LTC8727YT5/R6
LTC8727YT5/R6
    LINEARIN(先积)
    SOT23-5
    微功耗22μA,66ns,1.7V,轨至轨,推挽输出比较器
LTC8727YT5/R6 数据手册
LTC8725, LTC8726, LTC8727, LTC8728 P-1 General Description The LTC8725/LTC8727 and LTC8726 are tiny, single- and dual- channel comparators with open-drain output that offer the ultimate combination of high speed (66 ns propagation delay) and very low power consumption (22 μA), available in extremely small packages with features such as rail-to-rail inputs, low offset voltage (0.8 mV), large output drive current, and a wide range of supply voltages from 1.7 V to 5.5 V. The devices are very easy to implement in a wide variety of applications where require critical response time, power-sensitive, low-voltage, and/or tight board space. The output limits supply current surges and dynamic power consumption while switching. The open-drain output of the LTC8725/8726/8727 can be used as a level-shifter using a pull-up resistor. It can also be used as a wired-OR logic. All input and output pins can tolerate a continuous short-circuit fault condition to either rail. Internal hysteresis ensures clean output switching, even with slow-moving input signals. The LTC8725/8727 (single) is available in both SOT23-5L and SC70-5L, the LTC8726 (dual) is offered in DFN-8L, SOIC-8L and MSOP-8L packages. The quad-channel LTC8728 is offered in both SOIC-14L and TSSOP-14L packages. All devices are rated over −40 ℃ to +125 ℃ industrial temperature range. Features and Benefits  Micro-power Operating Current (22 μA) Preserves Battery Power  Fast 66 ns Propagation Delay (100-mV Overdrive)  Single 1.7 V to 5.5 V Supply Voltage Range – Can be Powered From the Same 1.8V/2.5V/3.3V/5V System Rails  Rail-to-Rail Input  Open-Drain Output Current Drive: 30 mA Typically at 5V Supply  Internal Hysteresis for Clean Switching  Internal RF/EMI Filter  Operating Temperature Range: −40 ℃ to +125 ℃ Applications           IR Receivers Consumer Accessories Handsets, Tablets and Notebooks Portable and Battery-Powered Devices Threshold Detectors and Discriminators Alarms and Monitoring Circuits Zero-Crossing Detectors Window Comparators Level Translators Line Receivers Pin Configurations (Top View) LTC8725 LTC8726 LTC8726 LTC8728 SOT23-5L / SC70-5L DFN-8L SOIC-8L / MSOP-8L SOIC-14L / TSSOP-14L OUT 1 5 +VS –VS 2 4 –IN +IN 3 LTC8727 SOT23-5L OUTA 1 8 +VS –INA 2 7 OUTB OUT A 1 +INA 3 6 –INB –IN A 2 –VS 5 +INB 4 +IN A 3 –VS 4 A B 8 +VS 7 OUT B 6 –IN B 5 +IN B OUTA 1 +IN –VS 2 –IN 3 5 4 +VS OUT CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. OUTD –INA 2 13 –IND +INA 3 12 +IND +VS 4 11 –VS +INB 5 10 +INC A B 1 14 D C –INB 6 9 –INC OUTB 7 8 OUTC FN1617-38.1 — Data Sheet Micro-Power 22μA, 1.7V, RRI, Open-Drain Output Comparators LTC8725, LTC8726, LTC8727, LTC8728 P-2 Pin Description Symbol Description –IN Inverting input of the amplifier. The voltage range is from (VS– – 0.1V) to (VS+ + 0.1V). +IN Non-inverting input of the amplifier. This pin has the same voltage range as –IN. +VS Positive power supply. –VS Negative power supply. OUT Amplifier output. Ordering Information (2) Orderable Type Number Package Name Package Quantity Eco Class(1) Operating temperature Marking Code LTC8725YT5/R6 SOT23-5L 3 000 Green –40℃ to +125℃ CG5 LTC8725YC5/R6 SC70-5L 3 000 Green –40℃ to +125℃ CG5 LTC8727YT5/R6 SOT23-5L 3 000 Green –40℃ to +125℃ CG7 LTC8726YS8/R8 SOIC-8L 4 000 Green –40℃ to +125℃ CG8 Y LTC8726YV8/R6 MSOP-8L 3 000 Green –40℃ to +125℃ CG8Y LTC8726YF8/R6 DFN2x2-8L 3 000 Green –40℃ to +125℃ CG8 LTC8728YS14/R5 SOIC-14L 2 500 Green –40℃ to +125℃ CGQ Y LTC8728YT14/R6 TSSOP-14L 3 000 Green –40℃ to +125℃ CGQ Y (1) Eco Class - The planned eco-friendly classification: Pb-Free (RoHS) or Green (RoHS & Halogen Free). (2) Please