LTC8702YV8/R6
LTC8702YV8/R6
    LINEARIN(先积)
    MSOP-8
    超低功耗,310NA、1.7V、轨到轨输入、CMOS输入比较器
LTC8702YV8/R6 数据手册
LTC8701, LTC8702, LTC8703, LTC8704 P-1 General Description The LTC8701/8702/8703/8704 devices are single-, dual-, and quad- channel comparators with push-pull output that are ideal for power-sensitive, low-voltage applications. Featuring a nano-power (typical 310 nA), fast 12 μs propagation delay, and a wide range of supply voltages from 1.7 V to 5.5 V with rail-to-rail common-mode voltage range makes the LTC8701/8702/8703/8704 an ideal choice for a wide variety of portable electronics applications, such as handsets, tablets, notebooks and portable devices that have extremely power constraints and tight board space. The output of the LTC8701/8702/8703/8704 pulls to within 0.1 V of either supply rail without external pull-up circuitry, making these devices ideal for interface with both CMOS and TTL logics. All input and output pins can tolerate a continuous short-circuit fault condition to either rail. Internal hysteresis ensures clean output switching, even with slow-moving input signals. The LTC8701/LTC8703 (single) is available in both SOT23-5L and SC70-5L packages. The LTC8702 (dual) is offered in SOIC-8L, MSOP-8L and DFN-8L packages. The quad-channel LTC8704 is offered in both SOIC-14L and TSSOP-14L packages. All devices are rated over −40 ℃ to +85 ℃ industrial temperature range. Features and Benefits Nanopower Operating Current (310 nA) Preserves Battery Power Propagation Delay: 12 μs (100-mV Overdrive) Rail-to-Rail Input Push-Pull Output Current Drive: 30 mA Typically at 5V Supply Internal Hysteresis for Clean Switching Internal RF/EMI Filter Single 1.7 V to 5.5 V Supply Voltage Range – Can be Powered From the Same 1.8V/2.5V/3.3V/5V System Rails  Operating Temperature Range: −40 ℃ to +85 ℃        Applications        Handsets, Tablets and Notebooks Wearables and Consumer Accessories Portable Medical Instruments Alarms and Monitoring Circuits Level Detectors IR Receivers Multi-vibrators Pin Configurations (Top View) LTC8701 LTC8701R LTC8702 LTC8704 SOT23-5L / SC70-5L SOT23-5L SOIC-8L / MSOP-8L SOIC-14L / TSSOP-14L OUT 1 5 +VS –VS 2 5 –VS OUT 1 +VS 2 4 –IN +IN 3 4 –IN +IN 3 LTC8701 LTC8702 DFN-8L DFN-8L OUT 1 8 +VS OUTA 1 OUTA 1 –INA 2 +INA 3 –VS 4 A B 8 +VS 7 OUTB 6 –INB 5 +INB LTC8703 SOT23-5L / SC70-5L OUTA 1 –INA 2 A 14 OUTD 13 –IND D +INA 3 12 +IND +VS 4 11 –VS +INB 5 10 +INC B C –INB 6 9 –INC OUTB 7 8 OUTC 8 +VS –IN 2 7 NC –INA 2 7 OUTB +IN 3 6 –VS +INA 3 6 –INB NC 4 5 NC –VS 4 5 +INB +IN 1 5 +VS –VS 2 –IN 3 4 OUT CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-32.1a — Data Sheet Ultra-Low Power 310nA, 1.7V, RRI, CMOS Input Comparators LTC8701, LTC8702, LTC8703, LTC8704 P-2 Pin Description Symbol Description –IN Negative input. The voltage range is from (VS– – 0.1V) to (VS+ + 0.1V). +IN Positive input. This pin has the same voltage range as –IN. +VS Positive power supply. The voltage is from 1.7V to 5.5V. Split supplies are possible as long as the voltage between VS+ and VS– is from 1.7V to 5.5V. –VS Negative power supply. It is normally tied to ground. It can also be tied to a voltage other than ground as long as the voltage between VS+ and VS– is from 1.7V to 5.5V. OUT Comparator output. Ordering Information Orderable Type Number Package Name Package Quantity Eco Class(1) Operating Temperature Marking Code LTC8701YT5/R6 SOT23-5L Tape and Reel, 3 000 Green (RoHS & no Sb/Br) –40℃ to +85℃ CL1 LTC8701YC5/R6 SC70-5L Tape and Reel, 3 000 Green (RoHS & no Sb/Br) –40℃ to +85℃ CL1 LTC8701YF8/R6 DFN2x2-8L Tape and Reel, 3 000 Green (RoHS & no Sb/Br) –40℃ to +85℃ CL1 LTC8701RYT5/R6 SOT23-5L Tape and Reel, 3 000 Green (RoHS & no Sb/Br) –40℃ to +85℃ CL9 LTC8702YS8/R8 SOIC-8L Tape and Reel, 4 000 Green (RoHS & no Sb/Br) –40℃ to +85℃ CL2 Y LTC8702YV8/R6 MSOP-8L Tape and Reel, 3 000 Green (RoHS & no Sb/Br) –40℃ to +85℃ CL2Y LTC8702YF8/R6 DFN2x2-8L Tape and Reel, 3 000 Green (RoHS & no Sb/Br) –40℃ to +85℃ CL2 LTC8703YT5/R6 SOT23-5L Tape and Reel, 3 000 Green (RoHS & no Sb/Br) –40℃ to +85℃ CL3 LTC8703YC5/R6 SC70-5L Tape and Reel, 3 000 Green (RoHS & no Sb/Br) –40℃ to +85℃ CL3 LTC8704YS14/R5 SOIC-14L Tape and Reel, 2 500 Green (RoHS & no Sb/Br) –40℃ to +85℃ CL4 Y LTC8704YT14/R6 TSSOP-14L Tape and Reel, 3 000 Green (RoHS & no Sb/Br) –40℃ to +85℃ CL4 Y (1) Eco Class - The planned eco-friendly classification: Pb-Free (RoHS) or Green (RoHS & Halogen Free). (2) Please contact to your Linearin representative for the latest availability information and product content details. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-32.1a — Data Sheet Ultra-Low Power 310nA, 1.7V, RRI, CMOS Input Comparators LTC8701, LTC8702, LTC8703, LTC8704 P-3 Limiting Value In accordance with the Absolute Maximum Rating System (IEC 60134). Parameter Absolute Maximum Rating Supply Voltage, VS+ to VS– 10.0 V Signal Input Terminals: Voltage, Current VS– – 0.3 V to VS+ + 0.3 V, ±10 mA Output Short-Circuit Continuous Storage Temperature Range, Tstg –65 ℃ to +150 ℃ Junction Temperature, TJ 150 ℃ Lead Temperature Range (Soldering 10 sec) 260 ℃ ESD Rating Parameter Electrostatic Discharge Voltage Item Value Human body model (HBM), per MIL-STD-883J / Method 3015.9 ±5 000 Charged device model (CDM), per ESDA/JEDEC JS-002-2014 ±2 000 Machine model (MM), per JESD22-A115C ±250 (1) JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process. (2) JEDEC document JEP157 states that 250-V CDM allows safe manufacturing with a standard ESD control process. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. Unit V FN1617-32.1a — Data Sheet Ultra-Low Power 310nA, 1.7V, RRI, CMOS Input Comparators LTC8701, LTC8702, LTC8703, LTC8704 P-4 Electrical Characteristics VS = 5.0V, TA = +25℃, unless otherwise noted. Boldface limits apply over the specified temperature range, TA = −40 to +85 ℃. Symbol Parameter Conditions Min. Typ. Max. ±0.5 ±3.5 Unit OFFSET VOLTAGE VCM = 0 VOS Input offset voltage VOS TC Offset voltage drift TA = −40 to +85 ℃ PSRR Power supply rejection ratio VS = 1.7 to 5.5 V, VCM < (VS+ − 1V) 65 TA = −40 to +85 ℃ 60 VHYST Input hysteresis VCM = 0 5 VCM = VS /2 5 TA = +85 ℃ 150 VCM = VS /2 10 TA = −40 to +85 ℃ ±4.0 mV μV/℃ ±1 85 dB mV INPUT BIAS CURRENT IB Input bias current IOS Input offset current pA pA INPUT VOLTAGE RANGE VCM CMRR Common-mode voltage range Common-mode rejection ratio VS––0.1 VCM = −0.1 to 5.1 V 62 VCM = 0 to 4.8 V, TA = −40 to +85 ℃ 56 VS = 1.8 V, VCM = −0.1 to 1.9 V 60 VCM = 0 to 1.6 V, TA = −40 to +85 ℃ 55 VS++0.1 V 84 dB 82 INPUT IMPEDANCE RIN Input resistance CIN Input capacitance 100 GΩ Differential 2.0 Common mode 3.5 pF OUTPUT VOH High output voltage swing ISOURCE = 1 mA VS+–90 TA = −40 to +85 ℃ VS+–120 VOL Low output voltage swing ISINK = 1 mA ISC Output short-circuit current Source current, OUT to VS /2 VS+–73 VS–+48 TA = −40 to +85 ℃ mV VS–+60 VS–+80 30 Sink current, OUT to VS /2 36 –27 –22 mV mA POWER SUPPLY VS IQ Operating supply voltage Quiescent current (per comparator) TA = −40 to +85 ℃ 1.7 5.5 VS = 1.8 V, VCM = 0.3V 310 VS = 1.8 V, VCM = 1.5V 380 VS = 5.0 V, VCM = 0.3V 355 VS = 5.0 V, VCM = 4.7V 440 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. V nA 670 FN1617-32.1a — Data Sheet Ultra-Low Power 310nA, 1.7V, RRI, CMOS Input Comparators LTC8701, LTC8702, LTC8703, LTC8704 P-5 Electrical Characteristics (continued) VS = 5.0V, TA = +25℃, unless otherwise noted. Boldface limits apply over the specified temperature range, TA = −40 to +85 ℃. Symbol Parameter Conditions Min. Typ. Max. Unit SWITCHING CHARACTERISTICS tPD+ Propagation delay time, Low to high tPD– Propagation delay time, High to low tR Rise time tF Fall time THERMAL CHARACTERISTICS TA θJA Input overdrive = 10 mV, CL = 15 pF Input overdrive = 100 mV, CL = 15 pF Input overdrive = 10 mV, CL = 15 pF Input overdrive = 100 mV, CL = 15 pF Input overdrive = 10 mV, CL = 15 pF Input overdrive = 100 mV, CL = 15 pF Input overdrive = 10 mV, CL = 15 pF Input overdrive = 100 mV, CL = 15 pF Operating temperature range Package Thermal Resistance 16 17 μs 13 230 ns 190 300 ns 220 -40 +85 SC70-5L 333 SOT23-5L 190 DFN2x2-8L 80 MSOP-8L 216 SOIC-8L 125 TSSOP-14 112 SOIC-14L 115 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. μs 12 ℃ ℃/W FN1617-32.1a — Data Sheet Ultra-Low Power 310nA, 1.7V, RRI, CMOS Input Comparators LTC8701, LTC8702, LTC8703, LTC8704 P-6 Typical Performance Characteristics At TA=+25℃, VS=5.0V, VCM=VS /2, RL=10kΩ, and CL=15pF, unless otherwise noted. 