GP8101-F50-N-SH
GP8101-F50-N-SH
    LINEARIN(先积)
    SOP-8
    PAC(PWM到模拟转换器)0%-100%PWM至0-5V/0-10V
GP8101-F50-N-SH 数据手册
P-1 特性  GP8101将0%-100%占空比的PWM信号输入,线性转换成0-5V或者0-10V的模拟电压输出。  GP8101M将0%-100%占空比的高频调制后的PWM信号输入,线性转换成0-5V或者0-10V的模拟 电压输出。此芯片需要与高频调制APC芯片(GP9301M、GP9303M等)同时使用,用于模拟信 号的电容隔离,或者变压器隔离。  输入信号范围0%-100%  输入PWM信号的频率范围: 50Hz to 50KHz(小于50Hz请联系先积)  输入PWM信号高电平:3.0V-5.5V  输出电压误差:< 1% (0.5%)  输出电压线性度误差 50Hz 输出电压范围 N:0-5V/0-10V 精度 封装 工作温度 订购码 < 0.5% SOP8 -40℃-85℃ GP8101-F50-NH-SW < 1% SOP8 -40℃-85℃ GP8101-F50-N-SW CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1601-40.1 — Data Sheet GP8101/GP8101M PAC (PWM to Analog Converter) 0%-100% PWM to 0-5V/0-10V P-8 9. 封装信息 SOP8 (计量单位:毫米) 符号 最小值 正常值 最大值 A1 0.10 – 0.25 A 1.35 – 1.75 b 0.31 – 0.51 C 0.17 – 0.25 D 4.80 – 5.05 E1 3.81 – 3.99 E 5.79 – 6.20 e 注意:  此图仅供一般参考。有关合适的尺寸,公差,基准 等,请参阅JEDEC图纸 1.27 BSC L 0.40 – 1.27 Ø 0° – 8° CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1601-40.1 — Data Sheet GP8101/GP8101M PAC (PWM to Analog Converter) 0%-100% PWM to 0-5V/0-10V
GP8101-F50-N-SH 价格&库存
很抱歉,暂时无法提供与“GP8101-F50-N-SH”相匹配的价格&库存,您可以联系我们找货