contact to your Linearin representative for the latest availability information and product content details. Limiting Value In accordance with the Absolute Maximum Rating System (IEC 60134). Parameter Absolute Maximum Rating Supply Voltage, VS+ to VS– 10.0 V Signal Input Terminals: Voltage, Current VS– – 0.5 V to VS+ + 0.5 V, ±10 mA Output Short-Circuit Continuous Storage Temperature Range, Tstg –65 ℃ to +150 ℃ Junction Temperature, TJ 150 ℃ Lead Temperature Range (Soldering 10 sec) 260 ℃ ESD Rating Parameter Electrostatic Discharge Voltage Item Value Human body model (HBM), per MIL-STD-883J / Method 3015.9 (1) ±5 000 Charged device model (CDM), per ESDA/JEDEC JS-002-2014 ±2 000 Machine model (MM), per JESD22-A115C (2) ±250 (1) JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process. (2) JEDEC document JEP157 states that 250-V CDM allows safe manufacturing with a standard ESD control process. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. Unit V FN1617-38.1 — Data Sheet Micro-Power 22μA, 1.7V, RRI, Open-Drain Output Comparators LTC8725, LTC8726, LTC8727, LTC8728 P-3 Electrical Characteristics VS = 5.0V, TA = +25℃, unless otherwise noted. Boldface limits apply over the specified temperature range, TA = −40 to +125 ℃. Symbol Parameter Conditions Min. Typ. Max. ±0.8 ±3.5 Unit OFFSET VOLTAGE VOS Input offset voltage VOS TC Offset voltage drift PSRR Power supply rejection ratio VHYST Input hysteresis VCM = VS /2 TA = −40 to +125 ℃ ±4.0 TA = −40 to +125 ℃ μV/℃ ±1.5 VS = 1.8 to 5.5 V, VCM < (VS+ − 1V) 65 (VS–+0.1V) < VCM < (VS+–1V), TA = −40 to +125 ℃ 60 mV 80 dB VCM = VS /2 3 VCM = VS+ /2 5 TA = +85 ℃ 200 TA = +125 ℃ 1,000 VCM = VS+ /2 10 mV INPUT BIAS CURRENT IB IOS Input bias current Input offset current pA pA INPUT VOLTAGE RANGE VCM CMRR Common-mode voltage range Common-mode rejection ratio TA = −40 to +85 ℃ VS––0.1 VS++0.1 TA = −40 to +125 ℃ VS–+0.1 VS+–0.2 VCM = −0.1 to 5.0 V VCM = 0.1 to 4.8 V, TA = −40 to +125 ℃ VS = 2.0 V, VCM = −0.1 to 2.0 V 60 VCM = 0.1 to 1.8 V, TA = −40 to +125 ℃ 52 82 55 56 V dB 78 INPUT IMPEDANCE RIN Input resistance CIN Input capacitance 100 GΩ Differential 2.0 Common mode 3.5 ISINK = 1 mA 44 pF OUTPUT VOL Low output voltage swing ISC Output short-circuit current TA = −40 to +125 ℃ 58 90 Sink current 30 mV mA POWER SUPPLY VS Operating supply voltage TA = −40 to +125 ℃ VS = 1.8 V, VCM = 0.5V, IO = 0 IQ Quiescent current (per comparator) 1.7 5.5 19 TA = −40 to +125 ℃ VS = 5.0 V, VCM = 0.5V, IO = 0 26 37 22 TA = −40 to +125 ℃ V 32 μA 46 SWITCHING CHARACTERISTICS tPD– Propagation delay time, High to low Input overdrive = 20 mV, CL = 15 pF 155 Input overdrive = 100 mV, CL = 15 pF 66 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. ns FN1617-38.1 — Data Sheet Micro-Power 22μA, 1.7V, RRI, Open-Drain Output Comparators LTC8725, LTC8726, LTC8727, LTC8728 P-4 Electrical Characteristics (continued) VS = 5.0V, TA = +25℃, unless otherwise noted. Boldface limits apply over the specified temperature range, TA = −40 to +125 ℃. Symbol tF Parameter Fall time Conditions Min. Input overdrive = 20 mV, CL = 15 pF Input overdrive = 100 mV, CL = 15 pF Typ. Max. 8 Unit ns 6 THERMAL CHARACTERISTICS TA θJA Operating temperature range Package Thermal Resistance -40 +125 SC70-5L 333 SOT23-5L 190 DFN2x2-8L 94 MSOP-8L 201 SOIC-8L 125 TSSOP-14L 112 SOIC-14L 115 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. ℃ ℃/W FN1617-38.1 — Data Sheet Micro-Power 22μA, 1.7V, RRI, Open-Drain Output Comparators LTC8725, LTC8726, LTC8727, LTC8728 P-5 FN1617-38.1 — Data Sheet Micro-Power 22μA, 1.7V, RRI, Open-Drain Output Comparators Typical Performance Characteristics At TA=+25℃, VS=±2.5V, VCM=VS /2, RL=10kΩ connected to VS /2, and CL=15pF, unless otherwise noted. 