CA55-D6R3M477T
CA55-D6R3M477T
    XIANGYEE(湘怡电子)
    D7343-31
    钽电容 D7343-31 470µF ±20% 6.3V 30mΩ 7.30 x 4.30mm 3.10mm 1.871A
CA55-D6R3M477T 数据手册
Solid Tantalum Capacitors CA55 Series Conductive Polymer Chip Tantalum Capacitors Features  Epoxy molded encapsulation, Chip, Easy for integration, Polarized;  Extremely low ESR , Volumetrically efficient , Stable in electrical & storage performances , Long life-span, High reliability;  Typical applications include DC/DC converters , notebook PCs , portable electronics , telecommunications (mobile phone and base station ), displays ,SSD,HDD and USB;  Operative Standard: QJ/PWV517-2013; Dimensions(mm) Case Code EIA Code EIA Metric L W1 H W2 S A 1206 3216-16 3.20±0.20 1.60+0.20 1.60±0.20 0.80±0.20 1.20±0.20 B 1210 3528-19 3.50±0.20 2.80±0.20 1.90±0.20 0.80±0.20 2.20±0.20 C 2312 6032-25 6.00±0.20 3.20±0.20 2.50±0.20 1.30±0.20 2.20±0.20 H 2917 7343-20 7.30±0.20 4.30±0.20 2.00±0.20 1.30±0.20 2.40±0.20 D 2917 7343-28 7.30±0.20 4.30±0.20 2.80±0.20 1.30±0.20 2.40±0.20 E 2917 7343-43 7.30±0.40 4.30±0.40 4.10±0.40 1.30±0.20 2.40±0.20 V 2924 7361-36 7.30±0.40 6.10±0.40 3.60±0.40 1.35±0.20 3.00±0.20 W 2924 7361-41 7.30±0.40 6.10±0.40 4.10±0.40 1.35±0.20 3.00±0.20 How to order - CA55 Separator Type M 010 D Case Size Rated DC voltage See table above 2R5=2.5Vdc; 004=4Vdc; 6R3=6.3Vdc; 010=10Vdc 016=16Vdc; 020=20Vdc 025=25Vdc; 035=35Vdc 050=50Vdc; 063=63Vdc 075=75Vdc; 100=100Vdc 107 Tolerance Capacitance Code M=±20% pF code: 1st two digits represent significant figures, 3rd digit represents multiplier (number of zeros to follow) E080 T Package ESR T=Reel B=Bulk Last three digits specify ESR in mΩ (080=80 mΩ) Environmental Compliance RoHS Compliant (6/6) according to Directive 2002/95/EC when ordered with 100%Sn solder, Gold plated or Nonmagnetic 100% Sn solder. LEAD-FREE Marking Rate Voltage less than 63Vdc Rate Voltage as 63Vdc or more Capacitance Value in pF : 107=100uF A=10Vdc Polarity Band (Anode +) Rate Voltage Code A=10Vdc Rate Voltage Polarity Band (Anode +) Capacitance Value in pF :106=10uF Technical Specifications Technical Data Operating Temperature Range Rated Capacitance Range Capacitance Tolerance Leakage Current DCL Equivalent Series Resistance ESR Termination Finished Resistance to soldering heat C ○ HUNAN XIANGYEE ZHONGYUAN TECHNOLOGY CO.,LTD All technical data relate to an ambient temperature of +25℃ -55℃ to +105℃ 0.47 ~ 1000 μF at 100 Hz M tolerance (±20%); 0.1CV (μA)at rated voltage after 5 minutes Refer to Part Number Electrical Specifications Table Sn Plating (standard), Gold and SnPb Plating upon request 3×260℃ peak for max. 10s reflow Page 1 of 14 CA55 Series Conductive Polymer Chip Tantalum Capacitors CAPACITANCE AND RATED VOLTAGE RANGE (LETTER DENOTES CASE SIZE & ESR) Rated Voltage(V) 2.5 4 6.3 Capacitance(μF) 10 16 Case Code & ESR 1 B(300), 1.5 B(300), 2.2 B(300), 3.3 A(250), B(150,300), 4.7 A(250), A(250), B(100,150,300), C(150), 6.8 A(180,250), A(200), B(100,150,300), C(150), A(120,250,300), A(80,120,300), B(100), A(200), B(100,200,300), C(150), 10 15 A(120,300), B(100), A(300), B(90), A(80,200), B(90), C(70), 22 A(300), B(90), C(70), A(90,300), B(90), C(70), A(80), B(90,300), C(70), 33 47 A(70,300), B(90), C(70), A(90), A(70,200), B(90), C(70), A(70,120,200), B(40,90,200), C(70,100), B(40), B(90,200), C(70,100), A(150,200), B(40,90), C(70), B(35,70,90), C(70,100), A(150), B(35,55,80), C(45,70), H(45,60,100), C(70,100), D(60), D(45,60,100), A(150,200,300), B(25,40,80), A(70), B(25,45,70), C(25,45,70), C(25,45,70), H(25,55), C(70), H(45), D(60), D(45,60,80), B(25,40,70), C(25,45,100), B(25,45,70), C(25,55), C(55), H(25,55), H(25,45), D(60), H(25,45), D(25,60), D(25,40,60), E(50), B(25,55,70), C(25,45), B(35,70), C(25,55), B(25,70,200), C(25,45), H(25,45), D(40), H(25,45), D(25,65), H(25,50), D(40,60), E(50), B(35,70), C(25,45), C(25,45), H(25,50), H(25,40), D(25,60), D(25,60), E(50), 470 C(25,45), H(25,50), D(25,40,60), H(25,50), D(25,60), E(50), H(35,55), D(30), V(40), E(35,50), 680 D(25,40), E(50), D(25), V(40), E(35,50), E(25), 1000 D(30), V(40), E(50), 68 A(70,250), 100 A(200), B(25,40), B(70), 150 B(70), 220 330 A(250), B(25,40,80), C(70), H(25,50), D(25,60), E(50), B(100,150,300), C(70,150), D(80), B(150), C(70,150), D(60,80), E(80), C(70,150), H(45,70), D(60,80), E(80), C(150), H(45,80), D(35,70,90), E(50,80), H(50,90), D(50,80), E(50,80), H(50), D(60,80), E(40,80), V(80), W(80), E(40,80), H(25,50), D(25,60), E(50), V(40), V(80), W(80), E(35,50,80), V(40), E(35,50), V(40), V(80), W(80), E(25,50,80), Continue Rated Voltage(V) 20 25 35 Capacitance(μF) 63 Case Code & ESR 0.68 B(300), B(350), B(350,400), 1 B(300), B(300) B(350), B(300,350) B(300), C(200,300), D(120), 1.5 B(300), B(300), C(150), B(200,350), C(200), B(300,350), C(200,300), C(200,300), D(120), 2.2 A(250), B(150,300), B(250,300), C(100,150), B(200,(350), C(200), B(350), C(200,300), C(200), D(120), 3.3 A(250), B(150,00), C(150), B(250,300), C(100,150), B(200,350), C(200), C(200), D(100), C(200), D(120), 4.7 B(150,300), C(100,150), B(150,250,300), C(100,150), B(200,350), C(200), C(200), D(100), C(200), D(75,120,300), E(120), 6.8 B(150,300), C(100,150), 10 B(100,150,300), C(100,150), 15 B(90), C(80,150), D(70,80), 22 33 47 C ○ 50 B(90,150,300), C(100,150), C(200), D(90), B(100,150,300), B(200), C(200), C(100,150), D(90), H(70,120), D(90), E(90), B(100,150), C(150), C(200), H(100,125), H(90), D(90), E(80), D(70,100), E(90), C(100,150), H(45,70), B(150), C(100,150), H(90), D(60,80), E(50,80), H(60,90), D(60,80,100), E(80), C(150), H(70), D(60,80), E(50,80), C(150), H(55,70,90), D(55,80), E(50,80), H(60,100), D(60,80,100), E(80), D(60,80,100), E(50,80), 68 D(55,80), E(45,80), D(80), V(80), E(50,80), 100 D(55), V(80), E(45,80), V(80), W(80), E(60,80), 150 V(80), W(80), E(80), V(80), W(80), 220 V(80), W(80), E(80), HUNAN XIANGYEE ZHONGYUAN TECHNOLOGY CO.,LTD D(70,100), E(90), D(65), D(100), V(90), E(55,70,90), V(90), W(90), E(30,55,90), C(200), H(70,90), D(70,100,120), D(120), E(100,150), D(90,120), E(70,100), D(120), E(50,(100,150), V(100), E(70,100), V(120), E(35,120,150), V(100), W(100), E(75,100), W(120), V(100), W(100), E(75), W(100), W(90), Page 2 of 14 CA55 Series Conductive Polymer Chip Tantalum Capacitors RATING & PART NUMBER REFERENCE Rated Category Voltage Voltage Case Max. DCL Max. DF Max. ESR Code @+25℃ @+25℃,100Hz @+25℃,100KHz V V μF μA % mΩ +45℃ +85℃ +105℃ ℃ CA55-A2R5#476TE090 2.5 2.3 47 A 11.8 8 90 850 595 212 105 3 CA55-A2R5#686TE070 2.5 2.3 68 A 