LTC8825XT5/R6
LTC8825XT5/R6
    LINEARIN(先积)
    SOT23-5
    :微功率500kHz,精密,1.8V, RRIO CMOS放大器
LTC8825XT5/R6 数据手册
LTC8825, LTC8826, LTC8828 P-1 General Description The LTC882x family of single-, dual-, and quad- channel amplifiers provides input offset voltage correction for low offset (maximum 350 μV) and drift (typically 0.8 μV/℃) through the use of proprietary techniques. Featuring rail-to-rail input and output swings, and low quiescent current (typical 15 µA at 5V supply) combined with a wide bandwidth of 500 kHz and very low noise (6 μVP-P at 0.1 to 10 Hz) makes this family very attractive for a variety of battery-powered applications such as wearables, tablets, and portable medical devices. The low input bias current supports these amplifiers to be used in applications with mega-ohm source impedances. The robust design of the LTC882x operational amplifiers provides ease-of-use to the circuit designer: integrated RF/EMI rejection filter, no phase reversal in overdrive conditions, and high electro-static discharge (ESD) protection (5-kV HBM and 2-kV CDM). The LTC882x amplifiers are optimized for operation at voltages as low as +1.8 V (±0.9 V) and up to +5.5 V (±2.75 V). The LTC8825/8827 (single) is available in both SOT23-5L and SC70-5L packages. The LTC8826 (dual) is offered in DFN-8L, SOIC-8L and MSOP-8L packages. The quadchannel LTC8828 is offered in both SOIC-14L and TSSOP-14L packages. All of the devices are specified over the extended temperature range of −40 ℃ to +125 ℃. Features and Benefits         500 kHz GBW Micro-power 15 μA Supply Current (at 5V Supply, Per Amplifier) Low Input Offset Voltage: ±350 μV Maximum Low Noise: 6 μVP-P at 0.1 to 10 Hz Single 1.8 V to 5.5 V Supply Voltage Range Rail-to-Rail Input and Output Internal RF/EMI Filter Extended Temperature Range: −40℃ to +125℃ Applications  Battery-Powered Instruments: – Consumer, Industrial, Medical, Notebooks  Wearable Fitness Devices  Audio Outputs  Sensor Signal Conditioning: – Sensor Interfaces, Loop-Powered, Active Filters  Wireless Sensors: – Home Security, Remote Sensing, Wireless Metering Pin Configurations (Top View) LTC8825 LTC8826 LTC8826 LTC8828 SOT23-5L / SC70-5L DFN-8L SOIC-8L / MSOP-8L SOIC-14L / TSSOP-14L OUT 1 –VS 2 +IN 3 5 4 +VS –IN LTC8827 OUTA 1 8 +VS –INA 2 7 OUTB +INA 3 6 –INB –VS 4 5 +INB OUTA –INA 1 2 8 7 A 1 –VS 2 –IN 3 5 4 OUTB OUTA 1 14 OUTD –INA 2 13 –IND A +INA 3 –VS 4 B SOT23-5L / SC70-5L +IN +VS +VS OUT CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. D 6 –INB +INA 3 12 +IND 5 +INB +VS 4 11 –VS +INB 5 10 +INC –INB 6 9 –INC OUTB 7 8 OUTC B C FN1617-35T.1 — Data Sheet Micropower 500kHz, Precision, 1.8V, RRIO CMOS Amplifiers LTC8825, LTC8826, LTC8828 P-2 Pin Description Symbol Description –IN Inverting input of the amplifier. +IN Non-inverting input of the amplifier. +VS Positive (highest) power supply. –VS Negative (lowest) power supply. OUT Amplifier output. Ordering Information Type Number Package Name Package Quantity Marking Code (1) LTC8825XT5/R6 SOT23-5L Tape and Reel, 3 000 AL1xxx LTC8825XC5/R6 SC70-5L Tape and Reel, 3 000 AL1xxx LTC8826XF8/R6 DFN2x2-8L Tape and Reel, 3 000 AL2 LTC8826XS8/R8 SOIC-8L Tape and Reel, 4 000 AL2IX LTC8826XV8/R6 MSOP-8L Tape and Reel, 3 000 AL2I LTC8827XT5/R6 SOT23-5L Tape and Reel, 3 000 AL3xxx LTC8827XC5/R6 SC70-5L Tape and Reel, 3 000 AL3xxx LTC8828XS14/R5 SOIC-14L Tape and Reel, 2 500 AL4IX LTC8828XT14/R6 TSSOP-14L Tape and Reel, 3 000 AL4IX (1) There may be multiple device markings, a varied marking character of “x” , or additional marking, which relates to the logo, the lot trace code information, or the environmental category on the device. Limiting Value In accordance with the Absolute Maximum Rating System (IEC 60134). Parameter Absolute Maximum Rating Supply Voltage, VS+ to VS– 10.0 V Signal Input Terminals: Voltage, Current VS– – 0.3 V to VS+ + 0.3 V, ±10 mA Output Short-Circuit Continuous Storage Temperature Range, Tstg –65 ℃ to +150 ℃ Junction Temperature, TJ 150 ℃ Lead Temperature Range (Soldering 10 sec) 260 ℃ ESD Rating Parameter Electrostatic Discharge Voltage Item Value Human body model (HBM), per MIL-STD-883J / Method 3015.9 (1) ±5 000 Charged device model (CDM), per ESDA/JEDEC JS-002-2014 (2) ±2 000 Machine model (MM), per JESD22-A115C ±250 (1) JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process. (2) JEDEC document JEP157 states that 250-V CDM allows safe manufacturing with a standard ESD control process. