LTC358XF8/R6
LTC358XF8/R6
    LINEARIN(先积)
    DFN8L
    双,通用,1.2MHz,RRIO,1.8V CMOS放大器
LTC358XF8/R6 数据手册
LTC321, LTC358, LTC324 P-1 General Description The LTC321/LTC358/LTC324 family of single-, dual-, and quad- channel operational amplifiers is specifically designed for general-purpose cost-sensitive systems and applications. Featuring rail-to-rail input and output (RRIO) swings, and low quiescent current (typical 85 µA) combined with a wide bandwidth (1.2 MHz) and low noise (30 nV/√Hz at 1 kHz) makes this family very attractive for a variety of battery-powered applications that require a good balance between cost and performance, such as audio outputs, consumer electronics, smoke detectors, portable medical devices and white goods. The low input bias current supports these amplifiers to be used in applications with mega-ohm source impedances. The robust design of the LTC321/LTC358/LTC324 family provides ease-of-use to the circuit designer: unity-gain stability with capacitive loads of up to 500 pF, integrated RF/EMI rejection filter, no phase reversal in overdrive conditions, and high electro-static discharge (ESD) protection (5-kV HBM). The LTC321/LTC358/LTC324 amplifiers are optimized for operation at voltages as low as +1.8 V (±0.9 V) and up to +5.5 V (±2.75 V), and over the extended temperature range of −40 ℃ to +125 ℃. The LTC321 (single) is available in both SOT23-5L and SC70-5L packages. The LTC358 (dual) is offered in SOIC-8L, DFN-8L and MSOP-8L packages. The quad-channel LTC324 is offered in SOIC-14L, TSSOP-14L and QFN-16L packages. Features and Benefits          General Purpose Amplifiers for Cost-Sensitive Systems 1.2 MHz GBW for Unity-Gain Stable Micro-Power: 85 μA Supply Current Per Amplifier Low Input Offset Voltage: ±3.0 mV Maximum Low Noise: 30 nV/√Hz at 1 kHz Single 1.8 V to 5.5 V Supply Voltage Range Rail-to-Rail Input and Output Internal RF/EMI Filter Extended Temperature Range: −40℃ to +125℃ Applications  Battery-Powered Instruments: – Consumer, Industrial, Medical, Notebooks  Audio Outputs  Wireless Sensors: – Home Security, Remote Sensing, Wireless Metering  Sensor Signal Conditioning: – Sensor Interfaces, Loop-Powered, Active Filters Pin Configurations (Top View) 3 4 OUT OUTA 1 8 +VS –INA 2 7 OUTB +INA 3 6 –INB –VS 4 5 +INB SOIC-8L / MSOP-8L OUTA –INA 1 2 +INA 3 –VS 4 8 7 A B +VS OUTB 6 –INB 5 +INB 16 15 14 13 +INA 1 12 +IND +VS 2 11 –VS +INB 3 10 +INC –INB 4 9 –INC 5 6 7 8 OUTC –IN 5 +VS NC 2 NC 1 OUTB +IN –VS –IND LTC324 SOIC-14L / TSSOP-14L OUTD LTC324 QFN3x3-16L OUTA LTC358 DFN2x2-8L –INA LTC321 SOT23-5L / SC70-5L CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. OUTA 1 14 OUTD –INA 2 13 –IND +INA 3 12 +IND +VS 4 11 –VS +INB 5 10 +INC –INB 6 9 –INC OUTB 7 8 OUTC A B D C FN1617-33GL.3b — Data Sheet General Purpose 1.2MHz, RRIO, 1.8V CMOS Amplifiers LTC321, LTC358, LTC324 P-2 Pin Description Symbol Description –IN Inverting input of the amplifier. The voltage range is from (VS– – 0.1V) to (VS+ + 0.1V). +IN Non-inverting input of the amplifier. This pin has the same voltage range as –IN. +VS Positive power supply. –VS Negative power supply. OUT Amplifier output. Ordering Information Type Number Package Name Package Quantity Marking Code (1) LTC321XT5/R6 SOT23-5L Tape and Reel, 3 000 321, 321I LTC321XC5/R6 SC70-5L Tape and Reel, 3 000 321 LTC358XS8/R8 SOIC-8L Tape and Reel, 4 000 358 x, C42 LTC358XF8/R6 DFN2x2-8L Tape and Reel, 3 000 358x, C42 LTC358XV8/R6 MSOP-8L Tape and Reel, 3 000 358x, AG2 LTC324XS14/R5 SOIC-14L Tape and Reel, 2 500 324 x, C44 LTC324XT14/R6 TSSOP-14L Tape and Reel, 3 000 324 x, AG4 LTC324XF16/R6 QFN3x3-16L Tape and Reel, 3 000 AG4x, 324x (1) There may be multiple device markings, a varied marking character of “x” , or