40 50 VCM=0.5V +125℃ 30 Supply Current (μA) Supply Current (μA) 35 25 20 15 +25℃ –40℃ 10 VS = 5V VOD = 50mV 45 40 35 Output Low Voltage 30 5 Output High Voltage 0 25 1.5 2 2.5 3 3.5 4 4.5 5 5.5 6 0 1 Supply Voltage (V) Supply Current vs. Supply Voltage 175 VCM = VS / 2 VOD = 50mV 150 +125℃ 125 Propagation Delay (ns) Propagation Delay H-L (ns) 3 100 75 –40℃ 4 5 Supply Current vs. Common-Mode Input 175 +25℃ 50 25 0 VCM = VS / 2 VOD = 100mV TA = +25℃ 150 125 100 75 50 25 0 1.5 2 2.5 3 3.5 4 4.5 5 5.5 1.5 2 2.5 Supply Voltage (V) 350 4 4.5 5 5.5 190 Propagation Delay H-L (ns) 300 3.5 Propagation Delay (tPHL) vs. Supply Voltage VCM = VS / 2 VOD = 10mV TA = +25℃ 325 3 Supply Voltage (V) Propagation Delay (tPHL) vs. Supply Voltage Propagation Delay (ns) 2 Common-Mode Voltage (V) 275 250 225 200 175 180 VOD = 20mV 170 160 150 140 130 120 1.5 2 2.5 3 3.5 4 4.5 5 5.5 0 Supply Voltage (V) Propagation Delay (tPHL) vs. Supply Voltage 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 Common-Mode Voltage (V) Propagation Delay (tPHL) vs. Input Common-Mode CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. LTC8725, LTC8726, LTC8727, LTC8728 P-6 Typical Performance Characteristics At TA=+25℃, VS=±2.5V, VCM=VS /2, RL=10kΩ connected to VS /2, and CL=15pF, unless otherwise noted. 300 VS = 5.0V 250 Propagation Delay (ns) Propagation Delay (ns) 300 200 150 100 50 0 VS = 1.8V 250 200 150 100 50 0 10 100 1000 10 100 Overdrive Voltage (mV) Propagation Delay (tPHL) vs. Input Overdrive Propagation Delay (tPHL) vs. Input Overdrive 1000 VS = 5.0V VOD = 100mV Propagation Delay (ns) Propagation Delay (ns) 1000 100 10 1 0.01 0.1 VS = 1.8V VOD = 100mV 100 10 1 0.01 1 Output Capacitive Load (nF) 0.1 1 Output Capacitive Load (nF) Propagation Delay (tPHL) vs. Capacitive Load Propagation Delay (tPHL) vs. Capacitive Load 50 10 Short-Circuit Current (mA) Short-Circuit Current (mA) 1000 Overdrive Voltage (mV) VS = 5.0V 45 –ISC 40 35 30 25 VS = 1.8V 8 –ISC 6 4 2 0 20 -50 -25 0 25 50 75 100 125 -50 Temperature (℃) Short Circuit Current vs. Temperature -25 0 25 50 75 100 Temperature (℃) Short Circuit Current vs. Temperature CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. 125 FN1617-38.1 — Data Sheet Micro-Power 22μA, 1.7V, RRI, Open-Drain Output Comparators LTC8725, LTC8726, LTC8727, LTC8728 P-7 Typical Performance Characteristics At TA=+25℃, VS=±2.5V, VCM=VS /2, RL=10kΩ connected to VS /2, and CL=15pF, unless otherwise noted. 5 Output Voltage (V) 4 +25℃ +125℃ 3 2 –40℃ 1 0 0 5 10 15 20 25 30 35 40 45 50 Output Current (mA) Output Voltage vs. Output Sinking Current CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-38.1 — Data Sheet Micro-Power 22μA, 1.7V, RRI, Open-Drain Output Comparators LTC8725, LTC8726, LTC8727, LTC8728 P-8 Application Notes OPERATING VOLTAGE The LTC872x family of micro-power comparators of open-drain output are fully specified and ensured for operation from 1.7 V to 5.5 V and offers an excellent speed-to-power combination with a propagation delay of 66 ns and a quiescent supply current of 22 μA. This combination of fast response time at micropower enables power conscious systems to monitor and respond quickly to fault conditions. In addition, and many specifications apply over the industrial temperature range of –40℃ to +125℃. Parameters that vary significantly with operating voltages or temperature are illustrated in the Typical Characteristics graphs. INPUT VOLTAGE The input common-mode voltage range of the LTC872x comparators extends 100mV beyond the supply rails. This performance is achieved with a complementary input stage: an N-channel input differential pair in parallel with a P-channel differential pair. The N-channel pair is active for input voltages close to the