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. Unit V FN1617-35T.1 — Data Sheet Micropower 500kHz, Precision, 1.8V, RRIO CMOS Amplifiers LTC8825, LTC8826, LTC8828 P-3 Electrical Characteristics VS = 5.0V, TA = +25℃, VCM = VS /2, VO = VS /2, and RL = 10kΩ connected to VS /2, unless otherwise noted. Boldface limits apply over the specified temperature range, TA = −40 to +125 ℃. Symbol Parameter Conditions Min. Typ. Max. LTC8825, LTC8826 ±100 ±350 LTC8828 ±120 ±500 ±0.8 ±2.3 Unit OFFSET VOLTAGE VOS Input offset voltage VOS TC Offset voltage drift TA = −40 to +125 ℃ Power supply rejection ratio VS = 2.0 to 5.5 V, VCM < VS+ − 2V 98 TA = −40 to +125 ℃ 88 PSRR 115 μV μV/℃ dB INPUT BIAS CURRENT 1 IB Input bias current IOS Input offset current TA = +85 ℃ 150 TA = +125 ℃ 500 pA 1 pA μVP-P NOISE Vn Input voltage noise f = 0.1 to 10 Hz 6 en Input voltage noise density f = 10 kHz 62 f = 1 kHz 63 In Input current noise density f = 1 kHz 5 nV/√Hz fA/√Hz INPUT VOLTAGE VCM CMRR Common-mode voltage range Common-mode rejection ratio VS––0.1 VS++0.1 TA = −40 to +125 ℃ VS– VS+–0.1 VCM = 0 to 4.0 V 86 VCM = 0 to 4.0 V, TA = −40 to +125 ℃ 80 VS = 2.0 V, VCM = 0 to 1.0 V 82 VCM = 0 to 1.8 V, TA = −40 to +125 ℃ 77 V 102 95 dB INPUT IMPEDANCE RIN Input resistance CIN Input capacitance 100 GΩ Differential 2.0 Common mode 3.5 pF OPEN-LOOP GAIN AVOL Open-loop voltage gain RL = 25 kΩ, VO = 0.05 to 3.5 V 106 TA = −40 to +125 ℃ 100 RL = 5 kΩ, VO = 0.15 to 3.5 V 100 TA = −40 to +125 ℃ FREQUENCY RESPONSE Gain bandwidth GBW product Slew rate THD+N Total harmonic distortion + noise tS Settling time SR 118 112 dB 94 500 kHz G = +1, CL = 100 pF, VO = 1.5 to 3.5 V 0.25 V/μs G = +1, f = 1 kHz, RL = 2 kΩ, VO = 1 VRMS 0.005 % To 0.1%, G = +1, 1V step 6 To 0.01%, G = +1, 1V step 7 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. μs FN1617-35T.1 — Data Sheet Micropower 500kHz, Precision, 1.8V, RRIO CMOS Amplifiers LTC8825, LTC8826, LTC8828 P-4 Electrical Characteristics (continued) VS = 5.0V, TA = +25℃, VCM = VS /2, VO = VS /2, and RL = 10kΩ connected to VS /2, unless otherwise noted. Boldface limits apply over the specified temperature range, TA = −40 to +125 ℃. Symbol tOR Parameter Overload recovery time Conditions Min. To 0.1%, VIN * Gain > VS Typ. Max. 10 Unit μs OUTPUT VOH High output voltage swing RL = 25 kΩ VS+–8 VS+–5 RL = 5 kΩ VS+–36 VS+–26 VOL Low output voltage swing RL = 25 kΩ VS–+4 VS–+6 RL = 5 kΩ VS–+16 VS–+24 ISC Short-circuit current mV ±45 mV mA POWER SUPPLY VS Operating supply voltage IQ Quiescent current (per amplifier) 1.8 5.5 VS = 1.8V, TA = +25℃ 9 12 VS = 5.0V, TA = +25℃ 15 19 V μA THERMAL CHARACTERISTICS TA θJA Operating temperature range Package Thermal Resistance -40 +125 SC70-5L 333 SOT23-5L 190 DFN2x2-8L 80 MSOP-8L 216 SOIC-8L 125 TSSOP-14L 112 SOIC-14L 115 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. ℃ ℃/W FN1617-35T.1 — Data Sheet Micropower 500kHz, Precision, 1.8V, RRIO CMOS Amplifiers LTC8825, LTC8826, LTC8828 P-5 Typical Performance Characteristics At TA = +25℃, VCM = VS /2, and RL = 10kΩ connected to VS /2, unless otherwise noted. CL=10pF 80 50 100 45 60 40 40 20 20 0 Phase (deg) 80 60 AOL (dB) 120 -20 0 -40 -20 1000 Closed Loop Gain (dB) 100 -60 10k 100k CL=50pF 40 35 30 25 20 15 10 1M 10 100 Frequency (Hz) 25 Quiescent Current (μA) Quiescent Current (μA) 100k Closed-Loop Gain as a function of Frequency. 