additional marking, which relates to the logo, the lot trace code information, or the environmental category on the device. Limiting Value In accordance with the Absolute Maximum Rating System (IEC 60134). Parameter Absolute Maximum Rating Supply Voltage, VS+ to VS– 10.0 V Signal Input Terminals: Voltage, Current VS– – 0.5 V to VS+ + 0.5 V, ±10 mA Output Short-Circuit Continuous Storage Temperature Range, Tstg –65 ℃ to +150 ℃ Junction Temperature, TJ 150 ℃ Lead Temperature Range (Soldering 10 sec) 260 ℃ ESD Rating Parameter Electrostatic Discharge Voltage Item Value Human body model (HBM), per MIL-STD-883J / Method 3015.9 (1) ±5 000 Charged device model (CDM), per ESDA/JEDEC JS-002-2014 (2) ±2 000 Machine model (MM), per JESD22-A115C ±250 Unit V (1) JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process. Manufacturing with less than 500-V HBM is possible if necessary precautions are taken. (2) JEDEC document JEP157 states that 250-V CDM allows safe manufacturing with a standard ESD control process. Manufacturing with less than 250-V CDM is possible if necessary precautions are taken. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-33GL.3b — Data Sheet General Purpose 1.2MHz, RRIO, 1.8V CMOS Amplifiers LTC321, LTC358, LTC324 P-3 Electrical Characteristics VS = 5.0V, TA = +25℃, VCM = VS /2, VO = VS /2, and RL = 10kΩ connected to VS /2, unless otherwise noted. Boldface limits apply over the specified temperature range, TA = −40 to +125 ℃. Symbol Parameter Conditions Min. Typ. Max. Unit ±0.7 ±3.0 mV ±1 3.5 μV/℃ OFFSET VOLTAGE VOS Input offset voltage VOS TC Offset voltage drift TA = −40 to +125 ℃ PSRR Power supply rejection ratio VS = 2.0 to 5.5 V, VCM < VS+ − 2V 80 TA = −40 to +125 ℃ 75 110 dB INPUT BIAS CURRENT 5 IB IOS Input bias current 50 TA = −40 to +85 ℃ 200 TA = −40 to +125 ℃ 2000 Input offset current 10 50 pA pA NOISE Vn Input voltage noise f = 0.1 to 10 Hz 6 en Input voltage noise density f = 10 kHz 27 f = 1 kHz 30 In Input current noise density f = 1 kHz 5 μVP-P nV/√Hz fA/√Hz INPUT VOLTAGE VCM CMRR Common-mode voltage range Common-mode rejection ratio VS––0.1 VS = 5.5 V, VCM = −0.1 to 5.6 V 70 VCM = 0 to 5.3 V, TA = −40 to +125 ℃ 65 VS = 2.0 V, VCM = −0.1 to 2.1 V 65 VCM = 0 to 1.8 V, TA = −40 to +125 ℃ 60 VS++0.1 V 83 77 dB INPUT IMPEDANCE CIN Input capacitance Differential 2.0 Common mode 3.5 pF OPEN-LOOP GAIN AVOL Open-loop voltage gain RL = 50 kΩ, VO = 0.05 to 3.5 V 90 TA = −40 to +125 ℃ 85 RL = 2 kΩ, VO = 0.15 to 3.5 V 85 TA = −40 to +125 ℃ 80 105 100 dB FREQUENCY RESPONSE GBW Gain bandwidth product SR Slew rate G = +1, CL = 100 pF, VO = 1.5 to 3.5 V THD+N Total harmonic distortion + noise G = +1, f = 1 kHz, VO = 1 VRMS tS Settling time tOR Overload recovery time 1.2 MHz 1 V/μs 0.003 % To 0.1%, G = +1, 1V step 1.5 To 0.01%, G = +1, 1V step 1.8 To 0.1%, VIN * Gain > VS 2.5 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. μs μs FN1617-33GL.3b — Data Sheet General Purpose 1.2MHz, RRIO, 1.8V CMOS Amplifiers LTC321, LTC358, LTC324 P-4 Electrical Characteristics (continued) VS = 5.0V, TA = +25℃, VCM = VS /2, VO = VS /2, and RL = 10kΩ connected to VS /2, unless otherwise noted. Boldface limits apply over the specified temperature range, TA = −40 to +125 ℃. Symbol Parameter Conditions Min. Typ. Max. Unit OUTPUT VOH High output voltage swing RL = 50 kΩ VS+–6 VS+–3 RL = 2 kΩ VS+–100 VS+–65 VOL Low output voltage swing RL = 50 kΩ VS–+2 VS–+4 RL = 2 kΩ VS–+42 VS–+65 ISC Short-circuit current Source current through 10Ω 40 Sink current through 10Ω 50 mV mV mA POWER SUPPLY VS Operating supply voltage IQ Quiescent current (per amplifier) 1.8 5.5 85 TA = −40 to +125 ℃ 120 150 V μA THERMAL CHARACTERISTICS TA θJA Operating temperature range Package Thermal Resistance –40 +125 SC70-5L 333 SOT23-5L 190 DFN2x2-8L 94 MSOP-8L 201 SOIC-8L 125 QFN3x3-16L 65 TSSOP-14L 112 SOIC-14L 115 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. ℃ ℃/W FN1617-33GL.3b — Data Sheet General Purpose 1.2MHz, RRIO, 1.8V CMOS Amplifiers LTC321, LTC358, LTC324 P-5 Typical Performance Characteristics At TA = +25℃, VCM = VS /2, and RL = 10kΩ connected to VS /2, unless otherwise noted. 