KBPC5010
KBPC5010
    GOODWORK(固得沃克)
    KBPC
    单相50.0安培桥式整流器 VR=1KV IR=10A KBPC
KBPC5010 数据手册
KBPC50005 THRU KBPC5010 SINGLE PHASE 50.0 AMP BRIDGE RECTIFIERS VOLTAGE RANGE 50 to 1000 Volts CURRENT 50.0 Ampere KBPC FEATURES .452 MAX. (11.5) * Superior thermal design .480(12.2) .425(10.8) * 400 amperes surge capability 1.181(30.0) * Mounting: Hole thru for #8 screw 1.102(28.0) HOLE FOR NO. 8 SCREW * 1/4" universal faston terminal .673(17.1) .633(16.1) AC + .732(18.6) .692(17.6) .673(17.1) .633(16.1) 1.181(30.0) 1.102(28.0) AC .582(14.8) .543(13.8) .033X.250 (0.8X6.4) Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Rating 25 C ambient temperature uniess otherwies specified. Single phase half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. TYPE NUMBER KBPC50005 KBPC5001 KBPC5002 KBPC5004 KBPC5006 KBPC5008 KBPC5010 UNITS Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC Blocking Voltage Maximum Average Forward Rectified Current 50 35 50 100 70 100 200 140 200 400 280 400 600 420 600 800 560 800 1000 700 1000 V V V .375"(9.5mm) Lead Length at Tc=50 C Peak Forward Surge Current, 8.3 ms single half sine-wave 50.0 A superimposed on rated load (JEDEC method) Maximum Forward Voltage Drop per Bridge Element at25A D.C. Maximum DC Reverse Current Ta=25 C 450 1.2 10 A V mA 100 +150 +150 mA at Rated DC Blocking Voltage Operating Temperature Range, TJ Storage Temperature Range, TSTG Ta=100 C -65 -65 C C REV 1.0 2015 JAN PAGE:1/2 RATING AND CHARACTERISTIC CURVES (KBPC50005 THRU KBPC5010) FIG.2-MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT 60 Single Phase 50 Half Wave 60Hz Resistive Or Inductive Load 40 30 20 10 0 0 25 50 75 100 125 150 175 PEAK FORWARD SURGE CURRENT,(A) AVERAGE FORWARD CURRENT,(A) FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE 500 450 400 300 8.3ms Single Half Tj=25 C Sine Wave 200 JEDEC method 100 0 CASE TEMPERATURE,( C) 1 5 50 10 100 NUMBER OF CYCLES AT 60Hz FIG.3-TYPICAL FORWARD FIG.4-TYPICAL REVERSE CHARACTERISTICS CHARACTERISTICS 50 REVERSE LEAKAGE CURRENT, ( A) INSTANTANEOUS FORWARD CURRENT,(A) 50 10 3.0 1.0 Tj=25 C Pulse Width 300us 1% Duty Cycle 0.1 10 3.0 1.0 0.1 Tj=25 C .01 0 .2 .4 .6 .8 1.0 FORWARD VOLTAGE,(V) 1.2 1.4 .01 0 20 40 60 80 100 120 140 PERCENT OF RATED PEAK REVERSE VOLTAGE, (%) REV 1.0 2015 JAN PAGE:2/2
KBPC5010 价格&库存
很抱歉,暂时无法提供与“KBPC5010”相匹配的价格&库存,您可以联系我们找货
KBPC5010
  • 1+4.26930
  • 30+4.10880
  • 100+3.78780
  • 500+3.46680
  • 1000+3.30630
KBPC5010
  • 1+7.50600
  • 10+6.15600
  • 50+5.19480
  • 100+4.52520
  • 500+4.12560
  • 1000+3.92040
库存:284