17.0 8 70 964 675 241 105 3 CA55-A2R5#686TE250 2.5 2.3 68 A 17.0 6 250 510 357 127 105 3 CA55-A2R5#107TE200 2.5 2.3 100 A 25.0 6 200 570 399 143 105 3 CA55-B2R5#107TE025 2.5 2.3 100 B 25.0 8 25 1732 1212 433 105 3 CA55-B2R5#107TE040 2.5 2.3 100 B 25.0 8 40 1369 959 342 105 3 CA55-B2R5#107TE070 2.5 2.3 100 B 25.0 8 70 1035 725 259 105 3 CA55-B2R5#157TE070 2.5 2.3 150 B 37.5 6 70 1035 725 259 105 3 CA55-B2R5#227TE025 2.5 2.3 220 B 55.0 8 25 1732 1212 433 105 3 CA55-B2R5#227TE055 2.5 2.3 220 B 55.0 8 55 1168 817 292 105 3 CA55-B2R5#227TE070 2.5 2.3 220 B 55.0 8 70 1035 725 259 105 3 CA55-C2R5#227TE025 2.5 2.3 220 C 55.0 8 25 1897 1328 474 105 3 CA55-C2R5#227TE045 2.5 2.3 220 C 55.0 8 45 1414 990 354 105 3 CA55-D2R5#227TE040 2.5 2.3 220 D 55.0 10 40 1620 1134 405 105 3 CA55-H2R5#227TE025 2.5 2.3 220 H 55.0 10 25 2236 1565 559 105 3 CA55-H2R5#227TE045 2.5 2.3 220 H 55.0 10 45 1667 1167 417 105 3 CA55-B2R5#337TE035 2.5 2.3 330 B 82.5 8 35 1464 1025 366 105 3 CA55-B2R5#337TE070 2.5 2.3 330 B 82.5 8 70 1035 725 259 105 3 CA55-C2R5#337TE025 2.5 2.3 330 C 82.5 8 25 1897 1328 474 105 3 CA55-C2R5#337TE045 2.5 2.3 330 C 82.5 8 45 1414 990 354 105 3 CA55-D2R5#337TE025 2.5 2.3 330 D 82.5 10 25 2049 1435 512 105 3 CA55-D2R5#337TE060 2.5 2.3 330 D 82.5 10 60 1323 926 331 105 3 CA55-H2R5#337TE025 2.5 2.3 330 H 82.5 10 25 2236 1565 559 105 3 CA55-H2R5#337TE040 2.5 2.3 330 H 82.5 10 40 1768 1237 442 105 3 CA55-C2R5#477TE025 2.5 2.3 470 C 117.5 8 25 1897 1328 474 105 3 CA55-C2R5#477TE045 2.5 2.3 470 C 117.5 8 45 1414 990 354 105 3 CA55-D2R5#477TE025 2.5 2.3 470 D 117.5 10 25 2049 1435 512 105 3 CA55-D2R5#477TE040 2.5 2.3 470 D 117.5 6 40 1620 1134 405 105 3 CA55-D2R5#477TE060 2.5 2.3 470 D 117.5 10 60 1323 926 331 105 3 CA55-H2R5#477TE025 2.5 2.3 470 H 117.5 6 25 2236 1565 559 105 3 CA55-H2R5#477TE050 2.5 2.3 470 H 117.5 6 50 1581 1107 395 105 3 CA55-D2R5#687TE025 2.5 2.3 680 D 170.0 10 25 2049 1435 512 105 3 CA55-D2R5#687TE040 2.5 2.3 680 D 170.0 10 40 1620 1134 405 105 3 CA55-E2R5#687TE050 2.5 2.3 680 E 170.0 10 50 1581 1107 395 105 3 CA55-D2R5#108TE030 2.5 2.3 1000 D 250.0 10 30 1871 1310 468 105 3 CA55-E2R5#108TE050 2.5 2.3 1000 E 250.0 10 50 1581 1107 395 105 3 CA55-V2R5#108TE040 2.5 2.3 1000 V 250.0 10 40 1936 1356 484 105 3 CA55-A004#156TE120 4 3.6 15 A 6.0 10 120 736 515 184 105 3 CA55-A004#156TE300 4 3.6 15 A 6.0 6 300 465 326 116 105 3 CA55-B004#156TE100 4 3.6 15 B 6.0 10 100 866 606 217 105 3 CA55-A004#226TE300 4 3.6 22 A 8.8 6 300 465 326 116 105 3 CA55-B004#226TE090 4 3.6 22 B 8.8 10 90 913 639 228 105 3 CA55-C004#226TE070 4 3.6 22 C 8.8 10 70 1134 794 283 105 3 CA55-A004#336TE070 4 3.6 33 A 13.2 8 70 964 675 241 105 3 CA55-A004#336TE300 4 3.6 33 A 13.2 6 300 465 326 116 105 3 CA55-B004#336TE090 4 3.6 33 B 13.2 10 90 913 639 228 105 3 CA55-C004#336TE070 4 3.6 33 C 13.2 10 70 1134 794 283 105 3 CA55-A004#476TE070 4 3.6 47 A 18.8 8 70 964 675 241 105 3 CA55-A004#476TE200 4 3.6 47 A 18.8 6 200 570 399 143 105 3 CA55-B004#476TE090 4 3.6 47 B 18.8 10 90 913 639 228 105 3 CA55-C004#476TE070 4 3.6 47 C 18.8 10 70 1134 794 283 105 3 CA55-A004#686TE250 4 3.6 68 A 27.2 6 250 510 357 127 105 3 CA55-B004#686TE025 4 3.6 68 B 27.2 8 25 1732 1212 433 105 3 CA55-B004#686TE040 4 3.6 68 B 27.2 8 40 1369 959 342 105 3 CA55-B004#686TE080 4 3.6 68 B 27.2 8 80 968 678 242 105 3 Part Number capacitance 100kHz RMS Current (mA) Category Temperature MSL 1 Please do not use multimeter through the measuring procedures. 2 Capacitance and DF measured at :100Hz,U_=2.2°-1.0V,U~=1.0°-0.5V, Frequency=100Hz.Test only applied in series equivalent circuit. 3 Voltage derating is applied at +105℃.(The DCL parameter should be read after 5 minutes when it connected to the circuit). 4 Special size and demand could consult with us. C ○ HUNAN XIANGYEE ZHONGYUAN TECHNOLOGY CO.,LTD Page 3 of 14 CA55 Series Conductive Polymer Chip Tantalum Capacitors RATING & PART NUMBER REFERENCE Rated Category Voltage Voltage Case Max. DCL Max. DF Max. ESR Code @+25℃ @+25℃,100Hz @+25℃,100KHz V V μF μA % mΩ +45℃ +85℃ +105℃ ℃ CA55-C004#686TE070 4 3.6 68 C 27.2 10 70 1134 794 283 105 3 CA55-A004#107TE150 4 3.6 100 A 40.0 8 150 658 461 165 105 3 CA55-A004#107TE200 4 3.6 100 A 40.0 8 200 570 399 143 105 3 CA55-A004#107TE300 4 3.6 100 A 40.0 10 300 465 326 116 105 3 CA55-B004#107TE025 4 3.6 100 B 40.0 8 25 1732 1212 433 105 3 CA55-B004#107TE040 4 3.6 100 B 40.0 8 40 1369 959 342 105 3 CA55-B004#107TE080 4 3.6 100 B 40.0 8 80 968 678 242 105 3 CA55-C004#107TE070 4 3.6 100 C 40.0 10 70 1134 794 283 105 3 CA55-B004#157TE025 4 3.6 150 B 60.0 8 25 1732 1212 433 105 3 CA55-B004#157TE040 4 3.6 150 B 60.0 8 40 1369 959 342 105 3 CA55-B004#157TE070 4 3.6 150 B 60.0 8 70 1035 725 259 105 3 CA55-C004#157TE025 4 3.6 150 C 60.0 8 25 1897 1328 474 105 3 CA55-C004#157TE045 4 3.6 150 C 60.0 8 45 1414 990 354 105 3 CA55-C004#157TE100 4 3.6 150 C 60.0 8 100 949 664 237 105 3 CA55-D004#157TE060 4 3.6 150 D 60.0 10 60 1323 926 331 105 3 CA55-H004#157TE025 4 3.6 150 H 60.0 10 25 2236 1565 559 105 3 CA55-H004#157TE045 4 3.6 150 H 60.0 6 45 1667 1167 417 105 3 CA55-B004#227TE035 4 3.6 220 B 88.0 8 35 1464 1025 366 105 3 CA55-B004#227TE070 4 3.6 220 B 88.0 8 70 1035 725 259 105 3 CA55-C004#227TE025 4 3.6 220 C 88.0 8 25 1897 1328 474 105 3 CA55-C004#227TE055 4 3.6 220 C 88.0 8 55 1279 895 320 105 3 CA55-D004#227TE025 4 3.6 220 D 88.0 10 25 2049 1435 512 105 3 CA55-D004#227TE065 4 3.6 220 D 88.0 10 65 1271 890 318 105 3 CA55-H004#227TE025 4 3.6 220 H 88.0 10 25 2236 1565 559 105 3 CA55-H004#227TE045 4 3.6 220 H 88.0 10 45 1667 1167 417 105 3 CA55-C004#337TE025 4 3.6 330 C 132.0 8 25 1897 1328 474 105 3 CA55-C004#337TE045 4 3.6 330 C 132.0 8 45 1414 990 354 105 3 CA55-D004#337TE025 4 3.6 330 D 132.0 10 25 2049 1435 512 105 3 CA55-D004#337TE060 4 3.6 330 D 132.0 10 60 1323 926 331 105 3 CA55-E004#337TE050 4 3.6 330 E 132.0 10 50 1581 1107 395 105 3 CA55-H004#337TE025 4 3.6 330 H 132.0 10 25 2236 1565 559 105 3 CA55-H004#337TE050 4 3.6 330 H 132.0 6 50 1581 1107 395 105 3 CA55-D004#477TE025 4 3.6 470 D 188.0 10 25 2049 1435 512 105 3 CA55-D004#477TE060 4 3.6 470 D 188.0 10 60 1323 926 331 105 3 CA55-E004#477TE050 4 3.6 470 E 188.0 10 50 1581 1107 395 105 3 CA55-H004#477TE025 4 3.6 470 H 188.0 6 25 2236 1565 559 105 3 CA55-H004#477TE050 4 3.6 470 H 188.0 6 50 1581 1107 395 105 3 CA55-D004#687TE025 4 3.6 680 D 272.0 10 25 2049 1435 512 105 3 CA55-E004#687TE035 4 3.6 680 E 272.0 10 35 1890 1323 472 105 3 CA55-E004#687TE050 4 3.6 680 E 272.0 10 50 1581 1107 395 105 3 CA55-V004#687TE040 