LTC393YS8/R8
LTC393YS8/R8
    LINEARIN(先积)
    SOIC-8
    通用型,1.8V,轨至轨输入,开漏输出比较器
LTC393YS8/R8 数据手册
LTC331, LTC393 P-1 General Description The LTC331/393 single-/dual- channel comparators are drop-in, pin-for-pin compatible replacements for the LMV331/LMV393, and low-voltage versions of TL331/LM393. The devices with open-drain output offer the ultimate combination of high speed (100 ns propagation delay) and very low power consumption (37 μA), and feature such as rail-torail inputs, low offset voltage (typically 1 mV), large output drive current, and a wide range of supply voltages from 1.8 V to 5.5 V. The devices are very easy to implement in a wide variety of applications where require critical response time, power-sensitive, lowvoltage, and/or tight board space. Advantages of the LTC331/393 also include the added benefit of internal hysteresis provide noise immunity, preventing output oscillations even with slow-moving input signals. Designed with the most modern techniques, the LTC331/393 achieve superior performance over BiCMOS or bipolar versions on the market. The LTC331 (single) is available in both SOT23-5L and SC70-5L packages. The LTC393 (dual) is offered in DFN-8L, SOIC-8L, MSOP-8L and TSSOP-8L packages. All devices are rated over −40 ℃ to +85 ℃ industrial temperature range. Features and Benefits  Micro-power Operating Current (37 μA) Preserves Battery Power  Fast 100 ns Propagation Delay (100-mV Overdrive)  Single 1.8 V to 5.5 V Supply Voltage Range – Can be Powered From the Same 1.8V/2.5V/3.3V/5V System Rails  Rail-to-Rail Input  Open-Drain Output Current Drive: 30 mA Typically at 5V Supply  Internal Hysteresis for Clean Switching  Internal RF/EMI Filter  Operating Temperature Range: −40 ℃ to +85 ℃ Applications          Consumer Accessories Portable and Battery-Powered Devices Alarms and Monitoring Circuits Threshold Detectors and Discriminators Logic Level Shifting or Translation Zero-Crossing Detectors Window Comparators IR Receivers Line Receivers Pin Configurations (Top View) LTC331 LTC331R LTC393 LTC393 SOT23-5L / SC70-5L SOT23-5L DFN-8L SOIC-8L / MSOP-8L / TSSOP-8L +IN 1 –VS 2 –IN 3 5 4 +VS OUT –IN 1 –VS 2 +IN 3 5 4 +VS OUT OUTA 1 8 +VS –INA 2 7 OUTB OUT A 1 8 +VS +INA 3 6 –INB –IN A 2 7 OUT B –VS 4 5 +INB +IN A 3 6 –IN B –VS 4 5 +IN B CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. A B FN1617-38G.1a — Data Sheet General Purpose, 1.8V, RRI, Open-drain Output Comparators LTC331, LTC393 P-2 Pin Description Symbol Description –IN Negative input. The voltage range is from (VS– – 0.1V) to (VS+ + 0.1V). +IN Positive input. This pin has the same voltage range as –IN. +VS Positive power supply. –VS Negative power supply. OUT Comparator output. Ordering Information (3) Orderable Type Number Package Name Package Quantity Eco Class (1) Operating temperature Marking Code (2) LTC331YT5/R6 SOT23-5L 3 000 Green (RoHS & no Sb/Br) –40℃ to +85℃ CG7 LTC331YC5/R6 SC70-5L 3 000 Green (RoHS & no Sb/Br) –40℃ to +85℃ CG7 LTC331RYT5/R6 SOT23-5L 3 000 Green (RoHS & no Sb/Br) –40℃ to +85℃ CG9 LTC393YS8/R8 SOIC-8L 4 000 Green (RoHS & no Sb/Br) –40℃ to +85℃ CG8 Y LTC393YV8/R6 MSOP-8L 3 000 Green (RoHS & no Sb/Br) –40℃ to +85℃ CG8Y LTC393YT8/R6 TSSOP-8L 3 000 Green (RoHS & no Sb/Br) –40℃ to +85℃ CG8Y LTC393YF8/R6 DFN2x2-8L 3 000 Green (RoHS & no Sb/Br) –40℃ to +85℃ CG8 (1) Eco Class - The planned eco-friendly classification: Pb-Free (RoHS) or Green (RoHS & Halogen Free). (2) There may be multiple device markings, a varied marking character of “x” , or additional marking, which