DF62W-2S-2.2C
DF62W-2S-2.2C
    HRS(广濑)
    P=2.2mm
    胶壳 间距P=2.20mm 2Pin(1x2)
DF62W-2S-2.2C 数据手册
DF62/DF62W Series Apr.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces Dec. 2020 ⑥ DF62/DF62W Series/2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces Features Apr.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1. The slim, sleek design and smooth contour combine to complete connections in tight spaces. 16 16 Existing Products These connectors were designed to take full advantage of small/ narrow spaces. The contacts are arranged in a grid pattern which shortens the diagonal distances and the body was slimmed down by creating smooth outer surfaces. This design helps to save precious space and makes these connectors virtually tangle free. There is no visible or exposed metal which eliminates the possibility of electrical arcing between the connector and the inside of a metal conduit. DF62 Compact shape due to 2 × 2. 2 grid layout of pins ( Both are 7 contacts with 3A current rating) Grid Arrangement Smooth External Shape No Exposed Metal 2. Secure lock mechanism The friction lock emits a clear tactile click upon lock completion. The design prevents incomplete mating and connector disconnection. The socket lock can be visually checked through the plug window after mating. These indicators function together to prevent incomplete mating. 1.Visual Check Area 2. Locking is confirmed by an audible click. 3. Reliable contact design Two- point contact design that maintains contact reliability. 2 DF62/DF62W Series/2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces 4. Robust contact design (Non-Waterproof Type (DF62)) The unique design provides protection to the contacts and lance areas and it prevents any bending or deformity that might occur during mating, assembly or transportation. (Waterproof Type (DF62W)) Robust Box-shaped Contact design Designed for easy contact insertion. Apr.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 5. Multiple variations available There are several different wire counts available, giving the designer a wide variety to choose from for the application. Protected lock type, panel mount type and pin header type are also available. 6. Applicator sharing The applicators for the DF11 and DF59 Series ( existing products) can be adapted to accommodate the DF62 Series applicators. Note 1 : The DF11 Series applicators require part replacement in order to handle the difference in contact length. However once replaced the applicator can be used with DF11, DF59 and DF62. Note 2 : The die and hand tool are used only for the in designated purpases. Note 3 : Please contact Hirose for additional details. 7. Condensation prevention ( Waterproof Type DF62W) Housing Seal IP67 level water- resistance in mated condition. Wire Seal IP67 waterproof equivalent under specific conditions. Please contact a Hirose representative for detailed specifications and conditions. 3 Wire Seal DF62/DF62W Series/2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces Product Specifications ● DF62 Apr.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Rated Current (Note 1) No of Pos. 22 AWG 24 AWG 26-30 AWG Operating Temperature (Note 2) -35 ~ +105℃ 2 4A 2A 1A Storage Temperature Range (Note 4) -10 ~ +60℃ 3 3A 2A 1A Operating Humidity Range (Note 3) 20 ~ 80% 4 3A 2A 1A Storage Humidity Range (Note 4) 40 ~ 70% 5 3A 2A 1A 6 3A 2A 1A 7 3A 2A 1A 13 3A 2A 1A 24 2.5A 2A 1A Rated Voltage AC/DC 250V UL Rated Voltage AC/DC 29.9V Operating Temperature (Note 2) -35 ~ +75℃ C-UL Rated Voltage AC/DC 29.9V Operating Temperature (Note 2) -35 ~ +75℃ ● DF62W Rated Current (Note 1) No of Pos. 20 AWG 22 AWG 24 AWG 26 AWG Operating Temperature (Note 2) -40 ~ +105℃ 2 5A 4A 3.5A 3A Storage Temperature Range (Note 4) -10 ~ +60℃ 3 3.5A 3A 2A 1A Operating Humidity Range (Note 3) 20 ~ 80% 4 3.5A 3A 2A 1A Storage Humidity Range (Note 4) 40 ~ 70% 6 3.5A 3A 2A 1A 9 3.5A 3A 2A 1A Rated Voltage AC/DC 250V UL Rated Voltage AC/DC 29.9V Operating Temperature (Note 2) -40 ~ +75℃ C-UL Rated Voltage AC/DC 29.9V Operating Temperature (Note 2) -40 ~ +75℃ UL File Name UL : E52653 C-UL : E52653 4 DF62/DF62W Series/2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces Apr.