4 3.6 680 V 272.0 10 40 1936 1356 484 105 3 CA55-A6R3#106TE120 6.3 5.7 10 A 6.3 10 120 736 515 184 105 3 CA55-A6R3#106TE250 6.3 5.7 10 A 6.3 10 250 510 357 127 105 3 CA55-A6R3#106TE300 6.3 5.7 10 A 6.3 6 300 465 326 116 105 3 CA55-A6R3#156TE300 6.3 5.7 15 A 9.5 6 300 465 326 116 105 3 CA55-B6R3#156TE090 6.3 5.7 15 B 9.5 10 90 913 639 228 105 3 CA55-A6R3#226TE090 6.3 5.7 22 A 13.9 8 90 850 595 212 105 3 CA55-A6R3#226TE300 6.3 5.7 22 A 13.9 6 300 465 326 116 105 3 CA55-B6R3#226TE090 6.3 5.7 22 B 13.9 10 90 913 639 228 105 3 CA55-C6R3#226TE070 6.3 5.7 22 C 13.9 10 70 1134 794 283 105 3 CA55-A6R3#336TE070 6.3 5.7 33 A 20.8 8 70 964 675 241 105 3 CA55-A6R3#336TE120 6.3 5.7 33 A 20.8 8 120 736 515 184 105 3 CA55-A6R3#336TE200 6.3 5.7 33 A 20.8 6 200 570 399 143 105 3 CA55-B6R3#336TE040 6.3 5.7 33 B 20.8 8 40 1369 959 342 105 3 CA55-B6R3#336TE090 6.3 5.7 33 B 20.8 10 90 913 639 228 105 3 Part Number CONT’T capacitance 100kHz RMS Current (mA) Category Temperature MSL 1 Please do not use multimeter through the measuring procedures. 2 Capacitance and DF measured at :100Hz,U_=2.2°-1.0V,U~=1.0°-0.5V, Frequency=100Hz.Test only applied in series equivalent circuit. 3 Voltage derating is applied at +105℃.(The DCL parameter should be read after 5 minutes when it connected to the circuit). 4 Special size and demand could consult with us. C ○ HUNAN XIANGYEE ZHONGYUAN TECHNOLOGY CO.,LTD Page 4 of 14 CA55 Series Conductive Polymer Chip Tantalum Capacitors RATING & PART NUMBER REFERENCE Rated Category Voltage Voltage Case Max. DCL Max. DF Max. ESR Code @+25℃ @+25℃,100Hz @+25℃,100KHz V V μF μA % mΩ +45℃ +85℃ +105℃ ℃ CA55-B6R3#336TE200 6.3 5.7 33 B 20.8 6 200 612 429 153 105 3 CA55-C6R3#336TE070 6.3 5.7 33 C 20.8 10 70 1134 794 283 105 3 CA55-C6R3#336TE100 6.3 5.7 33 C 20.8 8 100 949 664 237 105 3 CA55-A6R3#476TE150 6.3 5.7 47 A 29.6 8 150 658 461 165 105 3 CA55-A6R3#476TE200 6.3 5.7 47 A 29.6 6 200 570 399 143 105 3 CA55-B6R3#476TE040 6.3 5.7 47 B 29.6 8 40 1369 959 342 105 3 CA55-B6R3#476TE090 6.3 5.7 47 B 29.6 10 90 913 639 228 105 3 CA55-C6R3#476TE070 6.3 5.7 47 C 29.6 10 70 1134 794 283 105 3 CA55-A6R3#686TE150 6.3 5.7 68 A 42.8 8 150 658 461 165 105 3 CA55-B6R3#686TE035 6.3 5.7 68 B 42.8 8 35 1464 1025 366 105 3 CA55-B6R3#686TE055 6.3 5.7 68 B 42.8 8 55 1168 817 292 105 3 CA55-B6R3#686TE080 6.3 5.7 68 B 42.8 8 80 968 678 242 105 3 CA55-C6R3#686TE070 6.3 5.7 68 C 42.8 10 70 1134 794 283 105 3 CA55-C6R3#686TE100 6.3 5.7 68 C 42.8 8 100 949 664 237 105 3 CA55-D6R3#686TE060 6.3 5.7 68 D 42.8 10 60 1323 926 331 105 3 CA55-A6R3#107TE070 6.3 5.7 100 A 63.0 8 70 964 675 241 105 3 CA55-B6R3#107TE025 6.3 5.7 100 B 63.0 8 25 1732 1212 433 105 3 CA55-B6R3#107TE045 6.3 5.7 100 B 63.0 8 45 1291 904 323 105 3 CA55-B6R3#107TE070 6.3 5.7 100 B 63.0 8 70 1035 725 259 105 3 CA55-C6R3#107TE025 6.3 5.7 100 C 63.0 8 25 1897 1328 474 105 3 CA55-C6R3#107TE045 6.3 5.7 100 C 63.0 8 45 1414 990 354 105 3 CA55-C6R3#107TE070 6.3 5.7 100 C 63.0 10 70 1134 794 283 105 3 CA55-D6R3#107TE060 6.3 5.7 100 D 63.0 10 60 1323 926 331 105 3 CA55-H6R3#107TE045 6.3 5.7 100 H 63.0 10 45 1667 1167 417 105 3 CA55-B6R3#157TE025 6.3 5.7 150 B 94.5 8 25 1732 1212 433 105 3 CA55-B6R3#157TE045 6.3 5.7 150 B 94.5 8 45 1291 904 323 105 3 CA55-B6R3#157TE070 6.3 5.7 150 B 94.5 8 70 1035 725 259 105 3 CA55-C6R3#157TE025 6.3 5.7 150 C 94.5 8 25 1897 1328 474 105 3 CA55-C6R3#157TE055 6.3 5.7 150 C 94.5 8 55 1279 895 320 105 3 CA55-D6R3#157TE025 6.3 5.7 150 D 94.5 10 25 2049 1435 512 105 3 CA55-D6R3#157TE060 6.3 5.7 150 D 94.5 10 60 1323 926 331 105 3 CA55-H6R3#157TE025 6.3 5.7 150 H 94.5 10 25 2236 1565 559 105 3 CA55-H6R3#157TE045 6.3 5.7 150 H 94.5 10 45 1667 1167 417 105 3 CA55-B6R3#227TE025 6.3 5.7 220 B 138.6 8 25 1732 1212 433 105 3 CA55-B6R3#227TE070 6.3 5.7 220 B 138.6 8 70 1035 725 259 105 3 CA55-B6R3#227TE200 6.3 5.7 220 B 138.6 10 200 612 429 153 105 3 CA55-C6R3#227TE025 6.3 5.7 220 C 138.6 8 25 1897 1328 474 105 3 CA55-C6R3#227TE045 6.3 5.7 220 C 138.6 8 45 1414 990 354 105 3 CA55-D6R3#227TE040 6.3 5.7 220 D 138.6 10 40 1620 1134 405 105 3 CA55-D6R3#227TE060 6.3 5.7 220 D 138.6 10 60 1323 926 331 105 3 CA55-E6R3#227TE050 6.3 5.7 220 E 138.6 10 50 1581 1107 395 105 3 CA55-H6R3#227TE025 6.3 5.7 220 H 138.6 10 25 2236 1565 559 105 3 CA55-H6R3#227TE050 6.3 5.7 220 H 138.6 6 50 1581 1107 395 105 3 CA55-D6R3#337TE025 6.3 5.7 330 D 207.9 10 25 2049 1435 512 105 3 CA55-D6R3#337TE060 6.3 5.7 330 D 207.9 10 60 1323 926 331 105 3 CA55-E6R3#337TE050 6.3 5.7 330 E 207.9 10 50 1581 1107 395 105 3 CA55-H6R3#337TE025 6.3 5.7 330 H 207.9 10 25 2236 1565 559 105 3 CA55-H6R3#337TE050 6.3 5.7 330 H 207.9 12 50 1581 1107 395 105 3 CA55-D6R3#477TE030 6.3 5.7 470 D 296.1 10 30 1871 1310 468 105 3 CA55-E6R3#477TE035 6.3 5.7 470 E 296.1 10 35 1890 1323 472 105 3 CA55-E6R3#477TE050 6.3 5.7 470 E 296.1 10 50 1581 1107 395 105 3 CA55-H6R3#477TE035 6.3 5.7 470 H 296.1 10 35 1890 1323 472 105 3 CA55-H6R3#477TE055 6.3 5.7 470 H 296.1 10 55 1508 1055 377 85 3 CA55-V6R3#477TE040 6.3 5.7 470 V 296.1 10 40 1936 1356 484 105 3 CA55-E6R3#687TE025 6.3 5.7 680 E 428.4 10 25 2236 1565 559 105 3 Part Number CONT’T capacitance 100kHz RMS Current (mA) Category Temperature MSL 1 Please do not use multimeter through the measuring procedures. 2 Capacitance and DF measured at :100Hz,U_=2.2°-1.0V,U~=1.0°-0.5V, Frequency=100Hz.Test only applied in series equivalent circuit. 3 Voltage derating is applied at +105℃.(The DCL parameter should be read after 5 minutes when it connected to the circuit). 4 Special size and demand could consult with us. C ○ HUNAN XIANGYEE ZHONGYUAN TECHNOLOGY CO.,LTD Page 5 of 14 CA55 Series Conductive Polymer Chip Tantalum Capacitors RATING & PART NUMBER REFERENCE Rated Category Voltage Voltage Case Max. DCL Max. DF Max. ESR Code @+25℃ @+25℃,100Hz @+25℃,100KHz V V μF μA % mΩ +45℃ +85℃ +105℃ ℃ CA55-A010#475TE250 10 9.0 4.7 A 4.7 10 250 510 357 127 105 3 CA55-A010#685TE180 10 9.0 6.8 A 6.8 10 180 601 421 150 105 3 CA55-A010#685TE250 10 9.0 6.8 A 6.8 10 250 510 357 127 105 3 CA55-A010#106TE080 10 9.0 10 A 10.0 8 80 901 631 225 105 3 CA55-A010#106TE120 10 9.0 10 A 10.0 8 120 736 515 184 105 3 CA55-A010#106TE300 10 9.0 10 A 10.0 10 300 465 326 116 105 3 CA55-B010#106TE100 10 9.0 10 B 10.0 10 100 866 606 217 105 3 CA55-A010#156TE080 10 9.0 15 A 15.0 8 80 901 631 225 105 3 CA55-A010#156TE200 10 9.0 15 A 15.0 6 200 570 399 143 105 3 CA55-B010#156TE090 10 9.0 15 B 15.0 10 90 913 639 228 105 3 CA55-C010#156TE070 10 9.0 15 C 15.0 10 70 1134 794 283 105 3 CA55-A010#226TE080 