GP8111S-TC50-EH
GP8111S-TC50-EH
    LINEARIN(先积)
    ESOP-8
    PAC(PWM到模拟转换器)16位DAC0%-50%PWM到0-10V
GP8111S-TC50-EH 数据手册
P-1 特性  GP8111S将0%-100%占空比的PWM信号输入,线性转换成0-10V的模拟电压输出。  输入信号范围0%-50%  输入PWM信号的频率范围: 50Hz to 50KHz(小于50Hz请联系先积)  输入PWM信号高电平:2.7V-5.5V  输出电压误差:< 0.5% (更高精度需要通过两点校准)  输出电压线性度误差:0.05%  输出短路保护,输出脚与地短路时芯片进入保护模式停止输出。  电源电压:9V – 36V  功耗:0.5V VCC@12V 20 mA TC 温度系数 50 *1:当芯片作为板级接口使用时,请选用12V电源,并在VCC上串接一个50mA的PTC,保证系统的可靠性。 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. PPM/℃ FN1601-44.1 — Data Sheet GP8111S PAC (PWM to Analog Converter) 16BIT DAC 0%-50%PWM to 0-10V P-6 7. 订购须知 GP 8 1 11 S - X - XX 产品类型 8:PAC 9:APC 温度范围 W:-40°C-85°C 供电电源 1:PWM INPUT 2:I2C 封装 S:ESOP8 系列号 温度系数 TC50:50PPM TC25:25PPM 温度系数 封装 工作温度 订购码 50PPM/℃ ESOP8 -40℃-85℃ GP8111S-TC50-EW CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1601-44.1 — Data Sheet GP8111S PAC (PWM to Analog Converter) 16BIT DAC 0%-50%PWM to 0-10V P-7 8. 封装信息 BOTTOM VIEW (计量单位:毫米) 符号 最小值 正常值 最大值 A1 0.10 – 0.25 A 1.35 – 1.75 注意: b 0.31 – 0.51 C 0.17 – 0.25  此图仅供一般参考。有关合适的尺寸,公差,基准 等,请参阅JEDEC图纸MS-012 D 4.80 – 5.05 D1 3.1 E1 3.81 E2 2.20 E 5.79 e 3.5 – 3.99 2.60 – 6.20 1.27 BSC CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1601-44.1 — Data Sheet GP8111S PAC (PWM to Analog Converter) 16BIT DAC 0%-50%PWM to 0-10V
GP8111S-TC50-EH
物料型号:GP8111S
器件简介:GP8111S是一个PWM信号转模拟信号转换器,相当于一个PWM信号输入,模拟信号输出的DAC。此芯片可以将占空比为0%到50%的PWM信号线性转换成0-10V的模拟电压,并且输出电压精度小于0.5%。
引脚分配: - PWM:输入PWM信号 - VCC:电源 - GND:地 - V5V:内部LDO,5V输出,必须外接大于1uF电容。 - NC:浮空 - VOUT:模拟电压输出,必须外接一个10uF电容
参数特性: - 输入PWM信号的频率范围:50Hz到50KHz - 输入PWM信号高电平:2.7V-5.5V - 输出电压误差:<0.5% - 输出电压线性度误差:0.05% - 电源电压:9V – 36V - 功耗:<4mA - 启动时间:<2ms - 工作温度:-40°C to 85°C
功能详解: - GP8111S内置16bit DAC,兼容50Hz到50KHz的PWM信号频率,输出电压范围为0-10V,占空比为0%至50%。 - 输出电压精度为0.5%,线性度可达到0.05%。 - 芯片具有输出短路保护功能,当输出脚与地短路时芯片进入保护模式停止输出。
应用信息: - 适用于马达调速、LED调光、逆变器、电源以及工业模拟信号隔离等领域。
封装信息: - GP8111S采用ESOP8封装,具体尺寸和公差请参阅JEDEC图纸MS-012。
GP8111S-TC50-EH 价格&库存
很抱歉,暂时无法提供与“GP8111S-TC50-EH”相匹配的价格&库存,您可以联系我们找货
