GBJ25005 THRU GBJ2510
SINGLE PHASE 25.0 AMP BRIDGE RECTIFIERS
VOLTAGE RANGE
50 to 1000 Volts
CURRENT
25.0 Amperes
GBJ
FEATURES
* Ideal for printed circuit board
.134(3.4)
.122(3.1)
1.193(30.3)
1.169(29.7)
.192(4.9)
.177(4.5)
.150(3.8)
.134(3.4)
.165(4.2)
.150(3.8)
.094(2.4)
.078(2.0)
.043(1.1)
.035(0.9)
.441(11.2)
.425(10.8)
* Mounting position: Any
.800(20.3)
.776(19.7)
* Low leakage current
.708(18.0)
.669(17.0)
.189
(4.8)
* Low forward voltage
.114(2.9)
.098(2.5)
.031(0.8)
.023(0.6)
.402(10.2) .303(7.7) .303(7.7)
SPACING
.386(9.8) .287(7.3) .287(7.3)
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Rating 25 C ambient temperature uniess otherwies specified.
Single phase half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
TYPE NUMBER
8 GBJ2510 UNITS
GBJ25005GBJ2501 GBJ2502 GBJ2504 GBJ2506 GBJ2508
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward (with heatsink Note 2)
50
35
50
100
70
100
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
V
V
V
25.0
A
4.2
A
superimposed on rated load (JEDEC method)
Maximum Forward Voltage Drop per Bridge Element at 3.0A D.C.
Maximum DC Reverse Current
Ta=25 C
350
1.05
10
A
V
mA
at Rated DC Blocking Voltage
Typical Junction Capacitance (Note 1)
Typical Thermal Resistance RqJC (Note 2)
Operating Temperature Range, TJ
Storage Temperature Range, TSTG
500
85
0.6
mA
PF
C/W
.375"(9.5mm) Lead Length at Tc=100 C (With heatsink)
Peak Forward Surge Current, 8.3 ms single half sine-wave
Ta=125 C
-55
-55
+150
+150
C
C
NOTES:
1. Measured at 1.0MHz and applied reverse voltage of 4.0V DC.
2. Thermal Resistance from Junction to Case with device mounted on 300mm x 300mm x 1.6mm Cu Plate Heatsink.
REV 1.0 2015 JAN
PAGE:1/2
RATING AND CHARACTERISTIC CURVES (GBJ25005 THRU GBJ2510)
FIG.2-MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
25
AVERAGE FORWARD CURRENT,(A)
WITH HEATSINK
Single Phase
Half Wave 60Hz
15
Resistive Or Inductive Load
10
WITHOUT HEATSINK
5
60
80
100
120 140
160
PEAK FORWARD SURGE CURRENT,(A)
FIG.1-TYPICAL FORWARD CURRENT
DERATING CURVE
500
400
300
Sine Wave
JEDEC method
100
CASE TEMPERATURE,( C)
8.3ms Single Half
Tj=25 C
200
50
10
5
100
FIG.3-TYPICAL FORWARD
FIG.4-TYPICAL REVERSE
CHARACTERISTICS
CHARACTERISTICS
50
50
10
10
REVERSE LEAKAGE CURRENT, (mA)
INSTANTANEOUS FORWARD CURRENT,(A)
NUMBER OF CYCLES AT 60Hz
3.0
1.0
Tj=25 C
Pulse Width 300us
1% Duty Cycle
0.1
3.0
Tj=100 C
1.0
0.1
Tj=25 C
.01
.4
.6
.8
1.0
FORWARD VOLTAGE,(V)
1.2
1.4
.01
60
80
100 120 140
PERCENT OF RATED PEAK REVERSE VOLTAGE, (%)
REV 1.0 2015 JAN
PAGE:2/2
很抱歉,暂时无法提供与“GBJ2510”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.14874
- 10+2.52252
- 30+2.25792