25 20 15 10 5 VS = 5.5 V 20 15 10 5 0 0 1.5 2 2.5 3 3.5 4 4.5 5 -50 5.5 Quiescent Current as a function of Supply Voltage. -25 0 25 50 75 100 125 Temperature (℃) Supply Voltage (V) Quiescent Current as a function of Temperature. 140 VS = 5V VCM = –VS 4,490 Samples Noise (nV/rtHz) 120 100 80 60 40 20 -350 -300 -250 -200 -150 -100 -50 0 50 100 150 200 250 300 350 Distribution (Unit) 10k Frequency (Hz) Open-loop Gain and Phase as a function of Frequency. 500 450 400 350 300 250 200 150 100 50 0 1k 0 10 Offset Voltage (μV) Offset Voltage Production Distribution 100 1k 10k 100k Frequency (Hz) Input Voltage Noise Spectral Density as a function of Frequency. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-35T.1 — Data Sheet Micropower 500kHz, Precision, 1.8V, RRIO CMOS Amplifiers LTC8825, LTC8826, LTC8828 P-6 Typical Performance Characteristics (continued) 140 140 120 120 100 100 PSRR (dB) CMRR (dB) At TA = +25℃, VCM = VS /2, and RL = 10kΩ connected to VS /2, unless otherwise noted. 80 60 80 60 40 40 20 20 0 0 1 10 100 1k 10k 100k 1M 1 Frequency (Hz) 10 100 1k 10k 100k Frequency (Hz) Common-mode Rejection Ratio as a function of Frequency. Power Supply Rejection Ratio as a function of Frequency. 50mV/div CL=20pF 1 V/div 1M CL = 20pF AV = +1 50 μs/div 5μs/div Large Signal Step Response (4V Step). Small Signal Step Response (200mV Step). CL=100pF 20mV/div 20mV/div CL=20pF 5μs/div 5μs/div Small Signal Step Response (100mV Step). Small Signal Step Response (100mV Step). CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-35T.1 — Data Sheet Micropower 500kHz, Precision, 1.8V, RRIO CMOS Amplifiers LTC8825, LTC8826, LTC8828 P-7 Typical Performance Characteristics (continued) At TA = +25℃, VCM = VS /2, and RL = 10kΩ connected to VS /2, unless otherwise noted. 80 Sourcing Current Output Voltage (V) 4 3 –40℃ +125℃ +25℃ 2 1 Sinking Current 0 Short-circuit Current (mA) 5 60 –ISC 40 +ISC 20 0 0 10 20 30 40 50 60 2 3 3.5 4 4.5 5 5.5 Supply Voltage (V) Output Current (mA) Output Voltage Swing as a function of Output Current. 2.5 Short-circuit Current as a function of Supply Voltage. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-35T.1 — Data Sheet Micropower 500kHz, Precision, 1.8V, RRIO CMOS Amplifiers P-8 LTC8825, LTC8826, LTC8828 Application Notes Featuring a maximized ratio of GBW-to-supply current, precision, low supply voltage, low input bias current, and rail-to-rail inputs and outputs, the LTC882x family is an excellent choice for precision or general-purpose, low-current, low-voltage, battery-powered applications. These CMOS operational amplifiers consume an ultra-low 15-μA (typically at 5-V supply voltage) supply current per amplifier. The LTC882x family is unity-gain stable with a 500-kHz GBW product, driving capacitive loads up to 20-pF. The capacitive load can be increased to 500-pF when the amplifier is configured for a 5-V/V gain. OPERATING VOLTAGE The LTC882x family is optimized for operation at voltages as low as +1.8 V (±0.9 V) and up to +5.5 V (±2.75 V). In addition, many specifications apply from –40 ℃ to +125 ℃. Parameters that vary significantly with operating voltages or temperature are illustrated in the Typical Characteristics graphs. INPUT EMI FILTER AND CLAMP CIRCUIT Figure 1 shows the input EMI filter and clamp circuit. The LTC882x op-amps have internal ESD protection diodes (D1, D2, D3, and D4) that are connected between the inputs and each supply rail. These diodes protect the input transistors in the event of electrostatic discharge and are reverse biased during normal operation. This protection scheme allows voltages as high as approximately 300-mV beyond the rails to be applied at the input of either terminal without causing permanent damage. These ESD protection current-steering diodes also provide in-circuit, input overdrive protection, as long as the current is limited to 10-mA as stated in the Absolute Maximum