LTC8722YS8/R8
LTC8722YS8/R8
    LINEARIN(先积)
    SOIC-8
    微功耗22μA,66ns,1.7V,轨至轨,推挽输出比较器
LTC8722YS8/R8 数据手册
LTC8721, LTC8722, LTC8723 P-1 General Description The LTC8721/LTC8722/LTC8723 are tiny, single- and dual- channel comparators with push-pull output that offer the ultimate combination of high speed (66 ns propagation delay) and very low power consumption (22 μA), available in extremely small packages with features such as rail-to-rail inputs, low offset voltage (0.8 mV), large output drive current, and a wide range of supply voltages from 1.7 V to 5.5 V. The devices are very easy to implement in a wide variety of applications where require critical response time, power-sensitive, low-voltage, and/or tight board space. The output of the LTC8721/LTC8722/LTC8723 pulls to within 0.1 V of either supply rail without external pull-up circuitry, making these devices ideal for interface with both CMOS and TTL logics. All input and output pins can tolerate a continuous short-circuit fault condition to either rail. Internal hysteresis ensures clean output switching, even with slow-moving input signals. The LTC8721/LTC8723 (single) is available in both SOT23-5L and SC70-5L packages. The LTC8722 (dual) is offered in DFN-8L, SOIC-8L and MSOP-8L packages. All devices are rated over −40 ℃ to +125 ℃ industrial temperature range. Features and Benefits  Micro-power Operating Current (22 μA) Preserves Battery Power  Fast 66 ns Propagation Delay (100-mV Overdrive)  Single 1.7 V to 5.5 V Supply Voltage Range – Can be Powered From the Same 1.8V/2.5V/3.3V/5V System Rails  Rail-to-Rail Input  Push-Pull Output Current Drive: 30 mA Typically at 5V Supply  Internal Hysteresis for Clean Switching  Internal RF/EMI Filter  Operating Temperature Range: −40 ℃ to +125 ℃ Applications           Consumer Accessories Handsets, Tablets and Notebooks Portable and Battery-Powered Devices Threshold Detectors and Discriminators Alarms and Monitoring Circuits Zero-Crossing Detectors Window Comparators Level Translators Line Receivers IR Receivers Pin Configurations (Top View) LTC8721 LTC8722 LTC8722 LTC8723 LTC8723R SOT23-5L / SC70-5L DFN-8L SOIC-8L / MSOP-8L SOT23-5L SOT23-5L OUT 1 5 +VS –VS 2 +IN 3 4 –IN OUTA 1 8 +VS –INA 2 7 OUTB OUT A 1 +INA 3 6 –INB –IN A 2 –VS 4 5 +INB +IN A 3 –VS 4 8 A B +VS 7 OUT B 6 –IN B 5 +IN B CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. +IN 1 5 +VS –VS 2 –IN 3 –IN 1 5 +VS –VS 2 4 OUT +IN 3 4 OUT FN1617-37.1a — Data Sheet Micro-Power 22μA, 66ns, 1.7V, RRI, CMOS Input Comparators LTC8721, LTC8722, LTC8723 P-2 Pin Description Symbol Description –IN Negative input. The voltage range is from (VS– – 0.1V) to (VS+ + 0.1V). +IN Positive input. This pin has the same voltage range as –IN. +VS Positive power supply. The voltage is from 1.7V to 5.5V. Split supplies are possible as long as the voltage between VS+ and VS– is from 1.7V to 5.5V. –VS Negative power supply. It is normally tied to ground. It can also be tied to a voltage other than ground as long as the voltage between VS+ and VS– is from 1.7V to 5.5V. OUT Comparator output. Ordering Information Orderable Type Number Package Name Package Quantity Eco Class(1) Operating Temperature Marking Code LTC8721YT5/R6 SOT23-5L 3 000 Green –40℃ to +125℃ CG1 LTC8721YC5/R6 SC70-5L 3 000 Green –40℃ to +125℃ CG1 LTC8722YF8/R6 DFN2x2-8L 3 000 Green –40℃ to +125℃ CG2 LTC8722YS8/R8 SOIC-8L 4 000 Green –40℃ to +125℃ CG2 Y LTC8722YV8/R6 MSOP-8 3 000 Green –40℃ to +125℃ CG2Y LTC8723YT5/R6 SOT23-5L 3 000 Green –40℃ to +125℃ CG3 LTC8723RYT5/R6 SOT23-5L 3 000 Green –40℃ to +125℃ CG0 (1) Eco Class - The planned eco-friendly classification: Pb-Free (RoHS) or Green (RoHS & Halogen Free). (2) Please contact to your Linearin representative for the latest availability information and product content details. Limiting Value In accordance with the Absolute Maximum Rating System (IEC 60134). Parameter Absolute Maximum Rating Supply Voltage, VS+ to VS– 10.0 V Signal Input Terminals: Voltage, Current VS– – 0.5 V to VS+ + 0.5 V, ±10 mA Output Short-Circuit Continuous Storage Temperature Range, Tstg –65 ℃ to +150 ℃ Junction Temperature, TJ 150 ℃ Lead Temperature Range (Soldering 10 sec) 260 ℃ ESD Rating Parameter Electrostatic Discharge Voltage Item Value Human body model (HBM), per MIL-STD-883J / Method 3015.9 ±5 000 Charged device model (CDM), per ESDA/JEDEC JS-002-2014 ±2 000 Machine model (MM), per JESD22-A115C ±250 (1) JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process. (2) JEDEC document JEP157 states that 250-V CDM allows safe manufacturing with a standard ESD control process. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. Unit V FN1617-37.1a — Data Sheet Micro-Power 22μA, 66ns, 1.7V, RRI, CMOS Input Comparators LTC8721, LTC8722, LTC8723 P-3 Electrical Characteristics VS = 5.0V, TA = +25℃, unless otherwise noted. Boldface limits apply over the specified temperature range, TA = −40 to +125 ℃. Symbol Parameter Conditions Min. Typ. Max. ±0.8 ±3.5 Unit OFFSET VOLTAGE VOS Input offset voltage VOS TC Offset voltage drift PSRR Power supply rejection ratio Hyst Input hysteresis VCM = VS /2 TA = −40 to +125 ℃ ±4.0 TA = −40 to +125 ℃ μV/℃ ±1 VS = 1.7 to 5.5 V, VCM < (VS+–1V) 65 (VS–+0.1V) < VCM < (VS+–1V), TA = −40 to +125 ℃ 60 mV 80 dB VCM = VS /2 3 VCM = VS+ /2 5 TA = +85 ℃ 200 TA = +125 ℃ 1,000 VCM = VS+ /2 10 mV INPUT BIAS CURRENT IB IOS Input bias current Input offset current pA pA INPUT VOLTAGE RANGE VCM CMRR Common-mode voltage range Common-mode rejection ratio TA = −40 to +85 ℃ VS––0.1 VS++0.1 TA = −40 to +125 ℃ VS–+0.1 VS+–0.2 VCM = −0.1 to 5.0 V VCM = 0.1 to 4.8 V, TA = −40 to +125 ℃ VS = 2.0 V, VCM = −0.1 to 2.0 V VCM = 0.1 to 1.8 V, TA = −40 to +125 ℃ 60 82 55 56 V dB 78 52 INPUT IMPEDANCE RIN CIN Input resistance Input capacitance 100 GΩ Differential 2.0 Common mode 3.5 63 pF OUTPUT VOH High output voltage swing ISOURCE = 1 mA VOL Low output voltage swing ISINK = 1 mA ISC Output short-circuit current TA = −40 to +125 ℃ 80 120 44 TA = −40 to +125 ℃ 58 90 ±30 mV mV mA POWER SUPPLY VS Operating supply voltage TA = −40 to +125 ℃ VS = 1.8 V, VCM = 0.5V, IO = 0 IQ Quiescent current (per comparator) 1.7 5.5 19 TA = −40 to +125 ℃ VS = 5.0 V, VCM = 0.5V, IO = 0 TA = −40 to +125 ℃ CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. 26 37 22 V 32 46 μA FN1617-37.1a — Data Sheet Micro-Power 22μA, 66ns, 1.7V, RRI, CMOS Input Comparators LTC8721, LTC8722, LTC8723 P-4 Electrical Characteristics (continued) VS = 5.0V, TA = +25℃, unless otherwise noted. Boldface limits apply over the specified temperature range, TA = −40 to +125 ℃. Symbol Parameter Conditions Min. Typ. Max. Unit SWITCHING CHARACTERISTICS tPD+ Propagation delay time, Low to high tPD– Propagation delay time, High to low tR Rise time tF Fall time Input overdrive = 20 mV, CL = 15 pF Input overdrive = 100 mV, CL = 15 pF Input overdrive = 20 mV, CL = 15 pF Input overdrive = 