10 9.0 22 A 22.0 8 80 901 631 225 105 3 CA55-B010#226TE090 10 9.0 22 B 22.0 10 90 913 639 228 105 3 CA55-B010#226TE300 10 9.0 22 B 22.0 6 300 500 350 125 105 3 CA55-C010#226TE070 10 9.0 22 C 22.0 10 70 1134 794 283 105 3 CA55-B010#336TE040 10 9.0 33 B 33.0 8 40 1369 959 342 105 3 CA55-B010#336TE090 10 9.0 33 B 33.0 10 90 913 639 228 105 3 CA55-B010#336TE200 10 9.0 33 B 33.0 6 200 612 429 153 105 3 CA55-C010#336TE070 10 9.0 33 C 33.0 10 70 1134 794 283 105 3 CA55-C010#336TE100 10 9.0 33 C 33.0 6 100 949 664 237 105 3 CA55-B010#476TE035 10 9.0 47 B 47.0 8 35 1464 1025 366 105 3 CA55-B010#476TE070 10 9.0 47 B 47.0 8 70 1035 725 259 105 3 CA55-B010#476TE090 10 9.0 47 B 47.0 10 90 913 639 228 105 3 CA55-C010#476TE070 10 9.0 47 C 47.0 10 70 1134 794 283 105 3 CA55-C010#476TE100 10 9.0 47 C 47.0 8 100 949 664 237 105 3 CA55-C010#686TE045 10 9.0 68 C 68.0 8 45 1414 990 354 105 3 CA55-C010#686TE070 10 9.0 68 C 68.0 10 70 1134 794 283 105 3 CA55-D010#686TE045 10 9.0 68 D 68.0 6 45 1528 1069 382 105 3 CA55-D010#686TE060 10 9.0 68 D 68.0 10 60 1323 926 331 105 3 CA55-D010#686TE100 10 9.0 68 D 68.0 10 100 1025 717 256 105 3 CA55-H010#686TE045 10 9.0 68 H 68.0 10 45 1667 1167 417 105 3 CA55-H010#686TE060 10 9.0 68 H 68.0 10 60 1443 1010 361 105 3 CA55-H010#686TE100 10 9.0 68 H 68.0 10 100 1118 783 280 105 3 CA55-C010#107TE025 10 9.0 100 C 100.0 8 25 1897 1328 474 105 3 CA55-C010#107TE045 10 9.0 100 C 100.0 8 45 1414 990 354 105 3 CA55-C010#107TE070 10 9.0 100 C 100.0 10 70 1134 794 283 105 3 CA55-D010#107TE045 10 9.0 100 D 100.0 6 45 1528 1069 382 105 3 CA55-D010#107TE060 10 9.0 100 D 100.0 10 60 1323 926 331 105 3 CA55-D010#107TE080 10 9.0 100 D 100.0 10 80 1146 802 286 105 3 CA55-H010#107TE025 10 9.0 100 H 100.0 10 25 2236 1565 559 105 3 CA55-H010#107TE055 10 9.0 100 H 100.0 10 55 1508 1055 377 105 3 CA55-C010#157TE055 10 9.0 150 C 150.0 8 55 1279 895 320 105 3 CA55-D010#157TE025 10 9.0 150 D 150.0 10 25 2049 1435 512 105 3 CA55-D010#157TE040 10 9.0 150 D 150.0 10 40 1620 1134 405 105 3 CA55-D010#157TE060 10 9.0 150 D 150.0 10 60 1323 926 331 105 3 CA55-E010#157TE050 10 9.0 150 E 150.0 10 50 1581 1107 395 105 3 CA55-H010#157TE025 10 9.0 150 H 150.0 10 25 2236 1565 559 105 3 CA55-H010#157TE055 10 9.0 150 H 150.0 6 55 1508 1055 377 105 3 CA55-D010#227TE025 10 9.0 220 D 220.0 10 25 2049 1435 512 105 3 CA55-D010#227TE060 10 9.0 220 D 220.0 10 60 1323 926 331 105 3 CA55-E010#227TE050 10 9.0 220 E 220.0 10 50 1581 1107 395 105 3 CA55-H010#227TE025 10 9.0 220 H 220.0 10 25 2236 1565 559 105 3 CA55-H010#227TE050 10 9.0 220 H 220.0 6 50 1581 1107 395 105 3 CA55-E010#337TE025 10 9.0 330 E 330.0 10 35 1890 1323 472 105 3 CA55-E010#337TE050 10 9.0 330 E 330.0 10 50 1581 1107 395 105 3 Part Number CONT’T capacitance 100kHz RMS Current (mA) Category Temperature MSL 1 Please do not use multimeter through the measuring procedures. 2 Capacitance and DF measured at :100Hz,U_=2.2°-1.0V,U~=1.0°-0.5V, Frequency=100Hz.Test only applied in series equivalent circuit. 3 Voltage derating is applied at +105℃.(The DCL parameter should be read after 5 minutes when it connected to the circuit). 4 Special size and demand could consult with us. C ○ HUNAN XIANGYEE ZHONGYUAN TECHNOLOGY CO.,LTD Page 6 of 14 CA55 Series Conductive Polymer Chip Tantalum Capacitors RATING & PART NUMBER REFERENCE Rated Category Voltage Voltage Case Max. DCL Max. DF Max. ESR Code @+25℃ @+25℃,100Hz @+25℃,100KHz V V μF μA % mΩ +45℃ +85℃ +105℃ ℃ CA55-V010#337TE040 10 9.0 330 V 330.0 10 40 1936 1356 484 105 3 CA55-B016#105TE300 16 12.8 1 B 1.6 10 300 500 350 125 105 3 CA55-B016#155TE300 16 12.8 1.5 B 2.4 10 300 500 350 125 105 3 CA55-B016#225TE300 16 12.8 2.2 B 3.5 10 300 500 350 125 105 3 CA55-A016#335TE250 16 12.8 3.3 A 5.3 10 250 510 357 127 105 3 CA55-B016#335TE150 16 12.8 3.3 B 5.3 10 150 707 495 177 105 3 CA55-B016#335TE300 16 12.8 3.3 B 5.3 10 300 500 350 125 105 3 CA55-A016#475TE250 16 12.8 4.7 A 7.5 10 250 510 357 127 105 3 CA55-B016#475TE100 16 12.8 4.7 B 7.5 10 100 866 606 217 105 3 CA55-B016#475TE150 16 12.8 4.7 B 7.5 10 150 707 495 177 105 3 CA55-B016#475TE300 16 12.8 4.7 B 7.5 10 300 500 350 125 105 3 CA55-C016#475TE150 16 12.8 4.7 C 7.5 10 150 775 542 194 105 3 CA55-A016#685TE200 16 12.8 6.8 A 10.9 6 200 570 399 143 105 3 CA55-B016#685TE100 16 12.8 6.8 B 10.9 10 100 866 606 217 105 3 CA55-B016#685TE150 16 12.8 6.8 B 10.9 10 150 707 495 177 105 3 CA55-B016#685TE300 16 12.8 6.8 B 10.9 10 300 500 350 125 105 3 CA55-C016#685TE150 16 12.8 6.8 C 10.9 10 150 775 542 194 105 3 CA55-A016#106TE200 16 12.8 10 A 16.0 6 200 570 399 143 105 3 CA55-B016#106TE100 16 12.8 10 B 16.0 10 100 866 606 217 105 3 CA55-B016#106TE200 16 12.8 10 B 16.0 6 200 612 429 153 105 3 CA55-B016#106TE300 16 12.8 10 B 16.0 10 300 500 350 125 105 3 CA55-C016#106TE150 16 12.8 10 C 16.0 10 150 775 542 194 105 3 CA55-B016#156TE100 16 12.8 15 B 24.0 10 100 866 606 217 105 3 CA55-B016#156TE150 16 12.8 15 B 24.0 6 150 707 495 177 105 3 CA55-B016#156TE300 16 12.8 15 B 24.0 10 300 500 350 125 105 3 CA55-C016#156TE070 16 12.8 15 C 24.0 10 70 1134 794 283 105 3 CA55-C016#156TE150 16 12.8 15 C 24.0 10 150 775 542 194 105 3 CA55-D016#156TE080 16 12.8 15 D 24.0 10 80 1146 802 286 105 3 CA55-B016#226TE150 16 12.8 22 B 35.2 6 150 707 495 177 105 3 CA55-C016#226TE070 16 12.8 22 C 35.2 10 70 1134 794 283 105 3 CA55-C016#226TE150 16 12.8 22 C 35.2 10 150 775 542 194 105 3 CA55-D016#226TE060 16 12.8 22 D 35.2 10 60 1323 926 331 105 3 CA55-D016#226TE080 16 12.8 22 D 35.2 10 80 1146 802 286 105 3 CA55-E016#226TE080 16 12.8 22 E 35.2 10 80 1250 875 313 105 3 CA55-C016#336TE070 16 12.8 33 C 52.8 10 70 1134 794 283 105 3 CA55-C016#336TE150 16 12.8 33 C 52.8 10 150 775 542 194 105 3 CA55-D016#336TE060 16 12.8 33 D 52.8 10 60 1323 926 331 105 3 CA55-D016#336TE080 16 12.8 33 D 52.8 10 80 1146 802 286 105 3 CA55-E016#336TE080 16 12.8 33 E 52.8 10 80 1250 875 313 105 3 CA55-H016#336TE045 16 12.8 33 H 52.8 10 45 1667 1167 417 105 3 CA55-H016#336TE070 16 12.8 33 H 52.8 10 70 1336 935 334 105 3 CA55-C016#476TE150 16 12.8 47 C 75.2 10 150 775 542 194 105 3 CA55-D016#476TE035 16 12.8 47 D 75.2 10 35 1732 1212 433 105 3 CA55-D016#476TE070 16 12.8 47 D 75.2 10 70 1225 857 306 105 3 CA55-D016#476TE090 16 12.8 47 D 75.2 10 90 1080 756 270 105 3 CA55-E016#476TE050 16 12.8 47 E 75.2 10 50 1581 1107 395 105 3 CA55-E016#476TE080 16 12.8 47 E 75.2 10 80 1250 875 313 105 3 CA55-H016#476TE045 16 12.8 47 H 75.2 10 45 1667 1167 417 105 3 CA55-H016#476TE080 16 12.8 47 H 75.2 10 80 1250 875 313 105 3 CA55-D016#686TE050 16 12.8 68 D 108.8 10 50 1449 1014 362 105 3 CA55-D016#686TE080 16 12.8 68 D 108.8 10 80 1146 802 286 105 3 CA55-E016#686TE050 16 12.8 68 E 108.8 10 50 1581 1107 395 105 3 CA55-E016#686TE080 16 12.8 68 E 108.8 10 80 1250 875 313 105 3 CA55-H016#686TE050 16 12.8 68 H 108.8 10 50 1581 1107 395 105 3 CA55-H016#686TE090 16 12.8 68 H 108.8 10 90 1179 825 295 105 3 Part Number CONT’T capacitance 100kHz RMS Current (mA) Category Temperature MSL 1 Please do not use multimeter through the measuring procedures. 