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Items Specifications Conditions Insulation Resistance Minimum of 1,000M Ω Measured with 500V DC Withstanding Voltage No flashover or breakdown Apply 650V AC for 1 min. Contact Resistance Maximum of 30m Ω Measured at a maximum of 20mV and 100mA (DC or 1000Hz) Vibration Resistance No electrical discontinuity of 1μ s or longer 10 cycles in each of three directions at frequency 10-55Hz, half amplitude 0.75mm Shock Resistance No electrical discontinuity of 1μ s or longer Acceleration : 490m/s2, 11ms, Semi-sinusoidal 3 axle direction 3 times each. Humidity Resistance Contact Resistance : Maximum of 30m Ω Insulation Resistance : Minimum of 1,000M Ω Left at temperature 40 ± 2℃ , humidity 90 to 95%, 96 hours Temperature Cycles Contact Resistance : Maximum of 30m Ω Insulation Resistance : Minimum of 1,000M Ω -55℃ : 30 minutes → 5 to 35℃ : 2 to 3 minutes → 85℃ : 30 minutes → 5 to 35℃ : 2 to 3 minutes, 5 cycles Mating Durability Contact Resistance : Maximum of 30m Ω Mating/unmating : 30 mating cycles Solder Heat Resistance There should be no melting of the resin part affecting performance. Flow : 260℃ , 10sec Hand soldering : temperature of soldering iron at 300℃ for 3sec. Note 1 : This is the maximum current rating while all pins are powered or used as all power lines. When isolating power lines into multiple circuits, current ratings may go above the stated current ratings. Please consult Hirose for details before doing this. Note 2 : Includes the temperature rise of power lines. Note 3 : The connector should be completely dry (no condensation present) Note 4 : The term "storage" refers to the long-term storage condition of unused products before PCB mounting. The operating temperature and humidity ranges are applied while in a non-energized state, while in transport or after PCB mounting. 5 DF62/DF62W Series/2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces Materials / Finish Item Socket Crimping Contact Plug Crimping Contact Crimping Socket Crimping Plug Crimping Socket (Note 1) Crimping Plug (Note 1) Component Contact Phosphorous Bronze Insulator PBT Seal Silicone Rubber Insulator Apr.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Material DF62 DF62W Header Finish Gold Plating or Tin Plating White Black UL Flammability Rating UL94V-0 Bengala - Black UL94V-0 Straight : Polyamide Right Angle : PBT PBT Contact Copper Alloy Gold Plating or Tin Plating - Retention Tab Brass Tin Plating - Seal (Note 1) Silicone Rubber Bengala - Note 1 : Waterproof type (DF62W) only 6 DF62/DF62W Series/2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. Note : The waterproof type and non-waterproof type are not intermateable. ■ Non-Waterproof Type ● Connector DF62B - # S - 2.2 C (##) Apr.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ❶ ❷ ❸ ❹ ❺ ❻ ❶ Series Name DF62B (Regular Type) DF62C (Protected Lock Type) DF62P (Panel Mount Type) ❹ Contact Pitch 2.2mm ❷ No. of Pos. 2, 3, 4, 5, 6, 7, 13, 24 ❺ Connection Part C : Crimping Housing ❸ Connector Type S : Socket EP : In-line Plug ❻ Color Socket (None : White, 11 : Black, 18 : Red) In-line Plug (None : Black, 10 : White, 18 : Red) ● Contact DF62 - EP 2428 PCF A ❶ ❷ ❸ ❹ ❺ ❶ Series Name DF62 ❷ Terminal Type EP : In-line Plug ❸ Applicable Wire Size 22  : 22 AWG 2428 : 24 to 28 AWG 30  : 30 AWG ● ❹ Contact Type / Packaging Type SCF : SC : PCF : PC : ❺ Plating Type A  : Gold plating None : Tin plating ❺ Connection Part Shape DSA : Straight Pin Header DS : Right Angle Pin Header ❻ Plating Type None : Tin Plating 01  : Gold Plating Socket crimping contact, reel Socket crimping contact, pieces Plug crimping contact, reel Plug crimping contact, pieces Connector DF62 - # P - 2.2 DSA (##) ❶ ❷ ❸ ❹ ❺ ❶ Series Name DF62 ❷ No. of Pos. 13, 24 ❸ Connector Type P : Pin Header ❹ Contact Pitch 2.2mm ❻ 7 DF62/DF62W Series/2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces ■ Waterproof Type ● Connector DF62W - # S - 2.2 C Apr.