relates to the logo, the lot trace code information, or the environmental category on the device. (3) Please contact to your Linearin representative for the latest availability information and product content details. Limiting Value In accordance with the Absolute Maximum Rating System (IEC 60134). Parameter Absolute Maximum Rating Supply Voltage, VS+ to VS– 10.0 V Signal Input Terminals: Voltage, Current VS– – 0.3 V to VS+ + 0.3 V, ±10 mA Output Short-Circuit Continuous Storage Temperature Range, Tstg –65 ℃ to +150 ℃ Junction Temperature, TJ 150 ℃ Lead Temperature Range (Soldering 10 sec) 260 ℃ ESD Rating Parameter Electrostatic Discharge Voltage Item Value Human body model (HBM), per MIL-STD-883J / Method 3015.9 (1) ±5 000 Charged device model (CDM), per ESDA/JEDEC JS-002-2014 (2) ±2 000 Machine model (MM), per JESD22-A115C ±250 (1) JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process. (2) JEDEC document JEP157 states that 250-V CDM allows safe manufacturing with a standard ESD control process. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. Unit V FN1617-38G.1a — Data Sheet General Purpose, 1.8V, RRI, Open-drain Output Comparators LTC331, LTC393 P-3 Electrical Characteristics VS = 5.0V, TA = +25℃, unless otherwise noted. Boldface limits apply over the specified temperature range, TA = −40 to +85 ℃. Symbol Parameter Conditions Min. Typ. Max. ±5.0 Unit OFFSET VOLTAGE VOS Input offset voltage VCM = 0 ±1 VOS TC Offset voltage drift TA = −40 to +85 ℃ ±2 PSRR Power supply rejection ratio VS = 1.8 to 5.5 V, VCM < (VS+ − 1V) 70 TA = −40 to +85 ℃ 66 Hyst Input hysteresis VCM = 0 3 VCM = VS+ /2 5 mV μV/℃ 82 dB mV INPUT BIAS CURRENT IB Input bias current IOS Input offset current TA = −40 to +85 ℃ 30 800 VCM = VS+ /2 10 TA = −40 to +85 ℃ 50 1,000 pA pA INPUT VOLTAGE RANGE VCM CMRR Common-mode voltage range Common-mode rejection ratio VS––0.1 VS = 5.5 V, VCM = −0.1 to 5.5 V 61 VCM = 0 to 5.3 V, TA = −40 to +85 ℃ 58 VS = 1.8 V, VCM = −0.1 to 1.8 V 58 VCM = 0 to 1.6 V, TA = −40 to +85 ℃ 55 VS++0.1 V 78 dB 77 INPUT IMPEDANCE RIN CIN Input resistance Input capacitance 100 GΩ Differential 2.0 Common mode 3.5 ISINK = 1 mA 50 pF OUTPUT VOL Low output voltage swing ISC Output short-circuit current TA = −40 to +85 ℃ 80 90 Sink current –30 mV –25 mA 5.5 V POWER SUPPLY VS Operating supply voltage 1.8 VS = 1.8 V, VCM = 0.5V, IO = 0 IQ Quiescent current (per comparator) 32 TA = −40 to +85 ℃ VS = 5.5 V, VCM = 0.5V, IO = 0 40 50 37 TA = −40 to +85 ℃ 45 μA 60 SWITCHING CHARACTERISTICS tPD– Propagation delay time, High to low tF Fall time Input overdrive = 20 mV, CL = 15 pF Input overdrive = 100 mV, CL = 15 pF Input overdrive = 20 mV, CL = 15 pF Input overdrive = 100 mV, CL = 15 pF CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. 240 100 20 10 ns ns FN1617-38G.1a — Data Sheet General Purpose, 1.8V, RRI, Open-drain Output Comparators LTC331, LTC393 P-4 Electrical Characteristics (continued) VS = 5.0V, TA = +25℃, unless otherwise noted. Boldface limits apply over the specified temperature range, TA = −40 to +85 ℃. Symbol Parameter Conditions Min. Typ. Max. Unit +85 ℃ THERMAL CHARACTERISTICS TA θJA Operating temperature range Package Thermal Resistance -40 SC70-5L 333 SOT23-5L 190 DFN2x2-8L 80 MSOP-8L 216 TSSOP-8L 160 SOIC-8L 125 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. ℃/W FN1617-38G.1a — Data Sheet General Purpose, 1.8V, RRI, Open-drain Output Comparators LTC331, LTC393 P-5 Typical Performance Characteristics At TA=+25℃, VS=±2.5V, VCM=VS /2, RL=10kΩ connected to VS /2, and CL=15pF, unless otherwise noted. 