KBJ10005
5 THRU KBJ1010
SINGLE PHASE 10.0 AMP BRIDGE RECTIFIERS
VOLTAGE RANGE
50 to 1000 Volts
CURRENT
4.0 Amperes
KBJ
FEATURES
* Ideal for printed circuit board
* Low forward voltage
* Low leakage current
* Mounting position: Any
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Rating 25 C ambient temperature uniess otherwies specified.
Single phase half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
TYPE NUMBER
KBJ10005 KBJ1001 KBJ1002 KBJ1004 KBJ1006 KBJ1008
8 KBJ1010
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward (with heatsink Note 2)
50
35
50
100
70
100
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
UNITS
V
V
V
10.0
A
Rectified Current at Tc=110 C (Without heatsink)
Peak Forward Surge Current, 8.3 ms single half sine-wave
3.0
A
superimposed on rated load (JEDEC method)
Maximum Forward Voltage Drop per Bridge Element at 5.0A D.C.
Maximum DC Reverse Current
Ta=25 C
200
1.05
5.0
A
V
A
at Rated DC Blocking Voltage
Typical Thermal Resistance RqJC (Note 1)
Typical Thermal Resistance RqJL (Note 2)
Operating Temperature Range, TJ
Storage Temperature Range, TSTG
500
2.3
6.0
A
C/W
C/W
Ta=100 C
-55
-55
+150
+150
C
C
NOTES:
1. Thermal Resistance from Junction to Case with device mounted on 100mm x 100mm x 1.6mm Cu Plate Heatsink.
2. Thermal Resistance from Junction to Lead without Heatsink.
REV 1.0 2019 JAN
PAGE:1/2
RATING AND CHARACTERISTIC CURVES (KBJ10005 THRU KBJ1010)
FIG.2-MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
AVERAGE FORWARD CURRENT,(A)
18
Single Phase
16
Half Wave 60Hz
14
Resistive Or Inductive Load
12
WITH HEATSINK
10
8
6
4
2
WITHOUT HEATSINK
60
80
100
120 140
160
PEAK FORWARD SURGE CURRENT,(A)
FIG.1-TYPICAL FORWARD CURRENT
DERATING CURVE
250
200
150
Sine Wave
100
JEDEC method
50
CASE TEMPERATURE,( C)
8.3ms Single Half
Tj=25 C
50
10
5
100
FIG.3-TYPICAL FORWARD
FIG.4-TYPICAL REVERSE
CHARACTERISTICS
CHARACTERISTICS
50
50
10
10
REVERSE LEAKAGE CURRENT, ( A)
INSTANTANEOUS FORWARD CURRENT,(A)
NUMBER OF CYCLES AT 60Hz
3.0
1.0
Tj=25 C
Pulse Width 300us
1% Duty Cycle
0.1
3.0
Tj=100 C
1.0
0.1
Tj=25 C
.01
.4
.6
.8
1.0
FORWARD VOLTAGE,(V)
1.2
1.4
.01
60
80
100 120 140
PERCENT OF RATED PEAK REVERSE VOLTAGE, (%)
REV 1.0 2019 JAN
PAGE:2/2
很抱歉,暂时无法提供与“KBJ1010”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.28900
- 30+2.23450
- 100+2.12550
- 500+2.01650
- 1000+1.96200
