NJM4580E-TE1
NJM4580E-TE1
    JRC(⽇本无线)
    SOP-8
    双运算放大器 SOP8_150MIL 15MHz
NJM4580E-TE1 数据手册
NJM4580 DUAL OPERATIONAL AMPLIFIER ■ GENERAL DESCRIPTION The NJM4580 is a dual operational amplifier, specially designed for improving the tone control, which is most suitable for the audio application. Featuring noiseless, higher gain bandwidth, high output current and low distortion ratio, and it is most suitable not only for acoustic electronic parts of audio pre-amp and active filter, but also for the industrial measurement tools. It is also suitable for the head phone amp at higher output current, and further more, it can be applied for the handy type set operational amplifier of general purpose in application of low voltage single supply type which is properly biased of the low voltage source. The D-Rank type products(NJM4580DD/LD/MD/ED) have specified maximum limits for equivalent input noise voltage. ■ FEATURES ● Operating Voltage ● Low Input Noise Voltage ● Wide GBW ● Low Distortion ● Slew Rate ● Bipolar Technology ● Package Outline ■ PACKAGE OUTLINE NJM4580R (MSOP8(VSP8 )) NJM4580M ( DMP8 ) NJM4580E ( SOP8 ) NJM4580D ( DIP8 ) ±2V~±18V 0.8µVrms typ. (RIAA) 15MHz typ. 0.0005% typ. 5V/µs typ. NJM4580V ( SSOP8 ) NJM4580L ( SIP8 ) DIP8, SIP8, DMP8, SSOP8, MSOP8(VSP8) MEET JEDEC MO-187-DA SOP8 JEDEC 150mil ■ PIN CONFIGURATION ( Top View ) 8 1 A 2 A B 7 B 3 6 5 4 NJM4580D, NJM4580M, NJM4580E NJM4580V, NJM4580R 1 2 3 4 5 6 7 8 PIN FUNCTION 1. A OUTPUT 2. A - INPUT 3. A +INPUT 4. V5. B +INPUT 6. B - INPUT 7. B OUTPUT 8. V+ NJM4580L ■ EQUIVALENT CIRCUIT ( 1/2 Shown ) V+ -INPUT +INPUT OUTPUT VVer.2012-09-14 -1- NJM4580 ■ABSOLUTE MAXIMUM RATINGS PARAMETER (Ta=25°C, unless otherwise noted.) SYMBOL + - RATING UNIT Supply Voltage V /V ±18 V Input Voltage VICM ±15 (Note1) V Differential Input Voltage VID ±30 (Note1) V PD DIP8, SIP8 : 800 DMP8, SOP8 : 300 SSOP8 : 250 MSOP8(VSP8) : 400 (Note2) mW Operating Temperature Range Topr -40~+85 °C Storage Temperature Range Tstg -40~+125 °C Power Dissipation (Note1) For supply voltage less than ±15V, the absolute maximum input voltage is equal to supply voltage. (Note2) On the PCB "EIA/JEDEC (114.3×76.2×1.57mm, 2 layers, FR-4)" ■ RECOMMENDED OPERATING CONDITIONS PARAMETER SYMBOL + Supply Voltage (Ta=25°C) CONDITION - V /V TYP. MAX. UNIT ±2 - ±18 V (V+/V-=±15V, Ta=25°C, unless otherwise noted.) ■ ELECTRICAL CHARACTERISTICS PARAMETER MIN. SYMBOL TEST CONDITION MIN. TYP. MAX. UNIT Input Offset Voltage VIO RS≤10kΩ - 0.3 3 mV Input Offset Current IIO - 5 200 nA Input Bias Current IB - 100 500 nA Voltage Gain AV RL≥2kΩ,VO=±10V 90 110 - dB Maximum Output Voltage VOM RL≥2kΩ ±12 ±13.5 - V Common Mode Input Voltage Range VICM ±12 ±13.5 - V Common Mode Rejection Ratio CMR RS≤10kΩ 80 110 - dB Supply Voltage Rejection Ratio SVR RS≤10kΩ 80 110 - dB - 6 9 mA Supply Current ICC Slew Rate SR RL≥2kΩ - 5 - V/µs Gain Bandwidth Product GB f=10kHz - 15 - MHz Total Harmonic