LTC7227YFS10
LTC7227YFS10
    LINEARIN(先积)
    QFN-10
    模拟开关
LTC7227YFS10 数据手册
LTC7227 P-1 General Description The LTC7227 is 2 to 1 port analog switches. Their wide bandwidth and low bit-to-bit skew allow them to pass high-speed differential signals with good signal integrity. Each switch is bidirectional and offers little or no attenuation of the high-speed signals at the outputs. Industry-leading advantages include a propagation delay of less than 250 ps, resulting from its low channel resistance and low I/O capacitance. Their high channel-to-channel crosstalk rejection results in minimal noise interference. Their bandwidth is wide enough to pass High-Speed USB 2.0 differential signals (480 Mbps). Features          RON is Typically 6Ω at VCC = 3.3 V Low Bit-to-Bit Skew: Typically 50 ps Low Crosstalk: -45 dB @ 250 MHz Low Current Consumption: 1.0 µA Near-Zero Propagation Delay: 250 ps Channel On-Capacitance: 3.5pF Typically VCC Operating Range: 1.65 V to 4.5 V >750 MHz Bandwidth (or Data Frequency) Available Packages: QFN1.8× 1.4-10L and MSOP-10L Applications   Differential Signal Data Routing USB 2.0 Signal Routing Order Information MODEL PACKAGE ORDERING NUMBER QFN1.8×1.4-10L LTC7227YFS10 MSOP-10L LTC7227YV10 LTC7222 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1620-24.1 — Data Sheet High-Speed USB 2.0 (480 Mbps) DPDT Switches LTC7227 P-2 Pin Description HSD2+ HSD2OE 8 VCC S 7 6 VCC 1 10 OE 5 HSD+ SEL 2 9 HSD2+ 9 4 HSD1- D+ 3 8 HSD2- 10 3 GND D- 4 7 HSD1+ GND 5 6 HSD1- 1 2 D+ D- QFN 1.8 X 1.4-10L MSOP-10L Figure1. Top View Pin Function Pin Name Function SEL Select Input OE Output Enable HSD1+,HSD1-,HSD2+,HSD2-,D+,D- Data Ports Truth Table OE SEL HSD1+,HSD1- HSD2+,HSD2- 1 X OFF OFF 0 0 ON OFF 0 1 OFF ON CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1620-24.1 — Data Sheet High-Speed USB 2.0 (480 Mbps) DPDT Switches LTC7227 P-3 Absolute Maximum Ratings Symbol Pin Parameter Value Unit VCC VCC Positive DC Supply Voltage -0.5 to +6.0 V D+,D- Analog Signal Voltage -0.5 to +5.5 VIN OE ,SEL Control Input Voltage -0.5 to VCC V ICC VCC Positive DC Supply Current VIS HSD1+,HSD1-,HSD2+,HSD2- TS Storage Temperature -0.5 to VCC V 50 mA -65 to +150 ℃ IIS_CON HSD1+,HSD1-,HSD2+,HSD2D+,D- Analog Signal Continuous Current-Closed Switch ±100 mA IIS_PK HSD1+,HSD1-,HSD2+,HSD2D+,D- Analog Signal Continuous Current 10% Duty Cycle ±150 mA IIN OE Control Input Current ±20 mA All pin Human Body Model, JEDEC: JESD22-A114 >8 ESD Air Discharge Contact >15 IEC 61000-4-2 System on USB Connector Pins D+, D- kV >8 Charged Device Model, JEDEC: JESD22-C101 >2 Stresses exceeding Maximum Ratings may damage the device. Maximum Ratings are stress ratings only.Functional operation above the Recommended Operating Conditions is not implied. Extended exposure to stresses above the Recommended Operating Conditions may affect device reliability. RECOMMENDED OPERATING CONDITIONS Symbol Pins VCC VIS VIN TA HSD1+,HSD1-,HSD2+,HSD2- D+,DOE Parameter Min Max Unit Positive DC Supply Voltage 1.65 4.5 V GND VCC GND 4.5 Digital Select Input Voltage GND VCC V Operating Temperature Range -40 +85 ℃ Analog Signal Voltage V Minimum and maximum values are guaranteed through test or design across the Recommended Operating Conditions, where applicable. Typical values are listed for guidance only and are based on the particular conditions listed for section, where applicable. These conditions are valid for all values found in the characteristics tables unless otherwise specified in the test conditions. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1620-24.1 — Data Sheet High-Speed USB 2.0 (480 Mbps) DPDT Switches LTC7227 P-4 DC Electrical Characteristics CONTROL INPUT (Typical: T = 25° C, VCC = 3.3 V) -40℃ to +85℃ Test Conditions Symbol Pins Parameter VIH OE Control Input High Voltage VV OE Control Input Low Voltage IIN OE Control Input Leakage Current 0≤VIS≤VCC VCC (V) Unit Min Typ Max 2.7 3.3 4.2 1.3 1.4 1.6 - - V 2.7 3.3 4.2 - 0.4 0.4 0.5 V 1.65 – 4.5 - ±1.0 µA - SUPPLY AND LEAKAGE CURRENT ( Typical: T = 25° C, VCC = 3.3 V ) Symbol Pins Parameter Test Conditions VCC(V) ICC VCC Quiescent Supply Current VIS= VCC or GND IOUT=0A ICCT VCC Increase in ICC per Control Voltage IOZ HSD1+ HSD1HSD2+ HSD2- IOFF D+,D- -40℃ to +85℃ unit Min Max 1.65 – 4.5 - 1.0 µA VIN=2.6V 3.6 - 10 µA OFF Stage Leakage Current 0≤VIS≤VCC 1.65 – 4.5 - ±1.0 µA Power OFF Leakage Current 0≤VIS≤4.5V 0 - ±1.0 µA HIGH SPEED ON RESISTANCE (Typical: T = 25° C, VCC = 3.3 V) Symbol Pins Parameter Test Conditions RON On-Resistance VIS = 0 V to 0.4 V, ION =8 mA RFLAT On-Resistance Flatness △RON On-Resistance Matching VCC(V) -40℃ to +85℃ Unit Min Typ Max 3.3 - 6.0 10 Ω VIS = 0 V to 1.0 V, ION =8 mA 3.3 - 0.5 - Ω VIS = 0 V to 0.4 V, ION =8 mA 3.3 - 0.2 - Ω CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1620-24.1 — Data Sheet High-Speed USB 2.0 (480 Mbps) DPDT Switches LTC7227 P-5 TIMING/FREQUENCY (Typical: T = 25° C, VCC = 3.3V, RL = 50Ω, CL = 5 pF, f = 1MHz) Symbol Pins Parameter tON Closed to Open Turn-ON Time tOFF Open to Closed Turn-OFF Time tBBM Break-BeforeMa ke Delay BW -3dB Bandwidth Test Conditions VIS = 0 V to VCC, ION = 8 mA VCC (V) -40℃ to +85℃ Min Typ Max unit 1.65- 4.5 - 14 30 ns 1.65- 4.5 - 10 20 ns 1.65- 4.5 CL=5pF 3.0- 4.5 CL=0pF 2.20 2.45 2.65 - - - 550 - - 900 - ns MHz ISOLATION (Typical: T = 25° C, VCC = 3.3V, RL = 50Ω, CL = 5 pF, f = 1 MHz) Symbol Pin Parameter Test Conditions OIRR Open OFF-Isolation f=250 MHz XTALK HSD1+ to HSD1- Non-Adjacent Channel f=250 MHz Crosstalk VCC (V) -40℃ to +85℃ unit Min Typ Max 1.65- 4.5 - -30 - dB 1.65- 4.5 - -45 - dB CAPACITANCE (Typical: T = 25° C, VCC = 3.3 V, RL = 50Ω, CL = 5 pF, f = 1 MHz) Symbol Pins Parameter CIN OE Control Pin Input Capacitance CON D+ to HSD1+ or HSD2+ ON Capacitance COFF HSD2+, HSD2- OFF Capacitance Test Conditions VCC (V) -40℃ to +85℃ Min Typ Max unit 0 1.8 pF OE= 0 V 3.3 4.0 pF VIS = 3.3 V OE=3.3 V 3.3 2.2 pF Figure2-a. ICC vs. VIN CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1620-24.1 — Data Sheet High-Speed USB 2.0 (480 Mbps) DPDT Switches LTC7227 P-6 Figure2-b. Response vs. frequency Figure2-c. Response vs. frequency DUT VCC Output 0.1μF VOUT 50Ω 35pF Swith Select Pin Figure3. tBBM (Time Break-Before-Make) DUT VCC 0.1μF Output VOUT Open 50Ω 35pF Input Figure 4. tON/tOFF VCC DUT 50Ω Output Open VOUT 35pF Input Figure 5. tON/tOFF CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1620-24.1 — Data Sheet High-Speed USB 2.0 (480 Mbps) DPDT Switches LTC7227 P-7 Reference 50Ω DUT Input Output Transmitted 50Ω Generator 50Ω Figure6. Off Channel Isolation/On Channel Loss (BW)/Crosstalk (On Channel to Off Channel)/V ONL Channel switch control/s test socket is normalized. Off isolation is measured across an off channel. On loss is the bandwidth of an On switch. VISO, Bandwidth and VONL are independent of the input signal direction. VOUT VISO = Off Channel Isolation = 20 Log VONL = On Channel Loss = 20 Log VIN VOUT VIN for VIN at 100 kHz for VIN at 100 kHz Bandwidth (BW) = the frequency 3 dB below VONL VCT = Use VISO setup and test to all other switch analog input/outputs terminated with 50Ω CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1620-24.1 — Data Sheet High-Speed USB 2.0 (480 Mbps) DPDT Switches P-8 LTC7227 Typical Performance Curves TA = +25° C, Unless Otherwise Specified (Continued) Figure7. EYE PATTERN: 480Mbps WITH USB SWITCHES IN THE SIGNAL PATH Figure8. EYE PATTERN: 480Mbps WITH USB SWITCHES IN THE SIGNAL PATH CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1620-24.1 — Data Sheet High-Speed USB 2.0 (480 Mbps) DPDT Switches LTC7227 P-9 Package Dimension QFN1.8×1.4-10L 0.50± 0.10 0.20±0.05 Side View 0.40 BSC Bottom View Unit:mm MSOP-10L 2.90~3.10 4.75~5.05 0.18~0.28 0°~6° 0.75~0.95 0.02~0.15 0.40~0.80 0.09~0.23 2.90~3.10 0.82~1.10 0.50 0.15 REF 0~0.05 0.55± 0.05 1.800±0.05 0.40± 0.10 1.400±0.05 PIN 1 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. Unit:mm FN1620-24.1 — Data Sheet High-Speed USB 2.0 (480 Mbps) DPDT Switches
LTC7227YFS10 价格&库存
很抱歉,暂时无法提供与“LTC7227YFS10”相匹配的价格&库存,您可以联系我们找货
