0.5mm Pitch Vertical Mating Connectors for Thin Wire Coaxial Cable
DF80 Series
Superb mating operability
¤&bb
¤&bb
May.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
O
■Features
N
1. Supports high speed connections
M
The single row alignment utilizes a 0.5mm pitch to
support 2.7Gbps & 5.4Gbps speeds and produces
excellent signal characteristics. Supports eDPTM
【Embedded DisplayPort TM 】version 1.3
Fig. 1
High contact reliability
2. Maximizes space
Designed to be a space saving connector, this
series features a 0.5mm pitch, a low-mated height,
and a single row layout in a vertical mating style.
1.72 ±0.08 (mated height)
3. Excellent mating operation
It features long mating guides and a generous lead
in opening that makes it easy to visually check the
connection. (Lead-in amount : ± 1mm)(Fig. 1)
(0.5) Effective mating
length
4. Reliable contact structure
The DF80 series utilizes its effective contact length
(0.5mm) and a 2 point type contact structure to
ensure high contact reliability.(Fig. 2)
5. Shield performance enhancement
Fig. 2
By utilizing multiple contacts between the plug and
receptacle shells, the shielding performance is
enhanced and creates a more reliable contact. (Fig. 3)
①
②
6. Durable plug structure
③
The plug has two metal covers around it to form a
rigid structure.
7. Secure locking system with a clear tactile
click
A tactile click ensures that the lock function has
been completed and is properly secured. This
system also produces excellent lock retention.
③
①
③
③
②
8. Structure supports a pull tab
The structure was designed to allow a pull tab to be
utilized to aid in un-mating the connector.
9. Halogen-free and RoHS compliant
All materials and substances used to produce these
parts comply with the Halogen-free and RoHS free
standards.
* Defined according to IEC 61249-2-21.
Br: 900 ppm or below, Cl : 900 ppm or below,
Br+Cl: 1,500 ppm or below
②
③
①
Multiple ground springs/points (8 places)
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2017.9③
Fig. 3
1
DF80 Series●0.5mm Pitch Vertical Mating Connectors for Thin Wire Coaxial Cable
■Product Specifications
【Discreet Cable】
32 AWG : 0.5A
36 AWG : 0.35A
【Thin wire coaxial cable】 (Note 3)
40 AWG : 0.2A
42 AWG : 0.2A
44 AWG : 0.15A
46 AWG : 0.1A
Rated
Current
Ratings
–35~+85ç (Note 1)
20 to 80%
Rated
Voltage
AC/DC 50V
1. Insulation Resistance
Minimum of 50Mø
Measured with DC 100V
2. Withstanding Voltage
No flashover or breakdown
Signal : Maximum of 80mø
GND : Maximum of 80mø
Apply AC 150V for 1 minute
Items
Storage Temperature Range −10~+60ç (Note 2)
Storage Humidity Range
40~70% (Note 2)
Specifications
3. Contact Resistance
4. Vibration Resistance
Operating Temperature Range
Operating Humidity Range
Conditions
100mA (DC or 1,000Hz) measurement
10 cycles in each of three directions at
frequency 10-55Hz, half amplitude 0.75mm
No electrical discontinuity of 1µs or greater
7. Durability
Contact resistance (difference from initial state)
Maximum of 50mø
Insulation resistance
Minimum of 25mø
50mø or below, Insulation resistance 25mø or
above
Contact Resistance : Maximum of 50mø
8. Soldering Heat
Resistance
Should be no melting of resin parts that affects
its performance
5. Humidity Resistance
6. Temperature Cycles
Left at temperature 40±2ç, humidity 90 to 95%,
96 hours
(−55ç : 30 minutes → 5~35ç : 2~3 minutes →
85ç : 30 minutes → 5~35ç : 2~3 minutes)
5 cycles
30 mating cycles
Reflow : according to the Recommended
Temperature Profile
Hand solder : Soldering iron temperature 350ç,
3 seconds
Note 1 : Includes the temperature rise caused by current flow.
Note 2 : The term “storage” refers to products stored for a long period prior to mounting and use. The operating temperature and
humidity range covers the non-energized condition of installed connectors in storage, shipment or during transportation
after board mounting.
Note 3 : With only the connector portion at an elevated temperature level, the rated current value is set.