100 mV, CL = 15 pF Input overdrive = 20 mV, CL = 15 pF Input overdrive = 100 mV, CL = 15 pF Input overdrive = 20 mV, CL = 15 pF Input overdrive = 100 mV, CL = 15 pF 138 ns 78 155 ns 66 10 ns 8 8 ns 6 THERMAL CHARACTERISTICS TA θJA Operating temperature range Package Thermal Resistance -40 +125 SC70-5L 333 SOT23-5L 190 DFN2x2-8L 80 MSOP-8L 216 SOIC-8L 125 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. ℃ ℃/W FN1617-37.1a — Data Sheet Micro-Power 22μA, 66ns, 1.7V, RRI, CMOS Input Comparators LTC8721, LTC8722, LTC8723 P-5 Typical Performance Characteristics At TA=+25℃, VS=±2.5V, VCM=VS /2, RL=10kΩ connected to VS /2, and CL=15pF, unless otherwise noted. 40 35 VCM=0.5V 30 25 20 15 +25℃ –40℃ 10 VS = 5V VOD = 50mV 32.5 +125℃ Supply Current (μA) Supply Current (μA) 35 30 27.5 Output Low Voltage 25 22.5 Output High Voltage 20 5 0 17.5 1.5 2 2.5 3 3.5 4 4.5 5 5.5 6 0 1 Supply Voltage (V) Supply Current vs. Supply Voltage 4 5 175 VCM = VS / 2 VOD = 50mV 150 Propagation Delay H-L (ns) Propagation Delay L-H (ns) 3 Supply Current vs. Common-Mode Input 175 +125℃ 125 100 75 –40℃ +25℃ 50 25 0 VCM = VS / 2 VOD = 50mV 150 +125℃ 125 100 75 –40℃ +25℃ 50 25 0 1.5 2 2.5 3 3.5 4 4.5 5 5.5 1.5 2 Supply Voltage (V) 175 tPD+ (L-H) 100 75 tPD– (H-L) 50 3.5 4 4.5 5 5.5 Propagation Delay H-L (tPD–) vs. Supply Voltage Propagation Delay (ns) 125 3 350 VCM = VS / 2 VOD = 100mV TA = +25℃ 150 2.5 Supply Voltage (V) Propagation Delay L-H (tPD+) vs. Supply Voltage Propagation Delay (ns) 2 Common-Mode Voltage (V) 25 0 VCM = VS / 2 VOD = 10mV TA = +25℃ 325 300 tPD– (H-L) 275 250 225 tPD+ (L-H) 200 175 1.5 2 2.5 3 3.5 4 4.5 5 5.5 1.5 Supply Voltage (V) Propagation Delay vs. Supply Voltage 2 2.5 3 3.5 4 4.5 5 Supply Voltage (V) Propagation Delay vs. Supply Voltage CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. 5.5 FN1617-37.1a — Data Sheet Micro-Power 22μA, 66ns, 1.7V, RRI, CMOS Input Comparators LTC8721, LTC8722, LTC8723 P-6 Typical Performance Characteristics At TA=+25℃, VS=±2.5V, VCM=VS /2, RL=10kΩ connected to VS /2, and CL=15pF, unless otherwise noted. 300 VS = 5.0V 250 Propagation Delay (ns) Propagation Delay (ns) 300 200 150 tPD+ (L-H) 100 50 tPD– (H-L) 0 VS = 1.8V 250 200 tPD– (H-L) 150 100 tPD+ (L-H) 50 0 10 100 1000 10 100 Overdrive Voltage (mV) Propagation Delay vs. Input Overdrive Propagation Delay vs. Input Overdrive 190 Propagation Delay H-L (ns) Propagation Delay L-H (ns) 170 VOD = 20mV 160 150 140 130 120 110 100 VOD = 20mV 180 170 160 150 140 130 120 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 0 Common-Mode Voltage (V) 1000 1 1.5 2 2.5 3 3.5 4 4.5 5 Propagation Delay H-L vs. Input Common-Mode 10000 VS = 5.0V VOD = 100mV Propagation Delay (ns) tPD+ (L-H) 100 tPD– (H-L) 10 1 0.01 0.5 Common-Mode Voltage (V) Propagation Delay L-H vs. Input Common-Mode Propagation Delay (ns) 1000 Overdrive Voltage (mV) 0.1 1 1000 tPD– (H-L) 100 tPD+ (L-H) 10 1 0.01 Output Capacitive Load (nF) Propagation Delay vs. Capacitive Load VS = 1.8V VOD = 100mV 0.1 Output Capacitive Load (nF) Propagation Delay vs. Capacitive Load CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. 1 FN1617-37.1a — Data Sheet Micro-Power 22μA, 66ns, 1.7V, RRI, CMOS Input Comparators LTC8721, LTC8722, LTC8723 P-7 Typical Performance Characteristics At TA=+25℃, VS=±2.5V, VCM=VS /2, RL=10kΩ connected to VS /2, and CL=15pF, unless otherwise noted. 