FH58A-71S-0.2SHW
FH58A-71S-0.2SHW
    HRS(广濑)
    SMD,P=0.2mm,卧贴(交错脚)
    FPC/FFC连接器 间距:0.20mm 71Pin 翻盖式 卧贴
FH58A-71S-0.2SHW 数据手册
0.2mm/0.25mm Pitch, 0.9mm Height, Top and Bottom Contact, Back Flip, High FPC Retention Force Connector FH58/FH58M Series Maximizes board space by utilizing its low-profile, and narrow pitch and depth May.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3. 1m m(41 Cont acts) 0.9mm m 9.8m 0.2m m Fig.1 ■Features 1. Maximizes board space Multi-functional chucking metal  [FPC in place] The combination of a fine pitch of 0.2mm/0.25mm and narrow depth of 3.1mm saves board space. (Fig.1)   *The depth of long actuator type is 3.4mm. 2. High FPC retention force • Chucking metal at both side of the connector provides high FPC retention force. (Fig.2) Being movable, the chucking metal allows this connector to accept horizontal FPC insertions; it provides a clear tactile click and increased retention force when the FPC is inserted. Clear tactile click when inserting FPC  [Locked] 3. High reliability top and bottom contact structure • Top and bottom spring contacts follows up-and-down movement of the FPC to provide secure connectivity. (Fig.3) High FPC retention force in locked state 4. Supports high-speed transmissions • Excellent impedance characteristics enables high speed transmission. By utilizing differential pairs of identical contacts (eveneven contacts or odd-odd contacts) these connectors are able to provide superb transmission characteristics and have achieved compliance with the eDP (ver.1.3), MIPI (D-PHY) and USB3.0 standards. (Fig.4) 5. Environmentally friendly • Halogen-free All materials and substances used to produce this product comply with Halogen-free standards. *Defined in accordance with to IEC 61249-2-21. Br : 900 ppm max, Cl : 900 ppm max, Br+Cl : 1500 ppm max. Fig.2 High connection reliability with bottom spring contact. When bottom contact is used, FPC is lifted upward FPC in Unloaded state Lifted Secured contact Spring contact maintains connection Bottom contact is deflecting Fig.3 FH58 Differential impedance 130ps rise time(20−80%) Connector FPC Fig.4 In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2022.4 1 FH58/FH58M Series●0.2mm/0.25mm Pitch, 0.9mm Height, Top and Bottom Contact, Back Flip, High FPC Retention Force Connector ■Product Specifications Operating Temperature Range -55 to +85°C (Note 1) Storage Temperature Range -10 to +50°C (Note 2) Current rating 0.2A Operating Humidity Range Relative humidity 90% RH Storage Humidity Range Relative humidity 90% RH Voltage rating AC 30Vrms Rating or less (no condensation) Recommended FPC SPC t=0.2±0.02 Gold plated Items 1.Insulation Resistance 2.Withstanding Voltage May.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. or less (no condensation) Specifications Conditions 50MΩ min 100V DC No flashover or insulation breakdown 90Vrms AC/1min 3.Contact Resistance 300mΩ max (0.2mm pitch products) 200mΩ max (0.25mm pitch products) *Including FPC conductor resistance 1mA AC 4.Mechanical Operation Contact resistance : 300mΩ max (0.2 mm pitch products)   200mΩ max (0.25 mm pitch products) 10 times insertions and extractions. No damages, cracks and looseness of parts 5.Vibration Resistance Contact resistance : 300mΩ max (0.2 mm pitch products) Frequency : 10 to 55 Hz, half amplitude : 0.75 mm, 200mΩ max (0.25 mm pitch products) for 10 cycles in 3 axial directions. No damages, cracks