600 VCM=0.8V = 0.5V 500 +85℃ Supply Current (nA) Supply Current (nA) 600 +25℃ 400 300 –40℃ 200 100 VCM = 3.0V TA = +85℃ 500 400 300 200 100 0 0 0 1 2 3 4 5 6 0 1 Supply Voltage (V) Supply Current vs. Supply Voltage 400 Supply Current (nA) Supply Current (nA) 4 5 6 5 6 600 +125℃ VVSS=1.8V =1.8V +85℃ 300 +25℃ –40℃ 200 100 VVSS==1.8V 5V 500 +85℃ +25℃ 400 300 –40℃ 200 100 0 0 0 0.5 1 1.5 0 2 Common-Mode Voltage (V) Supply Current vs. Common-Mode Input (VS = 1.8V) 350 100 3 4 VCM = –VS 300 Distribution (Unit) 150 2 Supply Current vs. Common-Mode Input (VS = 5.0V) VCM = –VS 200 1 Common-Mode Voltage (V) 250 250 200 150 100 50 50 0 0 -3.5 -3 -2.5 -2 -1.5 -1 -0.5 0 0.5 1 1.5 2 2.5 3 3.5 Distribution (Unit) 3 Supply Current vs. Supply Voltage 500 300 2 Supply Voltage (V) Offset Voltage (mV) Offset Voltage Production Distribution Input Hysteresis (mV) Hysteresis Production Distribution CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-32.1a — Data Sheet Ultra-Low Power 310nA, 1.7V, RRI, CMOS Input Comparators LTC8701, LTC8702, LTC8703, LTC8704 P-7 Typical Performance Characteristics At TA=+25℃, VS=5.0V, VCM=VS /2, RL=10kΩ, and CL=15pF, unless otherwise noted. 8 5 Sourcing Current Hysteresis+ 4 Output Voltage (V) VOS and VHYST (mV) 6 Offset 2 0 -2 Hysteresis– -4 4 –40℃ 3 +85℃ +25℃ 2 1 -6 Sinking Current 0 -8 0 1 2 3 4 0 5 10 Common-Mode Voltage (V) 40 Output Voltage vs. Output Current -20 Short-Circuit Current (mA) -2.5 Short-Circuit Current (mA) 30 Output Current (mA) VOS and VHYST vs. Common-Mode Input VS = 1.8V -2.7 -2.9 -3.1 -3.3 VS = 5.0V -25 -30 -35 -3.5 -40 -40 0 40 80 120 -40 0 Temperature (℃) 40 80 120 Temperature (℃) Short-Circuit Current vs. Temperature (VS = 1.8V) Short-Circuit Current vs. Temperature (VS = 5.0V) 20 16 VCM = VS / 2 VOD = 20mV 18 16 Propagation Delay L-H (μs) Propagation Delay H-L (μs) 20 +85℃ 14 12 10 8 +25℃ 6 –40℃ 4 2 0 VCM = VS / 2 VOD = 20mV 14 +85℃ 12 10 8 –40℃ 6 +25℃ 4 2 0 0 1 2 3 4 5 6 0 Supply Voltage (V) Propagation Delay H-L (tPD–) vs. Supply Voltage 1 2 3 4 5 Supply Voltage (V) Propagation Delay L-H (tPD+) vs. Supply Voltage CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. 6 FN1617-32.1a — Data Sheet Ultra-Low Power 310nA, 1.7V, RRI, CMOS Input Comparators LTC8701, LTC8702, LTC8703, LTC8704 P-8 Typical Performance Characteristics At TA=+25℃, VS=5.0V, VCM=VS /2, RL=10kΩ, and CL=15pF, unless otherwise noted. 25 VS = 1.8V VCM = VS/2 20 Propagation Delay (μs) Propagation Delay (μs) 25 15 tPD– (H-L) 10 tPD+ (L-H) 5 VS = 5.0V VCM = VS/2 20 15 10 tPD+ (L-H) 5 0 tPD– (H-L) 0 1 10 100 1000 1 10 Overdrive Voltage (mV) Propagation Delay vs. Input Overdrive (VS = 1.8V) 70 Propagation Delay H-L (μs) Propagation Delay L- (μs) 1000 Propagation Delay vs. Input Overdrive (VS = 5.0V) 80 70 60 50 +85℃ 40 +25℃ 30 20 10 –40℃ 60 50 +85℃ 40 +25℃ 30 20 10 0 –40℃ 0 10 100 1000 10 100 Overdrive Voltage (mV) 1000 Overdrive Voltage (mV) Propagation Delay H-L (tPD–) vs. Input Overdrive Propagation Delay L-H (tPD+) vs. Input Overdrive 10 10 VOD = 100mV Propagation Delay (μs) Propagation Delay (μs) 100 Overdrive Voltage (mV) 8 6 4 2 0 VOD = 100mV 8 6 4 2 0 0 1 2 3 4 5 6 0 Common-Mode Voltage (V) Propagation Delay H-L (tPD–) vs. Input CommonMode Voltage 1 2 3 4 5 6 Common-Mode Voltage (V) Propagation Delay L-H (tPD+) vs. Input CommonMode Voltage CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-32.1a — Data Sheet Ultra-Low Power 310nA, 1.7V, RRI, CMOS Input Comparators LTC8701, LTC8702, LTC8703, LTC8704 P-9 Typical Performance Characteristics At TA=+25℃, VS=5.0V, VCM=VS /2, RL=10kΩ, and CL=15pF, unless otherwise noted. 