DB207
DB207
    GOODWORK(固得沃克)
    DB_8.5X6.5MM_TM
    DB_8.5X6.5MM_TM
DB207 数据手册
DB202 Thru DB207 High Current Glass Passivated Molding Single-Phase Bridge Rectifier Reverse Voltage 100 to 1000V Forward Current 2.0 A FEATURES  Plastic Package has Underwriters Laboratory Flammability Classification 94V-0  High current capacity with small package  Glass passivated chip junctions  Superior thermal conductivity  High IFSM 1. Maximum & Thermal Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Parameter Symbol Symbol DB202 DB203 DB204 DB205 DB206 DB207 Unit Maximum repetitive voltage VRRM 100 200 400 600 800 1000 V Maximum RMS Voltage VRMS 70 140 280 420 560 700 V VDC 100 200 400 600 800 1000 V Maximum DC Blocking Voltage Maximum DC reverse current TA=25 ℃ at rated DC blocking voltage TA=125℃ Average rectified forward current wave Resistance load 60Hz Sine with Ta=55℃ Peak forward surge current 8.3ms single half sine-wave superimposed on rated load Max instantaneous forward voltage at 2.0A Peak forward surge current 8.3ms single half sine-wave superimposed on rated load Maximum thermal on P.C.B. without heat-sink Operating junction temperature Storage temperature IR 5 µA 500 Io 2 A IFSM 70 A VF 1.05 V I2t 20 A2sec RθJA 40 ℃/W TJ -55~150 ℃ Tstg -55~150 ℃ 1 DB202 Thru DB207 2. Ratings and Characteristic Curves ( TA = 25°C unless otherwise noted ) Fig.2 Case Temperature Ta(℃) Percent of Rated Peak Reverse Voltage% Fig.4 Peak Surge Forward Capability Peak Surge Forward Current IFSM(A) Forward Voltage Forward Current (A) Fig.3 Typical Reverse Characteristics nstantaneous Reverse Current (µA) Average Rectified Forward Current Io(A) Fig. 1 Derating Curve Forward Voltage VF Number of Cycles 2 DB202 Thru DB207 3. Marking Identification Note: 生产日期码包含4位数字,例如 “1018”,前两个数字“10” 表示为2010年,另外二个数字 “18” 是指第18周,即表示该产品为2010年18周生产。 型号: DB 2 05 bridge reverse voltage=600V average rectified forward Current=2A mean:DB series bridge 4. Dimension 3
DB207 价格&库存
很抱歉,暂时无法提供与“DB207”相匹配的价格&库存,您可以联系我们找货
DB207
    • 10+0.35945
    库存:40