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ❶ ❷ ❸ ❹ ❺ ❶ Series Name DF62W ❸ Connector Type S : Socket   EP : In-line Plug ❷ No. of Pos. 2, 3, 4, 6, 9 ❹ Contact Pitch 2.2mm ❺ Connection Part Shape C : Crimping Housing ❹ Contact Type / Packaging Type SCF : Socket Crimping Contact, Reel SC : Socket Crimping Contact, Pieces PCF : Plug Crimping Contact, Reel PC : Plug Crimping Contact, Pieces ❺ Plating Type A  : Gold Plating None : Tin Plating ❷ For Each Use Type WP : Waterproof Pin ● Contact DF62W - EP 2226 PCF A ❶ ❷ ❸ ❹ ❺ ❶ Series Name DF62W ❷ Terminal Type EP : In-line Plug ❸ Applicable Wire Size 2022 : 20 to 22 AWG 2226 : 22 to 26 AWG ● Waterproof Pin DF62W - WP ❶ ❶ ● Series Name ❷ DF62W Connector DF62WZ - # P - 2.2 DSA (##) ❶ ❷ ❸ ❹ ❺ ❻ ❶ Series Name DF62WZ ❹ Contact Pitch 2.2mm ❷ No. of Pos. 9 ❺ Connection Part Shape DSA : Straight Pin Header ❸ Connector Type P : Pin Header ❻ Plating Type 20 : Tin Plating 50 : Gold Plating 8 DF62/DF62W Series/2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces Socket (Standard Type) A 9.55 Apr.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. P=2.2 P=2 B Cavity No. Contact No. Marking 7pos. shown as an example. Unit : mm Part No. HRS No. No. of Pos. DF62B-2S-2.2C(##) CL0544-0551-0-## 2 DF62B-3S-2.2C(##) CL0544-0552-2-## 3 DF62B-4S-2.2C(##) CL0544-0553-5-## 4 DF62B-5S-2.2C(##) CL0544-0554-8-## 5 DF62B-6S-2.2C(##) CL0544-0555-0-## 6 DF62B-7S-2.2C(##) CL0544-0556-3-## 7 DF62B-13S-2.2C(##) CL0544-0557-6-## 13 9.3 11.08 DF62B-24S-2.2C(##) CL0544-0539-4-## 24 12.3 13.08 [Specification No. ] -##,(##) None : White (11) : Black (18) : Red 9 A B Purchase Unit 5.08 4.9 7.08 100pcs per bag 7.1 9.08 DF62/DF62W Series/2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces A Socket (Protected Lock Type) P=2.2 P=2 B Cavity No. Contact No. Marking Apr.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 7pos. shown as an example. Unit : mm Part No. HRS No. No. of Pos. DF62C-2S-2.2C(##) CL0544-0565-4-## 2 DF62C-3S-2.2C(##) CL0544-0566-7-## 3 DF62C-4S-2.2C(##) CL0544-0567-0-## 4 DF62C-5S-2.2C(##) CL0544-0568-2-## 5 DF62C-6S-2.2C(##) CL0544-0569-5-## 6 DF62C-7S-2.2C(##) CL0544-0570-4-## 7 DF62C-13S-2.2C(##) CL0544-0571-7-## 13 9.3 11.65 DF62C-24S-2.2C(##) CL0544-0541-6-## 24 12.3 13.65 [Specification No. ] -##,(##) None : White (11) : Black (18) : Red 10 A B Purchase Unit 5.65 4.9 7.65 100pcs per bag 7.1 9.65 DF62/DF62W Series/2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces Socket (Waterproof Type) Contact No. Cavity No. B 14.05 A P=2.2 P=2.2 Apr.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 9pos. shown as an example. Unit : mm Part No. HRS No. No. of Pos. DF62W-2S-2.2C CL0544-1002-7-00 2 DF62W-3S-2.2C CL0544-1004-2-00 3 DF62W-4S-2.2C CL0544-1006-8-00 4 DF62W-6S-2.2C CL0544-1008-3-00 6 DF62W-9S-2.2C CL0544-1010-5-00 9 A B 7.55 7.5 9.75 9.7 11.95 Note : The waterproof type and non-waterproof type are not intermateable. ■ Position Number Pin Configuration (Shown from the Mating Side) 2pos. 3pos. 1 2 4pos. 1 2 3 φ9.2mm φ10.4mm φ10.8mm 6pos. 9pos. 1 2 1 2 3 1 2 3 3 4 4 5 6 4 5 6 7 8 9 φ11.6mm φ13.3mm Note : Applicable jacket outer diameter : ⌀ 1.4 to 1.6mm 11 Purchase Unit 100pcs per bag DF62/DF62W Series/2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces A Plug (Standard Type) 16.05 P=2.2 P=2 B Cavity No. Contact No. Marking Apr.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 7pos. shown as an example. Unit : mm Part No. HRS No. No. of Pos. DF62B-2EP-2.2C(##) CL0544-0558-9-## 2 DF62B-3EP-2.2C(##) CL0544-0559-1-## 3 DF62B-4EP-2.2C(##) CL0544-0560-0-## 4 DF62B-5EP-2.2C(##) CL0544-0561-3-## 5 DF62B-6EP-2.2C(##) CL0544-0562-6-## 6 DF62B-7EP-2.2C(##) CL0544-0563-9-## 7 DF62B-13EP-2.2C(##) CL0544-0564-1-## 13 10.4 11.3 DF62B-24EP-2.2C(##) CL0544-0540-3-## 24 13.4 13.3 [Specification No. ] -##,(##) None : Black (10) : White (18) : Red 12 A B Purchase Unit 5.3 6.0 7.3 100pcs per bag 8.2 9.3 DF62/DF62W Series/2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces A Plug (Panel Mount Type) Cavity No. Apr.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. P=2.2 P=2 B 16.05 Contact No. Marking Unit : mm Part No. HRS No. No. of Pos. DF62P-2EP-2.2C(##) CL0544-0543-1-## 2 DF62P-3EP-2.2C(##) CL0544-0544-4-## 3 DF62P-4EP-2.2C(##) CL0544-0545-7-## 4 DF62P-5EP-2.2C(##) CL0544-0546-0-## 5 DF62P-6EP-2.2C(##) CL0544-0547-2-## 6 DF62P-7EP-2.2C(##) CL0544-0548-5-## 7 DF62P-13EP-2.2C(##) CL0544-0549-8-## 13 15.7 11.3 DF62P-24EP-2.2C(##) CL0544-0550-7-## 24 18.7 13.3 [Specification No. ] -##,(##) None : Black (10) : White (18) : Red 13 A B Purchase Unit 5.3 11.3 7.3 100pcs per bag 13.5 9.3 DF62/DF62W Series/2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces Plug (Waterproof Type) P=2.2 P=2.2 B 23.05 A Cavity No. Apr.