LTC5223YV10
LTC5223YV10
    LINEARIN(先积)
    MSOP-10
    模拟开关
LTC5223YV10 数据手册
LTC5223 P-1 DESCRIPTION The LTC5223 is an advanced CMOS analog switch fabricated in Sub−micron silicon gate CMOS technology. The part also features guaranteed Break Before Make (BBM) switching, assuring the switches never short the driver. FEATURES             Ultra-Low RON : 0.55 Ω - Maximum at VCC = 4.3 V Wide Supply Voltage Range: Single 1.65 V to 5.5 V Low Crosstalk Full 0 ~ VCC Signal Handling Capability High Off − Channel Isolation Low Standby Current: 50 nA Maximum Low Distortion RON Flatness: 0.15 Ω High Continuous Current Capability: ±300 mA Through Each Switch Suitable for Audio Block Switching, Ring-Tone Chips, Amplifier Switching, and Modems, etc. ESD : Human Body Model > 4 kV (Reference Document: MIL-STD-883H Method 3015.8) Available Packages: QFN1.8×1.4-10L, DFN3x3-10L, and MSOP-10L PIN CONFIGURATION (Top View) NC2 GND IN2 8 COM2 NO2 7 6 5 NC1 9 4 IN1 10 3 COM1 XCC 1 10 No2 NO1 2 9 COM2 COM1 3 8 IN2 1 1 IN1 4 7 NC2 VCC NO1 NC1 5 6 GND QFN 1.8 X 1.4-10L DFN 3 X 3-10L XCC 1 10 No2 NO1 2 9 COM2 COM1 3 8 IN2 IN1 4 7 NC2 NC1 5 6 GND MSOP-10L CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1620-22.1 — Data Sheet Ultra-Low 0.5Ω Dual SPDT Analog Switch LTC5223 P-2 ORDER INFORMATION Model LTC5223 Package Ordering Number Packing Option QFN1.8×1.4-10L LTC5223YFS10 Tape and Reel, 3 000 DFN3×3-10L LTC5223YF10 Tape and Reel, 3 000 MSOP-10L LTC5223YV10 Tape and Reel, 4 000 PIN DESCRIPTIONS Pin Symbol Description 1 VCC Power Supply 2 NO1 Independent Channels 3 COM1 Common Channels 4 IN1 Controls 5 NC1 Independent Channels 6 GND Ground (V) 7 NC2 Independent Channels 8 IN2 Controls 9 COM2 Common Channels 10 NO2 Independent Channels TRUTH TABLE IN1, IN2 NO1, NO2 NC1, NC2 0 OFF ON 1 ON OFF CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1620-22.1 — Data Sheet Ultra-Low 0.5Ω Dual SPDT Analog Switch LTC5223 P-3 RECOMMENDED OPERATING CONDITIONS Characteristic Symbol Min Max Unit DC Supply Voltag VCC 1.65 5.5 V Digital Select Input Voltage VIN GND 5.5 V Analog Input Voltage VIS GND VCC V Operating Temperature Range TA -45 +85 ℃ 0 20 0 10 Input Rise or Fall Time SELECT VCC = 1.6 V to 2.7 V VCC = 3.0 V to 5.5 V tR, tF ns/V ABSOLUTE MAXIIMUM RATINGS Characteristic Symbol Value Unit Supply Voltage VCC -0.5 to 6.0 V Analog Input Voltage VIS -0.5 to VCC + 0.5 V Digital Select Input Voltage VIN -0.5 to 6.0 V Output Voltage VOUT -0.5 to VCC + 0.5 V Continuous DC Current from COM to NC/NO Ian1 ±300 mA Ian1-pk1 ±500 mA Iclmp ±100 mA Peak Current from COM to NC/NO, 10 duty cycle (Note 1) Continuous DC Current into COM/NO/NC with respect to VCC or GND Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Note 1. Defined as 10% ON, 90% off duty cycle. CAUTION This integrated circuit can be damaged by ESD if you don’t pay attention to ESD protection. Lineaein recommends that all integrated circuits be handled with appropriate precautions. Failure to observe proper handling and installation procedures can cause damage. ESD damage can range from subtle performance degradation to complete device failure. Precision integrated circuits may be more susceptible to damage because very small parametric changes could cause the device not to meet its published specifications. Linearin reserves the right to make any change in circuit design, specification or other related things if necessary without notice at any time. Please contact Linearin sales office to get the latest data sheet. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1620-22.1 — Data Sheet Ultra-Low 0.5Ω Dual SPDT Analog Switch LTC5223 P-4 ELECTRICAL CHARACTERISTICS (DC) Symbol Parameter VIH VIL Test Conditions High-Level Input Voltage, Select Inputs Low−Level Input Voltage, Select Inputs VCC ± 10% TA = 25℃ Min Typ Max TA = –40 to +85℃ Min Max 1.65 ~ 1.95 1.1 1.1 2.3 ~ 2.5 1.2 1.2 2.7 ~ 3.0 1.3 1.3 3.0 ~ 3.6 1.4 1.4 4.3 1.5 Unit V 1.5 1.65 ~ 1.95 0.25 0.25 2.3 ~ 2.5 0.25 0.25 2.7 ~ 3.0 0.25 0.25 3.0 ~ 3.6 0.30 0.30 4.3 0.40 0.40 V IIN Maximum Input Leakage Current, Select Inputs VIN =VCC or GND 4.3 ±0.1 ±1.0 μA IOFF Power Off Leakage Current VIN =VCC or GND 0 ±0.5 ±2.0 μA ICC Maximum Quiescent Supply Current (Note 2) Select, VIS = VCC or GND 1.65 ~ 4.3 ±1.0 ±2.0 μA INO (OFF) INC (OFF) NC or NO Off Leakage Current VIN = VIL or VIH VNO or VNC = 0.3 V VCOM = 4.0 V 10 nA 4.3 -5.0 5.0 -10 4.3 -10 10 -100 100 COM ON Leakage Current (Note 3) ICOM (ON) RON RFLAT ∆RON VIN = VIL or VIH, VNO = 0.3 V or 4.0 V VNC floating VNC = 0.3 V or 4.0 V VNO floating VCOM = 0.3 V or 4.0 V OnResistance (Note 3) On−Resistance Flatness (Note 3) (Note 5) On-Resistance Match Between Channels (Note 3) (Note 4) VIS = GND to VCC, IIN = 100 mA ICOM = 100 mA VIS = 1.5 V ICOM = 100 mA VIS = 1.5 V 4.3 0.45 0.5 0.55 3.6 0.5 0.55 0.65 3.0 0.5 0.55 0.65 2.7 0.6 0.7 0.8 2.3 0.6 0.7 0.8 1.8 0.9 1.0 1.1 4.3 0.15 0.20 0.20 3.6 0.15 0.20 0.20 3.0 0.15 0.20 0.20 2.7 0.15 0.20 0.20 2.3 0.20 0.25 0.25 1.8 0.35 0.45 0.45 2.7 0.1 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. nA Ω Ω Ω FN1620-22.1 — Data Sheet Ultra-Low 0.5Ω Dual SPDT Analog Switch LTC5223 P-5 ELECTRICAL CHARACTERISTICS (AC) Symbol Parameter tPLH tPHL Propagation Delay tON Turn−On Time (Figure 1) Test Conditions VIS = 0.8 V VIS = 1.5 V VIS = 0.8 V tOFF tBBM BW Turn−Off Time (Figure 1) VIS = 1.5 V Break-Before-MakeTime (Note6)( Figure 2) CL= 35 pF RIS = 50 Ω VIS = 1.5 V On-Channel, -3 dB Bandwidth or Frequency Response (Figure 4) VCC ± 10% 1.65 ~ 1.95 2.3 ~ 2.7 3.0 ~ 3.3 3.6 ~ 5 1.65 ~ 1.95 2.3 ~ 2.7 3.0 ~ 3.3 3.6 ~ 4.3 1.65 ~ 1.95 2.3 ~ 2.7 3.0 ~ 3.3 3.6 ~ 4.3 1.65 ~ 1.95 2.3 ~ 2.7 3.0 ~ 3.3 3.6 ~ 4.3 Min 2 2 2 2 TA = 25℃ Typ Max 0.30 0.25 0.20 0.20 120 65 85 42 55 40 55 45 18 30 16 30 15 30 17 10 8 7 Unit ns ns ns ns 1.65 ~ 4.3 18 MHz FIS = 100 kHz, VIN = GND to VCC, CL = 5 pF RL = 50 Ω, VIS = 1VRMS 1.65 ~ 4.3 -66 dB Charge Injection Select Input to Common I/O (Figure 3) 1.65 ~ 1.95 43 2.3 ~ 2.7 3.0 ~ 3.3 3.6 ~ 4.3 51 51 49 pC 3.0 0.08 % 1.65 ~ 4.3 -72 dB RIS = 50 Ω Off-Channel Isolation (Figure 4) VISO Q VIN = 0 or VCC, RIS = 0 Ω, CL = 100 pF RL = 1 mΩ, Q = CL × ∆VOUT Total Harmonic Distortion THD +Noise THD FIS = 20 Hz to 20 kHz, RL = 600 Ω CL = 50 pF VIS = 2 VRMS Channel - to - Channel Crosstalk (Figure 4) VCT FIS = 100 kHz, VIN = GND to VCC RL = 50 Ω, CL = 5 pF, VIS = 1 VRMS CIN Control Pin Input Capacitance 3.6 3.5 pF CCN/CNO NC/NO Port Capacitance 3.6 60 pF CCOM COM Port Capacitance When Switch is Enabled 3.6 200 pF Note: 2. Guaranteed by design. 