100 120 VS = 1.8V VOD = 100mV Propagation Delay (μs) Propagation Delay (μs) 120 80 60 tPD+ (L-H) 40 tPD– (H-L) 20 0 0.01 0.1 1 10 100 80 20 10 100 50 VS = 5.0V VOD = 100mV 45 Propagation Delay (μs) Propagation Delay (μs) 1 Propagation Delay vs. Capacitive Load (VS = 1.8V) 45 30 25 20 tPD+ (L-H) 15 tPD– (H-L) 10 5 0 0.01 0.1 Output Capacitive Load (nF) Propagation Delay vs. Capacitive Load (VS = 1.8V) 35 tPD– (H-L) 40 Output Capacitive Load (nF) 40 tPD+ (L-H) 60 0 0.01 100 VS = 1.8V VOD = 20mV 0.1 1 10 100 40 35 30 25 tPD+ (LH) tPD– (H-L) 20 15 10 5 0 0.01 Output Capacitive Load (nF) Propagation Delay vs. Capacitive Load (VS = 5.0V) VS = 5.0V VOD = 20mV 0.1 1 10 100 Output Capacitive Load (nF) Propagation Delay vs. Capacitive Load (VS = 5.0V) CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-32.1a — Data Sheet Ultra-Low Power 310nA, 1.7V, RRI, CMOS Input Comparators LTC8701, LTC8702, LTC8703, LTC8704 P-10 Application Notes OPERATING VOLTAGE The LTC8701/8702/8703/8704 family of nano-power comparators is fully specified and ensured for operation from 1.7V to 5.5V (±0.85V to ±2.75V). In addition, and many specifications apply over the industrial temperature range of –40℃ to +85℃. Parameters that vary significantly with operating voltages or temperature are illustrated in the Typical Characteristics graphs. NOTE: Supply voltages (VS+ to VS–) higher than +10V can permanently damage the device. INPUT VOLTAGE The input common-mode voltage range of the LTC8701/8702/8703/8704 comparators extends 100mV beyond the supply rails. This performance is achieved with a complementary input stage: an Nchannel input differential pair in parallel with a Pchannel differential pair. The N-channel pair is active for input voltages close to the positive rail, typically VS+–1.4V to the positive supply, whereas the Pchannel pair is active for inputs from 100mV below the negative supply to approximately VS+–1.4V. There is a small transition region, typically VS+–1.2V to VS+– 1V, in which both pairs are on. This 200mV transition region can vary up to 200mV with process variation. Thus, the transition region (both stages on) can range from VS+–1.4V to VS+–1.2V on the low end, up to VS+–1V to VS+–0.8V on the high end. Within this transition region, PSRR, CMRR, offset voltage, offset drift, and THD can be degraded compared to device operation outside this region. INPUT VOLTAGE The LTC8701/8702/8703/8704 comparator family uses CMOS transistors at the inputs which prevent phase inversion when the input pins exceed the supply voltages. VS+ D1 RS1 500Ω IN+ D2 D3 CCM1 RS2 CDM 500Ω IN– D4 CCM2 VS– Figure 1. Input EMI Filter and Clamp Circuit Figure 1 shows the input EMI filter and clamp circuit. The LTC8701/8702/8703/8704 comparators have internal ESD protection diodes (D1, D2, D3, and D4) that are connected between the inputs and each supply rail. These diodes protect the input transistors in the event of electrostatic discharge and are reverse biased during normal operation. This protection scheme allows voltages as high as approximately 300mV beyond the rails to be applied at the input of either terminal without causing permanent damage. See the table of Absolute Maximum Ratings for more information. EMI REJECTION RATIO Circuit performance is often adversely affected by high frequency EMI. When the signal strength is low and transmission lines are long, an amplifier must accurately amplify the input signals. However, all comparator pins — the non-inverting input, inverting input, positive supply, negative supply, and output pins — are susceptible to EMI signals. These high frequency signals are coupled into an comparator by various means, such as conduction, near field radiation, or far field radiation. For example, wires and printed circuit board (PCB) traces can act as antennas and pick up high frequency EMI signals. Amplifiers do not amplify EMI or RF signals due to their relatively low bandwidth. However, due