BF356B
BF356B
    BFSEMICONDUCTOR(毕方半导体)
    SOP-4
    单向光耦 Viso=3750Vrms VF(typ)=1.24V IF=60mA Vo=80V CTR=130~260% SOP4
BF356B 数据手册
BF BF356 Series www.bfsemi.com SOP4, DC Input Photo Transistor Coupler SCHEMATIC Description The BF356 series combine an AlGaAs infrared inf emitting diode as the emitter which is optically 1 4 2 3 coupled to a silicon planar phototransistor detector in a plastic SOP4 package. package With the robust coplanar double mold structure, BF356 series provide the most stable isolation feature. Features  High isolation 3750 VRMS  CTR flexibility available see order       information DC input with transistor output Operating temperature range - 55 °C to 110 °C PIN DEFINITION 1. Anode 2. Cathode 3. Emitter 4. Collector PACKAGE OUTLINE REACH compliance Halogen free MSL class 1 Regulatory Approvals  UL - UL1577  VDE - EN60747-5-5(VDE0884 5(VDE0884-5)  CQC – GB4943.1, GB8898 Applications Switch mode power supplies • • Programmable controllers • • Household appliances Office equipment Document No: DWI-009 Rev:A00 Release Date: 2019/ 9/8/12 1 BF356 Series www.bfsemi.com SOP4, DC Input Photo Transistor Coupler ABSOLUTE MAXIMUM RATINGS PARAMETER SYMBOL VALUE UNIT NOTE INPUT Forward Current IF 60 mA Peak Forward Current IFP 1 A Reverse Voltage VR 6 V Input Power Dissipation PI 100 mW Collector - Emitter Voltage VCEO 80 V Emitter - Collector Voltage VECO 7 V Collector Current IC 50 mA Output Power Dissipation PO 150 mW Total Power Dissipation Ptot 200 mW Isolation Voltage Viso 3750 Vrms Operating Temperature Topr -55~110 °C Storage Temperature Tstg -55~125 °C Soldering Temperature Tsol 260 °C 1 OUTPUT COMMON 2 Note 1.100μs pulse, 100Hz frequency Note 2. AC For 1 Minute, R.H. = 40 ~ 60% Document No: DWI-009 Rev:A00 Release Date: 2019/8/12 2 BF356 Series www.bfsemi.com SOP4, DC Input Photo Transistor Coupler ELECTRICAL OPTICAL CHARACTERISTICS at Ta=25°C PARAMETER SYMBOL MIN TYP. MAX. UNIT TEST CONDITION NOTE INPUT Forward Voltage VF - 1.24 1.4 V IF=10mA Reverse Current IR - - 10 µA VR=6V Input Capacitance Cin - 10 - pF V=0, f=1kHz OUTPUT Collector Dark Current Collector-Emitter Breakdown Voltage Emitter-Collector Breakdown Voltage ICEO - - 100 nA VCE=20V, IF=0 BVCEO 80 - - V IC=0.1mA, IF=0 BVECO 7 - - V IE=0.1mA, IF=0 TRANSFER CHARACTERISTICS BF356 50 - 600 Current BF356A 80 - 160 Transfer Ratio BF356B 130 - 260 BF356C 200 - 400 BF356D 300 - 600 - 0.06 Collector-Emitter Saturation Voltage CTR VCE(sat) 10^12 10^14 % IF=5mA, VCE=5V 0.2 V IF=20mA, IC=1mA - Ω DC500V, 40 ~ 60% R.H. Isolation Resistance RISO Floating Capacitance CIO - 0.4 1 pF V=0, f=1MHz Cut-off Frequency fc - 80 - kHz VCE=2V, IC=2mA RL=100Ω,-3dB Response Time (Rise) tr - 3 18 µs Response Time (Fall) tf - 4 18 µs VCE=2V, IC=2mA RL=100Ω 4 3 3 Note 3. Fig.12&13 Note 4. Fig.14 Document No: DWI-009 Rev:A00 Release Date: 2019/8/12 3 BF BF356 Series www.bfsemi.com SOP4, DC Input Photo Transistor Coupler CHARACTERISTIC CURVES Fig.1 Forward Current vs. Ambient Temperature Fig.2 Collector Power Dissipation vs.Ambient Temperature Fig.3 Forward Current vs. Forward Voltage Fig.4 Collector Dark Current vs.Ambient Temperature Fig.5 Collector Current Fig.6 Collector Current vs. Collector-emitter emitter Voltage vs. Collector-emitter emitter Voltage Document No: DWI-009 Rev:A00 Release Date: 2019/ 9/8/12 4 BF BF356 Series www.bfsemi.com SOP4, DC Input Photo Transistor Coupler CHARACTERISTICCURVES Fig.7 Normalized Current Transfer Ratio vs. Forward Current Fig.8 Normalized Current Transfer Ratio vs.Ambient Temperature Fig.9 Collector-emitter emitter Saturation Voltage vs. Ambient Temperature Fig.10 Switching Time vs.Load Resistance Fig.11 Frequency Response Document No: DWI-009 Rev:A00 Release Date: 2019/ 9/8/12 5 BF BF356 Series www.bfsemi.com SOP4, DC Input Photo Transistor Coupler TEST CIRCUITS Fig.12 Test Circuits of Response Time Fig.13Curves s of Response Time Fig.14Test Circuits of Frequency Response Document No: DWI-009 Rev:A00 Release Date: 2019/ 9/8/12 6 BF BF356 Series www.bfsemi.com SOP4, DC Input Photo Transistor Coupler PACKAGE DIMENSIONS (Dimensions in mm unless otherwise stated) Recommended Solder Mask (Dimensions in mm unless otherwise stated) Document No: DWI-009 Rev:A00 Release Date: 2019/ 9/8/12 7 BF BF356 Series www.bfsemi.com SOP4, DC Input Photo Transistor Coupler CARRIER ARRIER TAPE SPECIFICATIONS (Dimensions in mm unless otherwise stated) Option T1 Option T2 Document