Ratings. VS+ D1 IN+ D2 RAIL-TO-RAIL INPUT The input common-mode voltage range of the LTC882x series extends 100-mV beyond the negative and positive supply rails. This performance is achieved with a complementary input stage: an Nchannel input differential pair in parallel with a Pchannel differential pair. The N-channel pair is active for input voltages close to the positive rail, typically VS+–1.4 V to the positive supply, whereas the Pchannel pair is active for inputs from 100-mV below the negative supply to approximately VS+–1.4 V. There is a small transition region, typically VS+–1.2 V to VS+–1 V, in which both pairs are on. This 200-mV transition region can vary up to 200-mV with process variation. Thus, the transition region (both stages on) can range from VS+–1.4 V to VS+–1.2 V on the low end, up to VS+–1 V to VS+–0.8 V on the high end. Within this transition region, PSRR, CMRR, offset voltage, offset drift, and THD can be degraded compared to device operation outside this region. The typical input bias current of the LTC882x opamps during normal operation is approximately 1-pA. In overdriven conditions, the bias current can increase significantly. The most common cause of an overdriven condition occurs when the operational amplifier is outside of the linear range of operation. When the output of the operational amplifier is driven to one of the supply rails, the feedback loop requirements cannot be satisfied and a differential input voltage develops across the input pins. This differential input voltage results in activation of parasitic diodes inside the front-end input chopping switches that combine with electromagnetic interference (EMI) filter resistors to create the equivalent circuit. Notice that the input bias current remains within specification in the linear region. RS1 5kΩ D3 CCM1 RS2 CDM 5kΩ IN– D4 CCM2 VS– Figure 1. Input EMI Filter and Clamp Circuit Operational amplifiers vary in susceptibility to EMI. If conducted EMI enters the operational amplifier, the dc offset at the amplifier output can shift from its nominal value when EMI is present. This shift is a result of signal rectification associated with the internal semiconductor junctions. Although all operational amplifier pin functions can be affected by EMI, the input pins are likely to be the most susceptible. The EMI filter of the LTC882x family is composed of two 5-kΩ input series resistors (RS1 and RS2), two common-mode capacitors (CCM1 and CCM2), and a differential capacitor (CDM). These RC networks set the −3 dB low-pass cutoff frequencies at 35-MHz for common-mode signals, and at 22-MHz for differential signals. RAIL-TO-RAIL OUTPUT Designed as a micro-power, low-noise operational amplifier, the LTC882x delivers a robust output drive capability. A class AB output stage with commonsource transistors is used to achieve full rail-to-rail output swing capability. For resistive loads up to 25kΩ, the output swings typically to within 5 mV of either supply rail regardless of the power-supply voltage applied. Different load conditions change the ability of the amplifier to swing close to the rails. For resistive loads up to 5-kΩ, the output swings typically to within 26-mV of the positive supply rail and within 16-mV of the negative supply rail. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-35T.1 — Data Sheet Micropower 500kHz, Precision, 1.8V, RRIO CMOS Amplifiers LTC8825, LTC8826, LTC8828 P-9 Application Notes (continued) CAPACITIVE LOAD AND STABILITY The LTC882x family of operational amplifiers is unity-gain stable for loads up to 20-pF. However, the capacitive load can be increased to 500-pF when the amplifier is configured for a minimum gain of 5-V/V. As with most amplifiers, driving larger capacitive loads than specified may cause excessive overshoot and ringing, or even oscillation. A heavy capacitive load reduces the phase margin and causes the amplifier