positive rail, typically VS+– 1.4V to the positive supply, whereas the P-channel pair is active for inputs from 100mV below the negative supply to approximately VS+–1.4V. There is a small transition region, typically VS+–1.2V to VS+–1V, in which both pairs are on. This 200mV transition region can vary up to 200mV with process variation. Thus, the transition region (both stages on) can range from VS+–1.4V to VS+–1.2V on the low end, up to VS+–1V to VS+–0.8V on the high end. Within this transition region, PSRR, CMRR, offset voltage, offset drift, and THD can be degraded compared to device operation outside this region. INPUT VOLTAGE The LTC8725/LTC8727 and LTC8726 comparator family uses CMOS transistors at the inputs which prevent phase inversion when the input pins exceed the supply voltages. VS+ D1 RS1 500Ω IN+ D2 D3 CCM1 RS2 CDM 500Ω IN– D4 CCM2 VS– Figure 1. Input EMI Filter and Clamp Circuit Figure 1 shows the input EMI filter and clamp circuit. The LTC8725/LTC8727 and LTC8726 comparators have internal ESD protection diodes (D1, D2, D3, and D4) that are connected between the inputs and each supply rail. These diodes protect the input transistors in the event of electrostatic discharge and are reverse biased during normal operation. This protection scheme allows voltages as high as approximately 500mV beyond the rails to be applied at the input of either terminal without causing permanent damage. See the table of Absolute Maximum Ratings for more information. EMI REJECTION RATIO Circuit performance is often adversely affected by high frequency EMI. When the signal strength is low and transmission lines are long, an amplifier must accurately amplify the input signals. However, all comparator pins — the non-inverting input, inverting input, positive supply, negative supply, and output pins — are susceptible to EMI signals. These high frequency signals are coupled into an comparator by various means, such as conduction, near field radiation, or far field radiation. For example, wires and printed circuit board (PCB) traces can act as antennas and pick up high frequency EMI signals. Amplifiers do not amplify EMI or RF signals due to their relatively low bandwidth. However, due to the nonlinearities of the input devices, comparators can rectify these out of band signals. When these high frequency signals are rectified, they appear as a dc offset at the output. The LTC872x comparators have integrated EMI filters at their input stage. A mathematical method of measuring EMIRR is defined as follows: EMIRR = 20 log (VIN_PEAK / ΔVOS) INTERNAL HYSTERESIS Most high-speed comparators oscillate in the linear region because of noise or undesired parasitic feedback. This tends to occur when the voltage on one input is at or equal to the voltage on the other input. To counter the parasitic effects and noise, the devices have an internal hysteresis of 5 mV. The hysteresis in a comparator creates two trip points: one for the rising input voltage and one for the falling input voltage. The difference between the trip points is the hysteresis. The average of the trip points is the offset voltage. When the comparator’s input voltages are equal, the hysteresis effectively causes one comparator input voltage to move quickly past the other, thus taking the input out of the region where oscillation occurs. Standard comparators require hysteresis to be added with external resistors. To increase hysteresis and noise margin e v e n m o r e , a d d CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-38.1 — Data Sheet Micro-Power 22μA, 1.7V, RRI, Open-Drain Output Comparators LTC8725, LTC8726, LTC8727, LTC8728 P-9 Application Notes positive feedback with two resistors as a voltage divider from the output