100 AOL (dB) 80 60 40 20 0 -20 -40 10 100 1k 10k 100k 1M 1,000 Voltage Noise (nV/√Hz) 140 120 100 80 60 40 20 0 -20 -40 -60 -80 10M Phase (deg) 120 100 10 1 1 100 Frequency (Hz) Open-loop Gain and Phase as a function of Frequency. 140 120 100 100 PSRR (dB) 120 CMRR (dB) 1M Input Voltage Noise Spectral Density as a function of Frequency. 140 80 60 80 60 40 40 20 20 0 0 1 100 10k 1M 1 100 Frequency (Hz) 10k 1M Frequency (Hz) Common-mode Rejection Ratio as a function of Frequency. Power Supply Rejection Ratio as a function of Frequency. 120 Quiescent Current (μA) 125 Quiescent Current (μA) 10k Frequency (Hz) 100 75 50 25 100 80 60 40 0 1.5 2 2.5 3 3.5 4 4.5 5 5.5 6 -50 0 25 50 75 100 125 Temperature (℃) Supply Voltage (V) Quiescent Current as a function of Supply Voltage. -25 Quiescent Current as a function of Temperature. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-33GL.3b — Data Sheet General Purpose 1.2MHz, RRIO, 1.8V CMOS Amplifiers LTC321, LTC358, LTC324 P-6 Typical Performance Characteristics (continued) At TA = +25℃, VCM = VS /2, and RL = 10kΩ connected to VS /2, unless otherwise noted. 350 300 Sourcing Current 4 250 Output Voltage (V) Distribution (Unit) 5 VCM = –VS 200 150 100 50 –40℃ 3 +125℃ +25℃ 2 1 Sinking Current -3 -2.625 -2.25 -1.875 -1.5 -1.125 -0.75 -0.375 0 0.375 0.75 1.125 1.5 1.875 2.25 2.625 3 0 0 0 10 Offset Voltage (mV) 30 40 50 60 70 Output Current (mA) Output Voltage Swing as a function of Output Current. Offset Voltage Production Distribution 80 60 Short-circuit Current (mA) Short-circuit Current (mA) 20 60 –ISC 40 20 +ISC 0 –ISC 50 40 +ISC 30 20 2 2.5 3 3.5 4 4.5 5 5.5 -50 0 25 50 75 100 125 Temperature (℃) Supply Voltage (V) Short-circuit Current as a function of Supply Voltage. -25 Short-circuit Current as a function of Temperature. CL=100pF 1V/div 25mV/div CL=100pF 5μs/div Large Signal Step Response. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. 2μs/div Small Signal Step Response. FN1617-33GL.3b — Data Sheet General Purpose 1.2MHz, RRIO, 1.8V CMOS Amplifiers P-7 LTC321, LTC358, LTC324 Application Notes The LTC321/LTC358/LTC324 is a family of low-power, rail-to-rail input and output operational amplifiers specifically designed for portable applications. These devices operate from 1.8 V to 5.5 V, are unity-gain stable, and suitable for a wide range of generalpurpose applications. The class AB output stage is capable of driving ≤ 10-kΩ loads connected to any point between VS+ and ground. The input commonmode voltage range includes both rails, and allows the LTC321/LTC358/LTC324 family to be used in virtually any single-supply application. Rail-to-rail input and output swing significantly increases dynamic range, especially in low-supply applications, and makes them ideal for driving sampling analogto-digital converters (ADCs). The LTC321/LTC358/LTC324 features 1.2-MHz bandwidth and 1-V/μs slew rate with only 85-μA supply current per amplifier, providing good ac performance at very low power consumption. DC applications are also well served with a low input noise voltage of 30-nV/√Hz at 1-kHz, low input bias current, and an input offset voltage of ±3.0-mV maximum. The typical offset voltage drift is 1-μV/℃, over the full temperature range the input offset voltage changes only 100-μV (0.7-mV to 0.8-mV). OPERATING VOLTAGE The LTC321/LTC358/LTC324 