to the nonlinearities of the input devices, comparators can rectify these out of band signals. When these high frequency signals are rectified, they appear as a dc offset at the output. The LTC8701/8702/8703/8704 comparators have integrated EMI filters at their input stage. A mathematical method of measuring EMIRR is defined as follows: EMIRR = 20 log (VIN_PEAK / ΔVOS) INTERNAL HYSTERESIS Most high-speed comparators oscillate in the linear region because of noise or undesired parasitic feedback. This tends to occur when the voltage on one input is at or equal to the voltage on the other input. To counter the parasitic effects and noise, the devices have an internal hysteresis of 5 mV. The hysteresis in a comparator creates two trip points: one for the rising input voltage and one for the falling input voltage. The difference between the trip points is the hysteresis. The average of the trip points is the offset voltage. When the comparator’s input voltages are equal, the hysteresis effectively causes one comparator input voltage to move quickly past the other, thus taking the input out of the region where oscillation occurs. Standard comparators require hysteresis to be added with external resistors. To increase hysteresis and noise margin even more, add positive feedback with two resistors as a voltage divider from the output to the noninverting input. Figure 2 illustrates the case where I N – i s f i x e d a n d CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-32.1a — Data Sheet Ultra-Low Power 310nA, 1.7V, RRI, CMOS Input Comparators LTC8701, LTC8702, LTC8703, LTC8704 P-11 Application Notes IN+ is varied. If the inputs were reversed, the figure would look the same, except the output would be inverted. VTRIP+ VIN+ VHYST VOS VIN– = 0 VTRIP– VOS = (VTRIP+ + VTRIP–)/2 VOH Comparator Output VOL Figure 2. Input and Output Waveform, Non-inverting Input Varied MAXIMIZING PERFORMANCE THROUGH PROPER LAYOUT to the temperature of the junction. The most common metallic junctions on a circuit board are solder-toboard trace and solder-to-component lead. If the temperature of the PCB at one end of the component is different from the temperature at the other end, the resulting Seebeck voltages are not equal, resulting in a thermal voltage error. This thermocouple error can be reduced by using dummy components to match the thermoelectric error source. Placing the dummy component as close as possible to its partner ensures both Seebeck voltages are equal, thus canceling the thermocouple error. Maintaining a constant ambient temperature on the circuit board further reduces this error. The use of a ground plane helps distribute heat throughout the board and reduces EMI noise pickup. INPUT-TO-OUTPUT COUPLING To minimize capacitive coupling, the input and output signal traces should not be parallel. This helps reduce unwanted positive feedback. To achieve the maximum performance of the extremely high input impedance and low offset voltage of the LTC8701/8702/8703/8704 devices, care is needed in laying out the circuit board. The PCB surface must remain clean and free of moisture to avoid leakage currents between adjacent traces. Surface coating of the circuit board reduces surface moisture and provides a humidity barrier, reducing parasitic resistance on the board. The use of guard rings around the comparator inputs further reduces leakage currents. Figure 3 shows proper guard ring configuration and the top view of a surface-mount layout. The guard ring does not need to be a specific width, but it should form a continuous loop around both inputs. By setting the guard ring voltage equal to the voltage at the non-inverting input, parasitic capacitance is minimized as well. For further reduction of leakage currents, components can be mounted to the PCB using Teflon standoff insulators. Guard Ring +IN –IN +VS Figure 3. Use a guard ring around sensitive pins Other potential sources of offset error are thermoelectric voltages on the circuit