to the non-inverting input. Figure 2 illustrates the case where IN– is fixed and IN+ is varied. If the inputs were reversed, the figure would look the same, except the output would be inverted. VTRIP+ VIN+ VHYST VOS VIN– = 0 VTRIP– VOS = (VTRIP+ + VTRIP–)/2 VOH Comparator Output VOL Figure 2. Input and Output Waveform, Non-inverting Input Varied MAXIMIZING PERFORMANCE THROUGH PROPER LAYOUT To achieve the maximum performance of the extremely high input impedance and low offset voltage of the LTC872x devices, care is needed in laying out the circuit board. The PCB surface must remain clean and free of moisture to avoid leakage currents between adjacent traces. Surface coating of the circuit board reduces surface moisture and provides a humidity barrier, reducing parasitic resistance on the board. The use of guard rings around the comparator inputs further reduces leakage currents. Figure 3 shows proper guard ring configuration and the top view of a surface-mount layout. The guard ring does not need to be a specific width, but it should form a continuous loop around both inputs. By setting the guard ring voltage equal to the voltage at the non-inverting input, parasitic capacitance is minimized as well. For further reduction of leakage currents, components can be mounted to the PCB using Teflon standoff insulators. Guard Ring +IN –IN Other potential sources of offset error are thermoelectric voltages on the circuit board. This voltage, also called Seebeck voltage, occurs at the junction of two dissimilar metals and is proportional to the temperature of the junction. The most common metallic junctions on a circuit board are solder-toboard trace and solder-to-component lead. If the temperature of the PCB at one end of the component is different from the temperature at the other end, the resulting Seebeck voltages are not equal, resulting in a thermal voltage error. This thermocouple error can be reduced by using dummy components to match the thermoelectric error source. Placing the dummy component as close as possible to its partner ensures both Seebeck voltages are equal, thus canceling the thermocouple error. Maintaining a constant ambient temperature on the circuit board further reduces this error. The use of a ground plane helps distribute heat throughout the board and reduces EMI noise pickup. INPUT-TO-OUTPUT COUPLING To minimize capacitive coupling, the input and output signal traces should not be parallel. This helps reduce unwanted positive feedback. +VS Figure 3. Use a guard ring around sensitive pins CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-38.1 — Data Sheet Micro-Power 22μA, 1.7V, RRI, Open-Drain Output Comparators LTC8725, LTC8726, LTC8727, LTC8728 P-10 Typical Application Circuits IR RECEIVER AFE AND WAKE- UP CIRCUIT Infrared (IR) communication is inherently immune to RF interference as long as there is a line-of-sight path between the transmitter and the receiver. It is also one of the lowest cost communication schemes. This makes it a good choice for implementing wireless communications in applications such as utility metering. A common system topology to extend battery life is to use a power efficient IR receiver analog front end (AFE) that is always on and wakes up the host only when there is a valid IR signal detected as shown in Figure 1. IR LED IR Receiver AFE Digital output (hardware wake-up event) GPIO MCU (Low Power) through R3. And finally R3 and R4 are used to introduce additional hysteresis to keep the output free of spurious toggles. VREF 3V Figure 4. Coin Cell Battery Powered IR Receiver R4 470kΩ 10MΩ 3V LTC872x Output to MCU (Also to wake-up MCU) R1 10MΩ C1 0.01μF Figure 5. IR Receiver AFE Using LTC8725 USE WINDOW COMPARATOR TO