family is optimized for operation at voltages as low as +1.8 V (±0.9 V) and up to +5.5 V (±2.75 V). In addition, many specifications apply from –40 ℃ to +125 ℃. Parameters that vary significantly with operating voltages or temperature are illustrated in the Typical Characteristics graphs. The typical input bias current of the LTC321/LTC358 /LTC324 during normal operation is approximately 5pA. In overdriven conditions, the bias current can increase significantly. The most common cause of an overdriven condition occurs when the operational amplifier is outside of the linear range of operation. When the output of the operational amplifier is driven to one of the supply rails, the feedback loop requirements cannot be satisfied and a differential input voltage develops across the input pins. This differential input voltage results in activation of parasitic diodes inside the front-end input chopping switches that combine with electromagnetic interference (EMI) filter resistors to create the equivalent circuit. Notice that the input bias current remains within specification in the linear region. INPUT EMI FILTER AND CLAMP CIRCUIT Figure 1 shows the input EMI filter and clamp circuit. The LTC321/LTC358/LTC324 op-amps have internal ESD protection diodes (D1, D2, D3, and D4) that are connected between the inputs and each supply rail. These diodes protect the input transistors in the event of electrostatic discharge and are reverse biased during normal operation. This protection scheme allows voltages as high as approximately 500-mV beyond the rails to be applied at the input of either terminal without causing permanent damage. These ESD protection current-steering diodes also provide in-circuit, input overdrive protection, as long as the current is limited to 20-mA as stated in the Absolute Maximum Ratings. VS+ NOTE: Supply voltages (VS+ to VS–) higher than +10 V can permanently damage the device. RAIL-TO-RAIL INPUT The input common-mode voltage range of the LTC321/LTC358/LTC324 extends 100-mV beyond the negative and positive supply rails. This performance is achieved with a complementary input stage: an Nchannel input differential pair in parallel with a Pchannel differential pair. The N-channel pair is active for input voltages close to the positive rail, typically VS+–1.4 V to the positive supply, whereas the Pchannel pair is active for inputs from 100-mV below the negative supply to approximately VS+–1.4 V. There is a small transition region, typically VS+–1.2 V to VS+–1 V, in which both pairs are on. This 200-mV transition region can vary up to 200-mV with process variation. Thus, the transition region (both stages on) can range from VS+–1.4 V to VS+–1.2 V on the low end, up to VS+–1 V to VS+–0.8 V on the high end. Within this transition region, PSRR, CMRR, offset voltage, offset drift, and THD can be degraded compared to device operation outside this region. D1 RS1 5kΩ IN+ D2 D3 CCM1 RS2 CDM 5kΩ IN– D4 CCM2 VS– Figure 1. Input EMI Filter and Clamp Circuit Operational amplifiers vary in susceptibility to EMI. If conducted EMI enters the operational amplifier, the dc offset at the amplifier output can shift from its nominal value when EMI is present. This shift is a result of signal rectification associated with the internal semiconductor junctions. Although all operational amplifier pin functions can be affected by EMI, the input pins are likely to be the most susceptible. The EMI filter of the LTC321/358/324 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-33GL.3b — Data Sheet General Purpose 1.2MHz, RRIO, 1.8V CMOS Amplifiers LTC321, LTC358, LTC324 P-8 Application Notes (continued) is composed of two 5-kΩ input series resistors (RS1 and RS2), two common-mode capacitors (CCM1 