frequency response to peak. Peaking corresponds to overshooting or ringing in the time domain. Therefore, it is recommended that external compensation be used if the LTC882x family requires greater capacitive-drive capability. This compensation is particularly important in the unitygain configuration, which is the worst case for stability. A quick and easy way to stabilize the op-amp for capacitive load drive is by adding a series resistor, RISO, between the amplifier output terminal and the load capacitance, as shown in Figure 2. RISO isolates the amplifier output and feedback network from the capacitive load. The bigger the RISO resistor value, the more stable VOUT will be. Note that this method results in a loss of gain accuracy because RISO forms a voltage divider with the RL. In unity gain applications with relatively small RL (approximately 5-kΩ), the capacitive load can be increased up to 100pF. RISO VOUT LTC882x VIN RL CL Figure 2. Indirectly Driving Heavy Capacitive Load An improvement circuit is shown in Figure 3. It provides DC accuracy as well as AC stability. The RF provides the DC accuracy by connecting the inverting signal with the output. CF RF RISO VOUT LTC882x VIN CL RL The CF and RISO serve to counteract the loss of phase margin by feeding the high frequency component of the output signal back to the amplifier’s inverting input, thereby preserving phase margin in the overall feedback loop. For no-buffer configuration, there are two others ways to increase the phase margin: (a) by increasing the amplifier’s gain, or (b) by placing a capacitor in parallel with the feedback resistor to counteract the parasitic capacitance associated with inverting node. OVERLOAD RECOVERY Overload recovery is defined as the time required for the operational amplifier output to recover from a saturated state to a linear state. The output devices of the operational amplifier enter a saturation region when the output voltage exceeds the rated operating voltage, either because of the high input voltage or the high gain. After the device enters the saturation region, the charge carriers in the output devices require time to return back to the linear state. After the charge carriers return back to the linear state, the device begins to slew at the specified slew rate. Thus, the propagation delay in case of an overload condition is the sum of the overload recovery time and the slew time. The overload recovery time for the LTC882x family is approximately 10-μs. EMI REJECTION RATIO Circuit performance is often adversely affected by high frequency EMI. When the signal strength is low and transmission lines are long, an op-amp must accurately amplify the input signals. However, all opamp pins — the non-inverting input, inverting input, positive supply, negative supply, and output pins — are susceptible to EMI signals. These high frequency signals are coupled into an op-amp by various means, such as conduction, near field radiation, or far field radiation. For example, wires and printed circuit board (PCB) traces can act as antennas and pick up high frequency EMI signals. Amplifiers do not amplify EMI or RF signals due to their relatively low bandwidth. However, due to the nonlinearities of the input devices, op-amps can rectify these out of band signals. When these high frequency signals are rectified, they appear as a dc offset at the output. The LTC882x op-amps have integrated EMI filters at their input stage. A mathematical method of measuring EMIRR is defined as follows: EMIRR = 20 log (VIN_PEAK / ΔVOS) INPUT-TO-OUTPUT COUPLING Figure 3. Indirectly Driving Heavy Capacitive Load with DC Accuracy To minimize capacitive coupling, the input and output signal traces should not be parallel. This helps reduce CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-35T.1 — Data Sheet Micropower 500kHz, Precision, 1.8V, RRIO CMOS Amplifiers LTC8825, LTC8826, LTC8828 