M1
M7
THRU
1.0 AMP SURFACE MOUNT SILICON RECTIFIERS
VOLTAGE RANGE
50 to 1000 Volts
CURRENT
1.0 Ampere
FEATURES
* Ideal for surface mount applications
* Easy pick and place
* Built-in strain relief
* High surge current capability
DO-214AC(SMA)
.102(2.60)
.094(2.40)
.058(1.47)
.052(1.32)
MECHANICAL DATA
.161(4.10)
.153(3.90)
* Case: Molded plastic
* Epoxy: UL 94V-0 rate flame retardant
* Terminals: Solder plated, solderable per MIL-STD-202F,
method 208 guranteed
* Polarity: Color band denotes cathode end
* Mounting position: Any
* Weight: 0.063 gram
.012(0.31)
.006(0.15)
.090(2.29)
.078(1.98)
.005
MAX.
(.127)
.208(5.28)
.194(4.93)
.060(1.52)
.030(0.76)
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Rating 25 C ambient temperature uniess otherwies specified.
Single phase half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
TYPE NUMBER
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified Current
M1
50
35
50
M2
M3
M4
M5
M6
100
70
100
200
140
200
400
280
400
600
420
600
800
560
800
M7
1000
700
1000
UNITS
V
V
V
.375"(9.5mm) Lead Length at Ta=75 C
Peak Forward Surge Current, 8.3 ms single half sine-wave
1.0
A
superimposed on rated load (JEDEC method)
Maximum Instantaneous Forward Voltage at 1.0A
Maximum DC Reverse Current
Ta=25 C
30
1.1
5.0
A
V
A
at Rated DC Blocking Voltage
Ta=100 C
Typical Junction Capacitance (Note 1)
Typical Thermal Resistance RqJA (Note 2)
Operating and Storage Temperature Range TJ, TSTG
50
15
50
A
pF
C/W
C
-65
+150
NOTES:
1. Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2. Thermal Resistance from Junction to Ambient.
REV 1.0 2015 JAN
PAGE:1/2
RATING AND CHARACTERISTIC CURVES (M1THRU M7)
FIG.1-TYPICAL FORWARD
FIG.2-TYPICAL FORWARD CURRENT DERATING CURVE
AVERAGE FORWARD CURRENT,(A)
CHARACTERISTICS
10
3.0
1.0
1.2
1.0
0.8
Single Phase
0.6
Half Wave 60Hz
Resistive Or Inductive Load
0.4
0.2
Tj=25 C
60
80
100
120
140
160
180
200
AMBIENT TEMPERATURE ( C)
Pulse Width 300us
1% Duty Cycle
0.1
FIG.4-MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
.01
.6
.7
.8
.9
1.0
1.1
1.2
1.3
FORWARD VOLTAGE,(V)
FIG.3 - TYPICAL REVERSE
CHARACTERISTICS
PEAK FORWAARD SURGE CURRENT,(A)
INSTANTANEOUS FORWARD CURRENT,(A)
50
50
40
30
8.3ms Single Half
Tj=25 C
Sine Wave
JEDEC method
10
100
5
50
10
100
FIG.5-TYPICAL JUNCTION CAPACITANCE
10
35
Tj=100 C
JUNCTION CAPACITANCE,(pF)
REVERSE LEAKAGE CURRENT, ( A)
NUMBER OF CYCLES AT 60Hz
1.0
Tj=25 C
.1
30
25
10
5
.01
60
80
.01
.05
.1
.5
1
5
10
50
100
100 120 140
PERCENTAGE RATED PEAK REVERSE VOLTAGE
REVERSE VOLTAGE,(V)
REV 1.0 2015 JAN
PAGE:2/2
很抱歉,暂时无法提供与“M7”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 100+0.05994
- 1000+0.04720
- 5000+0.03824
- 10000+0.03392
- 50000+0.03024
- 100000+0.02819
- 国内价格
- 1+0.11880
- 500+0.03960
- 2500+0.02640
- 5000+0.02167
- 国内价格
- 50+0.04396
- 400+0.04330
- 800+0.03461
- 2000+0.03409
