±20% 1kHz/0.25V 0.12 0.10 1.60 2.00 1.90 2.38 330 VE1040-390M 39±20% 1kHz/0.25V 0.15 0.11 1.44 1.80 1.80 2.20 390 VE1040-470M 47±20% 1kHz/0.25V 0.17 0.14 1.35 1.70 1.59 1.95 470 VE1040-560K 56±10% 1kHz/0.25V 0.20 0.16 1.20 1.50 1.50 1.82 560 VE1040-680K 68±10% 1kHz/0.25V 0.22 0.19 1.15 1.40 1.40 1.62 680 VE1040-820K 82±10% 1kHz/0.25V 0.25 0.22 1.00 1.20 1.35 1.60 820 VE1040-101K 100±10% 1kHz/0.25V 0.34 0.26 0.88 1.10 1.20 1.48 101 VE1040-121K 120±10% 1kHz/0.25V 0.40 0.30 0.80 1.00 1.10 1.38 121 VE1040-151K 150±10% 1kHz/0.25V 0.54 0.38 0.75 0.90 0.99 1.20 151 VE1040-181K 180±10% 1kHz/0.25V 0.62 0.44 0.64 0.80 0.90 1.10 181 VE1040-221K 220±10% 1kHz/0.25V 0.72 0.58 0.60 0.75 0.80 0.98 221 VE1040-271K 270±10% 1kHz/0.25V 0.95 0.68 0.56 0.70 0.75 0.90 271 VE1040-331K 330±10% 1kHz/0.25V 1.10 0.88 0.52 0.65 0.64 0.78 331 VE1040-391K 390±10% 1kHz/0.25V 1.25 0.99 0.48 0.60 0.60 0.75 391 VE1040-471K 470±10% 1kHz/0.25V 1.53 1.13 0.40 0.50 0.57 0.70 471 VE1040-561K 560±10% 1kHz/0.25V 1.90 1.40 0.35 0.45 0.50 0.63 561 Typical Performance curves: VE1040 Inductauce vs DC Current Curve VE1040 Temperature rise vs DC Current Curve Electrical Characteristics VE1054 Series Part No. L( uH ) DCR(Ω ) Isat(A) Irms(A) Test Frequency Max. Typ. Max. Typ. Max. Typ. Marking VE1054-100M 10±20% 1kHz/0.25V 60m 26m 4.00 5.00 4.00 4.50 100 VE1054-120M 12±20% 1kHz/0.25V 70m 31m 3.50 4.40 3.50 4.25 120 VE1054-150M 15±20% 1kHz/0.25V 80m 36m 3.05 3.80 2.70 3.48 150 VE1054-180K 18±10% 1kHz/0.25V 90m 46m 3.00 3.60 2.40 3.10 180 VE1054-220M 22±20% 1kHz/0.25V 100m 52m 2.55 3.20 2.38 2.95 220 VE1054-270M 27±20% 1kHz/0.25V 110m 62m 2.25 2.80 2.25 2.80 270 VE1054-330M 33±20% 1kHz/0.25V 120m 74m 2.10 2.60 2.15 2.60 330 VE1054-390M 39±20% 1kHz/0.25V 140m 93m 2.00 2.50 2.00 2.40 390 VE1054-470K 47±10% 1kHz/0.25V 0.17 0.10 1.95 2.40 1.80 2.20 470 VE1054-560K 56±10% 1kHz/0.25V 0.19 0.12 1.70 2.10 1.62 2.02 560 VE1054-680K 68±10% 1kHz/0.25V 0.22 0.15 1.50 1.90 1.58 1.97 680 VE1054-820K 82±10% 1kHz/0.25V 0.25 0.18 1.35 1.70 1.30 1.60 820 VE1054-101K 100±10% 1kHz/0.25V 0.35 0.21 1.20 1.50 1.28 1.58 101 VE1054-121K 120±10% 1kHz/0.25V 0.40 0.24 1.15 1.40 1.15 1.45 121 VE1054-151K 150±10% 1kHz/0.25V 0.47 0.30 1.05 1.30 1.10 1.39 151 VE1054-181K 180±10% 1kHz/0.25V 0.63 0.36 0.88 1.10 1.00 1.25 181 VE1054-221K 220±10% 1kHz/0.25V 0.73 0.45 0.85 1.05 0.96 1.18 221 VE1054-271K 270±10% 1kHz/0.25V 0.97 0.56 0.80 1.00 0.82 1.00 271 VE1054-331K 330±10% 1kHz/0.25V 1.15 0.65 0.76 0.95 0.70 0.89 331 VE1054-391K 390±10% 1kHz/0.25V 1.30 0.75 0.65 0.80 0.65 0.80 391 VE1054-471K 470±10% 1kHz/0.25V 1.48 0.93 0.56 0.70 0.62 0.78 471 VE1054-561K 560±10% 1kHz/0.25V 1.90 1.10 0.52 0.65 0.60 0.74 561 VE1054-681K 680±10% 1kHz/0.25V 2.25 1.30 0.48 0.60 0.54 0.65 681 VE1054-821K 820±10% 1kHz/0.25V 2.55 1.65 0.44 0.55 0.49 0.60 821 Typical Performance curves: VE1054 Inductauce vs DC Current Curve VE1054 Temperature rise vs DC Current Curve Supplier Information Supplier: Shenzhen Volume Source Electronics Co., Ltd. Manufacturer: ShenzhenVolume Source Electronics Co., Ltd. Manufacturing Address: Address: 16th Floor, Building T5-N4, Tian'an Digital City, Fenggang, Dongguan Tel: 0769-89891993 Fax: 0769-89891993-806 E-mail:yhp@volumesz.com.cn M.P:13316585579 Mr.Yu Http://www.volumesz.com.cn
VE4532-681M 价格&库存
很抱歉,暂时无法提供与“VE4532-681M”相匹配的价格&库存,您可以联系我们找货
VE4532-681M
  • 20+0.11325
  • 200+0.10575
  • 500+0.09825
  • 1000+0.09075
  • 3000+0.08700
  • 6000+0.08175