60 60 VCM=0.5V +85℃ 40 30 +25℃ –40℃ 20 VS = 5V VOD = 50mV 55 Supply Current (μA) Supply Current (μA) 50 10 50 Output Low Voltage 45 40 35 Output High Voltage 30 25 0 1.5 2 2.5 3 3.5 4 4.5 5 5.5 0 6 1 Supply Current vs. Supply Voltage 4 5 350 VCM = VS / 2 VOD = 100mV 175 Propagation Delay L-H (ns) Propagation Delay H-L (ns) 3 Supply Current vs. Common-Mode Input 200 150 +85℃ 125 100 –40℃ 75 +25℃ 50 25 0 VCM = VS / 2 VOD = 100mV RPU = 5.1kΩ TA = +25℃ 300 250 200 150 tPD+ (L-H) 100 50 0 1.5 2 2.5 3 3.5 4 4.5 5 5.5 1.5 2 Supply Voltage (V) 500 425 400 375 tPD– (H-L) 350 3.5 4 4.5 5 5.5 900 Propagation Delay L-H (ns) 450 3 Propagation Delay (tPLH) vs. Supply Voltage VCM = VS / 2 VOD = 10mV TA = +25℃ 475 2.5 Supply Voltage (V) Propagation Delay (tPHL) vs. Supply Voltage Propagation Delay H-L (ns) 2 Common-Mode Voltage (V) Supply Voltage (V) 325 300 VCM = VS / 2 VOD = 10mV RPU = 5.1kΩ TA = +25℃ 800 700 600 500 tPD+ (L-H) 400 300 1.5 2 2.5 3 3.5 4 4.5 5 5.5 1.5 Supply Voltage (V) Propagation Delay (tPHL) vs. Supply Voltage 2 2.5 3 3.5 4 4.5 5 Supply Voltage (V) Propagation Delay (tPLH) vs. Supply Voltage CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. 5.5 FN1617-38G.1a — Data Sheet General Purpose, 1.8V, RRI, Open-drain Output Comparators LTC331, LTC393 P-6 Typical Performance Characteristics At TA=+25℃, VS=±2.5V, VCM=VS /2, RL=10kΩ connected to VS /2, and CL=15pF, unless otherwise noted. 500 VS = 5.0V Propagation Delay (ns) Propagation Delay (ns) 500 400 300 tPD– (H-L) 200 100 VS = 1.8V 400 300 tPD– (H-L) 200 100 0 0 10 100 1000 10 100 Overdrive Voltage (mV) Propagation Delay (tPHL) vs. Input Overdrive Propagation Delay (tPHL) vs. Input Overdrive 1000 190 VOD = 50mV 180 Propagation Delay (ns) Propagation Delay H-L (ns) 1000 Overdrive Voltage (mV) 170 160 150 140 130 VS = 5.0V VOD = 100mV 100 10 0.01 120 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 tPD– (H-L) 5 0.1 1 Output Capacitive Load (nF) Common-Mode Voltage (V) Propagation Delay (tPHL) vs. Input Common-Mode Propagation Delay (tPHL) vs. Capacitive Load 1000 VS = 1.8V VOD = 100mV 4 tPD– (H-L) 100 10 0.01 Output Voltage (V) Propagation Delay (ns) 5 0.1 1 +85℃ 2 –40℃ 1 0 0 5 Output Capacitive Load (nF) Propagation Delay (tPHL) vs. Capacitive Load +25℃ 3 10 15 20 25 30 35 40 45 Output Current (mA) Output Voltage vs. Output Sinking Current CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. 50 FN1617-38G.1a — Data Sheet General Purpose, 1.8V, RRI, Open-drain Output Comparators LTC331, LTC393 P-7 Typical Performance Characteristics At TA=+25℃, VS=±2.5V, VCM=VS /2, RL=10kΩ connected to VS /2, and CL=15pF, unless otherwise noted. 10 Short-Circuit Current (mA) Short-Circuit Current (mA) 50 VS = 5.0V 45 40 35 30 VS = 1.8V 8 6 4 2 0 25 -50 -25 0 25 50 75 100 -50 Temperature (℃) Short Circuit Current vs. Temperature -25 0 25 50 75 Temperature (℃) Short Circuit Current vs. Temperature CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. 100 FN1617-38G.1a — Data Sheet General Purpose, 1.8V, RRI, Open-drain Output Comparators LTC331, LTC393 P-8 Application Notes OPERATING VOLTAGE The LTC331/LTC393 micro-power comparators of open-drain output are fully specified and ensured for operation from 1.8 V to 5.5 V and offers an excellent speed-to-power combination with a propagation delay of 100 ns and a quiescent supply current of 37 μA. This combination of fast response time at micropower enables power conscious systems to monitor and respond quickly to fault conditions. In addition, and