ZMM2V0-MS THRU ZMM75-MS
Semiconductor
Compiance
Silicon Epitaxial Planar Zener Diodes
in MiniMELF case especially for automatic insertion.
The Zener voltages are graded according to the
international E24 standard. Smaller voltage tolerances
and higher Zener voltages are upon request.
LL-34
REEL SPECIFICATION
P/N
PKG
QTY
LL34
2500
Absolute Maximum Ratings (Ta = 25 OC)
Parameter
Power Dissipation
Junction Temperature
Storage Temperature Range
1)
Value
Unit
Ptot
500 1)
mW
Tj
175
O
C
Tstg
- 55 to + 175
O
C
Symbol
Max.
Valid provided that electrodes are kept at ambient temperature
Characteristics at Ta = 25 OC
Parameter
Thermal Resistance Junction to Ambient Air
Forward Voltage
at IF = 100 mA
1)
Symbol
RthA
VF
0.3
1
1)
Unit
K/mW
V
www.msksemi.com
Semiconductor
Zener Voltage Range 1)
P/N
VZno
Dynamic Resistance
Reverse Leakage Current
Compiance
Temp. Coefficient
of Zener Voltage
VZT
at lZT
ZZT
ZZK
at IZK
Ta = 25 OC
Ta = 125 oC
at VR
(V)
(V)
(mA)
Max. (Ω)
Max. (Ω)
(mA)
Max. (µA)
Max. (µA)
(V)
TKvz (%/K)
ZMM2V0-MS
ZMM2V2-MS
ZMM2V4-MS
ZMM2V7-MS
2.0
2.2
2.4
2.7
1.8...2.15
2.08...2.33
2.28...2.56
2.5...2.9
5
5
5
5
85
85
85
85
600
600
600
600
1
1
1
1
100
75
50
10
200
160
100
50
1
1
1
1
-0.09...-0.06
-0.09...-0.06
-0.09...-0.06
-0.09...-0.06
ZMM3V0-MS
ZMM3V3-MS
ZMM3V6-MS
ZMM3V9-MS
ZMM4V3-MS
ZMM4V7-MS
ZMM5V1-MS
ZMM5V6-MS
ZMM6V2-MS
ZMM6V8-MS
ZMM7V5-MS
ZMM8V2-MS
ZMM9V1-MS
ZMM10-MS
ZMM11-MS
ZMM12-MS
ZMM13-MS
ZMM15-MS
ZMM16-MS
ZMM18-MS
ZMM20-MS
ZMM22-MS
ZMM24-MS
ZMM27-MS
ZMM30-MS
ZMM33-MS
ZMM36-MS
ZMM39-MS
ZMM43-MS
ZMM47-MS
ZMM51-MS
ZMM56-MS
ZMM62-MS
ZMM68-MS
ZMM75-MS
3.0
3.3
3.6
3.9
4.3
4.7
5.1
5.6
6.2
6.8
7.5
8.2
9.1
10
11
12
13
15
16
18
24
27
30
33
36
39
43
47
51
56
62
68
75
2.8...3.2
3.1...3.5
3.4...3.8
3.7...4.1
4...4.6
4.4...5
4.8...5.4
5.2...6
5.8...6.6
6.4...7.2
7...7.9
7.7...8.7
8.5...9.6
9.4...10.6
10.4...11.6
11.4...12.7
12.4...14.1
13.8...15.6
15.3...17.1
16.8...19.1
18.8...21.2
20.8...23.3
22.8...25.6
25.1...28.9
28...32
31...35
34...38
37...41
40...46
44...50
48...54
52...60
58...66
64...72
70...79
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
2.5
2.5
2.5
2.5
2.5
2.5
2.5
2.5
85
85
85
85
75
60
35
25
10
8
7
7
10
15
30
40
50
55
55
80
80
80
80
80
90
90
110
125
135
150
200
250
600
600
600
600
600
600
550
450
200
150
50
50
50
70
70
90
110
110
170
170
220
220
220
220
220
220
220
500
500
600
700
700
1000
1000
1000
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
4
2
2
2
1
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
40
40
40
40
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
5
5
5
10
10
10
10
10
1
1
1
1
1
1
1
1
2
3
5
6.2
6.8
7.5
8.2
9.1
10
11
12
13
15
16
18
24
27
30
33
36
39
43
47
51
56
-0.08...-0.05
-0.08...-0.05
-0.08...-0.05
-0.08...-0.05
-0.06...-0.03
-0.05...+0.02
-0.02...+0.02
-0.05...+0.05
0.03...0.06
0.03...0.07
0.03...0.07
0.03...0.08
0.03...0.09
0.03...0.1
0.03...0.11
0.03...0.11
0.03...0.11
0.03...0.11
0.03...0.11
0.03...0.11
0.03...0.11
0.04...0.12
0.04...0.12
0.04...0.12
0.04...0.12
0.04...0.12
0.04...0.12
0.04...0.12
0.04...0.12
0.04...0.12
0.04...0.12
0.04...0.12
0.04...0.12
0.04...0.12
0.04...0.12
m
1)
2)
Tested with pulses tp = 20 ms.
