GP8401-TC50-EH
GP8401-TC50-EH
    LINEARIN(先积)
    SOP10
    GP8401是一个PWM信号转模拟信号转换器,相当于一个PWM信号输入,模拟信号输出的DAC。此 芯片可以将占空比为0%到100%的两路PWM信号线性转换成0-5V或者0-10V的两路模拟电压,并且 ...
GP8401-TC50-EH 数据手册
P-1 特性  GP8401将2路0%-100%占空比的PWM信号输入,线性转换成0-5V或者0-10V的两路模拟电压输 出。  输入信号范围0%-100%  输入PWM信号的频率范围: 50Hz to 50KHz(小于50Hz请联系先积)  输入PWM信号高电平:2.7V-5.5V  输出电压误差:< 0.5% (两点校准可得0.1 %)  输出电压线性度误差:0.1%  输出短路保护,输出脚与地短路时芯片进入保护模式停止输出。  电源电压:9V - 36V  功耗:0.5V VCC@12V 最小 典型 最大 单位 9 12 36 V 3 5 mA VCC @12V 空载 SEL接地 0 5 V SEL接V5V 0 10 V *1:V5V上外挂负载后可能会轻微影响芯片精度。 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. 0.5 20 % mA FN1601-46.1 — Data Sheet GP8401 PAC (PWM to Analog Converter) Dual 0%-100% PWM to 0-5V/0-10V P-6 7. 订购须知 GP 8 4 01 - X- X - X X 产品类型 8:PAC 9:APC 温度范围 W:-40°C-85°C 封装 E:ESOP10 系列号 温度系数 TC50:50PPM/℃ TC25:25PPM/℃ PWM频率范围 F50: >50Hz 温度系数 精度 封装 工作温度 订购码 50PPM/℃ 0.5% ESOP10 -40℃-85℃ GP8401-TC50-EW CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1601-46.1 — Data Sheet GP8401 PAC (PWM to Analog Converter) Dual 0%-100% PWM to 0-5V/0-10V 8. 封装信息 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1601-46.1 — Data Sheet P-7 GP8401 PAC (PWM to Analog Converter) Dual 0%-100% PWM to 0-5V/0-10V
GP8401-TC50-EH
物料型号:GP8401 器件简介:GP8401是一个PWM信号转模拟信号转换器,可以将两路0%-100%占空比的PWM信号线性转换成0-5V或者0-10V的两路模拟电压输出。
引脚分配:PWM0和PWM1是输入PWM信号的管脚,VCC是电源,GND是地,V5V是内部LDO 5V输出,SEL用于选择输出电压幅度,VOUT0和VOUT1是模拟电压输出。
参数特性:输入信号范围0%-100%,输入PWM信号频率范围50Hz到50KHz,输入PWM信号高电平2.7V-5.5V,输出电压误差<0.5%,输出电压线性度误差0.1%。
功能详解:GP8401能够将PWM信号线性转换成模拟电压,具备输出短路保护,电源电压9V - 36V,功耗<4mA,启动时间<2ms,工作温度40°C到85°C。
应用信息:适用于通用信号转换,例如马达调速、LED调光、逆变器、电源和工业模拟信号隔离。
封装信息:ESOP10封装,尺寸和引脚分布信息在文档中有详细描述。
GP8401-TC50-EH 价格&库存
很抱歉,暂时无法提供与“GP8401-TC50-EH”相匹配的价格&库存,您可以联系我们找货