DETECT UNDER-VOLTAGE AND OVER-VOLTAGE Window comparators are commonly used to detect undervoltage (UV) and overvoltage (OV) conditions. Figure 6 shows a simple window comparator circuit. Power efficient comparators such as the LTC872x can be used in the IR receiver AFE to increase battery life. The LTC872x device is responsible for two major tasks: 1. IR signal conditioning, 2. Host system wake-up. The LTC872x device is constantly powered to always be ready to receive IR signals and wake up the host microcontroller (MCU) when data is received. The short working distance (approx 5 cm) is suitable for a virtual-contact operation where the IR transmitter and receiver are closely placed with an optional mechanical alignment guide. R3 470kΩ IR LED + 10MΩ R2 3.3V LTC8726 R1 RPU VS+ + UV_OV – Sensor VS– R2 MicroController VS+ + – R3 Figure 1 shows the IR receiver system block diagram. The host MCU is normally in the shutdown mode (during which the quiescent current is less than 1 μA) except when data is being transferred. VS– Figure 6. Window Comparator Figure 2 shows the detailed circuit design. The circuit establishes a threshold through R2 and C1 which automatically adapts to the ambient light level. To further reduce BOM cost, this example uses an IR LED as the IR receiver. The IR LED is reverse-biased to function as a photodiode (but at a reduced sensitivity). For this design, follow these design requirements: The low input bias current allows a greater load resistor value (R1) without sacrificing linearity, which in turn helps reduce the always-on supply current. Configure the circuit as shown in Figure 6. Connect VS+ to a 3.3-V power supply and VS– to ground. Make R 1, R2 and R3 each 10-MΩ resistors. These three resistors are used to create the positive and negative thresholds for the window comparator (VTH+ and VTH–). With each resistor being equal, VTH+ is 2.2 V and VTH– The load resistor R1 converts the IR light induced current into a voltage fed into the inverting input of the comparator. R2 and C1 establish a reference voltage VREF which tracks the mean amplitude of the IR signal. The non-inverting input is connected to VREF • Alert (logic low output) when an input signal is less than 1.1 V • Alert (logic low output) when an input signal is greater than 2.2 V • Alert signal is active low • Operate from a 3.3-V power supply CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-38.1 — Data Sheet Micro-Power 22μA, 1.7V, RRI, Open-Drain Output Comparators LTC8725, LTC8726, LTC8727, LTC8728 P-11 Typical Application Circuits is 1.1 V. Large resistor values such as 10-MΩ are used to minimize power consumption. The sensor output voltage is applied to the inverting and non-inverting inputs of the 2-channel LTC8726's. The LTC8726 is used for its open-drain output configuration. Using the LTC8726 allows the two comparator outputs to be Wire-ORed together. The respective comparator outputs will be low when the sensor is less than 1.1 V or greater than 2.2 V. VOUT will be high when the sensor is in the range of 1.1 V to 2.2 V. See the application curve in Figure 7. VIN VTH+ = 2.2 V VTH– = 1.1 V Time VOUT Time Figure 5. Window Comparator Results CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-38.1 — Data Sheet Micro-Power 22μA, 1.7V, RRI, Open-Drain Output Comparators LTC8725, LTC8726, LTC8727, LTC8728 P-12 Tape and Reel Information REEL DIMENSIONS TAPE DIMENSIONS K0 P1 B0 W Reel Diameter A0 Cavity A0 B0 K0 W P1 Reel Width (W1) Dimension designed to accommodate the component width Dimension designed to accommodate the component length Dimension designed to accommodate the component thickness Overall width of the carrier tape Pitch between successive cavity centers QUADRANT