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Contact No. 9pos. shown as an example. Unit : mm Part No. HRS No. No. of Pos. A B DF62W-2EP-2.2C CL0544-1003-0-00 2 7.5 6.7 DF62W-3EP-2.2C CL0544-1005-5-00 3 8.0 DF62W-4EP-2.2C CL0544-1007-0-00 4 9.1 DF62W-6EP-2.2C CL0544-1009-6-00 6 DF62W-9EP-2.2C CL0544-1011-8-00 9 Purchase Unit 9.15 11.3 100pcs per bag 11.35 Note : The waterproof type and non-waterproof type are not intermateable. ■ Position Number Pin Configuration (Shown from the Mating Side) 2pos. 3pos. 2 1 4pos. 2 1 3 φ8.5mm 6pos. 2 1 3 2 1 3 2 1 4 3 6 5 4 6 5 4 9 8 7 φ10.2mm φ9.7mm 9pos. φ11.5mm φ12.8mm Note : Applicable jacket outer diameter : φ 1.4 to 1.6mm ■ Socket Position Number Pin Configuration (Shown from the Mating Side) 2pos. 3pos. 4pos. 5pos. 6pos. 7pos. 13pos. 1 2 1 2 3 1 2 3 4 1 2 3 4 5 1 2 3 4 5 6 1 2 3 4 5 6 7 1 2 3 4 5 6 7 8 9 10 11 12 13 24pos. 1 6 11 16 2 3 4 5 7 8 9 10 12 13 14 15 17 18 19 20 21 22 23 24 ■ Plug Position Number Pin Configuration (Shown from the Mating Side) 2pos. 3pos. 4pos. 2 1 2 1 3 2 1 4 3 3 5pos. 6pos. 7pos. 13pos. 24pos. 2 1 5 4 3 2 1 6 5 4 2 1 5 4 3 7 6 3 2 1 7 6 5 4 11 10 9 8 13 12 5 4 3 2 1 10 9 8 7 6 14 15 14 13 12 11 20 19 18 17 16 24 23 22 21 DF62/DF62W Series/2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces Apr.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■ Position No. Diagram No.1 No.2 No.3 No.4 No.5 No.6 No.8 No.10 No.11 No.12 No.13 No.15 No.16 No.20 No.21 No.22 No.23 No.24 15 No.7 DF62/DF62W Series/2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces Socket Crimping Contact (11.15) 3 Apr.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.83 1.5 7.45 ● Reel Contact, Applicable Tool : Applicator Applicable Wire (Tin Plated Annealed Copper) (Note 1) Part No. HRS No. Finish DF62-22SCF DF62-22SCFA CL0544-0520-6-00 CL0544-0506-5-00 DF62-2428SCF DF62-2428SCFA DF62-30SCF DF62-30SCFA Stranded Calculated Wire Structure Cross-section Jacket Diameter UL AWG Tin Plated Gold Plated 1061 22 17/0.16mm 0.342mm2 φ1.2 to φ1.45mm CL0544-0521-9-00 CL0544-0500-9-00 Tin Plated Gold Plated 1007 24 26 28 11/0.16mm 7/0.16mm 7/0.127mm 0.221mm2 0.141mm2 0.089mm2 φ0.9 to φ1.45mm CL0544-0522-1-00 CL0544-0508-0-00 Tin Plated Gold Plated 1007 30 7/0.1mm 0.055mm2 φ0.75 to φ1.2mm Purchase Unit 15,000pcs per reel Note 1 : When using cables not specified by Hirose, please contact a Hirose sales representative. ● Loose Piece, Applicable Tool : Hand Crimping Tool Applicable Wire (Tin Plated Annealed Copper) (Note 2) Part No. HRS No. Finish DF62-22SC DF62-22SCA CL0544-0572-0-00 CL0544-0526-2-00 DF62-2428SC DF62-2428SCA DF62-30SC DF62-30SCA UL AWG Stranded Wire Structure Calculated Cross-section Jacket Diameter Tin Plated Gold Plated 1061 22 17/0.16mm 0.342mm2 φ1.26mm CL0544-0573-2-00 CL0544-0527-5-00 Tin Plated Gold Plated 1007 24 26 28 11/0.16mm 7/0.16mm 7/0.127mm 0.221mm2 0.141mm2 0.089mm2 φ1.42mm φ1.28mm φ1.18mm CL0544-0574-5-00 CL0544-0528-8-00 Tin Plated Gold Plated 1007 30 7/0.1mm 0.055mm2 φ0.82mm Note 2 : The applicable cables include only those listed above. 16 Purchase Unit 100pcs per bag DF62/DF62W Series/2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces Socket Crimp Contact (For Waterproof Version) (11.5) 3 Apr.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.37 1.6 7.8 ● Reel Contact, Applicable Tool : Applicator Applicable Wire (Tin Plated Annealed Copper) (Note 1) Part No. DF62W-2022SCF DF62W-2022SCFA DF62W-2226SCF DF62W-2226SCFA HRS No. Finish CL0544-1015-9-00 CL0544-1027-0-00 Tin Plated Gold Plated CL0544-1000-1-00 CL0544-1025-0-00 Tin Plated Gold Plated UL AWG Stranded Wire Structure Calculated Cross-section 3443 20 7/0.32mm 0.563mm2 1007 22 17/0.16mm 0.342mm2 1007 22 24 17/0.16mm 11/0.16mm 0.342mm2 0.221mm 1430 24 26 11/0.16mm 7/0.16mm 0.221mm2 0.141mm2 2 Jacket Diameter φ1.4 to φ1.6mm Purchase Unit 15,000pcs per reel Note 1 : When using cables not specified by Hirose, please contact a Hirose sales representative. Note 2 : There are cases in which use of a flexible wire (thin, stranded conductor or soft jacket material) may make insertion to socket difficult. Please contact a Hirose representative for more information. Note 3 : The waterproof type and non-waterproof type are a not intermateable. ● Loose Piece, Applicable Tool : Hand Crimping Tool Applicable Wire (Tin Plated Annealed Copper) (Note 4) Part No. DF62W-2022SC DF62W-2022SCA DF62W-2226SC DF62W-2226SCA HRS No. Finish CL0544-1017-4-00 CL0544-1045-0-00 Tin Plated Gold Plated CL0544-1012-0-00 CL0544-1044-0-00 Tin Plated Gold Plated UL AWG Stranded Wire Structure Calculated Cross-section Jacket Diameter 3443 20 7/0.32mm 0.563mm2 φ1.53mm 1007 22 17/0.16mm 0.342mm2 φ1.58mm 1007 22 24 17/0.16mm 11/0.16mm 0.342mm2 0.221mm2 φ1.58mm φ1.42mm 1430 26 7/0.16mm 0.141mm2 φ1.48mm Note 4 : The applicable cables include only those listed above. 