board. This voltage, also called Seebeck voltage, occurs at the junction of two dissimilar metals and is proportional CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-32.1a — Data Sheet Ultra-Low Power 310nA, 1.7V, RRI, CMOS Input Comparators LTC8701, LTC8702, LTC8703, LTC8704 P-12 Typical Application Circuits IR RECEIVER AFE AND WAKE- UP CIRCUIT Infrared (IR) communication is inherently immune to RF interference as long as there is a line-of-sight path between the transmitter and the receiver. It is also one of the lowest cost communication schemes. This makes it a good choice for implementing wireless communications in applications such as utility metering. These smart utility meters are hermetically sealed and use a combination of batteries and solar cells to power the system. Maintenance in the field can be costly, so minimizing system power consumption to extend battery life is desired. A common system topology to extend battery life is to use a power efficient IR receiver analog front end (AFE) that is always on and wakes up the host only when there is a valid IR signal detected as shown in Figure 1. Power efficient comparators such as the LTC870x can be used in the IR receiver AFE to increase battery life. IR LED IR Receiver AFE Digital output (hardware wake-up event) GPIO MCU (Low Power) + CR2032 10MΩ Figure 4. Coin Cell Battery Powered IR Receiver The LTC870x device is responsible for two major tasks: 1. IR signal conditioning, 2. Host system wake-up. The benefits of LTC870x for this application include the following: 1. Nano quiescent supply current (310 nA), 2. Low input bias current (5 pA) which allows a greater load resistor value. The LTC870x device is constantly powered to always be ready to receive IR signals and wake up the host microcontroller (MCU) when data is received. The short working distance (approx 5 cm) is suitable for a virtual-contact operation where the IR transmitter and receiver are closely placed with an optional mechanical alignment guide. Figure 1 shows the IR receiver system block diagram. The host MCU is normally in the shutdown mode (during which the quiescent current is less than 1 μA) except when data is being transferred. Figure 2 shows the detailed circuit design. The circuit establishes a threshold through R2 and C1 which automatically adapts to the ambient light level. To further reduce BOM cost, this example uses an IR LED as the IR receiver. The IR LED is reverse-biased to function as a photodiode (but at a reduced sensitivity). VREF 3V R2 R3 R4 470kΩ 470kΩ 10MΩ 3V IR LED LTC8701 Output to MCU (Also to wake-up MCU) R1 10MΩ C1 0.01μF Figure 5. IR Receiver AFE Using LTC8701 (Push- Pull Output) The low input bias current allows a greater load resistor value (R1) without sacrificing linearity, which in turn helps reduce the always-on supply current. The load resistor R1 converts the IR light induced current into a voltage fed into the inverting input of the comparator. R2 and C1 establish a reference voltage VREF which tracks the mean amplitude of the IR signal. The non-inverting input is connected to VREF through R3. And finally R3 and R4 are used to introduce additional hysteresis to keep the output free of spurious toggles. To achieve years of operation running on a single coin cell battery, the host MCU must be put in the shutdown power state. The MCU wakes up when data is received. After the data transmission is complete, the MCU reverts to the shutdown state and the overall supply current drops back to the micro amps level. PARAMETER Aggregated alwayson Current 2 μA Peak Current (Wireless Radio + IR LED) 30 mA Active Duration /Frequency 30 sec/30 days CR 2032 Coin Cell Battery Capacity 240 mAh CR 2032 Lifespan (minimum) 5 years Lead Temperature Range (Soldering 10 sec) 260 ℃ CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-32.1a — Data Sheet Ultra-Low Power 310nA, 1.7V, RRI, CMOS Input Comparators P-13 LTC8701, LTC8702, LTC8703, LTC8704 Typical Application Circuits Table 1 shows a power budget based on the following assumptions: 1. The aggregated always-on quiescent current is estimated as 2 μA, which includes the LTC8701 quiescent current, divider network current, and the MCU and supporting devices current in the shutdown state. 