and looseness of parts 6.Shock Resistance No electrical discontinuity of 1µs or longer Contact resistance : 300mΩ max (0.2 mm pitch products) Acceleration: 981 m/s2, duration 6 ms, half-sine 200mΩ max (0.25 mm pitch products) wave, at 3 times in 3 axial directions No damages, cracks and looseness of parts 7.Moisture Resistance in steady state Contact resistance : 300mΩ max (0.2 mm pitch products) 200mΩ max (0.25 mm pitch products) Insulation resistance : 50MΩ min No damages, cracks and looseness of parts 96 hours at 40°C and humidity of 90 to 95% 8.Temperature Cycles Contact resistance : 300mΩ max (0.2 mm pitch products) 200mΩ max (0.25 mm pitch products) Insulation resistance : 50MΩ min No damages, cracks and looseness of parts Temperature : -55→+15 to +35→+85→+15 to +35°C Time : 30 → 2 to 3 → 30 → 2 to 3 minutes 5 cycles with above conditions 9.Resistance to Soldering Heat No deformation of case or excessive looseness of the terminals Reflow : Recommended Temperature Profile Manual soldering : 350±10°C, 5 seconds Note 1 : Including temperature rise caused by current flow. Note 2 : The term “storage” refers to the long-term storage condition of unused products before PCB mounting. For no-electrification state after PCB mounting, the operating temperature and humidity are applied. ■Materials / Finish Parts Insulator Contact Metal fitting Material Treatment LCP PA Phosphor bronze Phosphor bronze Beige Black Nickel barrier gold plated Pure tin reflow plated UL Regulation UL94V-0 ーーー ■Part Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. FH 58 M A − 41S − 0.25 SHW (99) ❶ ❷ ❸ ❹ ❺ ❼ ❽ ❶ Series Name : FH ❺ No. of Contacts : 21,31,35,41,51,61,71 (0.2mm pitch),7 (0.25mm pitch) ❷ Series No. : 58 ❻ Contact Pitch : 0.2mm, 0.25mm ❸ No symbol : 0.2mm pitch M : 0.25mm pitch S : Housing reinforcement ❹ Actuator Type   No symbol : standard-type actuator     A : long-type actuator 2 ❻ ❼ Terminal Type   SHW…SMT horizontal staggered mounting type ❽ Specifications   None : Regular(5000 per reel) (99) : 500 per reel FH58/FH58M Series●0.2mm/0.25mm Pitch, 0.9mm Height, Top and Bottom Contact, Back Flip, High FPC Retention Force Connector ■Connector Dimensions 2.21±0.1 (E) (0.45) ( 90 Polarization mark 7 Contact point (0.36) HRS mark Contact point (1.03) Cavity No. (1.32) Number of contacts (1.54) May.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (0.12) D±0.15 (3.1:Actuator close) 2.47±0.1 2.62±0.1 C±0.15 0.9±0.1 Contact No.1 1.44±0.1(Vacuum pick up area) a (0.08) Lot No. °) a-a 2.13±0.15 Contact No.2 (0.08) a 0.3±0.1 A±0.15 B±0.15 (R) (0.08) 0.33±0.1 FH58(M) Series (0.2mm/0.25mm pitch, standard type actuator) (0.345) (FPC:t=0.2) Note 1 : The dimension in parentheses are for reference. 2 : Lead co-planarity including reinforced chucking metals shall be 0.1 max. 3 : To be delivered with tape and reel packages. See the packaging specifications for details. 4 : Note that preventive hole for sink mark or slit could be added for improvement. 5 : The quality remains good, even with the dark spots, which could occasionally occur on molded plastic. 6 : This product satisfies halogen free requirements defined as 900ppm maximum chlorine, 900ppm maximum bromine, and 1500ppm maximum total of chlorine and bromine. 