■Materials / Finish
Product
Component
Materials
Finish
Specifications
Insulator
Contact
Metal fitting
Insulator
Contact
Outer Shell
Outer Shell
LCP
Phosphorous bronze
Phosphorous bronze
LCP
Phosphorous bronze
Stainless steel
Stainless steel
Black
Gold plating
Tin plating
Black
Gold plating
Tin plating
Tin plating
UL94V-0
Receptacle
Plug
Shell
------------------UL94V-0
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
●Connector
DF 80 − * S − 0.5 V (* *)
❶
❷
❸
❹
DF 80 − * P −
❶
❷
❸
❶ Series Name : DF
❷ Series No. : 80/80 D
❸ No. of Contacts : 30, 40, 50
❹ Connector Type
S : Receptacle
P : Plug
❺ Contact pitch : 0.5mm
2
❹
❺
❻
❼
SHL
❽
❻ Termination method
V : Vertical SMT
SD : Thin wire coaxial plug
❼ Packaging Type
(51) Embossed packaging
❽ Separately installed parts
SHL : Outer shell
■Receptacle (SMT)
A±0.1
B±0.1
C±0.1
D±0.1
Contact
No.1
P=0.5±0.05
t=0.1±0.015
5±0.1
1.65±0.1
0.5±0.05
0.58±0.05
0.5±0.05
【Specification No.】- **, (**)
(51) : Embossed packaging
Unit : mm
Part No.
HRS No.
No. of Contacts
A
B
C
D
E
DF80-30S-0.5V(**)
662-8004-0 **
30
21.00
20.94
16.10
14.50
DF80-40S-0.5V(**)
662-8001-2 **
40
26.00
25.94
21.10
19.50
DF80-50S-0.5V(**)
662-8007-9 **
50
31.00
30.94
26.10
24.50
F
G
4.40
7.10
15.88
9.40
12.10
20.88
14.40
17.10
25.88
Note 1 : This product is sold in full reel quantities of 5,000 pcs/reel. Please place orders by full reel quantities.
Contact pad
Connector outline
GND pad
(0.25)
0.135±0.02
P=0.5±0.02
0.25±0.02
1.08±0.02
A
H±0.05
J±0.05
(K) Pattern prohibited area
D±0.05
4.5±0.05
5.5±0.05
A(FREE)
L ±0.05 Pattern prohibited area
M±0.05
N±0.05
P±0.05
0.65±0.02
(0.55) Pattern prohibited area
BRecommended PCB layout
(1.45) Pattern prohibited area
(1.86) Vacuum pick up area
(E) Vacuum pick up area
F±0.1
G±0.1
B±0.1
Unit : mm
Part No.
HRS No.
No. of Contacts
H
J
K
D
L
M
5.00
7.60
N
P
DF80-30S-0.5V(**)
662-8004-0 **
30
21.54 15.70 15.38 14.50
DF80-40S-0.5V(**)
662-8001-2 **
40
26.54 20.70 20.38 19.50 10.00 12.60 20.48 26.54
DF80-50S-0.5V(**)
662-8007-9 **
50
31.54 25.70 25.38 24.50 15.00 17.60 25.48 31.54
15.48 21.54
3
■Plug
A±0.1(Contact area)
P=0.5±0.05(Contact area pitch)
A±0.1(Contact Termination area)
P=0.5±0.05(Contact Termination area pitch)
5.1±0.1
1.69±0.1
B±0.05
C±0.1
Unit : mm
Part No.
HRS No.
No. of Contacts
A
B
C
D
DF80D-30P-0.5SD(**)
662-8018-5 **
30
14.50
15.62
18.40
15.48
DF80D-40P-0.5SD(**)
662-8118-0 **
40
19.50
20.62
23.40
20.48
DF80D-50P-0.5SD(**)
662-8020-7 **
50
24.50
25.62
28.40
25.48
Note 2 : When terminating electric wire, the outer shell (DF80-*P-SHL) is required.
BRecommended wire preparation diagram
E(FREE)
Center conductor
(Pre-soldered)
D±0.1
A±0.15
E
0.05±0.05
P=0.5±0.07
2.5±0.05
1.35±0.05
0.8±0.05
Dielectric
Note 1 : Pre-soldering with lead free solder is required for the center conductor.
4
Outer shield (for individual conductor)
0.05 mm Max.
Jacket
0.57 ±0.03 (Ground bar thickness)
0.34±0.05
■Outer shell
1.51±0.1
3-1.2±0.1
0.6±0.03
3.59±0.05
4.74±0.05
A±0.05
B±0.03
C±0.03
D±0.03
Unit : mm
Part No.
HRS No.
No. of Contacts
A
B
C
D
DF80-30P-SHL
662-8006-6
30
18.40
DF80-40P-SHL
662-8003-8
40
23.40
4.50
6.50
11.07
8.00
10.00
16.07
DF80-50P-SHL
662-8009-4
50
28.40
10.00
12.00
21.07
Note 1 : This product is sold in full reel quantities of 10,000 pcs/reel. Please place orders by full reel quantities.
5
BEmbossed tape and reel dimensions (JIS C 0806/IEC60286 compliant)
●Reel Dimensions
8±0.1
.1
+0 0
4±0.1
2±0.1
Product label
Ø1
3±
0.
2
(2.25)
Ø1.5 holes for feed
mechanism on back
edge of carrier tape
R0
.75
0.2±0.05
+0
0 .1
2±
0.5
Ø2
1±
B±0.1
C±0.1
(Ø79)
A±0.1
.5
Ø1
Ø382MAX
1.75±0.1
●Receptacle
D +20
E MAX
Unreeling Direction
Unit : mm
Part No.
