SI4056DY-T1-GE3
SI4056DY-T1-GE3
    VBSEMI(微碧)
    SOIC-8
    N-Channel 100 V (D-S) MOSFET
SI4056DY-T1-GE3 数据手册
SI4056DY-T1-GE3 www.VBsemi.com N-Channel 100 V (D-S) MOSFET FEATURES PRODUCT SUMMARY VDS (V) 100 RDS(on) (Ω) a ID (A) 0.020 at VGS = 10 V 10.4 0.027 at VGS = 8 V 9.5 • Halogen-free According to IEC 61249-2-21 Definition • Extremely Low Qgd for Switching Losses • 100 % Rg Tested • 100 % Avalanche Tested • Compliant to RoHS Directive 2002/95/EC Qg (Typ.) 23 nC D APPLICATIONS SO-8 • Primary Side Switch S 1 8 D S 2 7 D S 3 6 D G 4 5 D G S Top View N-Channel MOSFET ABSOLUTE MAXIMUM RATINGS (TA = 25 °C, unless otherwise noted) Symbol VDS VGS Parameter Drain-Source Voltage Gate-Source Voltage Continuous Drain Current (TJ = 150 °C) TC = 25 °C TC = 70 °C TA = 25 °C TA = 70 °C ID IDM Pulsed Drain Current TC = 25 °C TA = 25 °C IS Single Pulse Avalanche Current Single Pulse Avalanche Energy L = 0.1 mH IAS EAS Maximum Power Dissipation TC = 25 °C TC = 70 °C TA = 25 °C TA = 70 °C PD Continuous Source-Drain Diode Current Limit 100 ± 20 10.4 9.1 8.5b, c 7.5b, c Operating Junction and Storage Temperature Range Unit V A 50 4.5 2.6b, c 20 20 5.9 3.8 3.1b, c 2b, c - 55 to 150 TJ, Tstg mJ W °C THERMAL RESISTANCE RATINGS Parameter Maximum Junction-to-Ambientb, f t ≤ 10 s Maximum Junction-to-Foot (Drain) Steady State Symbol RthJA RthJF Typical 33 17 Maximum 40 21 Unit °C/W Notes: a. Based on TC = 25 °C. b. Surface mounted on 1” x 1” FR4 board. c. t = 10 s. d. Maximum under steady state conditions is 80 °C/W. 1 SI4056DY-T1-GE3 www.VBsemi.com SPECIFICATIONS (TJ = 25 °C, unless otherwise noted) Parameter Symbol Test Conditions Min. VDS VGS = 0 V, ID = 250 µA 100 Typ. Max. Unit Static Drain-Source Breakdown Voltage VDS Temperature Coefficient ΔVDS /TJ VGS(th) Temperature Coefficient ΔVGS(th) /TJ Gate-Source Threshold Voltage ID = 250 µA VGS(th) VDS = VGS , ID = 250 µA Gate-Source Leakage IGSS VDS = 0 V, VGS = ± 20 V Zero Gate Voltage Drain Current IDSS On-State Drain Currenta ID(on) Drain-Source On-State Resistancea RDS(on) Transconductancea gfs Forward V 172 mV/°C - 10 1.5 4.5 V ± 100 nA VDS = 100 V, VGS = 0 V 1 VDS = 100 V, VGS = 0 V, TJ = 55 °C 10 VDS ≥ 10 V, VGS = 10 V 30 µA A VGS = 10 V, ID = 5 A 0.020 VGS = 8 V, ID = 5 A 0.027 VDS = 15 V, ID = 5 A 23 Ω S Dynamicb Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss Total Gate Charge Qg Gate-Source Charge Qgs Gate-Drain Charge Qgd Gate Resistance Rg Turn-on Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time 1735 VDS = 50 V, VGS = 0 V, f = 1 MHz tr pF 37 VDS = 75 V, VGS = 10 V, ID = 5 A 28.5 43 23 35 VDS = 75 V, VGS = 8 V, ID = 5 A 8 f = 1 MHz 0.85 1.3 14 21 VDD = 50 V, RL = 10 Ω ID ≅ 5 A, VGEN = 10 V, Rg = 1 Ω 12 18 22 33 tf 6 10 td(on) 16 24 tr td(off) nC 6.5 td(on) td(off) 160 VDD = 50 V, RL = 10 Ω ID ≅ 5 A, VGEN = 8 V, Rg = 1 Ω tf 12 18 20 30 7 12 Ω ns Drain-Source Body Diode Characteristics Continuous Source-Drain Diode Current IS Pulse Diode Forward Currenta ISM Body Diode Voltage VSD Body Diode Reverse Recovery Time trr Body Diode Reverse Recovery Charge Qrr Reverse Recovery Fall Time ta Reverse Recovery Rise Time tb TC = 25 °C 7.7 50 IS = 2.6 A IF = 5 A, dI/dt = 100 A/µs, TJ = 25 °C A 0.77 1.2 V 63 95 ns 110 165 nC 49 14 ns Notes: a. Pulse test; pulse width ≤ 300 µs, duty cycle ≤ 2 % a. Guaranteed by design, not subject to production testing. Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. 2 SI4056DY-T1-GE3 www.VBsemi.com TYPICAL CHARACTERISTICS (25 °C, unless otherwise noted) 1.2 60 VGS = 10 V thru 7 V VGS = 6 V 0.9 I D - Drain Current (A) I D - Drain Current (A) 48 36 24 TC = 125 °C 0.6 TC = 25 °C 0.3 12 VGS = 5 V TC = - 55 °C 0 0.0 0 1 2 3 4 5 0 2 VDS - Drain-to-Source Voltage (V) 0.035 1600 C - Capacitance (pF) R DS(on) - On-Resistance (Ω) 2000 VGS = 8 V VGS = 10 V Ciss 800 400 0.015 0 10 30 20 40 50 Coss Crss 0 60 20 ID - Drain Current (A) 60 40 80 100 VDS - Drain-to-Source Voltage (V) On-Resistance vs. Drain Current and Gate Voltage Capacitance 2.5 10 ID = 5 A ID = 5 A VDS = 50 V VGS = 10 V 2.1 VDS = 75 V 6 VDS = 100 V 4 (Normalized) 8 R DS(on) - On-Resistance VGS - Gate-to-Source Voltage (V) 10 1200 0.020 0 8 Transfer Characteristics 0.040 0.025 6 VGS - Gate-to-Source Voltage (V) Output Characteristics 0.030 4 1.7 VGS = 8 V 1.3 0.9 2 0 0 6 12 18 Qg - Total Gate Charge (nC) Gate Charge 24 30 0.5 - 50 - 25 0 25 50 75 100 125 150 TJ - Junction Temperature (°C) On-Resistance vs. Junction Temperature 3 SI4056DY-T1-GE3 www.VBsemi.com TYPICAL CHARACTERISTICS (25 °C, unless otherwise noted) 0.20 I S - Source Current (A) 10 R DS(on) - Drain-to-Source On-Resistance (Ω) 100 TJ = 150 °C 1 TJ = 25 °C 0.1 0.01 0.001 ID = 5 A 0.16 0.12 TJ = 125 °C 0.08 TJ = 25 °C 0.04 0.00 0 0.2 0.4 0.6 0.8 1 0 1.2 2 VSD - Source-to-Drain Voltage (V) Power (W) VGS(th) (V) 10 160 0.5 ID = 5 mA - 0.5 - 1.0 120 80 40 - 25 0 25 50 100 75 125 150 0 0.001 Threshold Voltage 0.1 1 Single Pulse Power, Junction-to-Ambient 100 Limited by RDS(on)* 10 I D - Drain Current (A) 0.01 Time (s) TJ - Temperature ( C) 1 ms 1 10 ms 100 ms 0.1 TA = 25 °C Single Pulse 0.01 0.01 1s 10 s DC 1 10 100 1000 VDS - Drain-to-Source Voltage (V) minimum VGS at which RDS(on) is specified 0.1 * VGS Safe Operating Area, Junction-to-Ambient 4 8 200 1.0 - 1.5 - 50 6 On-Resistance vs. Gate-to-Source Voltage Source-Drain Diode Forward Voltage 0.0 4 VGS - Gate-to-Source Voltage (V) 10 SI4056DY-T1-GE3 www.VBsemi.com TYPICAL CHARACTERISTICS (25 °C, unless otherwise noted) 9 ID - Drain Current (A) 7 5 4 2 0 0 25 50 75 100 125 150 0 25 TC - Case Temperature (°C) 8.0 2.0 6.4 1.6 4.8 1.2 Power (W) Power (W) Current Derating* 3.2 1.6 0.8 0.4 0.0 0.0 0 25 50 75 100 125 150 50 75 100 TC - Case Temperature (°C) TA - Ambient Temperature (°C) Power, Junction-to-Case Power, Junction-to-Ambient 125 150 * The power dissipation PD is based on TJ(max) = 150 °C, using junction-to-case thermal resistance, and is more useful in settling the upper dissipation limit for cases where additional heatsinking is used. It is used to determine the current rating, when this rating falls below the package limit. 