and CCM2), and a differential capacitor (CDM). These RC networks set the −3 dB low-pass cutoff frequencies at 35-MHz for common-mode signals, and at 22-MHz for differential signals. RAIL-TO-RAIL OUTPUT Designed as a micro-power, low-noise op-amp, the LTC321/358/324 delivers a robust output drive capability. A class AB output stage with common source transistors is used to achieve full rail-to-rail output swing capability. For resistive loads up to 50kΩ, the output swings typically to within 3-mV of either supply rail regardless of the power-supply voltage applied. Different load conditions change the ability of the amplifier to swing close to the rails. For resistive loads up to 2-kΩ, the output swings typically to within 65-mV of the positive supply rail and within 42-mV of the negative supply rail. provides the DC accuracy by connecting the inverting signal with the output. The CF and RISO serve to counteract the loss of phase margin by feeding the high frequency component of the output signal back to the amplifier’s inverting input, thereby preserving phase margin in the overall feedback loop. For no-buffer configuration, there are two others ways to increase the phase margin: (a) by increasing the amplifier’s gain, or (b) by placing a capacitor in parallel with the feedback resistor to counteract the parasitic capacitance associated with inverting node. CF VOUT VIN CAPACITIVE LOAD AND STABILITY CL The LTC321/LTC358/LTC324 family can safely drive capacitive loads of up to 500-pF in any configuration. As with most amplifiers, driving larger capacitive loads than specified may cause excessive overshoot and ringing, or even oscillation. A heavy capacitive load reduces the phase margin and causes the amplifier frequency response to peak. Peaking corresponds to over-shooting or ringing in the time domain. Therefore, it is recommended that external compensation be used if these op-amps must drive a load exceeding 500-pF. This compensation is particularly important in the unity-gain configuration, which is the worst case for stability. A quick and easy way to stabilize the op-amp for capacitive load drive is by adding a series resistor, RISO, between the amplifier output terminal and the load capacitance, as shown in Figure 2. RISO isolates the amplifier output and feedback network from the capacitive load. The bigger the RISO resistor value, the more stable VOUT will be. Note that this method results in a loss of gain accuracy because RISO forms a voltage divider with the RL. RISO RF RISO VOUT VIN CL Figure 2. Indirectly Driving Heavy Capacitive Load An improvement circuit is shown in Figure 3. It provides DC accuracy as well as AC stability. The RF RL Figure 3. Indirectly Driving Heavy Capacitive Load with DC Accuracy OVERLOAD RECOVERY Overload recovery is defined as the time required for the operational amplifier output to recover from a saturated state to a linear state. The output devices of the operational amplifier enter a saturation region when the output voltage exceeds the rated operating voltage, either because of the high input voltage or the high gain. After the device enters the saturation region, the charge carriers in the output devices require time to return back to the linear state. After the charge carriers return back to the linear state, the device begins to slew at the specified slew rate. Thus, the propagation delay in case of an overload condition is the sum of the overload recovery time and the slew time. The overload recovery time for the LTC321/LTC358/LTC324 is approximately 2.5-μs. EMI REJECTION RATIO Circuit performance is often adversely affected by high frequency EMI. When the signal strength is low and transmission lines are long, an op-amp must accurately amplify the input signals. However, all opamp pins — the non-inverting input, inverting input, positive supply, negative supply, and output pins — are susceptible to EMI signals. These high frequency signals are coupled into an op-amp by various means, such as conduction, near field radiation, or far field radiation. For example, wires and printed circuit board (PCB) traces can act as antennas and pick up high frequency EMI signals. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-33GL.3b — Data Sheet General Purpose 1.2MHz, RRIO, 1.8V CMOS Amplifiers LTC321, LTC358, LTC324 P-9 Application Notes (continued) Amplifiers do not amplify EMI or RF signals due to their relatively low bandwidth. However, due to the nonlinearities of the input devices, op-amps can rectify these out of band signals. When these high frequency signals are rectified, they appear as a dc offset at the output. The LTC321/LTC358/LTC324 have integrated EMI filters at their input stage. A mathematical method of measuring EMIRR is defined as follows: EMIRR = 20 log (VIN_PEAK / ΔVOS) resulting in a thermal voltage error. This thermocouple error can be reduced by using dummy components to match the thermoelectric error source. Placing the dummy component as close as possible to its partner ensures both Seebeck voltages are equal, thus canceling the thermocouple error. Maintaining a constant ambient temperature on the circuit board further reduces this error. The use of a ground plane helps distribute heat throughout the board and reduces EMI noise pickup. INPUT-TO-OUTPUT COUPLING To minimize capacitive coupling, the input and output signal traces should not be parallel. This helps reduce unwanted positive feedback. MAXIMIZING PERFORMANCE THROUGH PROPER LAYOUT To achieve the maximum performance of the extremely high input impedance and low offset voltage of the LTC321/LTC358/LTC324, care is needed in laying out the circuit board. The PCB surface must remain clean and free of moisture to avoid leakage currents between adjacent traces. Surface coating of the circuit board reduces surface moisture and provides a humidity barrier, reducing parasitic resistance on the board. The use of guard rings around the amplifier inputs further reduces leakage currents. Figure 4 shows proper guard ring configuration and the top view of a surface-mount layout. The guard ring does not need to be a specific width, but it should form a continuous loop around both inputs. By setting the guard ring voltage equal to the voltage at the non-inverting input, parasitic capacitance is minimized as well. For further reduction of leakage currents, components can be mounted to the PCB using Teflon standoff insulators. Guard Ring +IN –IN +VS Figure 4. Use a guard ring around sensitive pins Other potential sources of offset error are thermoelectric voltages on the circuit board. This voltage, also called Seebeck voltage, occurs at the junction of two dissimilar metals and is proportional to the temperature of the junction. The most common metallic junctions on a circuit board are solder-toboard trace and solder-to-component lead. If the temperature of the PCB at one end of the component is different from the temperature at the other end, the resulting Seebeck voltages are not equal, CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-33GL.3b — Data Sheet General Purpose 1.2MHz, RRIO, 1.8V CMOS Amplifiers LTC321, LTC358, LTC324 P-10 Tape and Reel Information REEL DIMENSIONS TAPE DIMENSIONS K0 P1 B0 W Reel Diameter A0 Cavity A0 B0 K0 W P1 Reel Width (W1) Dimension designed to accommodate the component width Dimension designed to accommodate the component length Dimension designed to accommodate the component thickness Overall width