S3ABF THRU S3MBF
3.0 AMP SURFACE MOUNT SILICON RECTIFIERS
VOLTAGE RANGE
50 to 1000 Volts
CURRENT
3.0 Ampere
FEATURES
* Ideal for surface mount applications
* Easy pick and place
* Built-in strain relief
* Low forward voltage drop
SMBF
.173(4.4)
.165(4.2)
.086(2.2)
.075(1.9)
MECHANICAL DATA
.216(5.5)
.200(5.1)
* Case: Molded plastic
* Epoxy: UL 94V-0 rate flame retardant
* Metallurgically bonded construction
* Polarity: Color band denotes cathode end
* Mounting position: Any
.010(0.26)
.007(0.18)
.051(1.30)
.043(1.10)
.146(3.7)
.138(3.5)
.051(1.3)
.039(1.0)
Dimensionsin
in inches
inches and (millimeters)
Dimensions
(millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Rating 25 C ambient temperature uniess otherwies specified.
Single phase half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
TYPE NUMBER
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified Current
S3ABF S3BBF S3DBF S3GBF S3JBF S3KBF S3MBF UNITS
50
35
50
100
70
100
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
V
V
V
At TL=75 C
Peak Forward Surge Current, 8.3 ms single half sine-wave
3.0
A
superimposed on rated load (JEDEC method)
Maximum Instantaneous Forward Voltage at 3.0A
Maximum DC Reverse Current
Ta=25 C
100
1.10
5.0
A
V
A
at Rated DC Blocking Voltage
Ta=125 C
Typical Junction Capacitance (Note1)
Typical Thermal Resistance RqJL (Note 2)
Operating and Storage Temperature Range TJ, TSTG
250
A
pF
C/W
C
60
13
-65
+150
NOTES:
1. Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2. Thermal Resistance Junction to Lead.
REV 1.0 2015 JAN
PAGE:1/2
RATING AND CHARACTERISTIC CURVES (S3ABF THRU S3MBF)
FIG.1-TYPICAL FORWARD
FIG.2-TYPICAL FORWARD CURRENT DERATING CURVE
AVERAGE FORWARD CURRENT,(A)
CHARACTERISTICS
10
3.0
1.0
2.5
2.0
Single Phase
1.5
Half Wave 60Hz
Resistive Or Inductive Load
1.0
0.375"(9.5mm) Lead Length
0.5
60
80
100
120
140
160
180
200
AMBIENT TEMPERATURE,( C)
Tj=25 C
Pulse Width 300us
1% Duty Cycle
0.1
FIG.4-MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
.01
.6
.7
.8
.9
1.0
1.1
1.2
1.3
FORWARD VOLTAGE,(V)
FIG.3 - TYPICAL REVERSE
CHARACTERISTICS
PEAK FORWARD SURGE CURRENT,(A)
INSTANTANEOUS FORWARD CURRENT,(A)
50
3.0
100
80
60
8.3ms Single Half
Tj=25 C
Sine Wave
40
JEDEC method
100
5
50
10
100
NUMBER OF CYCLES AT 60Hz
FIG.5-TYPICAL JUNCTION CAPACITANCE
140
Tj=100 C
JUNCTION CAPACITANCE,(pF)
REVERSE LEAKAGE CURRENT, ( A)
10
1.0
Tj=25 C
.1
120
100
80
60
40
60
80
.01
.05
.1
.5
1
5
10
50
100
100 120 140
PERCENT OF RATED PEAK REVERSE VOLTAGE,(%)
REVERSE VOLTAGE,(V)
REV 1.0 2015 JAN
PAGE:2/2
很抱歉,暂时无法提供与“S3MBF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.16088
- 500+0.10662
- 2000+0.10502
- 5000+0.09187
- 国内价格
- 20+0.17550
- 200+0.13749
- 600+0.11632
- 5000+0.10023
- 10000+0.08921
- 20000+0.08327