The ZMM1 is a silicon diode with operation in forward direction. Hence, the index of all parameters should be "F" instead of "Z". Connect the cathode
electrode to the negative pole.
www.msksemi.com
Semiconductor
Compiance
Breakdown characteristics
Tj = constant (pulsed)
mA
50
ZMM...
Tj=25o C
ZMM 2.7
ZMM 1
Iz
ZMM 3.9
ZMM 3.3
ZMM 6.8
ZMM 4.7
40
ZMM 8.2
ZMM 5.6
30
Test current Iz
5mA
10
2
3
4
5
6
7
8
10 V
9
Vz
mA
30
ZMM...
Tj=25o C
ZMM 10
ZMM 12
Iz
ZMM 15
ZMM 18
ZMM 22
ZMM 27
Test current Iz
5mA
10
ZMM 33
ZMM 36
40 V
Vz
www.msksemi.com
Semiconductor
Compiance
ZMM...
mA
10
Iz
Tj=25o C
ZMM 39
ZMM 51
ZMM 43
ZMM 47
8
Test current Iz
5mA
6
4
2
40
50
60
70
80
90
100 V
Vz
Admissible power dissipation
versus ambient temperature
Forward characteristics
at ambient temperature.
mA
10
ZMM...
mW
500
ZMM...
3
102
iF
Ptot
400
10
o
Tj=100 C
1
Tj=25
-1
10
10
300
o
C
200
-2
-3
10
100
10-4
10-5
0.4
0.6
0.8
VF
1V
200o C
100
Tamb
www.msksemi.com
Semiconductor
Pulse thermal resistance
versus pulse duration
Dynamic resistance
versus Zener current
Valid provided that the electrodes are kept
K/W
10
ZMM...
3
ZMM...
1000
o
Tj=25 C
7
5
5
4
rthA
rzj
3
2
2
7
5
5
4
0.1
3
3
0.05
2
2
0.02
10
3
100
0.2
4
4
2
0.5
10
0.01
10
2.7
ZMM1
V=0
7
3.6
4.7
5
5
4
tp
4
3
tp
V=
3
PI
T
2
10-5 10-4 10-3
-2
10
10
tp
0.1
10 S
1
2
5
1
2
5
10
Dynamic resistance
ZMM...
100
ZMM...
o
Tj=25 C
o
Tj=25 C
7
rzj
4
5
4
3
VR=1V
3
33
2
VR =2V
27
22
10
100
7
VR =2V
4
18
15
5
4
VR=1V
5
12
3
3
10
2
6.8/8.2
ZMM6.2
2
1
10
1
2345
10
100mA
5
2
Iz
5
2
ZMM5.6
1
-1
Capacitance versus
Zener voltage
pF
1000
5.1
2
T
1
Ctot
Compiance
2345
0.1 2
5
1
2
5
10
2
5
100mA
100V
Vz at Iz=5 mA
Iz
www.msksemi.com
Semiconductor
Thermal differential resistance
versus Zener voltage
Dynamic resistance
10
ZMM...