2. Peak current during active data transmission and RF radio operation is estimated as 30 mA. 3. Each active session last for 30 seconds or less for every 30 days or longer. 4. The coin cell is based on an Energizer CR2032, which is specified at 240 mAh and includes a 1% annual self-discharge rate. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-32.1a — Data Sheet Ultra-Low Power 310nA, 1.7V, RRI, CMOS Input Comparators LTC8701, LTC8702, LTC8703, LTC8704 P-14 Tape and Reel Information REEL DIMENSIONS TAPE DIMENSIONS K0 P1 B0 W Reel Diameter A0 Cavity A0 B0 K0 W P1 Reel Width (W1) Dimension designed to accommodate the component width Dimension designed to accommodate the component length Dimension designed to accommodate the component thickness Overall width of the carrier tape Pitch between successive cavity centers QUADRANT ASSIGNMENTS FOR PIN 1 ORIETATION IN TAPE Sprocket Holes Q1 Q2 Q1 Q2 Q3 Q4 Q3 Q4 User Direction of Feed Pocket Quadrants * All dimensions are nominal Device LTC8701YT5/R6 Package Pins Type SOT23 5 SPQ 3 000 Reel Reel Diameter Width W1 (mm) (mm) 178 9.0 A0 (mm) B0 (mm) K0 (mm) P1 (mm) W (mm) Pin 1 Quadrant 3.3 3.2 1.5 4.0 8.0 Q3 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-32.1a — Data Sheet Ultra-Low Power 310nA, 1.7V, RRI, CMOS Input Comparators LTC8701, LTC8702, LTC8703, LTC8704 P-15 Package Outlines DIMENSIONS, SOT23-5L A2 A A1 D e1 Symbol A A1 A2 b c D E1 E e e1 L L1 θ θ L E E1 L1 e b Dimensions In Millimeters Min Max 1.25 0.04 0.10 1.00 1.20 0.33 0.41 0.15 0.19 2.820 3.02 1.50 1.70 2.60 3.00 0.95 BSC 1.90 BSC 0.60 REF 0.30 0.60 0° 8° Dimensions In Inches Min Max 0.049 0.002 0.004 0.039 0.047 0.013 0.016 0.006 0.007 0.111 0.119 0.059 0.067 0.102 0.118 0.037 BSC 0.075 BSC 0.024 REF 0.012 0.024 0° 8° c RECOMMENDED SOLDERING FOOTPRINT, SOT23-5L 1.0 0.039 0.95 0.037 0.95 0.037 0.7 0.028 2.4 0.094 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. mm ( inches ) FN1617-32.1a — Data Sheet Ultra-Low Power 310nA, 1.7V, RRI, CMOS Input Comparators LTC8701, LTC8702, LTC8703, LTC8704 P-16 Package Outlines (continued) DIMENSIONS, SC70-5L (SOT353) A2 A Symbol A1 D e1 A A1 A2 b C D E E1 e e1 L L1 θ θ e L E1 E L1 b Dimensions In Millimeters Min Max 0.90 1.10 0.00 0.10 0.90 1.00 0.15 0.35 0.08 0.15 2.00 2.20 1.15 1.35 2.15 2.45 0.65 typ. 1.20 1.40 0.525 ref. 0.26 0.46 0° 8° C RECOMMENDED SOLDERING FOOTPRINT, SC70-5L (SOT353) 0.50 0.0197 0.65 0.025 0.65 0.025 0.40 0.0157 1.9 0.0748 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. mm ( inches ) Dimensions In Inches Min Max 0.035 0.043 0.000 0.004 0.035 0.039 0.006 0.014 0.003 0.006 0.079 0.087 0.045 0.053 0.085 0.096 0.026 typ. 0.047 0.055 0.021 ref. 0.010 0.018 0° 8° FN1617-32.1a — Data Sheet Ultra-Low Power 310nA, 1.7V, RRI, CMOS Input Comparators LTC8701, LTC8702, LTC8703, LTC8704 P-17 Package Outlines (continued) DIMENSIONS, SOIC-8L A2 A A1 D b Symbol e A A1 A2 b C D E E1 e L θ L E E1 θ Dimensions In Millimeters Min Max 1.370 1.670 0.070 0.170 1.300 1.500 0.306 0.506 0.203 TYP. 4.700 5.100 3.820 4.020 5.800 6.200 1.270 TYP. 0.450 0.750 0° 8° Dimensions In Inches Min Max 0.054 0.066 0.003 0.007 0.051 0.059 0.012 0.020 0.008 TYP. 0.185 0.201 0.150 0.158 0.228 0.244 0.050 TYP. 0.018 0.030 0° 8° C RECOMMENDED SOLDERING FOOTPRINT, SOIC-8L 8X 5.40 0.213 (1.55) MAX (0.061) (3.90) MIN (0.154) 1 (0.60) MAX 8X (0.024) PITCH 1.270 0.050 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. mm ( inches ) FN1617-32.1a — Data Sheet Ultra-Low Power 310nA, 1.7V, RRI, CMOS Input Comparators LTC8701, LTC8702, LTC8703, LTC8704 P-18 Package Outlines (continued) DIMENSIONS, MSOP-8L A2 A A1 D b Symbol e A A1 A2 b C D E E1 e L θ L E1 E Dimensions In Millimeters Min Max 0.800 1.100 Dimensions In Inches Min Max 0.031 0.043 0.050 