17 Purchase Unit 100pcs per bag DF62/DF62W Series/2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces Apr.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Plug Crimping Contact ● Reel Contact, Applicable Tool : Applicator Applicable Wire (Tin Plated Annealed Copper) (Note 1) Part No. HRS No. Finish DF62-EP22PCF DF62-EP22PCFA CL0544-0523-4-00 CL0544-0507-8-00 Tin Plated Gold Plated DF62-EP2428PCF DF62-EP2428PCFA CL0544-0524-7-00 CL0544-0501-1-00 DF62-EP30PCF DF62-EP30PCFA CL0544-0525-0-00 CL0544-0509-3-00 UL AWG Stranded Wire Structure Calculated Cross-section Jacket Diameter 1061 22 17/0.16mm 0.342mm2 φ1.2 to φ1.45mm Tin Plated Gold Plated 1007 24 26 28 11/0.16mm 7/0.16mm 7/0.127mm 0.221mm2 0.141mm2 0.089mm2 φ0.9 to φ1.45mm Tin Plated Gold Plated 1007 30 7/0.1mm 0.055mm2 φ0.75 to φ1.2mm Purchase Unit 15,000pcs per reel Note 1 : When using cables not specified by Hirose, please contact a Hirose sales representative. ● Loose Piece, Applicable Tool : Hand Crimping Tool Applicable Wire (Tin Plated Annealed Copper) (Note 2) Part No. HRS No. Finish DF62-EP22PC DF62-EP22PCA CL0544-0575-8-00 CL0544-0529-0-00 DF62-EP2428PC DF62-EP2428PCA DF62-EP30PC DF62-EP30PCA UL AWG Stranded Wire Structure Tin Plated Gold Plated 1061 22 17/0.16mm 0.342mm2 φ1.26mm CL0544-0576-0-00 CL0544-0530-0-00 Tin Plated Gold Plated 24 26 28 11/0.16mm 7/0.16mm 7/0.127mm 0.221mm2 1007 0.141mm2 0.089mm2 φ1.42mm φ1.28mm φ1.18mm CL0544-0577-3-00 CL0544-0529-0-00 Tin Plated Gold Plated 1007 30 7/0.1mm 0.055mm2 φ0.82mm Note 2 : The applicable cables include only those listed above. 18 Calculated Cross-section Jacket Diameter Purchase Unit 100pcs per bag DF62/DF62W Series/2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces Plug Crimping Contact (For Waterproof Version) (15.3) 11.6 Apr.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.37 1.6 3 ● Reel Contact, Applicable Tool : Applicator Applicable Wire (Tin Plated Annealed Copper) (Note 1) Part No. HRS No. Finish DF62W-EP2022PCF DF62W-EP2022PCFA CL0544-1016-1-00 CL0544-1028-0-00 Tin Plated Gold Plated DF62W-EP2226PCF DF62W-EP2226PCFA CL0544-1001-4-00 CL0544-1026-0-00 Tin Plated Gold Plated UL AWG Stranded Wire Structure Calculated Cross-section 3443 20 7/0.32mm 0.563mm2 1007 22 17/0.16mm 0.342mm2 1007 22 24 17/0.16mm 11/0.16mm 0.342mm2 0.221mm2 1430 24 26 11/0.16mm 7/0.16mm 0.221mm2 0.141mm2 Jacket Diameter φ1.4 to φ1.6mm Purchase Unit 15,000pcs per reel Note 1 : When using cables not specified by Hirose, please contact a Hirose sales representative. Note 2 : There are cases in which use of a flexible wire (thin, stranded conductor or soft jacket material) may make insertion to socket difficult. Please contact a Hirose representative for more information. Note 3 : The waterproof type and non-waterproof type are not intermateable. ● Loose Piece, Applicable Tool : Hand Crimping Tool Applicable Wire (Tin Plated Annealed Copper) (Note 4) Part No. DF62W-EP2022PC DF62W-EP2022PCA DF62W-EP2226PC DF62W-EP2226PCA HRS No. Finish CL0544-1018-7-00 CL0544-1043-0-00 Tin Plated Gold Plated CL0544-1013-3-00 CL0544-1042-0-00 Tin Plated Gold Plated UL AWG Stranded Wire Structure Calculated Cross-section Jacket Diameter 3443 20 7/0.32mm 0.563mm2 φ1.53mm 1007 22 17/0.16mm 0.342mm 2 φ1.58mm 1007 22 24 17/0.16mm 11/0.16mm 0.342mm 2 0.221mm2 φ1.58mm φ1.42mm 1430 26 7/0.16mm 0.141mm2 φ1.48mm Note 4 : The applicable cables include only those listed above. 19 Purchase Unit 100pcs per bag DF62/DF62W Series/2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces Straight Pin Header 2.6 A □0.5 B Cavity No. C P=2 Contact No.1 Marking Contact No. Marking P=2.2 Unit : mm Part No. Tin Gold Purchase Plating Plating Unit HRS No. No. of Pos. A B C DF62-13P-2.2DSA(##) CL0544-0582-0-## 13 11.5 8.8 11.8 ○ - 100pcs per tray DF62-24P-2.2DSA(##) CL0544-0584-0-## 24 14.5 10.8 13.8 ○ - 80pcs per tray [Specification No. ] -##,(##) None : Tin Plating (01) : Gold Plating               Note : Please contact a Hirose representative for requests on gold plating pin count variations that have not been released. ■ Recommended PCB Layout   (Recommended Thickness t=1.6mm) [13pos.] 4.4±0.05 Connector Outline 6±0.05 P=2.2±0.05 P=2±0.05 13× φ0 .8 P=2.2±0.05 6.6±0.05 [24pos.] 8.8±0.05 Connector Outline P=2.2±0.05 8±0.05 P=2±0.05 Apr.