P-10 Application Notes (continued) unwanted positive feedback. MAXIMIZING PERFORMANCE THROUGH PROPER LAYOUT To achieve the maximum performance of the extremely high input impedance and low offset voltage of the LTC882x op-amps, care is needed in laying out the circuit board. The PCB surface must remain clean and free of moisture to avoid leakage currents between adjacent traces. Surface coating of the circuit board reduces surface moisture and provides a humidity barrier, reducing parasitic resistance on the board. The use of guard rings around the amplifier inputs further reduces leakage currents. Figure 4 shows proper guard ring configuration and the top view of a surface-mount layout. The guard ring does not need to be a specific width, but it should form a continuous loop around both inputs. By setting the guard ring voltage equal to the voltage at the non-inverting input, parasitic capacitance is minimized as well. For further reduction of leakage currents, components can be mounted to the PCB using Teflon standoff insulators. Guard Ring +IN –IN +VS Figure 4. Use a guard ring around sensitive pins Other potential sources of offset error are thermoelectric voltages on the circuit board. This voltage, also called Seebeck voltage, occurs at the junction of two dissimilar metals and is proportional to the temperature of the junction. The most common metallic junctions on a circuit board are solder-toboard trace and solder-to-component lead. If the temperature of the PCB at one end of the component is different from the temperature at the other end, the resulting Seebeck voltages are not equal, resulting in a thermal voltage error. This thermocouple error can be reduced by using dummy components to match the thermoelectric error source. Placing the dummy component as close as possible to its partner ensures both Seebeck voltages are equal, thus canceling the thermocouple error. Maintaining a constant ambient temperature on the circuit board further reduces this error. The use of a ground plane helps distribute heat throughout the board and reduces EMI noise pickup. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-35T.1 — Data Sheet Micropower 500kHz, Precision, 1.8V, RRIO CMOS Amplifiers LTC8825, LTC8826, LTC8828 P-11 Typical Application Circuits DIFFERENTIAL AMPLIFIER monitoring applications, 50-mV is adequate. 3. Calculate R1 as follows: R1 = RF×(VHYST÷VBATT) ≈ 10MΩ×(50mV÷2.4V) = 210kΩ R2 R1 Vn LTC882x 4. Select a threshold voltage for VIN rising (VTS) = 2.0V. VOUT Vp 5. Calculate R2 as follows: R2 = 1÷[VTS÷(VREF×R1)-1÷R1-1÷RF] = 1÷[2V÷(1.2V×210kΩ)-1÷210kΩ-1÷10MΩ] = 325kΩ R3 R4 VREF Figure 5. Differential Amplifier The circuit shown in Figure 5 performs the difference function. If the resistors ratios are equal R4/R3 = R2/R1, then: 6. Calculate RBIAS: The minimum supply voltage for this circuit is 1.8V. Providing 9μA of supply current assures proper operation. Therefore: RBIAS = (VBATTMIN-VREF)÷IBIAS = (1.8V-1.2V)÷ 9μA = 67kΩ VOUT = (Vp – Vn) × R2/R1 + VREF INSTRUMENTATION AMPLIFIER RF R1 RG IN+ + VREF R1 R2 R2 R1 IBIAS VBATT RBIAS LTC882x LTC882x VSTATUS LTC882x IN– R2 VOUT V1 VREF V2 VOUT =(V1  V2 )(1  R1 2 R1  )  VREF R2 RG Figure 7. Battery Monitor Figure 6. Instrumentation Amplifier The LTC882x family is well suited for conditioning sensor signals in battery-powered applications. Figure 6 shows a two op-amp instrumentation amplifier, using the LTC882x op-amps. The circuit works well for applications requiring rejection of common-mode noise at higher gains. The reference voltage (VREF) is supplied by a low-impedance source. In single voltage supply applications, the VREF is typically VS/2. PORTABLE GAS METER VS ½ LTC8822 C S REF RF W RB BATTERY MONITORING The low operating voltage and quiescent current of the LTC882x family make it an excellent choice for battery monitoring applications, as shown in Figure 7. In this circuit, VSTATUS