5 5 Sourcing Current 4 Output Voltage (V) Output Voltage (V) 4 –40℃ 3 +25℃ +125℃ 2 1 0 2 –40℃ 1 0 0 5 10 15 20 25 30 35 40 0 5 10 Output Current (mA) 15 20 25 30 35 40 45 50 Output Current (mA) Output Voltage vs. Output Sourcing Current Output Voltage vs. Output Sinking Current 50 Short-Circuit Current (mA) 10 Short-Circuit Current (mA) +25℃ +125℃ 3 VS = 1.8V 8 –ISC 6 4 +ISC 2 0 VS = 5.0V 45 –ISC 40 35 30 +ISC 25 20 -50 -25 0 25 50 75 100 125 -50 Temperature (℃) Short Circuit Current vs. Temperature -25 0 25 50 75 100 Temperature (℃) Short Circuit Current vs. Temperature CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. 125 FN1617-37.1a — Data Sheet Micro-Power 22μA, 66ns, 1.7V, RRI, CMOS Input Comparators LTC8721, LTC8722, LTC8723 P-8 Application Notes OPERATING VOLTAGE The LTC872x family of micro-power push-pull output comparators is fully specified and ensured for operation from 1.7 V to 5.5 V and offers an excellent speed-to-power combination with a propagation delay of 70 ns and a quiescent supply current of 22 μA. This combination of fast response time at micropower enables power conscious systems to monitor and respond quickly to fault conditions. In addition, and many specifications apply over the industrial temperature range of –40℃ to +125℃. Parameters that vary significantly with operating voltages or temperature are illustrated in the Typical Characteristics graphs. INPUT VOLTAGE The input common-mode voltage range of the LTC872x comparators extends 100mV beyond the supply rails. This performance is achieved with a complementary input stage: an N-channel input differential pair in parallel with a P-channel differential pair. The N-channel pair is active for input voltages close to the positive rail, typically VS+– 1.4V to the positive supply, whereas the P-channel pair is active for inputs from 100mV below the negative supply to approximately VS+–1.4V. There is a small transition region, typically VS+–1.2V to VS+–1V, in which both pairs are on. This 200mV transition region can vary up to 200mV with process variation. Thus, the transition region (both stages on) can range from VS+–1.4V to VS+–1.2V on the low end, up to VS+–1V to VS+–0.8V on the high end. Within this transition region, PSRR, CMRR, offset voltage, offset drift, and THD can be degraded compared to device operation outside this region. INPUT VOLTAGE The LTC8721/LTC8722/LTC8723 comparator family uses CMOS transistors at the inputs which prevent phase inversion when the input pins exceed the supply voltages. VS+ D1 RS1 500Ω IN+ D2 D3 CCM1 RS2 CDM 500Ω IN– D4 CCM2 VS– Figure 1. Input EMI Filter and Clamp Circuit Figure 1 shows the input EMI filter and clamp circuit. The LTC8721/LTC8722/LTC8723 comparators have internal ESD protection diodes (D1, D2, D3, and D4) that are connected between the inputs and each supply rail. These diodes protect the input transistors in the event of electrostatic discharge and are reverse biased during normal operation. This protection scheme allows voltages as high as approximately 500mV beyond the rails to be applied at the input of either terminal without causing permanent damage. See the table of Absolute Maximum Ratings for more information. EMI REJECTION RATIO Circuit performance is often adversely affected by high frequency EMI. When the signal strength is low and transmission lines are long, an amplifier must accurately amplify the input signals. However, all comparator pins — the non-inverting input, inverting input, positive supply, negative supply, and