GBU2510
GBU2510
    GOODWORK(固得沃克)
    DB-22X3.45MM_TM
    桥式整流器/整流桥 GBU VRRM=1KV IF=25A VF=1.05V
GBU2510 数据手册
GBU25005 THRU GBU2510 SINGLE PHASE 25.0 AMP BRIDGE RECTIFIERS VOLTAGE RANGE 50 to 1000 Volts CURRENT 25.0 Amperes GBU FEATURES .880(22.3) .860(21.8) * Ideal for printed circuit board * Low forward voltage .139(3.5) .133(3.4) .154(3.9) .146(3.7) .232(5.9) .224(5.7) * Low leakage current .752(19.1) .720(18.3) .106(2.7) .087(2.2) AC + * Polarity: marked on body .100(2.54) .085(2.16) * Mounting position: Any .720(18.29) .680(17.27) .047(1.2) .035(0.9) .106(2.7) .091(2.3) .024(0.6) .016(0.4) .210(5.33) SPACING .190(4.83) Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Rating 25 C ambient temperature uniess otherwies specified. Single phase half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. TYPE NUMBER 8 GBU2510 UNITS GBU25005GBU2501 GBU2502 GBU2504 GBU2506 GBU2508 Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC Blocking Voltage Maximum Average Forward (with heatsink Note 2) 50 35 50 100 70 100 200 140 200 400 280 400 600 420 600 800 560 800 1000 700 1000 V V V 25.0 A 4.2 A superimposed on rated load (JEDEC method) Maximum Forward Voltage Drop per Bridge Element at 12.5A D.C. Maximum DC Reverse Current Ta=25 C 350 1.05 10 A V A at Rated DC Blocking Voltage Typical Junction Capacitance (Note 1) Typical Thermal Resistance RqJC (Note 2) Operating Temperature Range, TJ Storage Temperature Range, TSTG 500 85 0.6 A PF C/W .375"(9.5mm) Lead Length at Tc=100 C (Without heatsink) Peak Forward Surge Current, 8.3 ms single half sine-wave Ta=125 C -55 -55 +150 +150 C C NOTES: 1. Measured at 1.0MHz and applied reverse voltage of 4.0V DC. 2. Thermal Resistance from Junction to Case with device mounted on 300mm x 300mm x 1.6mm Cu Plate Heatsink. REV 1.0 2019 JAN PAGE:1/2 RATING AND CHARACTERISTIC CURVES (GBU25005 THRU GBU2510) FIG.2-MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT 25 AVERAGE FORWARD CURRENT,(A) WITH HEATSINK 20 Single Phase Half Wave 60Hz 15 Resistive Or Inductive Load 10 WITHOUT HEATSINK 5 0 20 40 60 80 100 120 140 160 PEAK FORWARD SURGE CURRENT,(A) FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE 500 400 300 Sine Wave JEDEC method 100 0 1 CASE TEMPERATURE,( C) 8.3ms Single Half Tj=25 C 200 50 10 5 100 FIG.3-TYPICAL FORWARD FIG.4-TYPICAL REVERSE CHARACTERISTICS CHARACTERISTICS 50 50 10 10 REVERSE LEAKAGE CURRENT, (mA) INSTANTANEOUS FORWARD CURRENT,(A) NUMBER OF CYCLES AT 60Hz 3.0 1.0 Tj=25 C Pulse Width 300us 1% Duty Cycle 0.1 3.0 Tj=100 C 1.0 0.1 Tj=25 C .01 0 .2 .4 .6 .8 1.0 FORWARD VOLTAGE,(V) 1.2 1.4 .01 0 20 40 60 80 100 120 140 PERCENT OF RATED PEAK REVERSE VOLTAGE, (%) REV 1.0 2019 JAN PAGE:2/2
GBU2510 价格&库存
很抱歉,暂时无法提供与“GBU2510”相匹配的价格&库存,您可以联系我们找货