many specifications apply over the industrial temperature range of –40℃ to +85℃. Parameters that vary significantly with operating voltages or temperature are illustrated in the Typical Characteristics graphs. INPUT VOLTAGE The input common-mode voltage range of the LTC331/LTC393 family extends 100mV beyond the supply rails. This performance is achieved with a complementary input stage: an N-channel input differential pair in parallel with a P-channel differential pair. The N-channel pair is active for input voltages close to the positive rail, typically VS+– 1.4V to the positive supply, whereas the P-channel pair is active for inputs from 100mV below the negative supply to approximately VS+–1.4V. There is a small transition region, typically VS+–1.2V to VS+–1V, in which both pairs are on. This 200mV transition region can vary up to 200mV with process variation. Thus, the transition region (both stages on) can range from VS+–1.4V to VS+–1.2V on the low end, up to VS+–1V to VS+–0.8V on the high end. Within this transition region, PSRR, CMRR, offset voltage, offset drift, and THD can be degraded compared to device operation outside this region. INPUT VOLTAGE The LTC331/LTC393 comparator family uses CMOS transistors at the inputs which prevent phase inversion when the input pins exceed the supply voltages. VS+ D1 RS1 500Ω IN+ D2 D3 CCM1 RS2 CDM 500Ω IN– D4 CCM2 VS– Figure 1. Input EMI Filter and Clamp Circuit The LTC331/LTC393 comparators have internal ESD protection diodes (D1, D2, D3, and D4) that are connected between the inputs and each supply rail. These diodes protect the input transistors in the event of electrostatic discharge and are reverse biased during normal operation. This protection scheme allows voltages as high as approximately 300mV beyond the rails to be applied at the input of either terminal without causing permanent damage. See the table of Absolute Maximum Ratings for more information. EMI REJECTION RATIO Circuit performance is often adversely affected by high frequency EMI. When the signal strength is low and transmission lines are long, an amplifier must accurately amplify the input signals. However, all comparator pins — the non-inverting input, inverting input, positive supply, negative supply, and output pins — are susceptible to EMI signals. These high frequency signals are coupled into an comparator by various means, such as conduction, near field radiation, or far field radiation. For example, wires and printed circuit board (PCB) traces can act as antennas and pick up high frequency EMI signals. Amplifiers do not amplify EMI or RF signals due to their relatively low bandwidth. However, due to the nonlinearities of the input devices, comparators can rectify these out of band signals. When these high frequency signals are rectified, they appear as a dc offset at the output. The LTC331/LTC393 comparators have integrated EMI filters at their input stage. A mathematical method of measuring EMIRR is defined as follows: EMIRR = 20 log (VIN_PEAK / ΔVOS) INTERNAL HYSTERESIS Most high-speed comparators oscillate in the linear region because of noise or undesired parasitic feedback. This tends to occur when the voltage on one input is at or equal to the voltage on the other input. To counter the parasitic effects and noise, the devices have an internal hysteresis of 3 mV. The hysteresis in a comparator creates two trip points: one for the rising input voltage and one for the falling input voltage. The difference between the trip points is the hysteresis. The average of the trip points is the offset voltage. When the comparator’s input voltages are equal, the hysteresis effectively causes one comparator input voltage to move quickly past the other, thus taking the input out of the region where oscillation occurs. Standard comparators require hysteresis to be added with external resistors. To increase hysteresis and noise margin e v e n m o r e , a d d Figure 1 shows the input EMI filter and clamp circuit. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-38G.1a — Data Sheet General Purpose, 1.8V, RRI, Open-drain Output Comparators LTC331, LTC393 P-9 Application Notes positive feedback with two resistors as a voltage divider from the output to the non-inverting input. Figure 2 illustrates the case where IN– is fixed and IN+ is varied. If the inputs were reversed, the figure would look the same, except the output would be inverted. VTRIP+ VIN+ VHYST VOS VIN– = 0 VTRIP– VOS = (VTRIP+ + VTRIP–)/2 VOH Comparator Output VOL Figure 2. Input and Output Waveform, Non-inverting Input Varied MAXIMIZING PERFORMANCE THROUGH PROPER LAYOUT electric voltages on the circuit board. This voltage, also called Seebeck voltage, occurs at the junction of two dissimilar metals and is proportional to the temperature of the junction. The most common metallic junctions on a circuit board are solder-toboard trace and solder-to-component lead. If the temperature of the PCB at one end of the component is different from the temperature at the other end, the resulting Seebeck voltages are not equal, resulting in a thermal voltage error. This thermocouple error can be reduced by using dummy components to match the thermoelectric error source. Placing the dummy component as close as possible to its partner ensures both Seebeck voltages are equal, thus canceling the thermocouple error. Maintaining a constant ambient temperature on the circuit board further reduces this error. The use of a ground plane helps distribute heat throughout the board and reduces EMI noise pickup. INPUT-TO-OUTPUT COUPLING To minimize capacitive coupling, the input and output signal traces should not be parallel. This helps reduce unwanted positive feedback. To achieve the maximum performance of the extremely high input impedance and low offset voltage of the LTC331/LTC393 devices, care is needed in laying out the circuit board. The PCB surface must remain clean and free of moisture to avoid leakage currents between adjacent traces. Surface coating of the circuit board reduces surface moisture and provides a humidity barrier, reducing parasitic resistance on the board. The use of guard rings around the comparator inputs further reduces leakage currents. Figure 3 shows proper guard ring configuration and the top view of a surface-mount layout. The guard ring does not need to be a specific width, but it should form a continuous loop around both inputs. By setting the guard ring voltage equal to the voltage at the non-inverting input, parasitic capacitance is minimized as well. For further reduction of leakage currents, components can be mounted to the PCB using Teflon standoff insulators. Guard Ring +IN –IN +VS Figure 3. Use a guard ring around sensitive pins Other potential sources of offset error are thermoCAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-38G.1a — Data Sheet General Purpose, 1.8V, RRI, Open-drain Output Comparators LTC331, LTC393 P-10 Typical Application Circuits IR RECEIVER AFE AND WAKE- UP CIRCUIT Infrared (IR) communication is inherently immune to RF interference