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 13pos. shown as an example. 24 ×φ 0.8 + 0 - 0 .1 P=2.2±0.05 6.6±0.05 20 DF62/DF62W Series/2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces Right Angle Pin Header C A Cavity No. Contact No.1 Marking B t=0.47 2.4 P=2.2 3.6 P=2 Contact No. Marking □0.5 Unit : mm Part No. Tin Gold Purchase Plating Plating Unit HRS No. No. of Pos. A B C DF62-13P-2.2DS(##) CL0544-0581-0-## 13 11.5 12.9 19.5 ○ - DF62-24P-2.2DS(##) CL0544-0583-0-## 24 15.4 14.9 23.5 ○ ○ [Specification No. ] -##,(##) None : Tin Plating (01) : Gold Plating Note : Please contact a Hirose representative for requests on gold plating pin count variations that have not been released. ■ Recommended PCB Layout   (Recommended Thickness t=1.6mm) [13pos.] 4.4±0.05 P=2.2±0.05 13× φ0 +0 .9 .1 -0 P=2.2±0.05 3.045±0.05 6.6±0.05 P=2±0.05 7.45±0.05 6±0.05 1.945±0.05 φ3± 0.0 5 Connector Outline [24pos.] 8.8±0.05 4.145±0.05 P=2.2±0.05 24× φ0 +0 .9 .1 -0 P=2±0.05 9.45±0.05 8±0.05 Apr.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 13pos. shown as an example. P=2.2±0.05 3.045±0.05 6.6±0.05 φ3± 0.0 5 Connector Outline 21 100pcs per tray DF62/DF62W Series/2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces Straight Pin Header (Waterproof Type) A B 15.5 Contact No1. Marking P=2.2 Cavity No. P=2.2 9pos. shown as an example. Unit : mm Part No. DF62WZ-9P-2.2DSA(##) HRS No. No. of Pos. A B CL0544-1050-0-## 9 12 12.1 [Specification No. ] -##,(##) (20) : Tin Plating (50) : Gold Plating ■ Recommended PCB Layout   (Recommended Thickness t=1.6mm) [9pos.] - 0 .1 +0.1 -0 0.8 9×φ Connector Outline P=2.2±0.05 P=2.2±0.05 P=2.2±0.05 P=2.2±0.05 5.05±0.05 φ1 .8 +0 4.5±0.05 Apr.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2.85 □0.5 22 Tin Plating Gold Plating Purchase Unit ○ ○ 200pcs per tray DF62/DF62W Series/2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces Waterproof Pin 29 (Waterproof Surface) 30 φ16.5 30 Apr.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. φ17 CAV No. φ16.5 Part No. DF62W-WP HRS Logo HRS No. CL0544-1014-6-00 Purchase Unit 100pcs per bag Note : When using without the crimp contact inserted, fill the contact hole of socket and plug with a waterproof pin. 23 DF62/DF62W Series/2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces Applicable Crimping Tool ● DF62 Type Applicator Apr.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Press Body Hand Tool Extraction Tool Part No. HRS No. Applicable Contact AP105-DF62-22 CL0901-4626-3-00 DF62-22SCFA/SCF DF62-EP22PCFA/PCF AP105-DF62-2428 CL0901-4625-0-00 DF62-2428SCFA/SCF DF62-EP2428PCFA/PCF AP105-DF62-30 CL0901-4627-6-00 DF62-30SCFA/SCF DF62-EP30PCFA/PCF CM-105C CL0901-0001-0-00 - HT801/DF62-22(10) (Note 3) CL0550-0401-9-10 DF62-22SCA/SC DF62-EP22PCA/PC HT801/DF62-2428(10) (Note 4) CL0550-0400-6-10 DF62-2428SCA/SC DF62-EP2428PCA/PC HT801/DF62-30(10) (Note 5) CL0550-0402-1-10 DF62-30SCA/SC DF62-EP30PCA/PC DF62/RE-MD CL0902-4645-4-00 DF62-##SCFA/SCF/SCA/SC DF62-EP##PCFA/PCF/PCA/PC Note 1 : Issues with non-Hirose specified tools are outside the scope of warranty. Note 2 : Please conduct crimping work according to the "Crimping Quality Standard" (ETAD-H0642,ETAD-H0643)" and "Crimping Condition Table". Note 3 : The compatible wire is limited to UL1061 (22 AWG). Note 4 : The compatible wire is limited to UL1007 (24 to 28 AWG). Note 5 : The compatible wire is limited to UL1061 (30 AWG). ● DF62W Type Applicator Press Body Part No. HRS No. AP105-DF62W-2022 CL0901-4500-0-00 EHS899800H-UP (Note 2) - AP105-DF62W-2226 CL0901-4637-0-00 EHS888400H-UP (Note 2) - DF62W-2226SCF(A) DF62W-EP2226PCF(A) CM-105C CL0901-0001-0-00 - HT802/DF62W-2022 (Note 4) CL0550-0431-0-00 DF62W-2022SC(A) DF62W-EP2022PC(A) HT802/DF62W-2226 (Note 5) CL0550-0416-6-00 DF62W-2226SC(A) DF62W-EP2226PC(A) CL0902-4666-4-00 DF62W-2022SC(F)(A) DF62W-EP2022PC(F)(A) DF62W-2226SC(F)(A) DF62W-EP2226PC(F)(A) Hand Tool Extraction Tool Applicable Contact DF62W/RE-MD DF62W-2022SCF(A) DF62W-EP2022PCF(A) Note 1 : Issues with non-Hirose specified tools are outside the scope of warranty. Note 2 : Applicator manufactured by JAPAN AUTOMATIC MACHINE(J.A.M.). Please contact J.A.M. via the URL below regarding inquiries on the applicator or crimp defects. (URL : http://www.jam-net.co.jp) Note 3 : Please conduct crimping work according to the "Crimping Quality Standard" (ETAD-H0762-00, ETAD-H0763-00)" and "Crimping Condition Table". Note 4 : The compatible wire is limited to UL3443 (20 AWG) or UL1007 (22 AWG). Note 5 : The compatible wire is limited to UL1007 (22 to 24 AWG) or UL1430 (24 to 26 AWG). 