2 Capacitance and DF measured at :100Hz,U_=2.2°-1.0V,U~=1.0°-0.5V, Frequency=100Hz.Test only applied in series equivalent circuit. 3 Voltage derating is applied at +105℃.(The DCL parameter should be read after 5 minutes when it connected to the circuit). 4 Special size and demand could consult with us. C ○ HUNAN XIANGYEE ZHONGYUAN TECHNOLOGY CO.,LTD Page 7 of 14 CA55 Series Conductive Polymer Chip Tantalum Capacitors RATING & PART NUMBER REFERENCE Rated Category Voltage Voltage Case Max. DCL Max. DF Max. ESR Code @+25℃ @+25℃,100Hz @+25℃,100KHz V V μF μA % mΩ +45℃ +85℃ +105℃ ℃ CA55-D016#107TE060 16 12.8 100 D 160.0 10 60 1323 926 331 105 3 CA55-D016#107TE080 16 12.8 100 D 160.0 10 80 1146 802 286 105 3 CA55-E016#107TE040 16 12.8 100 E 160.0 6 40 1768 1237 442 105 3 CA55-E016#107TE080 16 12.8 100 E 160.0 10 80 1250 875 313 105 3 CA55-H016#107TE050 16 12.8 100 H 160.0 10 50 1581 1107 395 105 3 CA55-E016#157TE040 16 12.8 150 E 240.0 10 40 1768 1237 442 105 3 CA55-E016#157TE080 16 12.8 150 E 240.0 10 80 1250 875 313 105 3 CA55-V016#157TE080 16 12.8 150 V 240.0 10 80 1369 959 342 105 3 CA55-W016#157TE080 16 12.8 150 W 240.0 10 80 1581 1107 395 105 3 CA55-E016#227TE035 16 12.8 220 E 352.0 10 35 1890 1323 472 105 3 CA55-E016#227TE050 16 12.8 220 E 352.0 10 50 1581 1107 395 105 3 CA55-E016#227TE080 16 12.8 220 E 352.0 10 80 1250 875 313 105 3 CA55-V016#227TE040 16 12.8 220 V 352.0 10 40 1936 1356 484 105 3 CA55-V016#227TE080 16 12.8 220 V 352.0 10 80 1369 959 342 105 3 CA55-W016#227TE080 16 12.8 220 W 352.0 10 80 1581 1107 395 105 3 CA55-E016#337TE025 16 12.8 330 E 528.0 10 25 2236 1565 559 105 3 CA55-E016#337TE050 16 12.8 330 E 528.0 10 50 1581 1107 395 105 3 CA55-E016#337TE080 16 12.8 330 E 528.0 10 80 1250 875 313 105 3 CA55-V016#337TE040 16 12.8 330 V 528.0 10 40 1936 1356 484 105 3 CA55-V016#337TE080 16 12.8 330 V 528.0 10 80 1369 959 342 105 3 CA55-W016#337TE080 16 12.8 330 W 528.0 10 80 1581 1107 395 105 3 CA55-B020#105TE300 20 16.0 1 B 2.0 10 300 500 350 125 105 3 CA55-B020#155TE300 20 16.0 1.5 B 3.0 10 300 500 350 125 105 3 CA55-A020#225TE250 20 16.0 2.2 A 4.4 10 250 510 357 127 105 3 CA55-B020#225TE150 20 16.0 2.2 B 4.4 10 150 707 495 177 105 3 CA55-B020#225TE300 20 16.0 2.2 B 4.4 10 300 500 350 125 105 3 CA55-A020#335TE250 20 16.0 3.3 A 6.6 10 250 510 357 127 105 3 CA55-B020#335TE150 20 16.0 3.3 B 6.6 10 150 707 495 177 105 3 CA55-B020#335TE300 20 16.0 3.3 B 6.6 10 300 500 350 125 105 3 CA55-C020#335TE150 20 16.0 3.3 C 6.6 10 150 775 542 194 105 3 CA55-B020#475TE150 20 16.0 4.7 B 9.4 10 150 707 495 177 105 3 CA55-B020#475TE300 20 16.0 4.7 B 9.4 10 300 500 350 125 105 3 CA55-C020#475TE100 20 16.0 4.7 C 9.4 10 100 949 664 237 105 3 CA55-C020#475TE150 20 16.0 4.7 C 9.4 10 150 775 542 194 105 3 CA55-B020#685TE150 20 16.0 6.8 B 13.6 10 150 707 495 177 105 3 CA55-B020#685TE300 20 16.0 6.8 B 13.6 10 300 500 350 125 105 3 CA55-C020#685TE100 20 16.0 6.8 C 13.6 10 100 949 664 237 105 3 CA55-C020#685TE150 20 16.0 6.8 C 13.6 10 150 775 542 194 105 3 CA55-B020#106TE100 20 16.0 10 B 20.0 8 100 866 606 217 105 3 CA55-B020#106TE150 20 16.0 10 B 20.0 10 150 707 495 177 105 3 CA55-B020#106TE300 20 16.0 10 B 20.0 10 300 500 350 125 105 3 CA55-C020#106TE100 20 16.0 10 C 20.0 10 100 949 664 237 105 3 CA55-C020#106TE150 20 16.0 10 C 20.0 10 150 775 542 194 105 3 CA55-B020#156TE090 20 16.0 15 B 30.0 10 90 913 639 228 105 3 CA55-C020#156TE080 20 16.0 15 C 30.0 10 80 1061 742 265 105 3 CA55-C020#156TE150 20 16.0 15 C 30.0 10 150 775 542 194 105 3 CA55-D020#156TE070 20 16.0 15 D 30.0 10 70 1225 857 306 105 3 CA55-D020#156TE080 20 16.0 15 D 30.0 10 80 1146 802 286 105 3 CA55-C020#226TE100 20 16.0 22 C 44.0 10 100 949 664 237 105 3 CA55-C020#226TE150 20 16.0 22 C 44.0 10 150 775 542 194 105 3 CA55-D020#226TE060 20 16.0 22 D 44.0 10 60 1323 926 331 105 3 CA55-D020#226TE080 20 16.0 22 D 44.0 10 80 1146 802 286 105 3 CA55-E020#226TE050 20 16.0 22 E 44.0 10 50 1581 1107 395 105 3 CA55-E020#226TE080 20 16.0 22 E 44.0 10 80 1250 875 313 105 3 CA55-H020#226TE045 20 16.0 22 H 44.0 10 45 1667 1167 417 105 3 Part Number CONT’T capacitance 100kHz RMS Current (mA) Category Temperature MSL 1 Please do not use multimeter through the measuring procedures. 2 Capacitance and DF measured at :100Hz,U_=2.2°-1.0V,U~=1.0°-0.5V, Frequency=100Hz.Test only applied in series equivalent circuit. 3 Voltage derating is applied at +105℃.(The DCL parameter should be read after 5 minutes when it connected to the circuit). 4 Special size and demand could consult with us. C ○ HUNAN XIANGYEE ZHONGYUAN TECHNOLOGY CO.,LTD Page 8 of 14 CA55 Series Conductive Polymer Chip Tantalum Capacitors RATING & PART NUMBER REFERENCE Rated Category Voltage Voltage Case Max. DCL Max. DF Max. ESR Code @+25℃ @+25℃,100Hz @+25℃,100KHz V V μF μA % mΩ +45℃ +85℃ +105℃ ℃ CA55-H020#226TE070 20 16.0 22 H 44.0 6 70 1336 935 334 105 3 CA55-H020#226TE090 20 16.0 22 H 44.0 10 90 1179 825 295 105 3 CA55-C020#336TE150 20 16.0 33 C 66.0 10 150 775 542 194 105 3 CA55-D020#336TE060 20 16.0 33 D 66.0 10 60 1323 926 331 105 3 CA55-D020#336TE080 20 16.0 33 D 66.0 10 80 1146 802 286 105 3 CA55-E020#336TE050 20 16.0 33 E 66.0 10 50 1581 1107 395 105 3 CA55-E020#336TE080 20 16.0 33 E 66.0 10 80 1250 875 313 105 3 CA55-H020#336TE070 20 16.0 33 H 66.0 6 70 1336 935 334 105 3 CA55-C020#476TE150 20 16.0 47 C 94.0 10 150 775 542 194 105 3 CA55-D020#476TE055 20 16.0 47 D 94.0 10 55 1382 967 345 105 3 CA55-D020#476TE080 20 16.0 47 D 94.0 10 80 1146 802 286 105 3 CA55-E020#476TE050 20 16.0 47 E 94.0 10 50 1581 1107 395 105 3 CA55-E020#476TE080 20 16.0 47 E 94.0 10 80 1250 875 313 105 3 CA55-H020#476TE055 20 16.0 47 H 94.0 10 55 1508 1055 377 105 3 CA55-H020#476TE070 20 16.0 47 H 94.0 6 70 1336 935 334 105 3 CA55-H020#476TE090 20 16.0 47 H 94.0 10 90 1179 825 295 105 3 CA55-D020#686TE055 20 16.0 68 D 136.0 6 55 1382 967 345 105 3 CA55-D020#686TE080 20 16.0 68 D 136.0 10 80 1146 802 286 105 3 CA55-E020#686TE045 20 16.0 68 E 136.0 6 45 1667 1167 417 105 3 CA55-E020#686TE080 20 16.0 68 E 136.0 