as long as there is a line-of-sight path between the transmitter and the receiver. It is also one of the lowest cost communication schemes. This makes it a good choice for implementing wireless communications in applications such as utility metering. A common system topology to extend battery life is to use a power efficient IR receiver analog front end (AFE) that is always on and wakes up the host only when there is a valid IR signal detected as shown in Figure 1. IR LED IR Receiver AFE Digital output (hardware wake-up event) GPIO MCU (Low Power) through R3. And finally R3 and R4 are used to introduce additional hysteresis to keep the output free of spurious toggles. VREF 3V Figure 4. Coin Cell Battery Powered IR Receiver R4 470kΩ 10MΩ 3V LTC331 Output to MCU (Also to wake-up MCU) R1 10MΩ C1 0.01μF Figure 5. IR Receiver AFE Using LTC331 USE WINDOW COMPARATOR TO DETECT UNDER-VOLTAGE AND OVER-VOLTAGE Window comparators are commonly used to detect undervoltage (UV) and overvoltage (OV) conditions. Figure 6 shows a simple window comparator circuit. Power efficient comparators such as the LTC331 /LTC393 can be used in the IR receiver AFE to increase battery life. The LTC331/LTC393 device is responsible for two major tasks: 1. IR signal conditioning, 2. Host system wake-up. The LTC331/LTC393 device is constantly powered to always be ready to receive IR signals and wake up the host microcontroller (MCU) when data is received. The short working distance (approx 5 cm) is suitable for a virtual-contact operation where the IR transmitter and receiver are closely placed with an optional mechanical alignment guide. R3 470kΩ IR LED + 10MΩ R2 3.3V LTC393 R1 RPU VS+ + UV_OV – Sensor VS– R2 MicroController VS+ + – R3 Figure 1 shows the IR receiver system block diagram. The host MCU is normally in the shutdown mode (during which the quiescent current is less than 1 μA) except when data is being transferred. VS– Figure 6. Window Comparator Figure 2 shows the detailed circuit design. The circuit establishes a threshold through R2 and C1 which automatically adapts to the ambient light level. To further reduce BOM cost, this example uses an IR LED as the IR receiver. The IR LED is reverse-biased to function as a photodiode (but at a reduced sensitivity). For this design, follow these design requirements: The low input bias current allows a greater load resistor value (R1) without sacrificing linearity, which in turn helps reduce the always-on supply current. Configure the circuit as shown in Figure 6. Connect VS+ to a 3.3-V power supply and VS– to ground. Make R 1, R2 and R3 each 10-MΩ resistors. These three resistors are used to create the positive and negative thresholds for the window comparator (VTH+ and VTH–). With each resistor being equal, VTH+ is 2.2 V and VTH– The load resistor R1 converts the IR light induced current into a voltage fed into the inverting input of the comparator. R2 and C1 establish a reference voltage VREF which tracks the mean amplitude of the IR signal. The non-inverting input is connected to VREF • Alert (logic low output) when an input signal is less than 1.1 V • Alert (logic low output) when an input signal is greater than 2.2 V • Alert signal is active low • Operate from a 3.3-V power supply CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-38G.1a — Data Sheet General Purpose, 1.8V, RRI, Open-drain Output Comparators LTC331, LTC393 P-11 Typical Application Circuits is 1.1 V. Large resistor values such as 10-MΩ are used to minimize power consumption. The