24 DF62/DF62W Series/2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces Crimping ■ Items Required Prior to Starting The work- related documents listed below are required before starting harness assembly. ( The ● mark indicates a required document. ) When the documents shown below are not available, ask a Hirose sales personnel to provide them. Apr.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Document Title Automatic Hand Crimping Crimping Machine Tool Description Remarks (1) Main unit of crimping machine instruction manual Explanation of main press machine unit ● - Bundled with the purchase of the main press machine unit. (2) Applicator Spare Parts Identification Explanation for Applicator installation ● - (3) Crimp Conditions Standard values of : Crimp height Tensile strength ● - (4) Crimp Quality Standards Various standards for crimping conditions ● - (5) Operating lnstructions for Hand Tool Inspection items of : Crimp height Tensile strength and others - ● Bundled with the purchase of hand tool. (6) Harness Procedure Manual DF62 Series : ETAD-H0593 DF62W Series : ETAD-H0760 Harness procedure ● ● Ask a HRS sales representative. Bundled with the purchase of applicator. ■ Tools The tools specified by Hirose should be used for crimping work. Crimping work by tools other than those specified must not be done because it may result in contact failure, disconnection of cable, etc. The operating instructions manual is available for the crimping machine and the applicator. Be sure to carefully read the operating instructions manual before implementing the work. ■ Applicable Electric Wires Check that the electric wire to be used is within the applicable range. If you intend to use an electric wire other than those recommended, ask a HRS sales personnel. [ Precautions] ・Electric wires that are suitable for crimping connectors are tin- plated stranded softcopper wire. ・Avoid crimping solid wires, wires with polyester threads or tin- coated wires. ・Avoid crimping two electric wires together. ・The crimp height setting value ( Note) may vary between tin- plated and gold- plated contacts even if the same electric wires are used. ・The crimp height setting value ( Note) may vary depending on the difference in the core wire configuration even if the computed cross- sectional area is the same. Note : The crimp height is an important item that determines crimping quality. We execute crimping tests for each electric wire to ensure the optimal value for the crimp height with high precision, thereby ensuring optimal setup values. 25 DF62/DF62W Series/2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces Apr.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Precautions 1. Recommended Soldering Conditions ■ Soldering profile when using an automatic soldering device Soldering temperature : 260℃ ; Soldering time: no more than 10 seconds ■ Hand soldering conditions Temperature of soldering iron : 300℃ , soldering time : no more than 3 seconds 2. Cleaning Conditions Please refer to the "Wire-to-Board Connector Guide". Cleaning with IPA is allowed. (Other cleaning agents are not recommended due to the fact that it may change the push/pull feeling. Please contact us when you use other cleaning agents.) 3. Important Notes 1. Caution is required for mating and un-mating the connector without it being mounting on a PCB. Doing so can damage or deform the contacts. 2. During hand soldering, do not apply excess amounts of flux which can migrate onto the connector. 3. This product may have a slight differences in color depending on the production lot. This difference does not have any influence on the performance. 4. Please refer to "DF62 Series Mating and Unmating Procedure Document" (ETAD-H0599) and "DF62W Series Mating / Unmating Operation Instruction Manual" (ETAD-H0761) for points on handling during mating operations. 