3
10
Tj=25o C
7
ZMM...
3
rzth=RthA.Vz.
5
Vz
Tj
4
5
3
4
rzj
Compiance
2
3
2
10
rzth
10
5
4
2
3
7
47+51
43
39
5
4
2
10
ZMM36
3
5
4
3
2
10
2
negative
positive
2
0.1
1
4 5
23
2
3
10mA
4 5
1
2345
1
Iz
2345
10
100V
Vz at Iz=5 mA
Dynamic resistance
Temperature dependence of Zener voltage
mV/K
ZMM...
100
ZMM...
25
7
5
rzj
Vz
Tj
4
3
5mA
Iz=1mA
20mA
15
2
10
10
7
5
5
4
3
Tj=25 C
Iz=5 mA
o
1
1
2
3
4 5
10
2
3
4 5
100V
Vz at Iz=5 mA
-5
1
23 45
10
23 45
100V
Vz at Iz=5 mA
www.msksemi.com
Semiconductor
mV/K
Change of Zener voltage
versus junction temperature
V
ZMM...
100
Compiance
ZMM...
9
Iz=5 mA
8
80
Vz bei Iz=5mA
7
Vz
Tj
Vz
60
51V
6
43V
5
36V
4
40
3
2
1
Iz=5 mA
-1
60
80
100V
60
o
80 100 120 140 C
Vz at Iz=5 mA
Tj
Change of Zener voltge from turn-on
up to the point of thermal equilibrium
V
ZMM...
0.8
25
X)
Vz=35 V
0.7
V
1.6
15
1.4
10
0.6
Vz
ZMM...
Vz=rzth.Iz
Iz=5 mA
1.2
Vz
0.5
1
8
0.4
7
0.3
6.2
0.2
5.9
0.1
5.6
-0.1
X) at Iz=5 mA
-0.2
60
80
1
3.6
4.7
o
100 120 140 C
0.8
0.6
0.4
0.2
-0.4
1
2
3
4 5
10
2
3
4 5
100V
Tj
Vz at Iz=5 mA
www.msksemi.com
Semiconductor
Compiance
V
ZMM...
5
Vz=rzth.Iz
4
Vz
3
Iz=5 mA
2
1
Iz=2 mA
60
80
100V
Vz at Iz=5 mA
www.msksemi.com
Semiconductor
Compiance
Attention
■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications
that can handle applications that require extremely high levels of reliability, such as life-support systems,
aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious
physical and/or material damage. Consult with your MSKSEMI Semiconductor representative
nearest
you
before using any MSKSEMI Semiconductor products described or contained herein in such applications.
■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products
at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or
other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described
orcontained herein.
■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the
performance, characteristics, and functions of the described products in the independent state, and are not
guarantees of the performance, characteristics, and functions of the described products as mounted in the
customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent
device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment.
■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all
semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to
accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause
damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents
or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention
circuitsfor safedesign, redundant design, and structural design.
■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described
or contained herein are controlled under any of applicable local export control laws and regulations, such
products must not be exported without obtaining the export license from theauthorities
concerned
in
accordance with the above law.
■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or
mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise,
without the prior written permission of MSKSEMI Semiconductor.
■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not
guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable,
but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or
other rightsof third parties.
■ Any and all information described or contained herein are subject to change without notice due to
product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the
MSKSEMI Semiconductor productthat you intend to use.
www.msksemi.com
很抱歉,暂时无法提供与“ZMM5V6-MS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.05243
- 500+0.04084
- 2500+0.03530
- 5000+0.03150
- 25000+0.02812
- 50000+0.02627
- 国内价格
- 50+0.05190
- 500+0.04000
- 2500+0.03570
- 5000+0.03290
- 25000+0.03140
- 国内价格
- 1+0.15620
- 100+0.05236
- 1250+0.03267
- 2500+0.02563