ASSIGNMENTS FOR PIN 1 ORIETATION IN TAPE Sprocket Holes Q1 Q2 Q1 Q2 Q3 Q4 Q3 Q4 User Direction of Feed Pocket Quadrants * All dimensions are nominal Device LTC8725YT5/R6 Package Pins Type SOT23 5 SPQ 3 000 Reel Reel Diameter Width W1 (mm) (mm) 178 9.0 A0 (mm) B0 (mm) K0 (mm) P1 (mm) W (mm) Pin 1 Quadrant 3.3 3.2 1.5 4.0 8.0 Q3 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-38.1 — Data Sheet Micro-Power 22μA, 1.7V, RRI, Open-Drain Output Comparators LTC8725, LTC8726, LTC8727, LTC8728 P-13 Package Outlines DIMENSIONS, SOT23-5L A2 A A1 D e1 Symbol A A1 A2 b c D E1 E e e1 L L1 θ θ L E E1 L1 e b Dimensions In Millimeters Min Max 1.25 0.04 0.10 1.00 1.20 0.33 0.41 0.15 0.19 2.820 3.02 1.50 1.70 2.60 3.00 0.95 BSC 1.90 BSC 0.60 REF 0.30 0.60 0° 8° Dimensions In Inches Min Max 0.049 0.002 0.004 0.039 0.047 0.013 0.016 0.006 0.007 0.111 0.119 0.059 0.067 0.102 0.118 0.037 BSC 0.075 BSC 0.024 REF 0.012 0.024 0° 8° c RECOMMENDED SOLDERING FOOTPRINT, SOT23-5L 1.0 0.039 0.95 0.037 0.95 0.037 0.7 0.028 2.4 0.094 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. mm ( inches ) FN1617-38.1 — Data Sheet Micro-Power 22μA, 1.7V, RRI, Open-Drain Output Comparators LTC8725, LTC8726, LTC8727, LTC8728 P-14 Package Outlines (continued) DIMENSIONS, SC70-5L (SOT353) A2 A Symbol A1 D e1 A A1 A2 b C D E E1 e e1 L L1 θ θ e L E1 E L1 b Dimensions In Millimeters Min Max 0.90 1.10 0.00 0.10 0.90 1.00 0.15 0.35 0.08 0.15 2.00 2.20 1.15 1.35 2.15 2.45 0.65 typ. 1.20 1.40 0.525 ref. 0.26 0.46 0° 8° C RECOMMENDED SOLDERING FOOTPRINT, SC70-5L (SOT353) 0.50 0.0197 0.65 0.0256 0.65 0.0256 0.40 0.0157 1.9 0.0748 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. mm ( inches ) Dimensions In Inches Min Max 0.035 0.043 0.000 0.004 0.035 0.039 0.006 0.014 0.003 0.006 0.079 0.087 0.045 0.053 0.085 0.096 0.026 typ. 0.047 0.055 0.021 ref. 0.010 0.018 0° 8° FN1617-38.1 — Data Sheet Micro-Power 22μA, 1.7V, RRI, Open-Drain Output Comparators LTC8725, LTC8726, LTC8727, LTC8728 P-15 Package Outlines (continued) DIMENSIONS, DFN2x2-8L E A c A1 1 Nd D1 2 D b1 Exposed Thermal Pad Zone L h E1 h 2 e Symbol Min. 0.70 A A1 b b1 c D D1 Nd E E1 e L h 0.20 0.18 1.90 1.10 1.90 0.60 0.30 0.15 Millimeters Nom. 0.75 0.02 0.25 0.18 REF 0.20 2.00 1.20 1.50BSC 2.00 0.70 0.50BSC 0.35 0.20 1 b BOTTOM VIEW RECOMMENDED SOLDERING FOOTPRINT, DFN2x2-8L 1.60 0.0630 PACKAGE OUTLINE 8X 0.50 0.0197 1.00 0.0394 2.30 0.0906 1 0.50 PITCH 0.0197 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. 0.30 8X 0.0118 mm ( inches ) Max. 0.80 0.05 0.30 0.25 2.10 1.30 2.10 0.80 0.40 0.25 FN1617-38.1 — Data Sheet Micro-Power 22μA, 1.7V, RRI, Open-Drain Output Comparators LTC8725, LTC8726, LTC8727, LTC8728 P-16 Package Outlines (continued) DIMENSIONS, SOIC-8L A2 A A1 D b Symbol e A A1 A2 b C D E E1 e L θ L E E1 θ Dimensions In Millimeters Min Max 1.370 1.670 0.070 0.170 1.300 1.500 0.306 0.506 0.203 TYP. 4.700 5.100 3.820 4.020 5.800 6.200 1.270 TYP. 0.450 0.750 0° 8° Dimensions In Inches Min Max 0.054 0.066 0.003 0.007 0.051 0.059 0.012 0.020 0.008 TYP. 0.185 0.201 0.150 0.158 0.228 0.244 0.050 TYP. 0.018 0.030 0° 8° C RECOMMENDED SOLDERING FOOTPRINT, SOIC-8L 8X 5.40 0.213 (1.55) MAX (0.061) (3.90) MIN (0.154) 1 (0.60) MAX 8X (0.024) PITCH 1.270 0.050 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. mm ( inches ) FN1617-38.1 — Data Sheet Micro-Power 22μA, 1.7V, RRI, Open-Drain Output Comparators LTC8725, LTC8726, LTC8727, LTC8728 P-17 Package Outlines (continued) DIMENSIONS, MSOP-8L A2 A A1 D b Symbol e A A1 A2 b C D E E1 e L θ L E1 E Dimensions In Millimeters Min Max 0.800 1.100 Dimensions In Inches Min Max 0.031 0.043 0.050 0.150 0.750 0.950 0.290 0.380 0.150 0.200 2.900 3.100 2.900 3.100 4.700 5.100 0.650 TYP. 0.400 0.700 0° 8° 0.002 0.006 