2SC1815
NPN GENERAL PURPOSE SWITCHING TRANSISTOR
VOLTAGE 60Volts POWER 200mWatts
FEATURES
NPN epitaxial silicon, planar design.
Collector-emitter voltage VCE=50V.
Collector current IC=0.15A.
Transition frequency f T >80MHz @
IC=1mAdc, VCE=10Vdc, f=30MHz.
In compliance with EU RoHS 2002/95/EC
directives.
MECHANICAL DATA
Case: SOT-23, Plastic
Terminals: Solderable per MIL-STD-750,
method 2026
Approx. Weight: 0.008gram
Marking:HF
3
C
HF
B
2
1
E
MAXIMUM RATINGS(Ta=25℃ unless otherwise noted)
Symbol
Parameter
Vaule
Unit
VCBO
Collector-Base Voltage
60
V
VCEO
Collector-Emitter Voltage
50
V
VEBO
Emitter-Base Voltage
5
V
0.15
A
IC
Collector Current
PC
Total Device Dissipation
RθJA
0.2
W
O
Thermal Resistance Form Junction to Ambient
625
C/W
TJ
Junction Temperature
150
O
TSTG
Storage Temperature
-55~+150
O
C
C
2SC1815
ELECTRICAL CHARACTERISTICS(Ta=25℃ unless otherwise specified)
Parameter
Collector-Base breakdown voltage
Symbol
Min. Typ.Max.Units
IC=100uA,IE=0
60
V
Collector-Emitter breakdown voltage V (BR)CEO
IC=1mA,IB=0
50
V
Emitter-Base breakdown voltage
V (BR)EBO
IE=100uA,IC=0
5
V
Collector cut-off current
ICBO
V CB=60V,IC=0
ICEX
Base cut-off current
IBEX
Emitter cut-off current
IEBO
V EB=5V,IC=0
HFE
IC=0.1mA,V CE=5V
40
HFE
IC=1.0mA,V CE=5V
70
HFE
IC=1mA,V CE=5V
130
HFE
IC=50mA,V CE=5V
60
HFE
IC=100mA,V CE=1.0V
30
DC current gain*
V (BR)CBO
Test Condition
Collector-Emitter saturation voltage V CE(SAT)
V CE=55V,IB=0
0.1
uA
0.1
uA
0.1
uA
0.1
uA
400
IC=20mA,IB=1mA
0.2
V
IC=100mA,IB=10mA
0.3
V
IC=20mA,IB=1mA
0.85
V
IC=100mA,IB=10mA
0.95
V
Base-Emitter Saturation voltage*
V BE(SAT)
Input capacitance
C IB
V CB=5V,IE=0,f=1MHZ
4.0
pF
Output capacitance
C OB
V EB=0.5V,IC=0,f=1MHZ
8.0
pF
Transition ferquency
fT
IC=1mA,V CE=10V,f=30MHZ
Delay time
td
Rise time
tr
V CC=3V,V BE=-0.5V,
IC=10mA,IB=1.0mA
Storage time
ts
Fall time
tf
V CC=3V,V BE=-0.5V,
IB1=IB2=1.0mA
80
MHZ
35
nS
35
nS
200
nS
50
nS
*Pulse Test: Pulse Width
很抱歉,暂时无法提供与“2SC1815”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.05152
- 100+0.04102
- 300+0.03519
- 3000+0.02897
- 6000+0.02596
- 9000+0.02430
- 国内价格
- 50+0.04722
- 600+0.03225
- 国内价格
- 1+0.12980
- 200+0.04290
- 1500+0.02684
- 3000+0.02123