7 : Shows hook part of the chucking metal. Units : mm Part No. FH58-21S-0.2SHW(**) FH58S-25S-0.2SHW(**) HRS No. No. of Contacts A B C D E 580-3812-0 ** 21 5.8 3.6 4 4.8 5.53 ー 25 6.8 4.4 4.8 5.6 6.33 FH58-31S-0.2SHW(**) 580-3806-9 ** 31 7.8 5.6 6 6.8 7.53 FH58-35S-0.2SHW(**) 580-3810-0 ** 35 8.6 6.4 6.8 7.6 8.33 FH58-41S-0.2SHW(**) 580-3801-5 ** 41 9.8 7.6 8 8.8 9.53 FH58-51S-0.2SHW(**) 580-3807-0 ** 51 11.8 9.6 10 10.8 11.53 FH58M-7S-0.25SHW(**) 580-3811-0 ** 7 3.5 1 1.5 2.5 3.23 R 0.2 0.25 Note : Contact positions without HRS No. are currently under planning and developing. Please contact hirose for detailed information about product variation. 3 FH58/FH58M Series●0.2mm/0.25mm Pitch, 0.9mm Height, Top and Bottom Contact, Back Flip, High FPC Retention Force Connector FH58A Series (0.2mm pitch, long actuator type) A±0.15 B±0.15 Polarization mark ** May.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (E) 0.33±0.1 2.21±0.1 ( (0.45) 7 Contact point 2.13±0.15 D±0.15 Cavity No. HRS mark 0.3±0.1 (0.36) Number of contacts Contact point (1.03) (0.12) (1.32) C±0.15 (1.84) Contact No. 1 0.9±0.1 a (0.08) 90 2.47±0.1 2.62±0.1 ° ) a−a 1.44±0.1 (Vacuum pick up area) Lot No. (0.08) Contact No. 2 (0.08) a (3.4:Actuator close) (R) (0.345) (FPC:t=0.2) Note 1 : The dimension in parentheses are for reference. 2 : Lead co-planarity including reinforced chucking metals shall be 0.1 max. 3 : To be delivered with tape and reel packages. See the packaging specifications for details. 4 : Note that preventive hole for sink mark or slit could be added for improvement. 5 : The quality remains good, even with the dark spots, which could occasionally occur on molded plastic. 6 : This product satisfies halogen free requirements defined as 900ppm maximum chlorine, 900ppm maximum bromine, and 1500ppm maximum total of chlorine and bromine. 7 : Shows hook part of the chucking metal. Units : mm HRS No. No. of Contacts A B C D E FH58A-61S-0.2SHW(**) 580-3803-0 ** 61 13.8 11.6 12 12.8 13.53 FH58A-71S-0.2SHW(**) 580-3804-3 ** 71 15.8 13.6 14 14.8 15.53 FH58SA-71S-0.2SHW(**) 580-3826-0 ** 71 16 13.6 14 14.8 15.53 FH58SA-81S-0.2SHW(**) ー 81 18 15.6 16 16.8 17.53 Part No. Note : Contact positions without HRS No. are currently under planning and developing. Please contact hirose for detailed information about product variation. 4 R 0.2 FH58/FH58M Series●0.2mm/0.25mm Pitch, 0.9mm Height, Top and Bottom Contact, Back Flip, High FPC Retention Force Connector FH58(A) Series (P=0.2mm pitch, standard/long type actuator) 0.4 Contact No.1 (n+1)/2X 0.02 X 2× 0.02 X 0.2±0.02 C±0.02 X 0.27±0.02 F B 0.18±0.01 0.4 Recommended stencil thickness:t=0.1 (n-1)/2X 0.02 Y (Land pattern image) (n+1)/2X 0.02 Y 0.18±0.01 0.4 C±0.02 Y F 2× 0.02 Y 0.25±0.01 2.37±0.01 (Connector image) (0.2) 0.51±0.01 (n-1)/2X 0.02 Y Contact No.2 0.2±0.02 1.85±0.02 (0.14) 0.65±0.02 0.56±0.01 0.4 2.37±0.01 (0.26) B (0.2) Recommended Stencil Pattern 0.52±0.01 0.65±0.02 Recommended PCB Mounting Pattern Recommended Dimensions of PCB Mounting Pattern and Stencil Pattern Part No. FH58-21S-0.2SHW(**) FH58S-25S-0.2SHW(**) FH58-31S-0.2SHW(**) FH58-35S-0.2SHW(**) FH58-41S-0.2SHW(**) FH58-51S-0.2SHW(**) FH58A-61S-0.2SHW(**) FH58A-71S-0.2SHW(**) FH58SA-71S-0.2SHW(**) FH58SA-81S-0.2SHW(**) HRS No. 580-3812-0 ** B 3.6 4.4 5.6 6.4 7.6 9.6 11.6 13.6 13.6 15.6 No. of Contacts 21 25 31 35 41 51 61 71 71 81 ー 580-3806-9 ** 580-3810-0 ** 580-3801-5 ** 580-3807-0 ** 580-3803-0 ** 580-3804-3 ** 580-3826-0 ** ー Units : mm C 4 4.8 6 6.8 8 10 12 14 14 16 F 4.87 5.67 6.87 7.67 8.87 10.87 12.87 14.87 14.87 16.87 Note : Contact positions without HRS No. are