HRS No.
No. of Contacts
A
B
C
D
E
DF80-30S-0.5V(51)
662-8004-0 51
30
20.2
40.4
44.0
44.4
50.4
DF80-40S-0.5V(51)
662-8001-2 51
40
20.2
40.4
44.0
44.4
50.4
DF80-50S-0.5V(51)
662-8007-9 51
50
20.2
40.4
44.0
44.4
50.4
●Reel Dimensions
4±0.1
(2.5)
Product label
Ø1
3±
0.
2
(2.09)
Ø1.5 holes for feed
mechanism on back
8
Ø2
2±
1±
0.
B±0.1
C±0.3
D +20
E MAX
R0
.1
+00
.75
0.2±0.05
0.5
A±0.3
.5
(Ø79)
Ø1
Ø382MAX
8±0.1
1.75±0.1
●Plug
Unreeling Direction
Unit : mm
6
Part No.
HRS No.
No. of Contacts
A
B
C
D
E
DF80D-30P-0.5SD(51)
662-8018-5 51
30
20.2
40.4
44.0
44.4
50.4
DF80D-40P-0.5SD(51)
662-8118-0 51
40
20.2
40.4
44.0
44.4
50.4
DF80D-50P-0.5SD(51)
662-8020-7 51
50
20.2
40.4
44.0
44.4
50.4
BOperating Precautions
1. Recommended Soldering
Profile
MAX 250ç
(Supports lead-free mounting)
250
220ç
220
Temperature (ç)
200
180ç
180
150
150ç
100
90 to 120 seconds
Maximum of
60 seconds
Preheating time
Soldering time
Time (sec)
[Applicable Conditions]
1. Peak temperature : 250ç MAX
2. Heating parts : 220ç or above, within 60 seconds
3. Preheating parts : 150 to 180ç, 90 to 120 seconds
4. Number of times : No more than 2 times
*Solder composition : Sn- 3 Ag- 0.5 Cu
Note 1 : This temperature profile is recommended values.
2. Recommended hand solder
conditions
The maximum temperature of the soldering iron should be 350ç with a maximum
contact time of three seconds.
3. Recommended screen
thickness : Opening ratio
(pattern area ratio)
Thickness : 0.1mm, opening ratio : lead 100%, ground 100%
4. Leaning of PCB
Maximum of 0.02mm at the center of connector (using both edges of connector as
criteria)
5. Washing conditions
IPA washing OK. (Washing is not recommended as it may alter the tactile click feel
upon mating. Please contact your local rep if you plan on using another cleaning
agent.)
7
■Connector mating procedure
• When inserting the plug, press straight down on the entire surface of the plug until it is completely inserted.
• Do not press down on the wires when mating. Inserting the plug while pressing down on the wires may cause an
angled insertion to occur and may result in damage to the connector.
■Connector unmating procedure
• Un-mating the connector can be done in two different methods : unmating with fingers or with the pull tab.
• Do not pull/hold on the terminal wires during extraction. Doing so can lead to damaged or disconnected wires.
【Unmating with fingers】
Pull up on the extension hook that is part of the connectors plug.
Extension hook
• The extension hook is made of metal, so please use caution when manipulating it as it may cause damage to your nail or finger.
【Unmating with pull tab】
Pull up on the tab in the arrowed direction (vertically) to extract the plug.
■Do not mate and unmate this connector if it has not been mounted on a PCB, doing this can damage and
deform the contacts.
■Using excessive force while mating or unmating will damage the contacts or connector.
■When hand soldering, do not apply excessive amounts of flux. Doing so may promote solder wicking.
8
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose.com
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 09/2017. Contents are subject to change without notice for the purpose of improvements.
很抱歉,暂时无法提供与“DF80-40P-SHL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10000+1.4179610000+0.18380
- 20000+1.3502920000+0.17503
- 30000+1.3122430000+0.17009
- 50000+1.2658250000+0.16408
- 70000+1.2361570000+0.16023
- 国内价格 香港价格
- 1+2.376741+0.30807
- 10+1.9387010+0.25130
- 25+1.7837325+0.23121
- 50+1.6763050+0.21728
- 100+1.57675100+0.20438
- 250+1.45320250+0.18837
- 500+1.36666500+0.17715
- 1000+1.285041000+0.16657
- 2500+1.184742500+0.15357
- 国内价格 香港价格
- 1+2.994901+0.38820
- 10+2.5206210+0.32672
- 25+2.2245425+0.28835
- 50+2.0429350+0.26481
- 100+1.96278100+0.25442
- 250+1.76275250+0.22849
- 500+1.68235500+0.21807
- 1000+1.402081000+0.18174
- 2500+1.281862500+0.16616
- 国内价格
- 5+1.01661
- 50+0.81324
- 150+0.71151