10 80 1250 875 313 105 3 CA55-D020#107TE055 20 16.0 100 D 200.0 10 55 1382 967 345 105 3 CA55-E020#107TE045 20 16.0 100 E 200.0 6 45 1667 1167 417 105 3 CA55-E020#107TE080 20 16.0 100 E 200.0 10 80 1250 875 313 105 3 CA55-V020#107TE080 20 16.0 100 V 200.0 10 80 1369 959 342 105 3 CA55-E020#157TE080 20 16.0 150 E 300.0 10 80 1250 875 313 105 3 CA55-V020#157TE080 20 16.0 150 V 300.0 10 80 1369 959 342 105 3 CA55-W020#157TE080 20 16.0 150 W 300.0 10 80 1581 1107 395 105 3 CA55-E020#227TE080 20 16.0 220 E 440.0 10 80 1250 875 313 105 3 CA55-V020#227TE080 20 16.0 220 V 440.0 10 80 1369 959 342 105 3 CA55-W020#227TE080 20 16.0 220 W 440.0 10 80 1581 1107 395 105 3 CA55-B025#684TE300 25 20.0 0.68 B 1.7 10 300 500 350 125 105 3 CA55-B025#105TE300 25 20.0 1 B 2.5 10 300 500 350 125 105 3 CA55-B025#155TE300 25 20.0 1.5 B 3.8 10 300 500 350 125 105 3 CA55-C025#155TE150 25 20.0 1.5 C 3.8 10 150 775 542 194 105 3 CA55-B025#225TE250 25 20.0 2.2 B 5.5 10 250 548 383 137 105 3 CA55-B025#225TE300 25 20.0 2.2 B 5.5 10 300 500 350 125 105 3 CA55-C025#225TE100 25 20.0 2.2 C 5.5 10 100 949 664 237 105 3 CA55-C025#225TE150 25 20.0 2.2 C 5.5 10 150 775 542 194 105 3 CA55-B025#335TE250 25 20.0 3.3 B 8.3 10 250 548 383 137 105 3 CA55-B025#335TE300 25 20.0 3.3 B 8.3 10 300 500 350 125 105 3 CA55-C025#335TE100 25 20.0 3.3 C 8.3 10 100 949 664 237 105 3 CA55-C025#335TE150 25 20.0 3.3 C 8.3 10 150 775 542 194 105 3 CA55-B025#475TE150 25 20.0 4.7 B 11.8 6 150 707 495 177 105 3 CA55-B025#475TE250 25 20.0 4.7 B 11.8 10 250 548 383 137 105 3 CA55-B025#475TE300 25 20.0 4.7 B 11.8 10 300 500 350 125 105 3 CA55-C025#475TE100 25 20.0 4.7 C 11.8 10 100 949 664 237 105 3 CA55-C025#475TE150 25 20.0 4.7 C 11.8 10 150 775 542 194 105 3 CA55-B025#685TE090 25 20.0 6.8 B 17.0 6 90 913 639 228 105 3 CA55-B025#685TE150 25 20.0 6.8 B 17.0 6 150 707 495 177 105 3 CA55-B025#685TE300 25 20.0 6.8 B 17.0 10 300 500 350 125 105 3 CA55-C025#685TE100 25 20.0 6.8 C 17.0 10 100 949 664 237 105 3 CA55-C025#685TE150 25 20.0 6.8 C 17.0 10 150 775 542 194 105 3 CA55-B025#106TE100 25 20.0 10 B 25.0 8 100 866 606 217 105 3 CA55-B025#106TE150 25 20.0 10 B 25.0 6 150 707 495 177 105 3 CA55-B025#106TE300 25 20.0 10 B 25.0 10 300 500 350 125 105 3 Part Number CONT’T capacitance 100kHz RMS Current (mA) Category Temperature MSL 1 Please do not use multimeter through the measuring procedures. 2 Capacitance and DF measured at :100Hz,U_=2.2°-1.0V,U~=1.0°-0.5V, Frequency=100Hz.Test only applied in series equivalent circuit. 3 Voltage derating is applied at +105℃.(The DCL parameter should be read after 5 minutes when it connected to the circuit). 4 Special size and demand could consult with us. C ○ HUNAN XIANGYEE ZHONGYUAN TECHNOLOGY CO.,LTD Page 9 of 14 CA55 Series Conductive Polymer Chip Tantalum Capacitors RATING & PART NUMBER REFERENCE Rated Category Voltage Voltage Case Max. DCL Max. DF Max. ESR Code @+25℃ @+25℃,100Hz @+25℃,100KHz V V μF μA % mΩ +45℃ +85℃ +105℃ ℃ CA55-C025#106TE100 25 20.0 10 C 25.0 10 100 949 664 237 105 3 CA55-C025#106TE150 25 20.0 10 C 25.0 10 150 775 542 194 105 3 CA55-D025#106TE090 25 20.0 10 D 25.0 10 90 1080 756 270 105 3 CA55-B025#156TE100 25 20.0 15 B 37.5 6 100 866 606 217 105 3 CA55-B025#156TE150 25 20.0 15 B 37.5 6 150 707 495 177 105 3 CA55-C025#156TE150 25 20.0 15 C 37.5 10 150 775 542 194 105 3 CA55-D025#156TE090 25 20.0 15 D 37.5 10 90 1080 756 270 105 3 CA55-E025#156TE080 25 20.0 15 E 37.5 10 80 1250 875 313 105 3 CA55-H025#156TE090 25 20.0 15 H 37.5 10 90 1179 825 295 105 3 CA55-B025#226TE150 25 20.0 22 B 55.0 6 150 707 495 177 105 3 CA55-C025#226TE100 25 20.0 22 C 55.0 6 100 949 664 237 105 3 CA55-C025#226TE150 25 20.0 22 C 55.0 10 150 775 542 194 105 3 CA55-D025#226TE060 25 20.0 22 D 55.0 6 60 1323 926 331 105 3 CA55-D025#226TE080 25 20.0 22 D 55.0 10 80 1146 802 286 105 3 CA55-D025#226TE100 25 20.0 22 D 55.0 6 100 1025 717 256 105 3 CA55-E025#226TE080 25 20.0 22 E 55.0 10 80 1250 875 313 105 3 CA55-H025#226TE060 25 20.0 22 H 55.0 10 60 1443 1010 361 105 3 CA55-H025#226TE090 25 20.0 22 H 55.0 10 90 1179 825 295 105 3 CA55-D025#336TE060 25 20.0 33 D 82.5 10 60 1323 926 331 105 3 CA55-D025#336TE080 25 20.0 33 D 82.5 10 80 1146 802 286 105 3 CA55-D025#336TE100 25 20.0 33 D 82.5 6 100 1025 717 256 105 3 CA55-E025#336TE080 25 20.0 33 E 82.5 10 80 1250 875 313 105 3 CA55-H025#336TE060 25 20.0 33 H 82.5 10 60 1443 1010 361 105 3 CA55-H025#336TE100 25 20.0 33 H 82.5 6 100 1118 783 280 105 3 CA55-D025#476TE060 25 20.0 47 D 117.5 6 60 1323 926 331 105 3 CA55-D025#476TE080 25 20.0 47 D 117.5 10 80 1146 802 286 105 3 CA55-D025#476TE100 25 20.0 47 D 117.5 6 100 1025 717 256 105 3 CA55-E025#476TE050 25 20.0 47 E 117.5 6 50 1581 1107 395 105 3 CA55-E025#476TE080 25 20.0 47 E 117.5 10 80 1250 875 313 105 3 CA55-D025#686TE080 25 20.0 68 D 170.0 10 80 1146 802 286 105 3 CA55-E025#686TE050 25 20.0 68 E 170.0 6 50 1581 1107 395 105 3 CA55-E025#686TE080 25 20.0 68 E 170.0 10 80 1250 875 313 105 3 CA55-V025#686TE080 25 20.0 68 V 170.0 10 80 1369 959 342 105 3 CA55-E025#107TE060 25 20.0 100 E 250.0 10 60 1443 1010 361 105 3 CA55-E025#107TE080 25 20.0 100 E 250.0 10 80 1250 875 313 105 3 CA55-V025#107TE080 25 20.0 100 V 250.0 10 80 1369 959 342 105 3 CA55-W025#107TE080 25 20.0 100 W 250.0 10 80 1581 1107 395 105 3 CA55-V025#157TE080 25 20.0 150 V 375.0 10 80 1369 959 342 105 3 CA55-W025#157TE080 25 20.0 150 W 375.0 10 80 1581 1107 395 105 3 CA55-B035#684TE350 35 28.0 0.68 B 2.4 10 350 463 324 116 105 3 CA55-B035#105TE350 35 28.0 1 B 3.5 10 350 463 324 116 105 3 CA55-B035#155TE200 35 28.0 1.5 B 5.3 6 200 612 429 153 105 3 CA55-B035#155TE350 35 28.0 1.5 B 5.3 10 350 463 324 116 105 3 CA55-C035#155TE200 35 28.0 1.5 C 5.3 10 200 671 470 168 105 3 CA55-B035#225TE200 35 28.0 2.2 B 7.7 6 200 612 429 153 105 3 CA55-B035#225TE350 35 28.0 2.2 B 7.7 10 350 463 324 116 105 3 CA55-C035#225TE200 35 28.0 2.2 C 7.7 10 200 671 470 168 105 3 CA55-B035#335TE200 35 28.0 3.3 B 11.6 6 200 612 429 153 105 3 CA55-B035#335TE350 35 28.0 3.3 B 11.6 10 350 463 324 116 105 3 CA55-C035#335TE200 35 28.0 3.3 C 11.6 10 200 671 470 168 105 3 CA55-B035#475TE200 35 28.0 4.7 B 16.5 6 200 612 429 153 105 3 CA55-B035#475TE350 35 28.0 4.7 B 16.5 10 350 463 324 116 105 3 CA55-C035#475TE200 35 28.0 4.7 C 16.5 10 200 671 470 168 105 3 CA55-C035#685TE200 35 28.0 6.8 C 23.8 10 200 671 470 168 105 3 CA55-D035#685TE090 35 28.0 6.8 D 23.8 10 90 1080 756 270 105 3 Part Number CONT’T capacitance 100kHz RMS Current (mA) Category Temperature MSL 1 Please do not use multimeter through the measuring procedures. 