of the carrier tape Pitch between successive cavity centers QUADRANT ASSIGNMENTS FOR PIN 1 ORIETATION IN TAPE Sprocket Holes Q1 Q2 Q1 Q2 Q3 Q4 Q3 Q4 User Direction of Feed Pocket Quadrants * All dimensions are nominal Device LTC321XT5/R6 Package Pins Type SOT23 5 SPQ 3 000 Reel Reel Diameter Width W1 (mm) (mm) 178 9.0 A0 (mm) B0 (mm) K0 (mm) P1 (mm) W (mm) Pin 1 Quadrant 3.3 3.2 1.5 4.0 8.0 Q3 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-33GL.3b — Data Sheet General Purpose 1.2MHz, RRIO, 1.8V CMOS Amplifiers LTC321, LTC358, LTC324 P-11 Package Outlines (continued) DIMENSIONS, SOT23-5L A2 A A1 D e1 Symbol A A1 A2 b c D E1 E e e1 L L1 θ θ L E E1 L1 e b Dimensions In Millimeters Min Max 1.35 0.00 0.15 1.00 1.20 0.35 0.45 0.14 0.20 2.82 3.02 1.526 1.726 2.60 3.00 0.95 BSC 1.90 BSC 0.60 REF 0.30 0.60 0° 8° Dimensions In Inches Min Max 0.053 0.000 0.006 0.039 0.047 0.014 0.018 0.006 0.008 0.111 0.119 0.060 0.068 0.102 0.118 0.037 BSC 0.075 BSC 0.024 REF 0.012 0.024 0° 8° c RECOMMENDED SOLDERING FOOTPRINT, SOT23-5L 1.0 0.039 0.95 0.037 0.95 0.037 0.7 0.028 2.4 0.094 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. mm ( inches ) FN1617-33GL.3b — Data Sheet General Purpose 1.2MHz, RRIO, 1.8V CMOS Amplifiers LTC321, LTC358, LTC324 P-12 Package Outlines DIMENSIONS, SC70-5L (SOT353) A2 A Symbol A1 D e1 A A1 A2 b C D E E1 e e1 L L1 θ θ e L E1 E L1 b Dimensions In Millimeters Min Max 0.90 1.10 0.00 0.10 0.90 1.00 0.15 0.35 0.08 0.15 2.00 2.20 1.15 1.35 2.15 2.45 0.65 typ. 1.20 1.40 0.525 ref. 0.26 0.46 0° 8° C RECOMMENDED SOLDERING FOOTPRINT, SC70-5L (SOT353) 0.50 0.0197 0.65 0.0256 0.65 0.0256 0.40 0.0157 1.9 0.0748 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. mm ( inches ) Dimensions In Inches Min Max 0.035 0.043 0.000 0.004 0.035 0.039 0.006 0.014 0.003 0.006 0.079 0.087 0.045 0.053 0.085 0.096 0.026 typ. 0.047 0.055 0.021 ref. 0.010 0.018 0° 8° FN1617-33GL.3b — Data Sheet General Purpose 1.2MHz, RRIO, 1.8V CMOS Amplifiers LTC321, LTC358, LTC324 P-13 Package Outlines (continued) DIMENSIONS, SOIC-8L A2 A A1 D b Symbol e A A1 A2 b C D E E1 e L θ L E E1 θ Dimensions In Millimeters Min Max 1.370 1.670 0.070 0.170 1.300 1.500 0.306 0.506 0.203 TYP. 4.700 5.100 3.820 4.020 5.800 6.200 1.270 TYP. 0.450 0.750 0° 8° Dimensions In Inches Min Max 0.054 0.066 0.003 0.007 0.051 0.059 0.012 0.020 0.008 TYP. 0.185 0.201 0.150 0.158 0.228 0.244 0.050 TYP. 0.018 0.030 0° 8° C RECOMMENDED SOLDERING FOOTPRINT, SOIC-8L 8X 5.40 0.213 (1.55) MAX (0.061) (3.90) MIN (0.154) 1 (0.60) MAX 8X (0.024) PITCH 1.270 0.050 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. mm ( inches ) FN1617-33GL.3b — Data Sheet General Purpose 1.2MHz, RRIO, 1.8V CMOS Amplifiers LTC321, LTC358, LTC324 P-14 Package Outlines (continued) DIMENSIONS, DFN2x2-8L E A c A1 1 Nd D1 2 D b1 Exposed Thermal Pad Zone L h E1 h 2 e Symbol Min. 0.70 A A1 b b1 c D D1 Nd E E1 e L h 0.20 0.18 1.90 1.10 1.90 0.60 0.30 0.15 Millimeters Nom. 0.75 0.02 0.25 0.18 REF 0.20 2.00 1.20 1.50BSC 2.00 0.70 0.50BSC 0.35 0.20 1 b BOTTOM VIEW RECOMMENDED SOLDERING FOOTPRINT, DFN2x2-8L 1.60 0.0630 PACKAGE OUTLINE 8X 0.50 0.0197 1.00 0.0394 2.30 0.0906 1 0.50 PITCH 0.0197 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. 