currently under planning and developing. Please contact hirose for detailed information about product variation. FH58M Series (P=0.25mm pitch, standard type actuator) Recommended Stencil Pattern (Connector image) 0.5 0.25±0.02 C±0.02 X F 0.27±0.02 Contact No.1 (n+1)/2X 0.02 X 2X 0.02 X B 0.5 0.23±0.01 Recommended stencil thickness:t=0.1 (n-1)/2X 0.02 Y (Land pattern image) 0.5 0.23±0.01 C±0.02 Y F 0.25±0.01 (n+1)/2X 0.02 Y 2X 0.02 Y 2.37±0.01 (n-1)/2X (0.25) 0.02 X Contact No.2 0.51±0.01 1.85±0.02 (0.14) 0.25±0.02 0.56±0.01 B 0.5 2.37±0.01 (0.26) (0.25) 0.52±0.01 0.65±0.02 Recommended PCB Mounting Pattern 0.65±0.02 May.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Note 8 : 'n' shows the number of contacts. Note 8 : 'n' shows the number of contacts. Recommended Dimensions of PCB Mounting Pattern and Stencil Pattern Part No. FH58M-7S-0.25SHW(**) HRS No. 580-3811-0 ** No. of Contacts 7 B 1 C 1.5 Units : mm F 2.52 5 FH58/FH58M Series●0.2mm/0.25mm Pitch, 0.9mm Height, Top and Bottom Contact, Back Flip, High FPC Retention Force Connector FH58(A) Series (P=0.2mm pitch, standard/long type actuator) Contact No.1(Bottom contact) Z 0.75±0.05 0.2±0.02 9 0.1±0.02 9 0.1±0.02 9 0.055±0.02 0.055±0.02 (n+1) /2× 0.02 Z Contact No.1(Top contact) ) 12 .05 .2) 5) R0 R0 0.0 ( ( R ( R0 .1 R0 ±0 .1 .1 ± 0. 1 (0.05) Contact No.2(Bottom contact) 0.08±0.1 0.65±0.1 May.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.2 ) .1 R0 ( .2) R0 ( (2.33) (0.1) 1.2±0.05 0.8±0.05 (0.1) 0.75±0.05 0.245±0.02 9 0.1±0.02 (0.05) R0.1 5±0 .1 R0 R0 12 .1± .1± 0.1 0.1 0.2 0.02 10 Q 2.63±0.3 (Stiffener) G±0.05 C±0.02 0.62±0.1 1.2±0.1 1.3±0.1 1.63±0.3(Exposed conductor) Recommended FPC Dimensions Contact No.2(Top contact) (0.1) 0.15±0.02 0.195±0.02 0.1±0.02 0.1±0.02 0.2±0.02 (n-1) /2× 0.02 Z B H±0.05 11 G±0.05 Note 9 Shows recommended dimensions when lead for plating is required. Note 10 Dimension Q must be 0.5mm minimum. Note 11 Indicated tolerance is applicable to the exposed conductor. Note 12 Both end sides of contact pad on FPC cannot be used for signal transmission. Recommended FPC Pattern Dimensions Part No. FH58-21S-0.2SHW(**) FH58S-25S-0.2SHW(**) FH58-31S-0.2SHW(**) FH58-35S-0.2SHW(**) FH58-41S-0.2SHW(**) FH58-51S-0.2SHW(**) FH58A-61S-0.2SHW(**) FH58A-71S-0.2SHW(**) FH58SA-71S-0.2SHW(**) FH58SA-81S-0.2SHW(**) HRS No. 580-3812-0 ** ー 580-3806-9 ** 580-3810-0 ** 580-3801-5 ** 580-3807-0 ** 580-3803-0 ** 580-3804-3 ** 580-3826-0 ** ー No. of Contacts 21 25 31 35 41 51 61 71 71 81 Units : mm B 3.6 4.4 5.6 6.4 7.6 9.6 11.6 13.6 13.6 15.6 C 4 4.8 6 6.8 8 10 12 14 14 16 G 5.5 6.3 7.5 8.3 9.5 11.5 13.5 15.5 15.5 17.5 H 4.51 5.31 6.51 7.31 8.51 10.51 12.51 14.51 14.51 16.51 Note : Contact positions without HRS No. are currently under planning and developing. Please contact hirose for detailed information about product variation. FPC Configuration (Reference example) MATERIAL NAME Covering film layer Cover adhesive Surface treatment Copper foil Base adhesive MATERIAL Polyimide 1mil 1μm to 6μm nickel underplated 0.2μm gold plated (4) Cu 1/2oz 18 No adhesion Heat-hardened adhesive material Polyimide  1mil 25 Base film Reinforcement Heat-hardened adhesive material adhesive Stiffener Polyimide 5mil 6 THICKNESS (μm) 25 25 30 125 FH58/FH58M Series●0.2mm/0.25mm Pitch, 0.9mm Height, Top and Bottom Contact, Back Flip, High FPC Retention Force Connector FH58M Series (P=0.25mm pitch, standard type actuator) ( R0 ( .05 R ) ( 0 .2 R0 ) .0 0.08±0.1 5) 0.65±0.1 0.62±0.1 1.2±0.1 1.3±0.1 10 Q 1.63±0.3(Exposed conductor) 2.63±0.3 (Stiffener) Recommended FPC Dimensions G±0.05 C±0.02 Contact No.1 (Bottom contact) May.