is high as long as the battery voltage remains above 2-V (VREF = 1.2V). A low-power reference is used to set the trip point. Resistor values are selected as follows: C2 C1 RL VS ½ LTC8822 R1 R1 Figure 8. Portable Gas Meter Application 1. RF Selecting: Select RF such that the current through RF is approximately 1000x larger than the maximum bias current over temperature: RF = VREF÷(1000×IBMAX) = 1.2V÷(1000×100pA) = 12MΩ ≈ 10MΩ 2. Choose the hysteresis voltage, VHYST. For battery CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. VOUT FN1617-35T.1 — Data Sheet Micropower 500kHz, Precision, 1.8V, RRIO CMOS Amplifiers LTC8825, LTC8826, LTC8828 P-12 Tape and Reel Information REEL DIMENSIONS TAPE DIMENSIONS K0 P1 B0 W Reel Diameter A0 Cavity A0 B0 K0 W P1 Reel Width (W1) Dimension designed to accommodate the component width Dimension designed to accommodate the component length Dimension designed to accommodate the component thickness Overall width of the carrier tape Pitch between successive cavity centers QUADRANT ASSIGNMENTS FOR PIN 1 ORIETATION IN TAPE Sprocket Holes Q1 Q2 Q1 Q2 Q3 Q4 Q3 Q4 User Direction of Feed Pocket Quadrants * All dimensions are nominal Device LTC8825XT5/R6 Package Pins Type SOT23 5 SPQ 3 000 Reel Reel Diameter Width W1 (mm) (mm) 178 9.0 A0 (mm) B0 (mm) K0 (mm) P1 (mm) W (mm) Pin 1 Quadrant 3.3 3.2 1.5 4.0 8.0 Q3 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-35T.1 — Data Sheet Micropower 500kHz, Precision, 1.8V, RRIO CMOS Amplifiers LTC8825, LTC8826, LTC8828 P-13 Package Outlines DIMENSIONS, SOT23-5L A2 A A1 D e1 Symbol A A1 A2 b c D E1 E e e1 L L1 θ θ L E E1 L1 e b Dimensions In Millimeters Min Max 1.25 0.04 0.10 1.00 1.20 0.33 0.41 0.15 0.19 2.820 3.02 1.50 1.70 2.60 3.00 0.95 BSC 1.90 BSC 0.60 REF 0.30 0.60 0° 8° Dimensions In Inches Min Max 0.049 0.002 0.004 0.039 0.047 0.013 0.016 0.006 0.007 0.111 0.119 0.059 0.067 0.102 0.118 0.037 BSC 0.075 BSC 0.024 REF 0.012 0.024 0° 8° c RECOMMENDED SOLDERING FOOTPRINT, SOT23-5L 1.0 0.039 0.95 0.037 0.95 0.037 0.7 0.028 2.4 0.094 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. mm ( inches ) FN1617-35T.1 — Data Sheet Micropower 500kHz, Precision, 1.8V, RRIO CMOS Amplifiers LTC8825, LTC8826, LTC8828 P-14 Package Outlines (continued) DIMENSIONS, SC70-5L (SOT353) A2 A Symbol A1 D e1 A A1 A2 b C D E E1 e e1 L L1 θ θ e L E1 E L1 b Dimensions In Millimeters Min Max 0.90 1.10 0.00 0.10 0.90 1.00 0.15 0.35 0.08 0.15 2.00 2.20 1.15 1.35 2.15 2.45 0.65 typ. 1.20 1.40 0.525 ref. 0.26 0.46 0° 8° C RECOMMENDED SOLDERING FOOTPRINT, SC70-5L (SOT353) 0.50 0.0197 0.65 0.0256 0.65 0.0256 0.40 0.0157 1.9 0.0748 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. mm ( inches ) Dimensions In Inches Min Max 0.035 0.043 0.000 0.004 0.035 0.039 0.006 0.014 0.003 0.006 0.079 0.087 0.045 0.053 0.085 0.096 0.026 typ. 0.047 0.055 0.021 ref. 0.010 0.018 0° 8° FN1617-35T.1 — Data Sheet Micropower 500kHz, Precision, 1.8V, RRIO CMOS Amplifiers LTC8825, LTC8826, LTC8828 P-15 Package Outlines (continued) DIMENSIONS, DFN2x2-8L E A c A1 1 Nd D1 2 D b1 Exposed Thermal Pad Zone L h E1 h 2 e Symbol Min. 0.70 A A1 b b1 c D D1 Nd E E1 e L h 0.20 0.18 1.90 1.10 1.90 0.60 0.30 0.15 Millimeters Nom. 0.75 0.02 0.25 0.18 REF 0.20 2.00 1.20 1.50BSC 2.00 0.70 0.50BSC 0.35 0.20 1 b BOTTOM VIEW RECOMMENDED SOLDERING FOOTPRINT, DFN2x2-8L 1.60 0.0630 PACKAGE OUTLINE 8X 0.50 0.0197 1.00 0.0394 2.30 0.0906 1 0.50 PITCH 0.0197 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. 