Distortion THD AV=20dB,VO=5V,RL=2kΩ,f=1kHz - 0.0005 - % VNI RIAA,RS=2.2kΩ,30kHz LPF - 0.8 - µVrms Equivalent Input Noise Voltage ■ ELECTRICAL CHARACTERISTICS PARAMETER Equivalent Input Noise Voltage (D-rank type(Note3), V+/V-=±15V, Ta=25°C, unless otherwise noted.) SYMBOL TEST CONDITION MIN. TYP. MAX. UNIT VNI RIAA,RS=2.2kΩ - - 1.4 µVrms (Note3)D-rank type is a Equivalent Input Noise Voltage selected product. It s only DIP, DMP, SOP and SIP package. -2- Ver.2012-09-14 NJM4580 ■ TYPICAL CHARACTERISTICS 40dB Gain/Phase vs. Frequency Maximum Output Voltage vs. Frequency (V+/V-=±15V, RL=2kΩ, Ta=25ºC) 50 Gain 35 Phase 30 0 25 -30 20 -60 15 -90 10 -120 5 -150 0 1k 10k 100k 1M Frequency [Hz] Phase [deg] 40 Maximum Output Voltage [VPP] 45 Voltage Gain [dB] V+/V-=±15V, RL=2kΩ, Ta=25ºC 30 -180 10M 25 20 15 10 5 0 1k 100k 1M Frequency [Hz] V+/V-=±15V, Ta=25ºC V+/V-=±15V, Ta=25ºC 15 +VOM Maximum Output Voltage [V] Maximum Output Voltage [V] +VOM 10 5 0 -5 -10 -VOM -15 THD+N [%] 0.1 10 Output Current [mA] 10 5 0 -5 -10 -VOM -15 100 100 1k Load Resistance [Ω] THD vs. Output Voltage (Frequency) Voltage Noisevs. Frequency V+/V-=±15V, GV=20dB, RL=2kΩ V+/V-=±15V, RS=50Ω, GV=60dB, Ta=25ºC 20 Equivalent Input Noise Voltage [nV/√Hz] 1 10M Maximum Output Voltage vs. Load Resistance Maximum Output Voltage vs. Output Current 15 10k 0.01 f=20kHz f=1kHz 0.001 f=20Hz 0.0001 10k 15 10 5 0 0.1 Ver.2012-09-14 1 Output Voltage [Vrms] 10 1 10 100 Frequency [Hz] 1k -3- NJM4580 ■ TYPICAL CHARACTERISTICS Supply Current vs. Temperature Supply Current vs. Supply Voltage Ta=25ºC 7 6 10 Supply Current [mA] Supply Current [mA] V+/V-=±15V 12 5 4 3 2 8 6 4 2 1 0 0 0 ±2 ±4 ±6 ±8 ±10 ±12 ±14 ±16 ±18 + Supply Voltage V /V [V] -50 Input Offset Voltage vs. Temperature 125 V+/V-=±15V 450 400 Input Bias Current [nA] 1.5 Input Offset Voltage [mV] 0 25 50 75 100 Ambient Temperature [ºC] Input Bias Current vs. Temperature V+/V-=±15V 2 -25 1 0.5 0 -0.5 -1 -1.5 350 300 250 200 150 100 50 -2 0 -50 -25 0 25 50 75 100 Ambient Temperature [ºC] -50 125 Maximum Output Voltage vs. Supply Voltage -25 0 25 50 75 100 Ambient Temperature [ºC] 125 Maximum Output Voltage vs. Temperature RL=2kΩ, Ta=25ºC 18 15 12 10 V+/V-=±15V, RL=2kΩ +VOM 6 0 -6 -VOM -12 -18 5 0 -5 -10 -VOM -15 0 -4- Maximum Output Voltage [V] Maximum Output Voltage [V] +VOM ±2 ±4 ±6 ±8 ±10 ±12 ±14 ±16 ±18 + Supply Voltage V /V [V] -50 -25 0 25 50 75 100 Ambient Temperature [ºC] 125 Ver.2012-09-14 NJM4580 ■ TEST CIRCUIT Noise Voltage (RIAA) measurement circuit 3.3µ +15V -15V 100µ Rs 2.2k 100µ 40dB Amp 30kHz LPF 0.47µ 2.2µ Vout 56k 30k 330k 0.0024µ 0.0082µ 220k 47µ 610 [CAUTION] The specifications on this databook are only given for information , without any guarantee as regards either mistakes or omissions. The application circuits in this databook are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. Ver.2012-09-14 -5-
NJM4580E-TE1 价格&库存
很抱歉,暂时无法提供与“NJM4580E-TE1”相匹配的价格&库存,您可以联系我们找货