sensor output voltage is applied to the inverting and non-inverting inputs of the 2-channel LTC393's. The LTC393 is used for its open-drain output configuration. Using the LTC393 allows the two comparator outputs to be Wire-ORed together. The respective comparator outputs will be low when the sensor is less than 1.1 V or greater than 2.2 V. VOUT will be high when the sensor is in the range of 1.1 V to 2.2 V. See the application curve in Figure 7. VIN VTH+ = 2.2 V VTH– = 1.1 V Time VOUT Time Figure 5. Window Comparator Results CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-38G.1a — Data Sheet General Purpose, 1.8V, RRI, Open-drain Output Comparators LTC331, LTC393 P-12 Tape and Reel Information REEL DIMENSIONS TAPE DIMENSIONS K0 P1 B0 W Reel Diameter A0 Cavity A0 B0 K0 W P1 Reel Width (W1) Dimension designed to accommodate the component width Dimension designed to accommodate the component length Dimension designed to accommodate the component thickness Overall width of the carrier tape Pitch between successive cavity centers QUADRANT ASSIGNMENTS FOR PIN 1 ORIETATION IN TAPE Sprocket Holes Q1 Q2 Q1 Q2 Q3 Q4 Q3 Q4 User Direction of Feed Pocket Quadrants * All dimensions are nominal Device LTC331YT5/R6 Package Pins Type SOT23 5 SPQ 3 000 Reel Reel Diameter Width W1 (mm) (mm) 178 9.0 A0 (mm) B0 (mm) K0 (mm) P1 (mm) W (mm) Pin 1 Quadrant 3.3 3.2 1.5 4.0 8.0 Q3 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-38G.1a — Data Sheet General Purpose, 1.8V, RRI, Open-drain Output Comparators LTC331, LTC393 P-13 Package Outlines DIMENSIONS, SOT23-5L A2 A A1 D e1 Symbol A A1 A2 b c D E1 E e e1 L L1 θ θ L E E1 L1 e b Dimensions In Millimeters Min Max 1.25 0.04 0.10 1.00 1.20 0.33 0.41 0.15 0.19 2.820 3.02 1.50 1.70 2.60 3.00 0.95 BSC 1.90 BSC 0.60 REF 0.30 0.60 0° 8° Dimensions In Inches Min Max 0.049 0.002 0.004 0.039 0.047 0.013 0.016 0.006 0.007 0.111 0.119 0.059 0.067 0.102 0.118 0.037 BSC 0.075 BSC 0.024 REF 0.012 0.024 0° 8° c RECOMMENDED SOLDERING FOOTPRINT, SOT23-5L 1.0 0.039 0.95 0.037 0.95 0.037 0.7 0.028 2.4 0.094 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. mm ( inches ) FN1617-38G.1a — Data Sheet General Purpose, 1.8V, RRI, Open-drain Output Comparators LTC331, LTC393 P-14 Package Outlines (continued) DIMENSIONS, SC70-5L (SOT353) A2 A Symbol A1 D e1 A A1 A2 b C D E E1 e e1 L L1 θ θ e L E1 E L1 b Dimensions In Millimeters Min Max 0.90 1.10 0.00 0.10 0.90 1.00 0.15 0.35 0.08 0.15 2.00 2.20 1.15 1.35 2.15 2.45 0.65 typ. 1.20 1.40 0.525 ref. 0.26 0.46 0° 8° C RECOMMENDED SOLDERING FOOTPRINT, SC70-5L (SOT353) 0.50 0.0197 0.65 0.025 0.65 0.025 0.40 0.0157 1.9 0.0748 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. mm ( inches ) Dimensions In Inches Min Max 0.035 0.043 0.000 0.004 0.035 0.039 0.006 0.014 0.003 0.006 0.079 0.087 0.045 0.053 0.085 0.096 0.026 typ. 0.047 0.055 0.021 ref. 0.010 0.018 0° 8° FN1617-38G.1a — Data Sheet General Purpose, 1.8V, RRI, Open-drain Output Comparators LTC331, LTC393 P-15 Package Outlines (continued) DIMENSIONS, DFN2x2-8L E A c A1 1 Nd D1 2 D b1 Exposed Thermal Pad Zone L h E1 h 2 e Symbol Min. 0.70 A A1 b b1 c D D1 Nd E E1 e L h 0.20 0.18 1.90 1.10 1.90 0.60 0.30 0.15 Millimeters Nom. 0.75 0.02 0.25 0.18 REF 0.20 2.00 1.20 1.50BSC 2.00 0.70 0.50BSC 0.35 0.20 1 b BOTTOM VIEW RECOMMENDED SOLDERING FOOTPRINT, DFN2x2-8L 1.60 0.0630 PACKAGE OUTLINE 8X 0.50 0.0197 1.00 0.0394 2.30 0.0906 1 0.50 PITCH 0.0197 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. 