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.2±0.02 (0.07) ) 0.1 (R .2) 0 (R (2.33) (0.1) 1.2±0.05 0.8±0.05 R0 (0.1) .1 ± R0 0. .1 1 ± 0. 1 0.85±0.07 0.3±0.02 9 0.1±0.02 (0.07) 12 R0.15±0.1 R0 R0. .1± 1± 0.1 0.1 Z (n+1) /2× 0.02 Z Contact No.1(Top contact) 12 0.85±0.07 0.27 +0.04 −0.03 9 0.1±0.02 9 0.1±0.02 9 0.07±0.02 0.07±0.02 0.25 Contact No.2(Bottom contact) Contact No.2(Top contact) (0.1) 0.185±0.02 0.25±0.02 0.1±0.02 0.1±0.02 +0.04 0.27 −0.03 (n-1) /2× 0.02 Z B H±0.05 11 G±0.05 Note 9 Shows recommended dimensions when lead for plating is required. Note 10 Dimention Q must be 0.5 mm minimum. Note 11 Indicated tolerance is applicable to the exposed conductor. Note 12 Both end sides of contact pad on FPC cannot be used for signal transmission. Recommended FPC Pattern Dimensions Part No. FH58M-7S-0.25SHW(**) HRS No. 580-3811-0 ** No. of Contacts 7 Units : mm B 1 C 1.5 G 3.2 H 2.21 FPC Construction (Recommended Specifications) MATERIAL NAME Covering film layer Cover adhesive Surface treatment MATERIAL Polyimide 1mil 1μm to 6μm nickel underplated 0.2μm gold plated Copper foil Cu 1oz Base adhesive Heat-hardened adhesive Base film Polyimide  1mil Reinforcement Heat-hardened adhesive material adhesive Stiffener Polyimide 3mil THICKNESS (μm) 25 25 (4) 35 25 25 40 75 Note 1. This specification is recommendation for the construction of the FH58/FH58M series FPC (t=0.2±0.02 mm) 2. For details about the construction, please contact FPC manufactures. 7 FH58/FH58M Series●0.2mm/0.25mm Pitch, 0.9mm Height, Top and Bottom Contact, Back Flip, High FPC Retention Force Connector FH58(M)(A) Series (0.2mm/0.25mm pitch, standard/long type actuator) Packaging Specifications ●Embossed Carrier Tape Dimensions May.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 㸩 ࠉ 0. 0 1 4±0.1 (2) K ±0.3 L ± 0.1 K ± 0.2 M ± 0.1 (J) (0.3) .5 1.75±0.1 8±0.1 Ø1 1.75±0.1 M ± 0.1 1 0. 㸩 0 ࠉ .5 Ø1 (J) (0.3) 8±0.1 4±0.1 (2) 5) 5) +0.1 0 (Ø 1 3) ●Reel Dimensions 1.7 (R 0.7 1.5 +0.15 0 0.7 (R ●Leader, Trailer Dimensions (N:Reel inner width) Direction of unreeling Direction of unreeling (Ø 380) (Ø 80) 400mm MIN(Leader) 160mm以上 (Trailer, empty components) Embossed carrier tape 100mm MIN Top cover tape (empty components) (P:Reel outer width) Units : mm Part No. FH58-21S-0.2SHW(**) FH58S-25S-0.2SHW(**) FH58-31S-0.2SHW(**) FH58-35S-0.2SHW(**) FH58-41S-0.2SHW(**) FH58-51S-0.2SHW(**) FH58A-61S-0.2SHW(**) FH58A-71S-0.2SHW(**) FH58SA-71S-0.2SHW(**) FH58SA-81S-0.2SHW(**) FH58M-7S-0.25SHW(**) No. of Contacts HRS No. 580-3812-0 ** 21 ー 25 580-3806-9 ** 31 580-3810-0 ** 35 580-3801-5 ** 41 580-3807-0 ** 51 580-3803-0 ** 61 580-3804-3 ** 71 580-3826-0 ** 71 ー 81 580-3811-0 ** 7 J L 16 1.69 1.99 1.69 M N P 7.5 17.4 21.4 11.5 25.4 29.4 ー 24 Note : Contact positions without HRS No. are currently under planning and developing. Please contact hirose for detailed information about product variation. 8 K 32 28.4 14.2 33.4 37.4 16 ー 7.5 17.4 21.4 FH58/FH58M Series●0.2mm/0.25mm Pitch, 0.9mm Height, Top and Bottom Contact, Back Flip, High FPC Retention Force Connector Temperature Profile MAX 250℃ Applicable Conditions Reflow method 250 230℃ Temperature(℃) Solder 200 : IR/Hot air Reflow environment : Room air : Paste type Sn/3.0Ag/0.5Cu (M705-GRN360-K2-V made by Senju 200℃ Metal Industry Co.) Test PCB 150 150℃ : PCB material and size Glass epoxy 32.85×18.3×0.8mm Land size, per recommended on page 5. Metal mask 100 : Thickness and opening size May.