0.30 8X 0.0118 mm ( inches ) Max. 0.80 0.05 0.30 0.25 2.10 1.30 2.10 0.80 0.40 0.25 FN1617-35T.1 — Data Sheet Micropower 500kHz, Precision, 1.8V, RRIO CMOS Amplifiers LTC8825, LTC8826, LTC8828 P-16 Package Outlines (continued) DIMENSIONS, MSOP-8L A2 A A1 D b Symbol e A A1 A2 b C D E E1 e L θ L E1 E Dimensions In Millimeters Min Max 0.800 1.100 Dimensions In Inches Min Max 0.031 0.043 0.050 0.150 0.750 0.950 0.290 0.380 0.150 0.200 2.900 3.100 2.900 3.100 4.700 5.100 0.650 TYP. 0.400 0.700 0° 8° 0.002 0.006 0.030 0.037 0.011 0.015 0.006 0.008 0.114 0.122 0.114 0.122 0.185 0.201 0.026 TYP. 0.016 0.028 0° 8° θ C RECOMMENDED SOLDERING FOOTPRINT, MSOP-8L 8X (0.45) MAX (0.018) (1.45) MAX (0.057) 8X 4.40 (5.85) MAX 0.173 (0.230) (2.95) MIN (0.116) 0.65 PITCH 0.026 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. mm ( inches ) FN1617-35T.1 — Data Sheet Micropower 500kHz, Precision, 1.8V, RRIO CMOS Amplifiers LTC8825, LTC8826, LTC8828 P-17 Package Outlines (continued) DIMENSIONS, SOIC-8L A2 A A1 D b Symbol e A A1 A2 b C D E E1 e L θ L E E1 θ Dimensions In Millimeters Min Max 1.370 1.670 0.070 0.170 1.300 1.500 0.306 0.506 0.203 TYP. 4.700 5.100 3.820 4.020 5.800 6.200 1.270 TYP. 0.450 0.750 0° 8° Dimensions In Inches Min Max 0.054 0.066 0.003 0.007 0.051 0.059 0.012 0.020 0.008 TYP. 0.185 0.201 0.150 0.158 0.228 0.244 0.050 TYP. 0.018 0.030 0° 8° C RECOMMENDED SOLDERING FOOTPRINT, SOIC-8L 8X 5.40 0.213 (1.55) MAX (0.061) (3.90) MIN (0.154) 1 (0.60) MAX 8X (0.024) PITCH 1.270 0.050 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. mm ( inches ) FN1617-35T.1 — Data Sheet Micropower 500kHz, Precision, 1.8V, RRIO CMOS Amplifiers LTC8825, LTC8826, LTC8828 P-18 Package Outlines (continued) DIMENSIONS, TSSOP-14L A3 A2 A Symbol A1 D b e C L1 L E E1 A A1 A2 A3 b C D E E1 e L1 L θ Dimensions In Millimeters Min Max 1.200 0.050 0.150 0.900 1.050 0.390 0.490 0.200 0.290 0.130 0.180 4.860 5.060 6.200 6.600 4.300 4.500 0.650 TYP. 1.000 REF. 0.450 0.750 0° 8° Dimensions In Inches Min Max 0.047 0.002 0.006 0.035 0.041 0.015 0.019 0.008 0.011 0.005 0.007 0.191 0.199 0.244 0.260 0.169 0.177 0.026 TYP. 0.039 REF. 0.018 0.030 0° 8° θ RECOMMENDED SOLDERING FOOTPRINT, TSSOP-14L 14X (1.45) MAX (0.057) (4.40) MIN (0.173) PITCH 0.65 0.026 1 5.90 0.232 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. 14X (0.45) MAX (0.018) mm ( inches ) FN1617-35T.1 — Data Sheet Micropower 500kHz, Precision, 1.8V, RRIO CMOS Amplifiers LTC8825, LTC8826, LTC8828 P-19 Package Outlines (continued) DIMENSIONS, SOIC-14L A3 A2 A A1 D b C e L1 L E Symbol E1 A A1 A2 A3 b C D E E1 e L1 L θ Dimensions In Millimeters Min Max 1.450 1.850 0.100 0.300 1.350 1.550 0.550 0.750 0.406 TYP. 0.203 TYP. 8.630 8.830 5.840 6.240 3.850 4.050 1.270 TYP. 1.040 REF. 0.350 0.750 2° 8° Dimensions In Inches Min Max 0.057 0.073 0.004 0.012 0.053 0.061 0.022 0.030 0.016 TYP. 0.008 TYP. 0.340 0.348 0.230 0.246 0.152 0.159 0.050 TYP. 0.041 REF. 0.014 0.030 2° 8° θ RECOMMENDED SOLDERING FOOTPRINT, SOIC-14L 14X 5.40 0.213 (1.50) MAX (0.059) (3.90) MIN (0.154) 1 (0.60) MAX 14X (0.024) PITCH 1.270 0.050 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. mm ( inches ) FN1617-35T.1 — Data Sheet Micropower 500kHz, Precision, 1.8V, RRIO CMOS Amplifiers P-20 LTC8825, LTC8826, LTC8828 IMPORTANT NOTICE Linearin is a global fabless semiconductor company specializing in advanced high-performance highquality analog/mixed-signal IC products and sensor solutions. The company is devoted to the innovation of high performance, analog-intensive sensor front-end products and modular sensor solutions, applied in multi-market of medical & wearable devices, smart home, sensing of IoT, and intelligent industrial & smart factory (industrie 4.0). Linearin’s product families include widely-used standard catalog products, solution-based application specific standard products (ASSPs) and sensor modules that help customers achieve faster time-to-market products. Go to http://www.linearin.com for a complete list of Linearin product families. For additional product information, or full datasheet, please contact with the Linearin’s Sales Department or Representatives. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1617-35T.1 — Data Sheet Micropower 500kHz, Precision, 1.8V, RRIO CMOS Amplifiers
LTC8825XT5/R6 价格&库存
很抱歉,暂时无法提供与“LTC8825XT5/R6”相匹配的价格&库存,您可以联系我们找货
