U1M
U1M
    GOODWORK(固得沃克)
    SMF(SOD-123FL)
    1.0安培表面安装快速恢复整流器
U1M 数据手册
U1A U1M THRU 1.0 AMP SURFACE MOUNT FAST RECOVERY RECTIFIERS VOLTAGE RANGE 50 to 1000 Volts CURRENT 1.0 Ampere FEATURES * Ideal for surface mount applications * Easy pick and place * Built-in strain relief * Fast switching speed SOD123FL .114(2.9) .102(2.6) .043(1.1) .031(0.8) MECHANICAL DATA .148(3.75) .140(3.55) * Case: Molded plastic * Epoxy: UL 94V-0 rate flame retardant * Metallurgically bonded construction * Polarity: Color band denotes cathode end * Mounting position: Any .008(0.20) .005(0.12) .043(1.10) .036(0.90) .075(1.9) .067(1.7) .033(0.85) .022(0.55) Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Rating 25 C ambient temperature uniess otherwies specified. Single phase half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. U1A U1B U1D U1G U1J U1K U1M TYPE NUMBER Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC Blocking Voltage Maximum Average Forward Rectified Current 50 35 50 100 70 100 200 140 200 400 280 400 .375"(9.5mm) Lead Length at Ta=55 C Peak Forward Surge Current, 8.3 ms single half sine-wave Maximum DC Reverse Current 30 1.3 1.0 Ta=25 C at Rated DC Blocking Voltage Ta=100 C Maximum Reverse Recovery Time (Note 1) Typical Junction Capacitance (Note 2) Operating and Storage Temperature Range TJ, TSTG 800 560 800 1.7 5.0 100 75 50 -50 15 +150 1000 700 1000 UNITS V V V A 1.0 superimposed on rated load (JEDEC method) Maximum Instantaneous Forward Voltage at 1.0A 600 420 600 A V A A nS pF C NOTES: 1. Reverse Recovery Time test condition: IF=0.5A, IR=1.0A, IRR=0.25A 2. Measured at 1MHz and applied reverse voltage of 4.0V D.C. REV 1.0 2015 JAN PAGE:1/2 RATING AND CHARACTERISTIC CURVES (U1A THRU U1M) FIG.2-TYPICAL FORWARD CURRENT DERATING CURVE FIG.1-TYPICAL FORWARD CHARACTERISTICS AVERAGE FORWARD CURRENT,(A) -U1 D U1 U1 J-U G 1M 1.0 U1 A .1 1.2 1.0 0.8 0.6 Single Phase Half Wave 60Hz 0.4 Resistive Or Inductive Load 0.375"(9.5mm) Lead Length 0.2 0 0 25 50 75 100 125 150 175 AMBIENT TEMPERATURE ( C) Tj=25 C Pulse Width 300us 1% Duty Cycle .01 .6 .8 1.0 1.2 1.4 1.6 1.8 FORWARD VOLTAGE,(V) FIG.3- TEST CIRCUIT DIAGRAM AND REVERSE RECOVERY TIME CHARACTERISTICS 50W NONINDUCTIVE 10W NONINDUCTIVE ( ) (+) D.U.T. 25Vdc (approx.) PEAK FORWARD SURGE CURRENT,(A) .001 .4 FIG.4-MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT PULSE GENERATOR (NOTE 2) ( ) 30 24 18 Sine Wave JEDEC method 6 1 5 (+) 1W NONINDUCTIVE 8.3ms Single Half Tj=25 C 12 0 50 10 100 NUMBER OF CYCLES AT 60Hz OSCILLISCOPE (NOTE 1) NOTES: 1. Rise Time= 7ns max., Input Impedance= 1 megohm.22pF. 2. Rise Time= 10ns max., Source Impedance= 50 ohms. FIG.5-TYPICAL JUNCTION CAPACITANCE 70 trr JUNCTION CAPACITANCE,(pF) INSTANTANEOUS FORWARD CURRENT,(A) 10 | | | | | | | | +0.5A 0 -0.25A -1.0A 60 50 40 U1A-U 30 1G U1J- 20 U1M 10 1cm SET TIME BASE FOR 50 / 10ns / cm 0 .01 .05 .1 .5 1 5 10 50 100 REVERSE VOLTAGE,(V) REV 1.0 2015 JAN PAGE:2/2
很抱歉,暂时无法提供与“U1M”相匹配的价格&库存,您可以联系我们找货
U1M
  • 1+0.03749
  • 100+0.03499
  • 300+0.03249
  • 500+0.03000
  • 2000+0.02875
  • 5000+0.02800
U1M
  • 1+0.15620
  • 200+0.05236
  • 1500+0.03267
  • 3000+0.02596
库存:3000
U1M
  • 50+0.07460
  • 500+0.06074
  • 3000+0.04802
  • 6000+0.04340
  • 30000+0.03940
  • 45000+0.03715
库存:103880