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Per recommended on page 5. 50 0 This temperature profile is based on the above conditions. 25℃ (60 sec.) 90 to 120 sec. Preheating time (60 sec.) Soldering time It may vastly depending on solder paste type, manufacturer, PCB size and mounting materials. Please use only after checking the mounting conditions. Start Time(sec.) 9 FH58/FH58M Series●0.2mm/0.25mm Pitch, 0.9mm Height, Top and Bottom Contact, Back Flip, High FPC Retention Force Connector Operation Methods of Connectors and Precautions Operation Methods This connector requires delicate and careful handling due to its small design. 1.Initial condition q Actuator does not have to be operated before inserting FPC, as the connector is delivered with the actuator opened.  [Caution] The actuator is in open state when embossed delivery. May.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. • Do not close the actuator before inserting FPC. Closing the actuator without FPC could make the contact gap smaller, which could increase the FPC insertion force. 2.How to insert FPC qKeeping level with the PCB, make sure to insert the FPC all the way.  [Caution] • Insert the FPC with the actuator opened. • During FPC insertion, do not twist the FPC to up and down, right and left or an angle. It may cause deformation of the contacts and contact failure. Actuator (Open) Actuator (Close) FPC FPC PCB PCB Correct Operation Incorrect Operation 3.FPC insertion check Chucking metals guide the FPC tabs to the correct position. Make sure that the FPC tabs are located in proper position as shown in the figure below after FPC insertion. Incomplete FPC insertion Correct FPC insertion FPC cutout NG Through the FPC cutout, PCB is visible 10 OK The FPC cutout is hidden by the connector housing and PCB is not visible from the cutout FH58/FH58M Series●0.2mm/0.25mm Pitch, 0.9mm Height, Top and Bottom Contact, Back Flip, High FPC Retention Force Connector Operation Methods 4.How to lock qApply load to rotate the actuator by 90 degree after inserting the FPC. May.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. • Operate the actuator by hand without using sharp tool such as Tweezers. • To close the actuator, operate at the center of the actuator. • To close the actuator, do not operate the actuator at one end only. • Do not apply excess force to the housing during the operation. Rotate Do not apply excess force to the housing during the operation Close the actuator at the center Do not operate the actuator at one end only 5.How to remove FPC (How to unlock FPC) qSlowly flip up the actuator to release the lock. After rotating the actuator to the fully opened position carefully withdraw the FPC. wTo open the actuator, operate at the center of the actuator. (Do not lift up only one side of the actuator. The actuator can be twisted causing damage.) *The actuator is opened up to the movable limit 90 degree. Do not open the actuator beyond the specified degree or apply excess force to the actuator. Rotate Open the actuator at the center Do not apply force to the direction as shown in the figure and / or try to open more than 90° Do not operate the actuator at one end only *This connector utilizes a