output pins — are susceptible to EMI signals. These high frequency signals are coupled into an comparator by various means, such as conduction, near field radiation, or far field radiation. For example, wires and printed circuit board (PCB) traces can act as antennas and pick up high frequency EMI signals. Amplifiers do not amplify EMI or RF signals due to their relatively low bandwidth. However, due to the nonlinearities of the input devices, comparators can rectify these out of band signals. When these high frequency signals are rectified, they appear as a dc offset at the output. The LTC8721/LTC8722/LTC8723 comparators have integrated EMI filters at their input stage. A mathematical method of measuring EMIRR is defined as follows: EMIRR = 20 log (VIN_PEAK / ΔVOS) INTERNAL HYSTERESIS Most high-speed comparators oscillate in the linear region because of noise or undesired parasitic feedback. This tends to occur when the voltage on one input is at or equal to the voltage on the other input. To counter the parasitic effects and noise, the devices have an internal hysteresis of 5 mV. The hysteresis in a comparator creates two trip points: one for the rising input voltage and one for the falling input voltage. The difference between the trip points is the hysteresis. The average of the trip points is the offset voltage. When the comparator’s input voltages are equal, the hysteresis effectively causes one comparator input voltage to move quickly past the other, thus taking the input out of the region where oscillation occurs. Standard comparators require hysteresis to be added with external resistors. To increase hysteresis and noise margin e v e n m o r e , a d d CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-37.1a — Data Sheet Micro-Power 22μA, 66ns, 1.7V, RRI, CMOS Input Comparators LTC8721, LTC8722, LTC8723 P-9 Application Notes positive feedback with two resistors as a voltage divider from the output to the non-inverting input. Figure 2 illustrates the case where IN– is fixed and IN+ is varied. If the inputs were reversed, the figure would look the same, except the output would be inverted. VTRIP+ VIN+ VHYST VOS VIN– = 0 VTRIP– VOS = (VTRIP+ + VTRIP–)/2 VOH Comparator Output VOL Figure 2. Input and Output Waveform, Non-inverting Input Varied MAXIMIZING PERFORMANCE THROUGH PROPER LAYOUT electric voltages on the circuit board. This voltage, also called Seebeck voltage, occurs at the junction of two dissimilar metals and is proportional to the temperature of the junction. The most common metallic junctions on a circuit board are solder-toboard trace and solder-to-component lead. If the temperature of the PCB at one end of the component is different from the temperature at the other end, the resulting Seebeck voltages are not equal, resulting in a thermal voltage error. This thermocouple error can be reduced by using dummy components to match the thermoelectric error source. Placing the dummy component as close as possible to its partner ensures both Seebeck voltages are equal, thus canceling the thermocouple error. Maintaining a constant ambient temperature on the circuit board further reduces this error. The use of a ground plane helps distribute heat throughout the board and reduces EMI noise pickup. INPUT-TO-OUTPUT COUPLING To minimize capacitive coupling, the input and output signal traces should not be parallel. This helps reduce unwanted positive feedback. To achieve the