S8050
NPN GENERAL PURPOSE SWITCHING TRANSISTOR
VOLTAGE 25Volts POWER 300mWatts
FEATURES
NPN epitaxial silicon, planar design.
Collector-emitter voltage VCE=25V.
Collector current IC=0.5A.
Transition frequency f T >150MHz @
IC=20mAdc, VCE=6Vdc, f=30MHz.
In compliance with EU RoHS 2002/95/EC
directives.
MECHANICAL DATA
Case: SOT-23, Plastic
Terminals: Solderable per MIL-STD-750,
method 2026
Approx. Weight: 0.008gram
Rank
Range
L
H
3
C
J3Y
B
2
1
E
120-200 200-350
MAXIMUM RATINGS(Ta=25℃ unless otherwise noted)
Symbol
Parameter
Vaule
Unit
VCBO
Collector-Base Voltage
40
V
VCEO
Collector-Emitter Voltage
25
V
VEBO
Emitter-Base Voltage
5
V
IC
Collector Current
0.5
A
PC
Total Device Dissipation
0.3
W
Thermal Resistance Form Junction to Ambient
625
TJ
Junction Temperature
150
O
TSTG
Storage Temperature
-55~+150
O
RθJA
O
C/W
C
C
S8050
ELECTRICAL CHARACTERISTICS(Ta=25℃ unless otherwise specified)
Parameter
Collector-Base breakdown voltage
Symbol
Min. Typ.Max.Units
IC=100uA,IE=0
40
V
Collector-Emitter breakdown voltage V(BR)CEO
IC=1mA,IB=0
25
V
Emitter-Base breakdown voltage
V(BR)EBO
IE=100uA,IC=0
5
V
Collector cut-off current
ICBO
VCB=40V,IC=0
ICEX
Base cut-off current
IBEX
Emitter cut-off current
IEBO
VEB=5V,IC=0
HFE
IC=0.1mA,VCE=1.0V
40
HFE
IC=1mA,VCE=1.0V
70
HFE
IC=50mA,VCE=1.0V
100
HFE
IC=100mA,VCE=1.0V
60
HFE
IC=500mA,VCE=1.0V
30
DC current gain*
V(BR)CBO
Test Condition
Collector-Emitter saturation voltage VCE(SAT)
VCE=20V,IB=0
0.1
uA
0.1
uA
0.1
uA
0.1
uA
400
IC=100mA,IB=10mA
0.5
V
IC=500mA,IB=50mA
0.6
V
IC=100mA,IB=10mA
1.1
V
IC=500mA,IB=50mA
1.2
V
Base-Emitter Saturation voltage*
VBE(SAT)
Input capacitance
CIB
VCB=5V,IE=0,f=1MHZ
4.0
pF
Output capacitance
COB
VEB=0.5V,IC=0,f=1MHZ
8.0
pF
Transition ferquency
fT
IC=20mA,VCE=6V,f=30MHZ
Delay time
td
35
nS
Rise time
tr
VCC=3V,VBE=-0.5V,
IC=10mA,IB=1.0mA
35
nS
Storage time
ts
200
nS
Fall time
tf
VCC=3V,VBE=-0.5V,
IB1=IB2=1.0mA
50
nS
150
MHZ
*Pulse Test: Pulse Width
很抱歉,暂时无法提供与“S8050”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.05500
- 500+0.04895
- 3000+0.04186
- 6000+0.03981
- 30000+0.03806
- 45000+0.03715
- 国内价格
- 50+0.06847
- 600+0.05521
- 1200+0.05438
- 3000+0.04439
- 国内价格
- 1+0.18040
- 200+0.06006
- 1500+0.03751
- 3000+0.02981
