GP8101S-TC50-EH
GP8101S-TC50-EH
    LINEARIN(先积)
    ESOP-8
    PAC(PWM到模拟转换器)0%-100%PWM至0-5V/0-10V
GP8101S-TC50-EH 数据手册
P-1 特性  GP8101S将0%-100%占空比的PWM信号输入,线性转换成0-5V或者0-10V的模拟电压输出。  输入信号范围0%-100%  输入PWM信号的频率范围: 50Hz to 50KHz(小于50Hz请联系先积)  输入PWM信号高电平:2.7V-5.5V  输出电压误差:< 0.2%  输出电压线性度误差:0.1%  输出短路保护,输出脚与地短路时芯片进入保护模式停止输出。  电源电压:9V - 36V  功耗:0.5V VCC@12V TC 温度系数 *1:V5V上外挂负载后可能会轻微影响芯片精度。 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. 0.5 % 20 mA 50 PPM/℃ FN1601-42.1 — Data Sheet GP8101S PAC (PWM to Analog Converter) 0%-100% PWM to 0-5V/0-10V P-6 7. 订购须知 GP 8 1 01 S - X - XX 产品类型 8:PAC 9:APC 温度范围 W:-40°C-85°C H:-40°C-125°C 供电电源 1:PWM INPUT 2:I2C 封装 E:ESOP8 系列号 温度系数 TC50:50PPM TC25:25PPM 温度系数 封装 工作温度 订购码 50PPM/℃ ESOP8 -40℃-85℃ GP8101S-TC50-EW 50PPM/℃ ESOP8 -40℃-125℃ GP8101S-TC50-EH CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1601-42.1 — Data Sheet GP8101S PAC (PWM to Analog Converter) 0%-100% PWM to 0-5V/0-10V P-7 8. 封装信息 BOTTOM VIEW (计量单位:毫米) 符号 最小值 正常值 最大值 A1 0.10 – 0.25 A 1.35 – 1.75 b 0.31 – 0.51 C 0.17 – 0.25 D 4.80 – 5.05 – 3.99 D1 3.1 E1 3.81 E2 2.20 E 5.79 e 注意:  此图仅供一般参考。有关合适的尺寸,公差,基准 等,请参阅JEDEC图纸MS-012 3.5 2.60 – 6.20 1.27 BSC CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1601-42.1 — Data Sheet GP8101S PAC (PWM to Analog Converter) 0%-100% PWM to 0-5V/0-10V
GP8101S-TC50-EH 价格&库存
很抱歉,暂时无法提供与“GP8101S-TC50-EH”相匹配的价格&库存,您可以联系我们找货
