KBU810
KBU810
    GOODWORK(固得沃克)
    DB-4P_23.2X6.95MM_TM
    单相8.0安培桥式整流器
KBU810 数据手册
5 THRU KBU810 KBU8005 SINGLE PHASE 8.0 AMP BRIDGE RECTIFIERS VOLTAGE RANGE 50 to 1000 Volts CURRENT 8.0 Amperes KBU FEATURES * Ideal for printed circuit board .15FX.23L (3.8FX5.7L) HOLE THRU .935(23.7) .895(22.7) * Low forward voltage .700(17.8) .660(16.8) * Low leakage current .780(19.8) .740(18.8) * Polarity: marked on body AC * Mounting position: Any + 1.00 MIN. (25.4) .052(1.3) .048(1.2) DIA. .220(5.6) SPACING .180(4.6) .078 (2.0) .280(7.1) .268(6.8) Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Rating 25 C ambient temperature uniess otherwies specified. Single phase half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. TYPE NUMBER KBU8005KBU801 KBU802 KBU804 KBU806 KBU808 KBU810 UNITS Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC Blocking Voltage Maximum Average Forward Rectified Current 50 35 50 100 70 100 200 140 200 400 280 400 600 420 600 800 560 800 1000 700 1000 V V V .375"(9.5mm) Lead Length at Ta=40 C Peak Forward Surge Current, 8.3 ms single half sine-wave 8.0 A superimposed on rated load (JEDEC method) Maximum Forward Voltage Drop per Bridge Element at 4.0A D.C. Maximum DC Reverse Current Ta=25 C 170 1.1 10 A V mA 200 +150 +150 mA at Rated DC Blocking Voltage Operating Temperature Range, TJ Storage Temperature Range, TSTG Ta=100 C -65 -65 C C REV 1.0 2015 JAN PAGE:1/2 RATING AND CHARACTERISTIC CURVES (KBU8005 THRU KBU810) FIG.2-MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT PEAK FORWARD SURGE CURRENT,(A) 12 10 8 6 Single Phase 4 Half Wave 60Hz Resistive Or Inductive Load 2 0.375"(9.5mm) Lead Length 0 0 50 100 150 250 200 170 150 8.3ms Single Half Tj=25 C Sine Wave 100 JEDEC method 50 0 1 AMBIENT TEMPERATURE,( C) 5 50 10 100 NUMBER OF CYCLES AT 60Hz FIG.3-TYPICAL FORWARD FIG.4-TYPICAL REVERSE CHARACTERISTICS CHARACTERISTICS 50 50 10 10 REVERSE LEAKAGE CURRENT, (mA) INSTANTANEOUS FORWARD CURRENT,(A) AVERAGE FORWARD CURRENT,(A) FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE 3.0 1.0 Tj=25 C Pulse Width 300us 1% Duty Cycle 0.1 3.0 Tj=100 C 1.0 0.1 Tj=25 C .01 0 .2 .4 .6 .8 1.0 FORWARD VOLTAGE,(V) 1.2 1.4 .01 0 20 40 60 80 100 120 140 PERCENT OF RATED PEAK REVERSE VOLTAGE, (%) REV 1.0 2015 JAN PAGE:2/2
KBU810 价格&库存
很抱歉,暂时无法提供与“KBU810”相匹配的价格&库存,您可以联系我们找货
