K1812L300/12DR
Unit:mm
1、Physical Dimensions(size of 1812)
A
Part Number
K1812L300/12DR
B
C
D
Min
Max
Min
Max
Min
Max
Min
4.37
4.73
3.07
3.41
0.60
1.00
0.30
Top and Bottom View
Side View
A
C
Marking
Marking
B
T300
D
2、Electrical Characteristics
IT
(A)
IH
(A)
Part Number
Vmax
(V)
I max
(A)
Ttrip
(Max time to trip)
Current(A)
Time(S)
3.00
6.00
12
100
8.0
5.00
IH: Holding Current: maximum current at which the device will not trip in 25℃ still air.
IT: Tripping Current minimum current at which the device will trip in 25℃ still air.
Vmax: Maximum voltage device can withstand without damage at rated current.
I max: Maximum fault current device can withstand without damage at rated voltage.
T trip: Maximum time to trip(s) at assigned current.
Pd typ: Rated working power.
R min: Minimum resistance of device prior to trip at 25℃.
R1 max: Maximum resistance of device is measured one hours post reflow at 25℃.
Noted: All electrical function test is conducted after PCB mounted.
K1812L300/12DR
Pd typ
(W)
R min
(Ω)
R1max
(Ω)
1.2
0.012
0.060
3、Thermal Derating
K1812L300/12DR
Hold Current(A)
Trip Current(A)
Maximum ambient operating temperature
-40℃
-20℃
0℃
25℃
40℃
50℃
60℃
70℃
85℃
4.40
8.80
3.90
7.80
3.50
7.00
3.00
6.00
2.60
5.20
2.30
4.60
2.10
4.20
1.80
3.60
1.50
3.00
4、Solder Reflow Recommendations
20-40s
260℃
Recommended Pad Layout(mm)
Critlcal Zone
1.5±0.05
Ramp-up
1.5±0.05
Temperature
217℃
60-150s
200℃
3.2±0.1
Ramp-down
Preheat
150℃
60-180s
2.7±0.1
25℃
8 minutes max
Time
Average Ramp-Up Rate:3 ℃/second max
Ramp-Down Rate:6 ℃ /second max
Notes:If reflow temperatures exceed the recommended
profile,devices may not meet the performance requirements.
5、Package Information
Packing quantity:1500PCS/Reel
Note:Reel packaging per EIA-481-1 standard
1/1
很抱歉,暂时无法提供与“K1812L300/12DR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.53428
- 100+0.49639
- 300+0.45850
- 500+0.42060
- 2000+0.40166
- 5000+0.39029
- 国内价格
- 1+0.47080
- 50+0.27720
- 1500+0.24970
- 国内价格
- 5+0.55322
- 50+0.44980
- 150+0.39809
- 1500+0.33336
- 3000+0.30237
- 4500+0.28678