maximum performance of the extremely high input impedance and low offset voltage of the LTC8721/LTC8722/LTC8723 devices, care is needed in laying out the circuit board. The PCB surface must remain clean and free of moisture to avoid leakage currents between adjacent traces. Surface coating of the circuit board reduces surface moisture and provides a humidity barrier, reducing parasitic resistance on the board. The use of guard rings around the comparator inputs further reduces leakage currents. Figure 3 shows proper guard ring configuration and the top view of a surface-mount layout. The guard ring does not need to be a specific width, but it should form a continuous loop around both inputs. By setting the guard ring voltage equal to the voltage at the non-inverting input, parasitic capacitance is minimized as well. For further reduction of leakage currents, components can be mounted to the PCB using Teflon standoff insulators. Guard Ring +IN –IN +VS Figure 3. Use a guard ring around sensitive pins Other potential sources of offset error are thermoCAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-37.1a — Data Sheet Micro-Power 22μA, 66ns, 1.7V, RRI, CMOS Input Comparators LTC8721, LTC8722, LTC8723 P-10 Typical Application Circuits IR RECEIVER AFE AND WAKE- UP CIRCUIT Infrared (IR) communication is inherently immune to RF interference as long as there is a line-of-sight path between the transmitter and the receiver. It is also one of the lowest cost communication schemes. This makes it a good choice for implementing wireless communications in applications such as utility metering. A common system topology to extend battery life is to use a power efficient IR receiver analog front end (AFE) that is always on and wakes up the host only when there is a valid IR signal detected as shown in Figure 1. IR LED IR Receiver AFE Digital output (hardware wake-up event) GPIO MCU (Low Power) through R3. And finally R3 and R4 are used to introduce additional hysteresis to keep the output free of spurious toggles. VREF Figure 4. Coin Cell Battery Powered IR Receiver R4 470kΩ 10MΩ 3V LTC8721 Output to MCU (Also to wake-up MCU) R1 C1 10MΩ 0.01μF Figure 5. IR Receiver AFE Using LTC8721 USE WINDOW COMPARATOR TO DETECT UNDER-VOLTAGE AND OVER-VOLTAGE Window comparators are commonly used to detect undervoltage (UV) and overvoltage (OV) conditions. Figure 6 shows a simple window comparator circuit. Power efficient comparators such as the LTC872x can be used in the IR receiver AFE to increase battery life. The LTC872x device is responsible for two major tasks: 1. IR signal conditioning, 2. Host system wake-up. The LTC872x device is constantly powered to always be ready to receive IR signals and wake up the host microcontroller (MCU) when data is received. The short working distance (approx 5 cm) is suitable for a virtual-contact operation where the IR transmitter and receiver are closely placed with an optional mechanical alignment guide. R3 470kΩ IR LED + 10MΩ R2 3V 3.3V LTC8722 R1 + UV – Sensor OR Gate R2 Power Good + – OV R3 Figure 1 shows the IR receiver system block diagram. The host MCU is normally in the shutdown mode (during which the quiescent current is less than 1 μA) except when data is being transferred. Figure 6. Window Comparator Figure 2 shows the detailed circuit design. The circuit establishes a threshold through R2 and C1 which automatically adapts to the ambient light level. To further