3. Guaranteed by design. Resistance measurements do not include test circuit or package resistance. 4. ∆RON = RON (MAX) − RON (MIN) between NC1 and NC2 or between NO1 and NO2. 5. Flatness is defined as the difference between the maximum and minimum value of on−resistance as measured over the specified analog signal ranges. 6. Guaranteed by design in -40℃. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1620-22.1 — Data Sheet Ultra-Low 0.5Ω Dual SPDT Analog Switch LTC5223 P-6 TEST CIRCUITS DUT VCC 0.1μF Output VOUT Open 50Ω 35pF Input DUT VCC 0.1μF Output VOUT Open 50Ω 35pF Input Figure 1. tON/tOFF DUT VCC Output 0.1μF VOUT 50Ω 35pF Swith Select Pin Figure 2. tBBM DUT Open Output CL VIN Figure3: Charge Injection CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1620-22.1 — Data Sheet Ultra-Low 0.5Ω Dual SPDT Analog Switch LTC5223 P-7 TEST CIRCUITS (Cont.) Reference 50Ω DUT Input Output Transmitted 50Ω Generator 50Ω VISO = 20log (VOUT/VIN) VONL = 20log (VOUT/VIN) VCT = 20log (VOUT/VIN) BW = the frequency 3dB below V ONL Figure 4. -3dB Bandwidth/Off Channel Isolation/On Channel Loss(BW)/Crosstalk (On Channel to Off Channel)/V ONL TEST CIRCUITS (Cont.) CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1620-22.1 — Data Sheet Ultra-Low 0.5Ω Dual SPDT Analog Switch LTC5223 P-8 PACKAGE OUTLINE QFN1.8×1.4-10L PIN 1 DOT BY MARKING b D L1 PIN 1 IDENTIFICATION CHAMFER L E e TOP VIEW BOTTOM VIEW A A1 A3 SIDE VIEW Dimensions In Millimeters (mm) Symbol Min. Nom. Max. A 0.500 0.550 0.600 A1 0.000 A3 0.050 0.15 REF D 1.350 1.400 1.450 E 1.750 1.800 1.850 b 0.150 0.200 0.250 L 0.300 0.400 0.500 L1 0.400 0.500 0.600 e 0.40 BSC CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1620-22.1 — Data Sheet Ultra-Low 0.5Ω Dual SPDT Analog Switch LTC5223 P-9 PACKAGE OUTLINE DFN3×3-10L b D L1 k R E D2 (C=0.25) E2 LASER MARK L TOP VIEW e BOTTOM VIEW A A1 A3 SIDE VIEW Symbol A A1 A3 b D D2 e E E2 L k R Dimensions In Millimeters (mm) Min. Max. 0.700 0.800 0.000 0.050 0.203REF 0.180 0.300 2.900 3.100 2.450 2.550 0.400 0.600 2.900 3.100 1.450 1.650 0.350 0.450 0.150 0.090 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. b FN1620-22.1 — Data Sheet Ultra-Low 0.5Ω Dual SPDT Analog Switch LTC5223 P-10 PACKAGE OUTLINE MSOP-10L θ H C2 B1 B C3 C4 B2 A1 A2 A3 R A θ2 C1 θ3 R1 C θ Symbol A A1 A2 A3 B B1 B2 C C1 C2 Dimensions In Millimeters (mm) Min. 2.900 0.190 0.500 TYP 0.400 TYP 2.900 4.700 0.450 0.750 0.328 TYP CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. Max. 3.100 0.280 3.100 5.100 0.750 0.950 1.100 FN1620-22.1 — Data Sheet Ultra-Low 0.5Ω Dual SPDT Analog Switch
LTC5223YV10 价格&库存
很抱歉,暂时无法提供与“LTC5223YV10”相匹配的价格&库存,您可以联系我们找货