0.30 8X 0.0118 mm ( inches ) Max. 0.80 0.05 0.30 0.25 2.10 1.30 2.10 0.80 0.40 0.25 FN1617-33GL.3b — Data Sheet General Purpose 1.2MHz, RRIO, 1.8V CMOS Amplifiers LTC321, LTC358, LTC324 P-15 Package Outlines (continued) DIMENSIONS, MSOP-8L A2 A A1 D b Symbol e A A1 A2 b C D E E1 e L θ L E1 E Dimensions In Millimeters Min Max 0.800 1.100 Dimensions In Inches Min Max 0.031 0.043 0.050 0.150 0.750 0.950 0.290 0.380 0.150 0.200 2.900 3.100 2.900 3.100 4.700 5.100 0.650 TYP. 0.400 0.700 0° 8° 0.002 0.006 0.030 0.037 0.011 0.015 0.006 0.008 0.114 0.122 0.114 0.122 0.185 0.201 0.026 TYP. 0.016 0.028 0° 8° θ C RECOMMENDED SOLDERING FOOTPRINT, MSOP-8L 8X (0.45) MAX (0.018) (1.45) MAX (0.057) 8X 4.40 (5.85) MAX 0.173 (0.230) (2.95) MIN (0.116) 0.65 PITCH 0.026 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. mm ( inches ) FN1617-33GL.3b — Data Sheet General Purpose 1.2MHz, RRIO, 1.8V CMOS Amplifiers LTC321, LTC358, LTC324 P-16 Package Outlines (continued) DIMENSIONS, SOIC-14L A3 A2 A A1 D b C e L1 L E Symbol E1 A A1 A2 A3 b C D E E1 e L1 L θ Dimensions In Millimeters Min Max 1.450 1.850 0.100 0.300 1.350 1.550 0.550 0.750 0.406 TYP. 0.203 TYP. 8.630 8.830 5.840 6.240 3.850 4.050 1.270 TYP. 1.040 REF. 0.350 0.750 2° 8° Dimensions In Inches Min Max 0.057 0.073 0.004 0.012 0.053 0.061 0.022 0.030 0.016 TYP. 0.008 TYP. 0.340 0.348 0.230 0.246 0.152 0.159 0.050 TYP. 0.041 REF. 0.014 0.030 2° 8° θ RECOMMENDED SOLDERING FOOTPRINT, SOIC-14L 14X 5.40 0.213 (1.50) MAX (0.059) (3.90) MIN (0.154) 1 (0.60) MAX 14X (0.024) PITCH 1.270 0.050 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. mm ( inches ) FN1617-33GL.3b — Data Sheet General Purpose 1.2MHz, RRIO, 1.8V CMOS Amplifiers LTC321, LTC358, LTC324 P-17 Package Outlines DIMENSIONS, QFN3x3-16L SIDE VIEW A TOP VIEW Symbol A3 D A A3 b D D1 E E1 e h K L BOTTOM VIEW K 9 L 12 8 E 13 E1 e D1 h 5 16 PIN#1 4 Min. 0.70 0.20 2.90 1.60 2.90 1.60 0.20 0.225 0.35 Millimeters Nom. 0.75 0.210 REF. 0.25 3.00 1.65 3.00 1.65 0.50 BSC. 0.25 0.275 0.40 1 b RECOMMENDED SOLDERING FOOTPRINT, QFN3x3-16L 0.65 0.20 3.50 1.70 1.70 1.80 0.30 0.25 0.50 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. Max. 0.80 0.30 3.10 1.70 3.10 1.70 0.30 0.325 0.45 FN1617-33GL.3b — Data Sheet General Purpose 1.2MHz, RRIO, 1.8V CMOS Amplifiers LTC321, LTC358, LTC324 P-18 Package Outlines (continued) DIMENSIONS, TSSOP-14L A3 A2 A Symbol A1 D b e C L1 L E E1 A A1 A2 A3 b C D E E1 e L1 L θ Dimensions In Millimeters Min Max 1.200 0.050 0.150 0.900 1.050 0.390 0.490 0.200 0.290 0.130 0.180 4.860 5.060 6.200 6.600 4.300 4.500 0.650 TYP. 1.000 REF. 0.450 0.750 0° 8° Dimensions In Inches Min Max 0.047 0.002 0.006 0.035 0.041 0.015 0.019 0.008 0.011 0.005 0.007 0.191 0.199 0.244 0.260 0.169 0.177 0.026 TYP. 0.039 REF. 0.018 0.030 0° 8° θ RECOMMENDED SOLDERING FOOTPRINT, TSSOP-14L 14X (1.45) MAX (0.057) (4.40) MIN (0.173) PITCH 0.65 0.026 1 5.90 0.232 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. 14X (0.45) MAX (0.018) mm ( inches ) FN1617-33GL.3b — Data Sheet General Purpose 1.2MHz, RRIO, 1.8V CMOS Amplifiers P-19 LTC321, LTC358, LTC324 IMPORTANT NOTICE Linearin is a global fabless semiconductor company specializing in advanced high-performance highquality analog/mixed-signal IC products and sensor solutions. The company is devoted to the innovation of high performance, analog-intensive sensor front-end products and modular sensor solutions, applied in multi-market of medical & wearable devices, smart home, sensing of IoT, and intelligent industrial & smart factory (industrie 4.0). Linearin’s product families include widely-used standard catalog products, solution-based application specific standard products (ASSPs) and sensor modules that help customers achieve faster time-to-market products. Go to http://www.linearin.com for a complete list of Linearin product families. For additional product information, or full datasheet, please contact with the Linearin’s Sales Department or Representatives. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-33GL.3b — Data Sheet General Purpose 1.2MHz, RRIO, 1.8V CMOS Amplifiers
LTC358XF8/R6 价格&库存
很抱歉,暂时无法提供与“LTC358XF8/R6”相匹配的价格&库存,您可以联系我们找货
LTC358XF8/R6
  • 1+0.87500
  • 30+0.84375
  • 100+0.81250
  • 500+0.75000
  • 1000+0.71875
  • 2000+0.70000