reduce BOM cost, this example uses an IR LED as the IR receiver. The IR LED is reverse-biased to function as a photodiode (but at a reduced sensitivity). For this design, follow these design requirements: The low input bias current allows a greater load resistor value (R1) without sacrificing linearity, which in turn helps reduce the always-on supply current. Configure the circuit as shown in Figure 6. Connect VS+ to a 3.3-V power supply and VS– to ground. Make R1, R2 and R3 each 10-MΩ resistors. These three resistors are used to create the positive and negative thresholds for the window comparator (VTH+ and VTH–). With each resistor being equal, VTH+ is 2.2 V and VTH– The load resistor R1 converts the IR light induced current into a voltage fed into the inverting input of the comparator. R2 and C1 establish a reference voltage VREF which tracks the mean amplitude of the IR signal. The non-inverting input is connected to VREF • Alert (logic low output) when an input signal is less than 1.1 V • Alert (logic low output) when an input signal is greater than 2.2 V • Alert signal is active low • Operate from a 3.3-V power supply CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-37.1a — Data Sheet Micro-Power 22μA, 66ns, 1.7V, RRI, CMOS Input Comparators LTC8721, LTC8722, LTC8723 P-11 Typical Application Circuits is 1.1 V. Large resistor values such as 10-MΩ are used to minimize power consumption. The sensor output voltage is applied to the inverting and non-inverting inputs of the 2-channel LTC8722's. The respective comparator outputs will be low when the sensor is less than 1.1 V or greater than 2.2 V. VOUT will be high when the sensor is in the range of 1.1 V to 2.2 V. See the application curve in Figure 7. VIN VTH+ = 2.2 V VTH– = 1.1 V Time VOUT Time Figure 5. Window Comparator Results CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-37.1a — Data Sheet Micro-Power 22μA, 66ns, 1.7V, RRI, CMOS Input Comparators LTC8721, LTC8722, LTC8723 P-12 Package Outlines DIMENSIONS, SC70-5L (SOT353) A2 A Symbol A1 D e1 A A1 A2 b C D E E1 e e1 L L1 θ θ e L E1 E L1 b Dimensions In Millimeters Min Max 0.90 1.10 0.00 0.10 0.90 1.00 0.15 0.35 0.08 0.15 2.00 2.20 1.15 1.35 2.15 2.45 0.65 typ. 1.20 1.40 0.525 ref. 0.26 0.46 0° 8° C RECOMMENDED SOLDERING FOOTPRINT, SC70-5L (SOT353) 0.50 0.0197 0.65 0.025 0.65 0.025 0.40 0.0157 1.9 0.0748 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. mm ( inches ) Dimensions In Inches Min Max 0.035 0.043 0.000 0.004 0.035 0.039 0.006 0.014 0.003 0.006 0.079 0.087 0.045 0.053 0.085 0.096 0.026 typ. 0.047 0.055 0.021 ref. 0.010 0.018 0° 8° FN1617-37.1a — Data Sheet Micro-Power 22μA, 66ns, 1.7V, RRI, CMOS Input Comparators LTC8721, LTC8722, LTC8723 P-13 Package Outlines (continued) DIMENSIONS, SOT23-5L A2 A A1 D e1 Symbol A A1 A2 b c D E1 E e e1 L L1 θ θ L E E1 L1 e b Dimensions In Millimeters Min Max 1.25 0.04 0.10 1.00 1.20 0.33 0.41 0.15 0.19 2.820 3.02 1.50 1.70 2.60 3.00 0.95 BSC 1.90 BSC 0.60 REF 0.30 0.60 0° 8° Dimensions In Inches Min Max 0.049 0.002 0.004 0.039 0.047 0.013 0.016 0.006 0.007 0.111 0.119 0.059 0.067 0.102 0.118 0.037 BSC 0.075 BSC 0.024 REF 0.012 0.024 0° 8° c RECOMMENDED SOLDERING FOOTPRINT, SOT23-5L 1.0 0.039 0.95 0.037 0.95 0.037 0.7 0.028 2.4 0.094 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. mm ( inches ) FN1617-37.1a — Data Sheet Micro-Power 22μA, 66ns, 1.7V, RRI, CMOS Input Comparators LTC8721, LTC8722, LTC8723 P-14 Package Outlines (continued) DIMENSIONS, DFN2x2-8L E A c A1 1 Nd D1 2 D b1 Exposed Thermal Pad Zone L h E1 h 2 e Symbol Min. 0.70 A A1 b b1 c D D1 Nd E E1 e L h 0.20 0.18 1.90 1.10 1.90 0.60 0.30 0.15 Millimeters Nom. 0.75 0.02 0.25 0.18 REF 0.20 2.00 1.20 1.50BSC 2.00 0.70 0.50BSC 0.35 0.20 1 b BOTTOM VIEW RECOMMENDED SOLDERING FOOTPRINT, DFN2x2-8L 1.60 0.0630 PACKAGE OUTLINE 8X 0.50 0.0197 1.00 0.0394 2.30 0.0906 1 0.50 PITCH 0.0197 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. 