4. Handling Instructions Please refer to the "Wire-to-Board Connector Guide". While taking in consideration Specifications mentioned in this catalog are reference values. When considering to order or use this product, please confirm the " Drawing" and " Product Specifications" sheets. Use an appropriate cable when using the connector in combination with cables. If considering usage of a non- specified cable, please contact your sales representative. If assembly process is done by jigs & tools which are not identified by Hirose assurance will not be given. Please consult with your Hirose sales representative if you are planning to use the product for any of the following applications. ( Automotive, medical, public infrastructure, aerospace/ defense, etc. ) Hirose will consider the validity of the warranty depending on the conditions. 26 DF62/DF62W Series/2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces [ JAPAN ] [ GERMANY ] Headquarters GERMAN Branch / STUTTGART Office HIROSE ELECTRIC CO., LTD HIROSE ELECTRIC EUROPE B.V. Phone : +81-3-3491-7675 http://www.hirose.com Phone : +49-711-456002-1 http://www.hirose.com/eu/ YOKOHAMA Center NUREMBERG Office HIROSE ELECTRIC CO., LTD HIROSE ELECTRIC EUROPE B.V. Phone : +81-45-620-3491 http://www.hirose.com Phone : +49-911-326889-63 http://www.hirose.com/eu/ [ TAIWAN ] TAIWAN Office HIROSE ELECTRIC (TAIWAN) CO., LTD. Phone : +886-2-2555-7377 http://www.hirose.com/tw/ [ KOREA ] KOREA Office HIROSE KOREA CO.,LTD. HANOVER Office [ USA ] Apr.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. U.S Headquarters / CHICAGO Office HIROSE ELECTRIC EUROPE B.V. Phone : +49-511-978261-30 http://www.hirose.com/eu/ HIROSE ELECTRIC ( U.S.A.), INC. Phone : +1-630-282-6700 http://www.hirose.com/us/ SAN JOSE Office [ SINGAPORE ] [ FRANCE ] SINGAPORE Office HIROSE ELECTRIC PARIS Office HIROSE ELECTRIC ( U.S.A.), INC. HIROSE ELECTRIC EUROPE B.V. Phone : +1-408-253-9640 http://www.hirose.com/us/ Phone : +33-1-85764886 http://www.hirose.com/eu/ DETROIT Office (AUTOMOTIVE) HIROSE ELECTRIC ( U.S.A.), INC. Phone : +1-734-542-9963 http://www.hirose.com/us/ HIROSE ELECTRIC ( U.S.A.), INC. SINGAPORE PTE. LTD. Phone : +65-6324-6113 http://www.hirose.com/sg/ [ THAILAND ] [ ITALY ] BANGKOK Liaison Office MILAN Office HIROSE ELECTRIC EUROPE B.V. BOSTON Office Phone : +82-31-496-7000 http://www.hirose.co.kr/ Phone : +39-02-36636350 http://www.hirose.com/eu/ HIROSE ELECTRIC SINGAPORE PTE. LTD. Phone : +66-2-686-1255 http://www.hirose.com/sg/ Phone : +1-978-655-9850 http://www.hirose.com/us/ [ CHINA ] DALLAS Office HIROSE ELECTRIC ( U.S.A.), INC. Phone : +1-972-324-3370 http://www.hirose.com/us/ IRVINE Office HIROSE ELECTRIC ( U.S.A.), INC. Phone : +1-949-930-3750 http://www.hirose.com/us/ CHINA Headquarters / SHANGHAI Branch HIROSE ELECTRIC ( CHINA ) CO., LTD. PENANG Representative Office Phone : +86-21-6391-3355 http://www.hirose.com/cn/ SINGAPORE PTE. LTD. EU Headquarters / AMSTERDAM OFFICE HIROSE ELECTRIC Phone : +60-4-648-5536 http://www.hirose.com/sg/ SHENZHEN Branch HIROSE ELECTRIC ( CHINA ) CO., LTD. Phone : +86-755-8207-0851 http://www.hirose.com/cn/ [ INDIA ] BANGALORE Office BEIJING Branch [ THE NETHERLANDS ] [ MALAYSIA ] HIROSE ELECTRIC ( CHINA ) CO.,LTD. Phone : +86-10-5165-9332 Fhttp://www.hirose.com/cn/ HIROSE ELECTRIC INDIA PVT. LTD. Phone : +91-80-4120-1907 http://www.hirose.com/sg/ HIROSE ELECTRIC EUROPE B.V. Phone : +31-20-6557460 http://www.hirose.com/eu/ DELHI Office [ HONG KONG ] HONG KONG Office [ UNITED KINGDOM ] HIROSE ELECTRIC HONGKONG TRADING CO., LTD. UK Branch Phone : +852-2803-5338 http://www.hirose.com/hk/ HIROSE ELECTRIC EUROPE B.V. HIROSE ELECTRIC INDIA PVT. LTD. Phone : +91-120-660-8018 http://www.hirose.com/sg/ Phone : +44-1908-202050 http://www.hirose.com/eu/ 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN        https://www.hirose.com https://www.hirose-connectors.com ※ The contents of this catalog are current as of date of 12/ 2020. Contents are subject to change without notice for the purpose of improvements. 27 Apr.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. M E M O
DF62W-2S-2.2C 价格&库存
很抱歉,暂时无法提供与“DF62W-2S-2.2C”相匹配的价格&库存,您可以联系我们找货
DF62W-2S-2.2C
  • 5+7.74790
  • 25+7.62502
  • 50+7.46048
库存:285
DF62W-2S-2.2C
    库存:10000