0.030 0.037 0.011 0.015 0.006 0.008 0.114 0.122 0.114 0.122 0.185 0.201 0.026 TYP. 0.016 0.028 0° 8° θ C RECOMMENDED SOLDERING FOOTPRINT, MSOP-8L 8X (0.45) MAX (0.018) (1.45) MAX (0.057) 8X 4.40 (5.85) MAX 0.173 (0.230) (2.95) MIN (0.116) 0.65 PITCH 0.026 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. mm ( inches ) FN1617-38.1 — Data Sheet Micro-Power 22μA, 1.7V, RRI, Open-Drain Output Comparators LTC8725, LTC8726, LTC8727, LTC8728 P-18 Package Outlines (continued) DIMENSIONS, SOIC-14L A3 A2 A A1 D b C e L1 L E Symbol E1 A A1 A2 A3 b C D E E1 e L1 L θ Dimensions In Millimeters Min Max 1.450 1.850 0.100 0.300 1.350 1.550 0.550 0.750 0.406 TYP. 0.203 TYP. 8.630 8.830 5.840 6.240 3.850 4.050 1.270 TYP. 1.040 REF. 0.350 0.750 2° 8° Dimensions In Inches Min Max 0.057 0.073 0.004 0.012 0.053 0.061 0.022 0.030 0.016 TYP. 0.008 TYP. 0.340 0.348 0.230 0.246 0.152 0.159 0.050 TYP. 0.041 REF. 0.014 0.030 2° 8° θ RECOMMENDED SOLDERING FOOTPRINT, SOIC-14L 14X 5.40 0.213 (1.50) MAX (0.059) (3.90) MIN (0.154) 1 (0.60) MAX 14X (0.024) PITCH 1.270 0.050 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. mm ( inches ) FN1617-38.1 — Data Sheet Micro-Power 22μA, 1.7V, RRI, Open-Drain Output Comparators LTC8725, LTC8726, LTC8727, LTC8728 P-19 Package Outlines (continued) DIMENSIONS, TSSOP-14L A3 A2 A Symbol A1 D b e C L1 L E E1 A A1 A2 A3 b C D E E1 e L1 L θ Dimensions In Millimeters Min Max 1.200 0.050 0.150 0.900 1.050 0.390 0.490 0.200 0.290 0.130 0.180 4.860 5.060 6.200 6.600 4.300 4.500 0.650 TYP. 1.000 REF. 0.450 0.750 0° 8° Dimensions In Inches Min Max 0.047 0.002 0.006 0.035 0.041 0.015 0.019 0.008 0.011 0.005 0.007 0.191 0.199 0.244 0.260 0.169 0.177 0.026 TYP. 0.039 REF. 0.018 0.030 0° 8° θ RECOMMENDED SOLDERING FOOTPRINT, TSSOP-14L 14X (1.45) MAX (0.057) (4.40) MIN (0.173) PITCH 0.65 0.026 1 5.90 0.232 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. 14X (0.45) MAX (0.018) mm ( inches ) FN1617-38.1 — Data Sheet Micro-Power 22μA, 1.7V, RRI, Open-Drain Output Comparators P-20 LTC8725, LTC8726, LTC8727, LTC8728 IMPORTANT NOTICE Linearin is a global fabless semiconductor company specializing in advanced high-performance highquality analog/mixed-signal IC products and sensor solutions. The company is devoted to the innovation of high performance, analog-intensive sensor front-end products and modular sensor solutions, applied in multi-market of medical & wearable devices, smart home, sensing of IoT, and intelligent industrial & smart factory (industrie 4.0). Linearin’s product families include widely-used standard catalog products, solution-based application specific standard products (ASSPs) and sensor modules that help customers achieve faster time-to-market products. Go to http://www.linearin.com for a complete list of Linearin product families. For additional product information, or full datasheet, please contact with the Linearin’s Sales Department or Representatives. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-38.1 — Data Sheet Micro-Power 22μA, 1.7V, RRI, Open-Drain Output Comparators
LTC8727YT5/R6
物料型号包括LTC8725、LTC8726、LTC8727和LTC8728,这些是微功耗、1.7V供电、RRI、开漏输出比较器。
器件简介为小巧的单通道和双通道比较器,具有高速(66纳秒传播延迟)和极低功耗(22微安)的特点。
引脚分配为单通道比较器有OUT、+VS、-IN、+IN和-VS引脚;双通道比较器在此基础上增加了OUTB、-INB和+INB引脚。
参数特性包括22微安的微功耗操作电流、1.7V至5.5V的单电源电压范围、轨到轨输入和开漏输出,以及30毫安的大输出驱动电流。
功能详解涉及内部滞后确保干净输出切换,内部射频/电磁干扰滤波器,以及在-40°C至+125°C的工业温度范围内工作。
应用信息包括红外接收器、消费附件、手机、平板电脑和笔记本电脑、便携式和电池供电设备、阈值检测器和鉴别器、报警和监控电路、零交叉检测器、窗口比较器和电平转换器等。
封装信息为单通道比较器提供SOT23-5L和SC70-5L封装,双通道比较器提供DFN-8L、SOIC-8L和MSOP-8L封装,四通道比较器提供SOIC-14L和TSSOP-14L封装。
所有设备均在-40°C至+125°C的温度范围内额定。
LTC8727YT5/R6 价格&库存
很抱歉,暂时无法提供与“LTC8727YT5/R6”相匹配的价格&库存,您可以联系我们找货
LTC8727YT5/R6
  • 1+1.63125
  • 30+1.57500
  • 100+1.46250
  • 500+1.35000
  • 1000+1.29375
