APE
Washable
RoHS Compliant
Subminiature Pushbutton Switches
UL
■Features
■ Specifications
1. Twin-contact clip mechanism for high reliability.
0.4VA AC、DC
2. Process sealed structure
Rating
Max:50mA 60VAC/DC Min:1μA 20mVAC/DC
3. Gold-plated contacts.
Initial contact resistance 50mΩ max.
UL:48VAC/DC 50mA
Dielectric strength
4. Terminal pin pitch: 2.54 mm.
(1.5mA 200μVAC)
250VAC 1 minute
(500VDC)
Initial Insulation resistance 500MΩ min.
5. UL recognized
Electrical life
10,000 operations at maximum rating.
30,000 operations at 0.4VA
Operating force
0.78∼2.94N
Operating
temperature range
Storage
temperature range
−20∼+85℃
−40∼+85℃
■Part Numbering
A
Series code
PE
Actuator shape
2
F
Number of poles
Code
Type
Fig.
Number of poles
PE
Push type
1
1 pole
2
2 poles
2
Switching function
Terminal style
Code Switching function
F
ON -(ON)
■Optional Accessories………………………… Page 253.
(ON)
:Momentary.
M
- 10 - Z
Actuator shape
Clip contact mechanism
Fig.
Terminal style
Code
Actuator shape
2
PC Straight
M
Standard
5
Right angle
(0.2 inch pitch)
6
Right angle
(0.3 inch pitch)
APE−M(Standard type)
SPDT
Switching
function
Part No.
PC Straight
APE1F−2M−10−Z
ON
(ON)
Connecting terminals
2−3
2−1
ON
2−3
5−6
(ON)
2−1
5−4
★APE1F−5M−10−Z
ON
(ON)
2−3
2−1
APE1F−6M−10−Z
ON
(ON)
2−3
2−1
ON
2−3
5−6
(ON)
2−1
5−4
Terminal numbers are not shown on the switch.
DPDT
Switching
function
Part No.
APE2F−2M−10−Z
PC Straight
SPDT
Switching
function
Part No.
0.2R/A
SPDT
Switching
function
Part No.
0.3R/A
DPDT
Switching
function
Part No.
☆APE2F−6M−10−Z
0.3R/A
(ON)
:Momentary.
☆:Semi-standard products.
★:Made to order products.
APE
■Right angle terminals
1 pole
●The space between the terminal rows are available in
two dimensions: 0.2 inches (5.08 mm) and 0.3 inches
(7.62 mm).
[Example] 0.2-inch pitch : APE1F-5M-10-Z
0.3-inch pitch : APE1F-6M-10-Z
2 poles
■Button Shape
■Bracket Installation Procedure
Standard(M)
■Mounting of Switch
●Use PC boards with hole diameter of 1mm.
●Do not bend the terminal pins before mounting the switch on
the PC board.
●After mounting the switch, do not place the device in such a
way that the device weight will be applied on to the actuator of
the switch.
●Do not apply load exceeding 12.7 N to the actuator. If load
exceeding 12.7 N is expected to be applied to the actuator,
please use a Bracket (optional accessory sold separately).
Maximum load will be 29.4 N when a Bracket is used.
●Use Bracket 140000640314 or 140000640318 for side-byside mounting.
● To i n c r e a s e m o u n t i n g s t r e n g t h , u s e B r a c k e t
140000640315.
●PC Hole Layouts will change depending on the Bracket.
Please refer to P.245.
:Optional Accessories.
■Color Cap Mounting
Refer to P.249.
APE
■ Soldering Specifications
⑴Manual Soldering
Device:Soldering iron
380°
C, Max.; 3 seconds, Max.
⑵Auto Soldering
Device:Jet wave type or dip type
275°
C, Max.; 6 seconds, Max.
・Pre-heating should be done at temperatures ranging from 80°
C to 120°
C and within 120 seconds.
■Flux Cleaning
⑴Solvent :Fluorine or Alcohol type.
⑵Cleaning after soldering should be done after the terminal
temperature falls to 90℃ or below, or after leaving the
switch for five minutes or longer at room temperature.
⑶Do not use ultrasonic cleaning.
■PC Hole Layouts(AP・APE)
PC Straight
2 poles
APE
2 poles
Terminal
Type
1 pole
AP-M
AP-S
APE
0.2−inch pitch
0.3−inch pitch
FU
231
2 poles
140000640318
■Packaging Specification
■Right-angle Terminal
15
AP-M
KU
1 pole
140000640315
JI
SO
SO
AP-M
AP-S
AP-H
APE
140000640314
When optional Bracket is used.
JI
Type
Without Bracket
FU
Mounting
KU
196
很抱歉,暂时无法提供与“APE1F-2M-10-Z”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+30.290671+3.91230