No: DWI-009 Rev:A00 Release Date: 2019/ 9/8/12 8 BF BF356 Series www.bfsemi.com SOP4, DC Input Photo Transistor Coupler REEL SPECIFICATIONS (Dimensions in mm unless otherwise stated) Option T1 & T2 Document No: DWI-009 Rev:A00 Release Date: 2019/ 9/8/12 9 BF356 Series www.bfsemi.com SOP4, DC Input Photo Transistor Coupler BOX SPECIFICATIONS (Reel Type) Inner Box  L x W x H = 36cm x 36cm x 6.9cm Outer Box  L x W x H = 45cm x 38cm x 38cm Document No: DWI-009 Rev:A00 Release Date: 2019/8/12 10 BF356 Series www.bfsemi.com SOP4, DC Input Photo Transistor Coupler ORDERING AND MARKING INFORMATION MARKING INFORMATION BF 356 X V Y A WW BF 356X VYAWW : Company Abbr. : Part Number : CTR Rank : VDE Option : Fiscal Year : Manufacturing Code : Work Week ORDERING INFORMATION LABEL INFORMATION BF356X(Z)-GV BF – Company Abbr. 356 – Part Number X – Rank (A/B/C/D or None) Z – Tape and Reel Option (T1/T2) G – Green V – VDE Option (V or None) PACKING QUANTITY Option Quantity Quantity – Inner box Quantity – Outer box T1 3000 Units/Reel 3 Reels/Inner box 5 Inner box/Outer box = 45k Units T2 3000 Units/Reel 3 Reels/Inner box 5 Inner box/Outer box = 45k Units Document No: DWI-009 Rev:A00 Release Date: 2019/8/12 11 BF356 Series www.bfsemi.com SOP4, DC Input Photo Transistor Coupler REFLOW INFORMATION REFLOW PROFILE Profile Feature Sn-Pb Assembly Profile Pb-Free Assembly Profile Temperature Min. (Tsmin) 100 150°C Temperature Max. (Tsmax) 150 200°C Time (ts) from (Tsmin to Tsmax) 60-120 seconds 60-120 seconds Ramp-up Rate (tL to tP) 3°C/second max. 3°C/second max. Liquidous Temperature (TL) 183°C 217°C Time (tL) Maintained Above (TL) 60 – 150 seconds 60 – 150 seconds Peak Body Package Temperature 235°C +0°C / -5°C 260°C +0°C / -5°C Time (tP) within 5°C of 260°C 20 seconds 30 seconds Ramp-down Rate (TP to TL) 6°C/second max 6°C/second max Time 25°C to Peak Temperature 6 minutes max. 8 minutes max. Document No: DWI-009 Rev:A00 Release Date: 2019/8/12 12 BF356 Series www.bfsemi.com SOP4, DC Input Photo Transistor Coupler DISCLAIMER  BF SEMICONDUCTOR is continually improving the quality, reliability, function and design. BF SEMICONDUCTOR reserves the right to make changes without further notices.  The characteristic curves shown in this datasheet are representing typical performance which are not guaranteed.  BF SEMICONDUCTOR makes no warranty, representation or guarantee regarding the suitability of the products for any particular purpose or the continuing production of any product. To the maximum extent permitted by applicable law, BF SEMICONDUCTOR disclaims (a) any and all liability arising out of the application or use of any product, (b) any and all liability, including without limitation special, consequential or incidental damages, and (c) any and all implied warranties, including warranties of fitness for particular  The products shown in this publication are designed for the general use in electronic applications such as office automation, equipment, communications devices, audio/visual equipment, electrical application and instrumentation purpose, non-infringement and merchantability.  This product is not intended to be used for military, aircraft, automotive, medical, life sustaining or lifesaving applications or any other application which can result in human injury or death.  Please contact BF SEMICONDUCTOR sales agent for special application request.  Immerge unit’s body in solder paste is not recommended.  Parameters provided in datasheets may vary in different applications and performance may vary over time. All operating parameters, including typical parameters, must be validated in each customer application by the customer’s technical experts. Product specifications do not expand or otherwise modify BF SEMICONDUCTOR’s terms and conditions of purchase, including but not limited to the warranty expressed therein.  Discoloration might be occurred on the package surface after soldering, reflow or long-time use. It neither impacts the performance nor reliability. Document No: DWI-009 Rev:A00 Release Date: 2019/8/12 13
BF356B
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入、输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件可以实现信号的多路切换,具有低导通电阻和快速响应时间。
6. 应用信息:广泛应用于通信、工业控制和医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为3x3mm。
BF356B 价格&库存
很抱歉,暂时无法提供与“BF356B”相匹配的价格&库存,您可以联系我们找货
BF356B
  • 1+0.31050
  • 10+0.29900
  • 100+0.27140
  • 500+0.25760
