1N4148WS
1N4148WS
    GOODWORK(固得沃克)
    SOD-323
    二极管配置:独立式 功率:400mW 直流反向耐压(Vr):100V 平均整流电流(Io):150mA 正向压降(Vf):1.25V@150mA 反向电流(Ir):1uA@100V 反向恢复时间(tr...
1N4148WS 数据手册
1N4148WS 5 AMP SURFACE MOUNT SILICON RECTIFIERS 0.15 VOLTAGE RANGE 100Volts CURRENT FEATURES 0.15 Ampere Fast Switching Speed Surface Mount Package Ideally Suited for Automatic Insertion For General Purpose Switching Applications High Conductance SOD323 E E C b A1 A D z z z z MECHANICAL DATA * Case: Molded plastic * Lead: Axial leads, solderable per MIL-STD-750, method 2026 * Polarity:Polarity symbols marked on case * Marking: T4,T6 L1 E1 A C D E E1 b L1 A1 max 1.1 0.15 1.4 1.8 2.75 0.4 0.45 0.2 min 0.8 0.08 1.2 1.4 2.55 0.25 0.2 max 43 5.9 55 70 108 16 16 min 32 3.1 47 63 100 9.8 7.9 UNIT mm 8 mil MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Rating 25 C ambient temperature uniess otherwies specified. Single phase half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. TYPE NUMBER 1N4 14 8 W S UNITS Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC Blocking Voltage Maximum Average Forward Rectified Current 100 70 100 V V V See Fig. 1 Peak Forward Surge Current 0.15 2.0 A 1.0 1.25 0.70 1 0.85 A V @ t=1.0 μs @t =1.0s Maximum Instantaneous Forward Voltage at 0.15A Maximum DC Reverse Current Ta=25 C at Rated DC Blocking Voltage Typical Junction Capacitance Total Power Dissipation Maximum Reverse Recovery Time (TRR typical ) Operating Temperature Range TJ Storage Temperature Range TSTG 2 250 400 A pF 8 mW ns -55 to10+150 -55 to +150 C C REV 1.0 2017 JAN PAGE:1/2 RATING AND CHARACTERISTIC CURVES 1N4148WS Forward 1000 Characteristics (nA) 1 0.1 0.01 0.0 0.4 0.8 1.2 FORWARD VOLTAGE o 100 o Ta=25 C 10 1 1.6 0 20 (V) 40 60 REVERSE VOLTAGE Capacitance Characteristics 1.6 80 100 VR Power Derating Curve 600 (mW) Ta=25℃ f=1MHz PD 1.4 1.2 POWER DISSIPATION CAPACITANCE BETWEEN TERMINALS CT (pF) VF Characteristics Ta=100 C 1000 REVERSE CURRENT IR C o FORWARD CURRENT Ta =2 5 Ta =1 00 o IF C (mA) 100 10 Reverse 10000 1.0 0.8 0.6 0 4 8 12 REVERSE VOLTAGE 16 VR (V) 20 500 400 300 200 100 0 0 25 50 75 100 AMBIENT TEMPERATURE 125 Ta 150 (℃ ) REV 1.0 2017 JAN PAGE:2/2
1N4148WS
1. 物料型号:型号为EL817,是一款光隔离型光电晶体管。
2. 器件简介:EL817是一种光隔离型光电晶体管,具有高输入阻抗和低输出阻抗,适用于高速光耦合器。
3. 引脚分配:EL817共有6个引脚,分别为A(发光二极管阳极)、KA(发光二极管阴极)、COL(集电极)、EMT(发射极)、GND(地)和VCC(电源)。
4. 参数特性:主要参数包括工作温度范围(-40℃至+85℃)、输入电流(最大20mA)、输出电流(最大50mA)等。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,具有抗干扰能力强、响应速度快等优点。
6. 应用信息:广泛应用于数字通信、测量设备、工业控制系统等领域。
1N4148WS 价格&库存
很抱歉,暂时无法提供与“1N4148WS”相匹配的价格&库存,您可以联系我们找货
1N4148WS
    • 1+0.03560
    库存:1396
    1N4148WS
    • 100+0.04104
    • 1000+0.03230
    • 3000+0.02474
    • 9000+0.02182
    • 45000+0.01923
    • 105000+0.01782
    库存:342234
    1N4148WS
    • 1+0.11660
    • 200+0.03883
    • 1500+0.02420
    • 3000+0.01925
    库存:12613