2 Capacitance and DF measured at :100Hz,U_=2.2°-1.0V,U~=1.0°-0.5V, Frequency=100Hz.Test only applied in series equivalent circuit. 3 Voltage derating is applied at +105℃.(The DCL parameter should be read after 5 minutes when it connected to the circuit). 4 Special size and demand could consult with us. C ○ HUNAN XIANGYEE ZHONGYUAN TECHNOLOGY CO.,LTD Page 10 of 14 CA55 Series Conductive Polymer Chip Tantalum Capacitors RATING & PART NUMBER REFERENCE Rated Category Voltage Voltage Case Max. DCL Max. DF Max. ESR Code @+25℃ @+25℃,100Hz @+25℃,100KHz V V μF μA % mΩ +45℃ +85℃ +105℃ ℃ CA55-B035#106TE200 35 28.0 10 B 35.0 6 200 612 429 153 105 3 CA55-C035#106TE200 35 28.0 10 C 35.0 10 200 671 470 168 105 3 CA55-D035#106TE090 35 28.0 10 D 35.0 10 90 1080 756 270 105 3 CA55-E035#106TE090 35 28.0 10 E 35.0 10 90 1179 825 295 105 3 CA55-H035#106TE070 35 28.0 10 H 35.0 6 70 1336 935 334 105 3 CA55-H035#106TE120 35 28.0 10 H 35.0 10 120 1021 714 255 105 3 CA55-C035#156TE200 35 28.0 15 C 52.5 6 200 671 470 168 105 3 CA55-D035#156TE070 35 28.0 15 D 52.5 6 70 1225 857 306 105 3 CA55-D035#156TE100 35 28.0 15 D 52.5 6 100 1025 717 256 105 3 CA55-E035#156TE090 35 28.0 15 E 52.5 10 90 1179 825 295 105 3 CA55-H035#156TE100 35 28.0 15 H 52.5 10 100 1118 783 280 105 3 CA55-H035#156TE125 35 28.0 15 H 52.5 10 125 1000 700 250 105 3 CA55-D035#226TE070 35 28.0 22 D 77.0 6 70 1225 857 306 105 3 CA55-D035#226TE100 35 28.0 22 D 77.0 6 100 1025 717 256 105 3 CA55-E035#226TE090 35 28.0 22 E 77.0 10 90 1179 825 295 105 3 CA55-D035#336TE065 35 28.0 33 D 115.5 10 65 1271 890 318 105 3 CA55-D035#336TE100 35 28.0 33 D 115.5 6 100 1025 717 256 105 3 CA55-E035#336TE055 35 28.0 33 E 115.5 6 55 1508 1055 377 105 3 CA55-E035#336TE070 35 28.0 33 E 115.5 6 70 1336 935 334 105 3 CA55-E035#336TE090 35 28.0 33 E 115.5 10 90 1179 825 295 105 3 CA55-V035#336TE090 35 28.0 33 V 115.5 10 90 1291 904 323 105 3 CA55-E035#476TE030 35 28.0 47 E 164.5 10 30 2041 1429 510 105 3 CA55-E035#476TE055 35 28.0 47 E 164.5 6 55 1508 1055 377 105 3 CA55-E035#476TE090 35 28.0 47 E 164.5 10 90 1179 825 295 105 3 CA55-V035#476TE090 35 28.0 47 V 164.5 10 90 1291 904 323 105 3 CA55-W035#476TE090 35 28.0 47 W 164.5 10 90 1491 1043 373 105 3 CA55-W035#686TE090 35 28.0 68 W 238.0 10 90 1491 1043 373 105 3 CA55-B050#684TE350 50 40.0 0.68 B 3.4 10 350 463 324 116 105 3 CA55-B050#684TE400 50 40.0 0.68 B 3.4 6 400 433 303 108 105 3 CA55-B050#105TE300 50 40.0 1 B 5.0 6 300 500 350 125 105 3 CA55-B050#105TE350 50 40.0 1 B 5.0 10 350 463 324 116 105 3 CA55-B050#155TE300 50 40.0 1.5 B 7.5 6 300 500 350 125 105 3 CA55-B050#155TE350 50 40.0 1.5 B 7.5 10 350 463 324 116 105 3 CA55-C050#155TE200 50 40.0 1.5 C 7.5 10 200 671 470 168 105 3 CA55-C050#155TE300 50 40.0 1.5 C 7.5 6 300 548 383 137 105 3 CA55-B050#225TE350 50 40.0 2.2 B 11.0 10 350 463 324 116 105 3 CA55-C050#225TE200 50 40.0 2.2 C 11.0 10 200 671 470 168 105 3 CA55-C050#225TE300 50 40.0 2.2 C 11.0 6 300 548 383 137 105 3 CA55-C050#335TE200 50 40.0 3.3 C 16.5 10 200 671 470 168 105 3 CA55-D050#335TE100 50 40.0 3.3 D 16.5 10 100 1025 717 256 105 3 CA55-C050#475TE200 50 40.0 4.7 C 23.5 10 200 671 470 168 105 3 CA55-D050#475TE100 50 40.0 4.7 D 23.5 10 100 1025 717 256 105 3 CA55-C050#685TE200 50 40.0 6.8 C 34.0 10 200 671 470 168 105 3 CA55-D050#685TE070 50 40.0 6.8 D 34.0 10 70 1225 857 306 105 3 CA55-D050#685TE100 50 40.0 6.8 D 34.0 10 100 1025 717 256 105 3 CA55-D050#685TE120 50 40.0 6.8 D 34.0 10 120 935 655 234 105 3 CA55-H050#685TE070 50 40.0 6.8 H 34.0 10 70 1336 935 334 105 3 CA55-H050#685TE090 50 40.0 6.8 H 34.0 10 90 1179 825 295 105 3 CA55-D050#106TE090 50 40.0 10 D 50.0 10 90 1080 756 270 105 3 CA55-D050#106TE120 50 40.0 10 D 50.0 10 120 935 655 234 105 3 CA55-E050#106TE070 50 40.0 10 E 50.0 6 70 1336 935 334 105 3 CA55-E050#106TE100 50 40.0 10 E 50.0 10 100 1118 783 280 105 3 CA55-E050#156TE070 50 40.0 15 E 75.0 6 70 1336 935 334 105 3 CA55-E050#156TE100 50 40.0 15 E 75.0 10 100 1118 783 280 105 3 CA55-V050#156TE100 50 40.0 15 V 75.0 10 100 1225 857 306 105 3 Part Number CONT’T capacitance 100kHz RMS Current (mA) Category Temperature MSL 1 Please do not use multimeter through the measuring procedures. 2 Capacitance and DF measured at :100Hz,U_=2.2°-1.0V,U~=1.0°-0.5V, Frequency=100Hz.Test only applied in series equivalent circuit. 3 Voltage derating is applied at +105℃.(The DCL parameter should be read after 5 minutes when it connected to the circuit). 4 Special size and demand could consult with us. C ○ HUNAN XIANGYEE ZHONGYUAN TECHNOLOGY CO.,LTD Page 11 of 14 CA55 Series Conductive Polymer Chip Tantalum Capacitors RATING & PART NUMBER REFERENCE Rated Category Voltage Voltage Case Max. DCL Max. DF Max. ESR Code @+25℃ @+25℃,100Hz @+25℃,100KHz V V μF μA % mΩ +45℃ +85℃ +105℃ ℃ CA55-E050#226TE075 50 40.0 22 E 110.0 10 75 1291 904 323 105 3 CA55-E050#226TE100 50 40.0 22 E 110.0 10 100 1118 783 280 105 3 CA55-V050#226TE100 50 40.0 22 V 110.0 10 100 1225 857 306 105 3 CA55-W050#226TE100 50 40.0 22 W 110.0 10 100 1414 990 354 105 3 CA55-E050#336TE075 50 40.0 33 E 165.0 10 75 1291 904 323 105 3 CA55-V050#336TE100 50 40.0 33 V 165.0 10 100 1225 857 306 105 3 CA55-W050#336TE100 50 40.0 33 W 165.0 10 100 1414 990 354 105 3 CA55-W050#476TE100 50 40.0 47 W 235.0 10 100 1414 990 354 105 3 CA55-B063#105TE300 63 50.4 1 B 6.3 8 300 500 350 125 105 3 CA55-C063#105TE200 63 50.4 1 C 6.3 10 200 671 470 168 105 3 CA55-C063#105TE300 63 50.4 1 C 6.3 6 300 548 383 137 105 3 CA55-D063#105TE120 63 50.4 1 D 6.3 10 120 935 655 234 105 3 CA55-C063#155TE200 63 50.4 1.5 C 9.5 10 200 671 470 168 105 3 CA55-C063#155TE300 63 50.4 1.5 C 9.5 6 300 548 383 137 105 3 CA55-D063#155TE120 63 50.4 1.5 D 9.5 10 120 935 655 234 105 3 CA55-C063#225TE200 63 50.4 2.2 C 13.9 10 200 671 470 168 105 3 CA55-D063#225TE120 63 50.4 2.2 D 13.9 10 120 935 655 234 105 3 CA55-C063#335TE200 63 50.4 3.3 C 20.8 10 200 671 470 168 105 3 CA55-D063#335TE120 63 50.4 3.3 D 20.8 10 120 935 655 234 105 3 CA55-C063#475TE200 63 50.4 4.7 C 29.6 6 200 671 470 168 105 3 CA55-D063#475TE075 63 50.4 4.7 D 29.6 10 75 1183 828 296 105 3 CA55-D063#475TE120 63 50.4 4.7 D 29.6 10 120 935 655 234 105 3 CA55-D063#475TE300 63 50.4 4.7 D 29.6 10 300 592 414 148 105 3 CA55-E063#475TE120 63 50.4 4.7 E 29.6 10 120 1021 714 255 105 3 CA55-D063#685TE120 63 50.4 6.8 D 42.8 10 120 935 655 234 105 3 CA55-E063#685TE100 63 50.4 6.8 E 42.8 6 100 1118 783 280 105 3 CA55-E063#685TE150 63 50.4 6.8 E 42.8 6 150 913 639 228 105 3 CA55-D063#106TE120 63 50.4 10 D 63.0 10 120 935 655 234 105 3 CA55-E063#106TE050 63 50.4 10 E 63.0 10 50 1581 1107 395 105 3 CA55-E063#106TE100 63 50.4 10 E 63.0 6 100 1118 783 280 105 3 CA55-E063#106TE150 63 50.4 10 E 63.0 6 150 913 639 228 105 3 CA55-E063#156TE035 63 50.4 15 E 94.5 10 35 1890 1323 472 105 3 CA55-E063#156TE120 63 50.4 15 E 94.5 10 120 1021 714 255 105 3 CA55-E063#156TE150 63 50.4 15 E 94.5 10 150 913 639 228 105 3 CA55-V063#156TE120 63 50.4 15 V 94.5 10 120 1118 783 280 105 3 CA55-W063#226TE120 63 50.4 22 W 138.6 10 120 1291 904 323 105 3 Part Number CONT’T capacitance 100kHz RMS Current (mA) Category Temperature MSL 1 Please do not use multimeter through the measuring procedures. 