CJS-1201TA1
CJS-1201TA1
    NIDEC(尼得科)
    SMD,5.4x2.5mm
    滑动开关 SMD,5.4x2.5mm 单刀双掷 立贴
CJS-1201TA1 数据手册
SLIDE SWITCHES (SMD) RoHS compliant CJS INTERNAL STRUCTURE ① ② ⑤ ③ ⑥ ④ Part name Material ■ FEATURES ① Cover Polyphenylenesulphide ● RoHS compliant ● Easy to set slider with line marking ● With neutral detent type lined up to 1 pole 2contacts switch ● Compatible with most automatic pick & place machinery ● Compact and space saving SMD type ② Slider Polyamide ③ Housing ④ Slider contact ⑤ Fixed contact ⑥ Terminal pin Flammability UL94V-0 Polyphenylenesulphide Copper alloy, Gold-plated ■ PART NUMBER DESIGNATION C J S - 1 2 0 1 T B 1 Series name No. of poles 1:1 pole Structure 1:Non-washable type (Without seal tape) Standard type 2:Non-washable type (With seal tape) Blank : Washable type (With seal tape) No. of contacts 2:2 contacts Setting position 0:Top setting Shape of terminal A:J-hook B:Gull wing Neutral detent 0:Without neutral detent 1:With neutral detent SPDT : Single Pole Double Throw ※ Please refer to the LIST OF PART NUMBERS when placing orders. Form of packaging T:Taping (Reel) Blank:plastic bag — CJS SLIDE SWITCHES (SMD) ■ LIST OF PART NUMBERS No. of poles 1 No. of poles 1 No. of contacts 2 No. of contacts 2 Setting position Non-washable type (Without seal tape) Non-washable type (With seal tape) Neutral detent Form of packaging Without neutral detent Taping CJS-1200TA1 CJS-1200TB1 CJS-1200TA2 CJS-1200TB2 1000pcs./reel Plastic bag CJS-1200A1 CJS-1200B1 CJS-1200A2 CJS-1200B2 100pcs./pack A J-hook (    ) Gull wing ) A B (     J-hook (    ) Gull wing B (     ) Pieces in package Top setting Setting position With neutral detent Taping CJS-1201TA1 CJS-1201TB1 CJS-1201TA2 CJS-1201TB2 1000pcs./reel Plastic bag CJS-1201A1 CJS-1201B1 CJS-1201A2 CJS-1201B2 100pcs./pack Neutral detent Form of packaging Without neutral detent Taping CJS-1200TA CJS-1200TB 1000pcs./reel Plastic bag CJS-1200A CJS-1200B 100pcs./pack Taping CJS-1201TA CJS-1201TB 1000pcs./reel Plastic bag CJS-1201A CJS-1201B 100pcs./pack Washable type (With seal tape) A J-hook (    ) Gull wing B (     ) Pieces in package Top setting With neutral detent ※ Verify the above part numbers when placing orders. Taping version can be supplied only in reel unit. CJS SLIDE SWITCHES (SMD) ■ STANDARD SPECIFICATIONS Operating temp. range Storage temp. range Sealing Net weight ■ ELECTRICAL CHARACTERISTICS Contact rating Non-switching Switching Minimum − 40 ~ 85 °C Washable type available with seal tape Contact resistance Approx. 0.05g (CJS-1200) Approx. 0.06g (CJS-1201) Insulation resistance Dielectric strength ■ MECHANICAL CHARACTERISTICS Operating force DC50 V 100 mA DC6 V, 100 mA DC24 V, 25 mA DC20 mV 1 μ A 100 m Ω maximum 100 M Ω (DC100 V) minimum AC250 V, 60 s ■ ENVIRONMENTAL CHARACTERISTICS 5.9 N {0.6 kgf} maximum Vibration (Amplitude) 1.5 mmor (Acceleration) 98 m/s2, 10-500 Hz, 3 directions for 10 cycles each Stop strength 10 N {1.02 kgf}, 60 s Shock 490 m/s2, 11 ms 6 directions for 3 times each Solderability 245 ± 3 °C, 2 ~ 3 s Load life Continuous load 200 cycles, DC6 ± 0.5 V, 100 ± 10 mA Reflow:255 °C (Peak temperature) (Please refer to the profile below) Humidity Soldering heat − 10 ~ 65 °C, Relative humidity 0 ~ 96 %, 24 h for 10 cycles Manual soldering:350 ± 10 °C, 3 ~ 4 s High temp. exposure 85 °C, 96 h Shear (Adhesion) 5 N {0.51 kgf} 10 s Low temp. exposure − 40 °C, 96 h Substrate bending Width 90 mm, bend 3 mm, 5 s, 1 time Pull-off strength Thermal shock 5 N {0.51 kgf} 10 s { } : Reference only 〈Reflow profile for soldering heat evaluation〉 Temperature (℃) 250 200 150 100 50 Peak : 250 +5 0 ℃ Over 230 ℃ 180 ℃ 150 ℃ Pre Heating Zone 90 ± 30 s 30 ± 10 s Heating time Soldering Zone Reflow : two times maximum − 40 (0.5 h) ~ 85 °C (0.5 h), 5 cycles CJS SLIDE SWITCHES (SMD) ■ OUTLINE DIMENSIONS Unless otherwise specified, tolerance : ± 0.3 (Unit : mm) ● CJS-1200A1 3 – 0.6 ● CJS-1200B1 3 – 0.6 +0.1 –0.05 Production date code 2 – C +0.1 –0.05 C ② 2 0. 5 ① Terminal No.1 ③ – C Terminal No.1 Schematic ③ 5.4 4.2 Stroke 0.6 2.5 0.15 +0.1 –0.05 0.3 0 0.1 –0.1 2.5 max. 0.15 +0.1 –0.05 2.5 max. 0 0.1 –0.1 ① 2.5 1.1 ● CJS-1201A1 3.5 0.4 min. 0.4 min. ● CJS-1201B1 3 – 0.6 +0.1 –0.05 2 – C +0.1 –0.05 C ② Production date code 5 ① ③ Terminal No.1 Schematic C 0. 5 ① ③ Stroke 2.8 +0.3 0 0.15 +0.1 –0.05 0 –0.1 2.5 max. 0.15 +0.1 –0.05 2.5 0.6 0.3 0.6 0.3 2.5 max. 4.2 6 2.5 0.6 – Schematic Stroke 6 1.1 3.5 3.5 0.1 0.6 C ② Production date code 2 0. Terminal No.1 0 0.1 –0.1 5 2.8 +0.3 0 3.5 3 – 0.6 0. Schematic 0.3 5.4 Stroke 0.6 C ② Production date code 0.4 min. 0.4 min. 3.5 3.5 1200A□ 1201A□ 1200A□ 1201A□ 2.6 0 1.3 0 1.3 3-1 2.6 0.7 1.6 3-1 1.3 0.7 1.6 1.6 B type 1.6 A type 1.3 ■ RECOMMENDED P.C.B. PAD OUTLINE DIMENSIONS 3-1 3-1 0 0 3.5 3.5 (Unit : mm) 1200B□ 1201B□ 1200B□ 1201B□ Note) The zero point is the center of mounting. CJS SLIDE SWITCHES (SMD) ■ PACKAGING SPECIFICATIONS ● Taping version is packaged in 1000 pcs. per reel. Orders will be accepted for units of 1000 pcs., i.e., 1000, 2000, 3000 pcs., etc. ● Taping version is boxed with two reels (2000 pcs.). Maximum number of consecutive missing pieces=2 Leader length and reel dimension are shown in the diagrams below: ● Embossed tape dimensions ● Reel dimensions (Unit: mm) (Conforms to JIS C 0806) 17.4 ± 1 Empty End φ 13±0.2 Head 40 mm min. 2±0.5 20 pitches min. Leader 400 mm min. Direction of feed φ 50 min. Filled φ 254 ± 2 Empty φ 21±0.8 21.4 ± 1 ● CJS-1200TA□ , 1200TB□ , 1201TA□ , 1201TB□ 2 ± 0.1 0.3 ± 0.1 (CJS-1200B1) Installation example 16 8 ± 0.1 4 ± 0.1 1.75 ± 0.1 +0.1 0 7.5 ± 0.1 φ 1.5 (Unit: mm) (Conforms to JIS C 0806) Terminal No.1 Direction of feed ● Boxing of bulk pack in a plastic bag is performed with 100 pcs. (standard 500 pcs.) per box. 3
CJS-1201TA1 价格&库存
很抱歉,暂时无法提供与“CJS-1201TA1”相匹配的价格&库存,您可以联系我们找货
CJS-1201TA1
  • 1+16.90763
  • 10+16.55168
  • 25+15.19907
  • 50+15.02109
  • 100+14.83125
库存:581
CJS-1201TA1
  • 1+15.691201+2.02930
  • 10+15.4277010+1.99530
  • 25+14.1221025+1.82640
  • 100+13.76270100+1.77990
  • 250+12.62480250+1.63280
  • 500+8.72000500+1.12780
  • 1000+6.743601000+0.87220
  • 2000+6.168702000+0.79780
库存:1288