0.30 8X 0.0118 mm ( inches ) Max. 0.80 0.05 0.30 0.25 2.10 1.30 2.10 0.80 0.40 0.25 FN1617-37.1a — Data Sheet Micro-Power 22μA, 66ns, 1.7V, RRI, CMOS Input Comparators LTC8721, LTC8722, LTC8723 P-15 Package Outlines (continued) DIMENSIONS, MSOP-8L A2 A A1 D b Symbol e A A1 A2 b C D E E1 e L θ L E1 E Dimensions In Millimeters Min Max 0.800 1.100 Dimensions In Inches Min Max 0.031 0.043 0.050 0.150 0.750 0.950 0.290 0.380 0.150 0.200 2.900 3.100 2.900 3.100 4.700 5.100 0.650 TYP. 0.400 0.700 0° 8° 0.002 0.006 0.030 0.037 0.011 0.015 0.006 0.008 0.114 0.122 0.114 0.122 0.185 0.201 0.026 TYP. 0.016 0.028 0° 8° θ C RECOMMENDED SOLDERING FOOTPRINT, MSOP-8L 8X (0.45) MAX (0.018) (1.45) MAX (0.057) 8X 4.40 (5.85) MAX 0.173 (0.230) (2.95) MIN (0.116) 0.65 PITCH 0.026 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. mm ( inches ) FN1617-37.1a — Data Sheet Micro-Power 22μA, 66ns, 1.7V, RRI, CMOS Input Comparators LTC8721, LTC8722, LTC8723 P-16 Package Outlines (continued) DIMENSIONS, SOIC-8L A2 A A1 D b Symbol e A A1 A2 b C D E E1 e L θ L E E1 θ Dimensions In Millimeters Min Max 1.370 1.670 0.070 0.170 1.300 1.500 0.306 0.506 0.203 TYP. 4.700 5.100 3.820 4.020 5.800 6.200 1.270 TYP. 0.450 0.750 0° 8° Dimensions In Inches Min Max 0.054 0.066 0.003 0.007 0.051 0.059 0.012 0.020 0.008 TYP. 0.185 0.201 0.150 0.158 0.228 0.244 0.050 TYP. 0.018 0.030 0° 8° C RECOMMENDED SOLDERING FOOTPRINT, SOIC-8L 8X 5.40 0.213 (1.55) MAX (0.061) (3.90) MIN (0.154) 1 (0.60) MAX 8X (0.024) PITCH 1.270 0.050 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. mm ( inches ) FN1617-37.1a — Data Sheet Micro-Power 22μA, 66ns, 1.7V, RRI, CMOS Input Comparators P-17 LTC8721, LTC8722, LTC8723 IMPORTANT NOTICE Linearin is a global fabless semiconductor company specializing in advanced high-performance highquality analog/mixed-signal IC products and sensor solutions. The company is devoted to the innovation of high performance, analog-intensive sensor front-end products and modular sensor solutions, applied in multi-market of medical & wearable devices, smart home, sensing of IoT, and intelligent industrial & smart factory (industrie 4.0). Linearin’s product families include widely-used standard catalog products, solution-based application specific standard products (ASSPs) and sensor modules that help customers achieve faster time-to-market products. Go to http://www.linearin.com for a complete list of Linearin product families. For additional product information, or full datasheet, please contact with the Linearin’s Sales Department or Representatives. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-37.1a — Data Sheet Micro-Power 22μA, 66ns, 1.7V, RRI, CMOS Input Comparators
LTC8722YS8/R8 价格&库存
很抱歉,暂时无法提供与“LTC8722YS8/R8”相匹配的价格&库存,您可以联系我们找货
LTC8722YS8/R8
  • 1+1.45000
  • 30+1.40000
  • 100+1.30000
  • 500+1.20000
  • 1000+1.15000
LTC8722YS8/R8
  • 1+2.12300
  • 100+1.70500
  • 1000+1.51800
  • 2000+1.43000
  • 4000+1.36400
库存:3