2 Capacitance and DF measured at :100Hz,U_=2.2°-1.0V,U~=1.0°-0.5V, Frequency=100Hz.Test only applied in series equivalent circuit. 3 Voltage derating is applied at +105℃.(The DCL parameter should be read after 5 minutes when it connected to the circuit). 4 Special size and demand could consult with us. C ○ HUNAN XIANGYEE ZHONGYUAN TECHNOLOGY CO.,LTD Page 12 of 14 CA55 Series Conductive Polymer Chip Tantalum Capacitors A,B,C,D,E,V,W Case Product Packaging Embossed (Plastic) Carrier Tape Dimensions Diagram of Taping Dimensions Case A0±0.10 B0±0.10 K±0.10 W±0.30 E±0.10 A 1.83 3.57 1.65 8 1.75 B 3.15 3.77 2.22 8 C 3.45 6.4 2.92 D 4.48 7.62 E 4.5 V W F±0.05 P±0.10 P1±0.05 P2±0.10 D+0.20 D1+0.25 3.5 4 2 4 1.5 1 1.75 3.5 4 2 4 1.5 1 12 1.75 5.5 8 2 4 1.5 1.5 3.22 12 1.75 5.5 8 2 4 1.5 1.5 7.5 4.5 12 1.75 5.5 8 2 4 1.5 1.5 6.4 7.6 4.4 12 1.75 5.5 8 2 4 1.5 1.5 7.2 8.1 4.75 16 1.75 7.5 12 2 4 1.5 1.5 ±0.2mm over 10 sprocket hole spaces Reel Dimensions Reel Size Tape Wide A B C W T 180mm (7") 8mm 178±2.00 50 min 13.0±0.50 8.4+1.5/-0 1.50±0.50 180mm (7") 12mm 178±2.00 50 min 13.0±0.50 12.4+1.5/-0 1.50±0.50 180mm (7") 16mm 178±2.00 50 min 13.0±0.50 16.4+1.5/-1 1.50±0.50 Packaging Quantity Case size A B C D E V W Quantity (pcs / plate) 2000 2000 500 500 400 400 400 Reel Dimensions Land Dimension /Courtyard Case code Metric Size Code Density Level A: Maximum (Most) Land Protrusion (mm) Density Level B : Median (Nominal) Land Protrusion (mm) Density Level C: Minimum (Least) Land Protrusion (mm) Case EIA W L S V1 V2 W L S V1 V2 W L S V1 V2 A 3216–18 1.35 2.20 0.62 6.02 2.8 1.23 1.8 0.82 4.92 2.3 1.13 1.42 0.98 4.06 2.04 B 3528–21 2.35 2.21 0.92 6.32 4.0 2.23 1.8 1.12 5.22 3.5 2.13 1.42 1.28 4.36 3.24 C 6032–25 2.35 2.77 2.37 8.92 4.5 2.23 2.37 2.57 7.82 4 2.13 1.99 2.73 6.96 3.74 D 7343–31 2.55 2.77 3.67 10.22 5.6 2.43 2.37 3.87 9.12 5.1 2.33 1.99 4.03 8.26 4.84 E 7343–43 2.55 2.77 3.67 10.22 5.6 2.43 2.37 3.87 9.12 5.1 2.33 1.99 4.03 8.26 4.84 Density Level A: For low-density product applications. Recommended for wave solder applications and provides a wider process window for reflow solder processes. Density Level B: For products with a moderate level of component density. Provides a robust solder attachment condition for reflow solder processes. Density Level C: For high component density product applications. Before adapting the minimum land pattern variations the user should perform qualification testing based on the conditions outlined in IPC standard 7351 (IPC–7351). 1 Height of these chips may create problems in wave soldering. 2 Land pattern geometry is too small for silkscreen outline. C ○ HUNAN XIANGYEE ZHONGYUAN TECHNOLOGY CO.,LTD Surface Mount Footprints Page 13 of 14 CA55 Series Conductive Polymer Chip Tantalum Capacitors Soldering Process XIANGYEE tantalum capacitors are compatible with wave (single or dual), convection, IR, or vapor phase reflow techniques. Preheating of these components is recommended to avoid extreme thermal stress. XIANGYEE's recommended profile conditions for convection and IR reflow reflect the profile conditions of the IPC/J–STD–020D standard for moisture sensitivity testing. The devices can safely withstand a maximum of three reflow passes at these conditions. Hand soldering should be performed with care due to the difficulty in process control. If performed, care should be taken to avoid contact of the soldering iron to the molded case. The iron should be used to heat the solder pad, applying solder between the pad and the termination, until reflow occurs. Once reflow occurs, the iron should be removed immediately. “Wiping” the edges of a chip and heating the top surface is not recommended. During typical reflow operations, a slight darkening of the gold- colored epoxy may be observed. This slight darkening is normal and not harmful to the product. Marking permanency is not affected by this change. Profile Feature SnPb Assembly Pb-Free Assembly Temperature Minimum (TSmin) 100° C 150° C Temperature Maximum (TSmax) 150° C 200° C Time (ts) from Tsmin to Tsmax) 60 – 120 seconds 60 – 120 seconds Ramp-up Rate (TL to TP) 3° C/seconds maximum 3° C/seconds maximum Liquidous Temperature (TL) 183° C 217° C Time Above Liquidous (tL) 60 – 150 seconds 60 – 150 seconds Peak Temperature (TP) 220° C* ,235° C** 250° C* , 260° C** 20 seconds maximum 30 seconds maximum Ramp-down Rate (TP to TL) 6° C/seconds maximum 6° C/seconds maximum Time 25° C to Peak Temperature 6 minutes maximum 8 minutes maximum Preheat/Soak Time within 5° C of Maximum Peak Temperature (tP) Recommended Reflow Profile Note: All temperatures refer to the center of the package, measured on the package body surface that is facing up during assembly reflow. *Case Size D, E **Case Size A, B, C Storage Tantalum dielectric chip capacitors are unaffected by the following storage condition for 2 years: Temperature: -10°C – +50°C Humidity: 75% RH maximum Atmospheric pressure: 860 mbar ~ 1060mbar Tantalum capacitors exhibit a very low random failure rate after long periods of storage and apart from this there are no known modes of failure under normal storage conditions. All capacitors will withstand any environmental conditions within their ratings for the periods given in the detail specifications. Storage for longer periods under high humidity conditions may affect the leakage current of resin protected capacitors. Solderability of solder coated surfaces may be affected by storage of excess of 2 years. C ○ HUNAN XIANGYEE ZHONGYUAN TECHNOLOGY CO.,LTD Page 14 of 14
CA55-D6R3M477T 价格&库存
很抱歉,暂时无法提供与“CA55-D6R3M477T”相匹配的价格&库存,您可以联系我们找货
CA55-D6R3M477T
    • 500+4.01810
    • 1000+3.94680
    • 1500+3.87550
    • 2000+3.80305
    库存:10000
    CA55-D6R3M477T
    • 5+21.35040
    • 100+12.73620
    • 200+8.91540
    • 500+6.36810
    • 1000+6.04970
    • 5000+5.60400