back flip system; the actuator is placed on the side opposite of the FPC insertion opening. Do not attempt to open the actuator from the FPC insertion side. 11 FH58/FH58M Series●0.2mm/0.25mm Pitch, 0.9mm Height, Top and Bottom Contact, Back Flip, High FPC Retention Force Connector Operation Methods 6. FPC routing after connection qDepending on a FPC rounding, a load is applied to connector, and a contact failure may occur. To prevent a failure, take the following notes into a consideration during mechanism design. [Caution] • Make sure that FPC and stiffener do not contact chassis. • Avoid applying forces to FPC in vertical or horizontal directions. In addition, avoid pulling up and down on the FPC. • When fixing FPC after FPC cabling, avoid pulling FPC, and route the wire FPC with slack. In this regard, the stiffener is parallel to the PCB. • Do not mount other components touching to the FPC underneath the FPC stiffener. May.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. FPC stiffener stiffener FPC FPC PCB stiffener FPC PCB Component part PCB Cautions when Mounting PCB SWarp of PCB Minimize warp of the PCB as much as possible. Lead co-planarity including reinforced metals is 0.1mm or less. Too much wrap of the PCB may result in a soldering failure. SFlexible board design Please make sure to put a stiffener on the backside of the flexible board. We recommend a glass epoxy material with the thickness of 0.3mm MIN. SLoad to Connector Do not add 0.5N or greater external force when unreel or pick and place the connector etc, or it may get broken. In addition, do not insert the FPC or operate the connector before mounting. Connector SLoad to PCB • Splitting a large PCB into several pieces • Screwing the PCB Avoid the handling described above so that no force is exerted on the PCB during the assembly process. Otherwise, the connector may become defective. SInstructions on manual soldering Follow the instructions shown below when soldering the connector manually during work, etc. FPC (For connectormounting) qDo not perform manual soldering with the FPC inserted into the connector. wDo not heat the connector excessively. Be very careful not to let the soldering iron contact any parts other than connector leads. Otherwise, the connector may be deformed or melt. eDo not supply excessive solder (or flux). If excessive solder (or flux) is supplied on the terminals, solder or flux may adhere to the contacts or rotating parts of the actuator, resulting in poor contact or a rotation failure of the actuator. Supplying excessive solder to the chucking metals may hinder actuator rotation, resulting in breakage of the connector. 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN https://www.hirose.com/ 12 The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 04/2022. Contents are subject to change without notice for the purpose of improvements.
FH58A-71S-0.2SHW 价格&库存
很抱歉,暂时无法提供与“FH58A-71S-0.2SHW”相匹配的价格&库存,您可以联系我们找货
FH58A-71S-0.2SHW
库存:45
FH58A-71S-0.2SHW
  • 1+2.73049
  • 10+2.51549
  • 30+2.47249
  • 100+2.34349
库存:2
FH58A-71S-0.2SHW
  • 1+30.663761+3.97860
  • 10+26.0354310+3.37808
  • 25+24.4057125+3.16662
  • 50+23.2392550+3.01528
  • 100+22.13001100+2.87135
  • 250+20.74379250+2.69149
  • 500+19.75379500+2.56304
  • 1000+19.492821000+2.52918
库存:4553
FH58A-71S-0.2SHW
  • 1+3.92700
  • 100+3.26700
  • 1250+3.03600
  • 2500+2.88200
  • 5000+2.77200
FH58A-71S-0.2SHW
    库存:2488