0.30 8X 0.0118 mm ( inches ) Max. 0.80 0.05 0.30 0.25 2.10 1.30 2.10 0.80 0.40 0.25 FN1617-38G.1a — Data Sheet General Purpose, 1.8V, RRI, Open-drain Output Comparators LTC331, LTC393 P-16 Package Outlines (continued) DIMENSIONS, MSOP-8L A2 A A1 D b Symbol e A A1 A2 b C D E E1 e L θ L E1 E Dimensions In Millimeters Min Max 0.800 1.100 Dimensions In Inches Min Max 0.031 0.043 0.050 0.150 0.750 0.950 0.290 0.380 0.150 0.200 2.900 3.100 2.900 3.100 4.700 5.100 0.650 TYP. 0.400 0.700 0° 8° 0.002 0.006 0.030 0.037 0.011 0.015 0.006 0.008 0.114 0.122 0.114 0.122 0.185 0.201 0.026 TYP. 0.016 0.028 0° 8° θ C RECOMMENDED SOLDERING FOOTPRINT, MSOP-8L 8X (0.45) MAX (0.018) (1.45) MAX (0.057) 8X 4.40 (5.85) MAX 0.173 (0.230) (2.95) MIN (0.116) 0.65 PITCH 0.026 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. mm ( inches ) FN1617-38G.1a — Data Sheet General Purpose, 1.8V, RRI, Open-drain Output Comparators LTC331, LTC393 P-17 Package Outlines (continued) DIMENSIONS, TSSOP-8L A3 A2 A A1 Symbol D b C e L1 L E E1 A A1 A2 A3 b C D E E1 e L1 L θ Dimensions In Millimeters Min Max 1.200 0.020 0.150 0.900 1.050 0.390 0.490 0.200 0.290 0.130 0.180 2.900 3.100 6.200 6.600 4.300 4.500 0.650 typ. 1.000 ref. 0.450 0.750 0° 8° Dimensions In Inches Min Max 0.047 0.001 0.006 0.035 0.041 0.015 0.019 0.008 0.011 0.005 0.007 0.114 0.122 0.244 0.260 0.169 0.177 0.026 typ. 0.039 ref. 0.018 0.030 0° 8° θ RECOMMENDED SOLDERING FOOTPRINT, TSSOP-8L 8X (1.45) MAX (0.057) (4.40) MIN (0.173) PITCH 0.65 0.026 8X 5.90 0.232 (0.45) MAX (0.018) mm ( inches ) CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-38G.1a — Data Sheet General Purpose, 1.8V, RRI, Open-drain Output Comparators LTC331, LTC393 P-18 Package Outlines (continued) DIMENSIONS, SOIC-8L A2 A A1 D b Symbol e A A1 A2 b C D E E1 e L θ L E E1 θ Dimensions In Millimeters Min Max 1.370 1.670 0.070 0.170 1.300 1.500 0.306 0.506 0.203 TYP. 4.700 5.100 3.820 4.020 5.800 6.200 1.270 TYP. 0.450 0.750 0° 8° Dimensions In Inches Min Max 0.054 0.066 0.003 0.007 0.051 0.059 0.012 0.020 0.008 TYP. 0.185 0.201 0.150 0.158 0.228 0.244 0.050 TYP. 0.018 0.030 0° 8° C RECOMMENDED SOLDERING FOOTPRINT, SOIC-8L 8X 5.40 0.213 (1.55) MAX (0.061) (3.90) MIN (0.154) 1 (0.60) MAX 8X (0.024) PITCH 1.270 0.050 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. mm ( inches ) FN1617-38G.1a — Data Sheet General Purpose, 1.8V, RRI, Open-drain Output Comparators P-19 LTC331, LTC393 IMPORTANT NOTICE Linearin is a global fabless semiconductor company specializing in advanced high-performance highquality analog/mixed-signal IC products and sensor solutions. The company is devoted to the innovation of high performance, analog-intensive sensor front-end products and modular sensor solutions, applied in multi-market of medical & wearable devices, smart home, sensing of IoT, and intelligent industrial & smart factory (industrie 4.0). Linearin’s product families include widely-used standard catalog products, solution-based application specific standard products (ASSPs) and sensor modules that help customers achieve faster time-to-market products. Go to http://www.linearin.com for a complete list of Linearin product families. For additional product information, or full datasheet, please contact with the Linearin’s Sales Department or Representatives. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-38G.1a — Data Sheet General Purpose, 1.8V, RRI, Open-drain Output Comparators
LTC393YS8/R8 价格&库存
很抱歉,暂时无法提供与“LTC393YS8/R8”相匹配的价格&库存,您可以联系我们找货
LTC393YS8/R8
  • 1+0.98000
  • 30+0.94500
  • 100+0.91000
  • 500+0.84000
  • 1000+0.80500
  • 2000+0.78400