5 SI4056DY-T1-GE3 www.VBsemi.com TYPICAL CHARACTERISTICS (25 °C, unless otherwise noted) 1 Normalized Effective Transient Thermal Impedance Duty Cycle = 0.5 0.2 Notes: 0.1 0.1 PDM 0.05 t1 t2 1. Duty Cycle, D = 0.02 t1 t2 2. Per Unit Base = RthJA = 65 °C/W 3. TJM - TA = PDMZthJA(t) 4. Surface Mounted Single Pulse 0.01 10-4 10-3 10-2 10-1 10 1 100 1000 Square Wave Pulse Duration (s) Normalized Thermal Transient Impedance, Junction-to-Ambient 1 Normalized Effective Transient Thermal Impedance Duty Cycle = 0.5 0.2 0.1 0.05 0.02 Single Pulse 0.01 10 -4 10-3 10-2 10-1 Square Wave Pulse Duration (s) Normalized Thermal Transient Impedance, Junction-to-Foot 6 1 10 SI4056DY-T1-GE3 www.VBsemi.com SOIC (NARROW): 8-LEAD JEDEC Part Number: MS-012 8 6 7 5 E 1 3 2 H 4 S h x 45 D C 0.25 mm (Gage Plane) A e B All Leads q A1 L 0.004" MILLIMETERS INCHES DIM Min Max Min Max A 1.35 1.75 0.053 0.069 A1 0.10 0.20 0.004 0.008 B 0.35 0.51 0.014 0.020 C 0.19 0.25 0.0075 0.010 D 4.80 5.00 0.189 0.196 E 3.80 4.00 0.150 e 0.101 mm 1.27 BSC 0.157 0.050 BSC H 5.80 6.20 0.228 0.244 h 0.25 0.50 0.010 0.020 L 0.50 0.93 0.020 0.037 q 0° 8° 0° 8° S 0.44 0.64 0.018 0.026 ECN: C-06527-Rev. I, 11-Sep-06 DWG: 5498 7 SI4056DY-T1-GE3 www.VBsemi.com RECOMMENDED MINIMUM PADS FOR SO-8 0.172 (4.369) 0.028 0.022 0.050 (0.559) (1.270) Recommended Minimum Pads Dimensions in Inches/(mm) 8 0.152 (3.861) 0.047 (1.194) 0.246 (6.248) (0.711) SI4056DY-T1-GE3 www.VBsemi.com Disclaimer All products due to improve reliability, function or design or for other reasons, product specifications and data are subject to change without notice. Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or incomplete data contained in the table or any other any disclosure of any information related to the product.(www.VBsemi.com) Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability, including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties, including a particular purpose, non-infringement and merchantability guarantee. Statement on certain types of applications are based on knowledge of the product is often used in a typical application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific product features in the products described in the specification is appropriate for use in a particular application. Parameter data sheets and technical specifications can be provided may vary depending on the application and performance over time. All operating parameters, including typical parameters must be made by customer's technical experts validated for each customer application. Product specifications do not expand or modify Taiwan VBsemi purchasing terms and conditions, including but not limited to warranty herein. Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving, or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and other terms and conditions in writing. The information provided in this document and the company's products without a license, express or implied, by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product names and trademarks referred to herein are trademarks of their respective representatives will be all. Material Category Policy Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be RoHS compliant and meets the definition of restrictions under Directive of the European Parliament 2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com) Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive 2011/65 /. Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
SI4056DY-T1-GE3 价格&库存
很抱歉,暂时无法提供与“SI4056DY-T1-GE3”相匹配的价格&库存,您可以联系我们找货
