B
THRU MB10S
MB05S
SINGLE PHASE 0.8 AMP SURFACE MOUNT BRIDGE RECTIFIERS
VOLTAGE RANGE
50 to 1000 Volts
CURRENT
0.8 Ampere
MBS
FEATURES
* Ideal for printed circuit board
* Reliable low cost construction utilizing molded
plastic technique
* High surge current capability
* Polarity: Symbol molded on body
* Mounting position: Any
.051(1.3)
.157(4.0) .035(0.9)
.141(3.6)
2.75(7.0)
MAX.
.014(.35)
.006(.15)
.043(1.1) .008(0.2)
.027(0.7)
MAX.
.031(0.8)
.023(0.6)
* Weight: 0.12 grams
.193(4.9)
.177(4.5)
.106(2.7)
.090(2.3)
.118(3.0)
MAX.
.106(2.7)
.090(2.3)
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Rating 25 C ambient temperature uniess otherwies specified.
Single phase half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
TYPE NUMBER
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified Current
MB05S
MB1S
MB2S
MB4S
MB6S
50
35
50
100
70
100
200
140
200
400
280
400
600
420
600
MB8S MB10S UNIT
800
560
800
1000
700
1000
V
V
V
at Ta=40 C(Note 1)
Peak Forward Surge Current, 8.3 ms single half sine-wave
0.8
A
superimposed on rated load (JEDEC method)
Maximum Forward Voltage Drop per Bridge Element at 0.4A D.C.
Maximum DC Reverse Current
Ta=25 C
30
1.0
5.0
A
V
at Rated DC Blocking Voltage
Ta=125 C
Typical Thermal Resistance RqJA (Note 2)
Operating Temperature Range, TJ
Storage Temperature Range, TSTG
500
75
-55 +150
-55 +150
μA
μA
m
C/W
C
C
NOTES: 1. Mounted on P.C. Board.
2. Thermal Resistance Junction to Ambient.
REV 1.0 2017 JAN
PAGE:1/2
RATING AND CHARACTERISTIC CURVES (MB05S THRU MB10S)
FIG.2-MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
1.2
1.0
0.8
0.6
Single Phase
Half Wave 60Hz
0.4
Resistive Or Inductive Load
0.2
50
75
100 125
150
175
AMBIENT TEMPERATURE ( C)
PEAK FORWAARD SURGE CURRENT,(A)
AVERAGE FORWARD CURRENT,(A)
FIG.1-TYPICAL FORWARD CURRENT
DERATING CURVE
50
40
30
8.3ms Single Half
Tj=25 C
Sine Wave
JEDEC method
10
5
50
10
100
NUMBER OF CYCLES AT 60Hz
FIG.3-TYPICAL FORWARD
FIG.4-TYPICAL REVERSE
CHARACTERISTICS
CHARACTERISTICS
50
T J =125°C
10
REVERSE LEAKAGE CURRENT, (mA)
INSTANTANEOUS FORWARD CURRENT,(A)
50
3.0
1.0
Tj=25 C
Pulse Width 300us
1% Duty Cycle
0.1
10
3.0
1.0
0.1
Tj=25 C
.01
.4
.6
.8
1.0
FORWARD VOLTAGE,(V)
1.2
1.4
.01
60
80
100 120 140
PERCENTAGE OF PEAK REVERSE VOLTAGE, (%)
REV 1.0 2017 JAN
PAGE:2/2
很抱歉,暂时无法提供与“MB6S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.09464
- 600+0.07548
- 1200+0.07435
- 3000+0.05734