0.150 0.750 0.950 0.290 0.380 0.150 0.200 2.900 3.100 2.900 3.100 4.700 5.100 0.650 TYP. 0.400 0.700 0° 8° 0.002 0.006 0.030 0.037 0.011 0.015 0.006 0.008 0.114 0.122 0.114 0.122 0.185 0.201 0.026 TYP. 0.016 0.028 0° 8° θ C RECOMMENDED SOLDERING FOOTPRINT, MSOP-8L 8X (0.45) MAX (0.018) (1.45) MAX (0.057) 8X 4.40 (5.85) MAX 0.173 (0.230) (2.95) MIN (0.116) 0.65 PITCH 0.026 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. mm ( inches ) FN1617-32.1a — Data Sheet Ultra-Low Power 310nA, 1.7V, RRI, CMOS Input Comparators LTC8701, LTC8702, LTC8703, LTC8704 P-19 Package Outlines (continued) DIMENSIONS, DFN2x2-8L E A c A1 1 Nd D1 2 D b1 Exposed Thermal Pad Zone L h E1 h 2 e Symbol Min. 0.70 A A1 b b1 c D D1 Nd E E1 e L h 0.20 0.18 1.90 1.10 1.90 0.60 0.30 0.15 Millimeters Nom. 0.75 0.02 0.25 0.18 REF 0.20 2.00 1.20 1.50BSC 2.00 0.70 0.50BSC 0.35 0.20 1 b BOTTOM VIEW RECOMMENDED SOLDERING FOOTPRINT, DFN2x2-8L 1.60 0.0630 PACKAGE OUTLINE 8X 0.50 0.0197 1.00 0.0394 2.30 0.0906 1 0.50 PITCH 0.0197 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. 0.30 8X 0.0118 mm ( inches ) Max. 0.80 0.05 0.30 0.25 2.10 1.30 2.10 0.80 0.40 0.25 FN1617-32.1a — Data Sheet Ultra-Low Power 310nA, 1.7V, RRI, CMOS Input Comparators LTC8701, LTC8702, LTC8703, LTC8704 P-20 Package Outlines (continued) DIMENSIONS, SOIC-14L A3 A2 A A1 D b C e L1 L E Symbol E1 A A1 A2 A3 b C D E E1 e L1 L θ Dimensions In Millimeters Min Max 1.450 1.850 0.100 0.300 1.350 1.550 0.550 0.750 0.406 TYP. 0.203 TYP. 8.630 8.830 5.840 6.240 3.850 4.050 1.270 TYP. 1.040 REF. 0.350 0.750 2° 8° Dimensions In Inches Min Max 0.057 0.073 0.004 0.012 0.053 0.061 0.022 0.030 0.016 TYP. 0.008 TYP. 0.340 0.348 0.230 0.246 0.152 0.159 0.050 TYP. 0.041 REF. 0.014 0.030 2° 8° θ RECOMMENDED SOLDERING FOOTPRINT, SOIC-14L 14X 5.40 0.213 (1.50) MAX (0.059) (3.90) MIN (0.154) 1 (0.60) MAX 14X (0.024) PITCH 1.270 0.050 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. mm ( inches ) FN1617-32.1a — Data Sheet Ultra-Low Power 310nA, 1.7V, RRI, CMOS Input Comparators LTC8701, LTC8702, LTC8703, LTC8704 P-21 Package Outlines (continued) DIMENSIONS, TSSOP-14L A3 A2 A Symbol A1 D b e C L1 L E E1 A A1 A2 A3 b C D E E1 e L1 L θ Dimensions In Millimeters Min Max 1.200 0.050 0.150 0.900 1.050 0.390 0.490 0.200 0.290 0.130 0.180 4.860 5.060 6.200 6.600 4.300 4.500 0.650 TYP. 1.000 REF. 0.450 0.750 0° 8° Dimensions In Inches Min Max 0.047 0.002 0.006 0.035 0.041 0.015 0.019 0.008 0.011 0.005 0.007 0.191 0.199 0.244 0.260 0.169 0.177 0.026 TYP. 0.039 REF. 0.018 0.030 0° 8° θ RECOMMENDED SOLDERING FOOTPRINT, TSSOP-14L 14X (1.45) MAX (0.057) (4.40) MIN (0.173) PITCH 0.65 0.026 1 5.90 0.232 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. 14X (0.45) MAX (0.018) mm ( inches ) FN1617-32.1a — Data Sheet Ultra-Low Power 310nA, 1.7V, RRI, CMOS Input Comparators P-22 LTC8701, LTC8702, LTC8703, LTC8704 IMPORTANT NOTICE Linearin is a global fabless semiconductor company specializing in advanced high-performance high- quality analog/mixed-signal IC products and sensor solutions. The company is devoted to the innovation of high performance, analog-intensive sensor front-end products and modular sensor solutions, applied in multi-market of medical & wearable devices, smart home, sensing of IoT, and intelligent industrial & smart factory (industrie 4.0). Linearin’s product families include widely-used standard catalog products, solution-based application specific standard products (ASSPs) and sensor modules that help customers achieve faster time-to-market products. Go to http://www.linearin.com for a complete list of Linearin product families. For additional product information, or full datasheet, please contact with the Linearin’s Sales Department or Representatives. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-32.1a — Data Sheet Ultra-Low Power 310nA, 1.7V, RRI, CMOS Input Comparators
LTC8702YV8/R6 价格&库存
很抱歉,暂时无法提供与“LTC8702YV8/R6”相匹配的价格&库存,您可以联系我们找货
LTC8702YV8/R6
  • 1+4.50360
  • 10+3.74760
  • 30+3.36960
库存:7
