LTC358HXV8/R6
LTC358HXV8/R6
    LINEARIN(先积)
    MSOP-8
    双1MHz通用RRIO CMOS放大器
LTC358HXV8/R6 数据手册
LTC358H P-1 General Description The LTC358H is a general purpose, low positive offset (+1.0 to +2.5 mV), high frequency response and micro-power dual operational amplifier. With an excellent bandwidth of 1MHz, a slew rate of 1V/μs, and a quiescent current of 95μA per amplifier at 5V, the LTC358H can be designed into a wide range of applications. The LTC358H op-amp is designed to provide optimal performance in low voltage and low power systems. The input common-mode voltage range includes true ground, and with low positive input offset voltage of +1.0 to +2.5mV. This part provides rail-to-rail output swing into heavy loads. The LTC358H op-amp is specified for single or dual power supplies of 1.8V to 5.5V. All models are specified over the extended industrial temperature range of −40℃ to +125℃. The LTC358H is available in both 8-lead SOIC and MSOP packages. Features and Benefits     General Purpose 1 MHz Amplifiers, Low Cost High Slew Rate: 1 V/μs Low Positive Offset Voltage: +1.0 to 2.5 mV Low Power: 95 μA per Amplifier Supply Current Settling Time to 0.1% with 2V Step: 1.2 μs Unit Gain Stable Rail-to-Rail Input and Output – Input Voltage Range: -0.1 to +5.1 V at 5V Supply Operating Power Supply: +1.8 V to +5.5 V Operating Temperature Range: −40 ℃ to +125 ℃ ESD Rating: HBM – 5 kV, CDM – 2 kV Upgrade to LMV358 Op-amp         Smoke/Gas/Environment Sensors Audio Outputs Battery and Power Supply Control Portable Equipments and Mobile Devices Active Filters Sensor Interfaces Battery-Powered Instrumentation Medical instrumentation        Applications Pin Configurations (Top View) LTC358H SOIC-8L / MSOP8L OUT A 1 ﹣IN A 2 ﹢IN A 3 ﹣VS 4 A B 8 ﹢VS 7 OUT B 6 ﹣IN B 5 ﹢IN B CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1615-34.2b — Data Sheet 1MHz General Purpose, RRIO CMOS Amplifiers LTC358H P-2 Pin Description Symbol Description –IN Inverting input of the amplifier. The voltage range can go from (VS– – 0.1V) to (VS+ + 0.1V). +IN Non-inverting input of the amplifier. This pin has the same voltage range as –IN. +VS Positive power supply. The voltage is from 1.8V to 5.5V. Split supplies are possible as long as the voltage between VS+ and VS– is between 1.8V and 5.5V. A bypass capacitor of 0.1μF as close to the part as possible should be used between power supply pins or between supply pins and ground. –VS Negative power supply. It is normally tied to ground. It can also be tied to a voltage other than ground as long as the voltage between VS+ and VS– is from 1.8V to 5.5V. If it is not connected to ground, bypass it with a capacitor of 0.1μF as close to the part as possible. OUT Amplifier output. Ordering Information Type Number Package Name Package Quantity Marking Code (1) LTC358HXS8/R8 SO-8 Tape and Reel, 4 000 358 T, AG2IX LTC358HXV8/R6 MSOP-8 Tape and Reel, 3 000 358T, AG2I (1) There may be multiple device markings, a varied marking character of “x” , or additional marking, which relates to the logo, the lot trace code information, or the environmental category on the device. Limiting Value In accordance with the Absolute Maximum Rating System (IEC 60134). Parameter Absolute Maximum Rating Supply Voltage, VS+ to VS– 10.0 V Signal Input Terminals: Voltage, Current VS– – 0.3 V to VS+ + 0.3 V, ±10 mA Output Short-Circuit Continuous Storage Temperature Range, Tstg –65 ℃ to +150 ℃ Junction Temperature, TJ 150 ℃ Lead Temperature Range (Soldering 10 sec) 260 ℃ ESD Rating Parameter Electrostatic Discharge Voltage Item Value Human body model (HBM), per MIL-STD-883J / Method 3015.9 (1) ±5 000 Charged device model (CDM), per ESDA/JEDEC JS-002-2014 ±2 000 Machine model (MM), per JESD22-A115C (2) Unit V ±250 (1) JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process. Manufacturing with less than 500-V HBM is possible if necessary precautions are taken. (2) JEDEC document JEP157 states that 250-V CDM allows safe manufacturing with a standard ESD control process. Manufacturing with less than 250-V CDM is possible if necessary precautions are taken. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1615-34.2b — Data Sheet 1MHz General Purpose, RRIO CMOS Amplifiers LTC358H P-3 Electrical Characteristics VS = 5.0V, TA = +25℃, VCM = VS /2, VO = VS /2, and RL = 10kΩ connected to VS /2, unless otherwise noted. Boldface limits apply over the specified temperature range, TA = −40 to +125 ℃. Symbol Parameter Conditions Min. Typ. Max. Unit +1.6 +2.5 mV INPUT CHARACTERISTICS VOS Input offset voltage +1.0 VOS TC Offset voltage drift over Temperature IB Input bias current TA = +85 ℃ 150 TA = +125 ℃ 500 μV/℃ 2 1 IOS Input offset current VCM Common-mode voltage range CMRR Common-mode rejection ratio AVOL Open-loop voltage gain RIN Input resistance CIN Input capacitance pA 5 VS––0.1 VS = 5.5 V, VCM = −0.1 to 5.6 V 80 VCM = 0 to 5.3 V, TA = −40 to +125 ℃ 70 VS = 2.0 V, VCM = −0.1 to 2.1 V 74 VCM = 0 to 1.8 V, TA = −40 to +125 ℃ 65 RL = 10 kΩ, VO = 0.05 to 3.5 V 90 TA = −40 to +125 ℃ 85 pA VS++0.1 V 96 dB 88 105 dB 100 GΩ Differential 2.0 Common mode 3.5 pF OUTPUT CHARACTERISTICS VOH VOL ZOUT ISC High output voltage swing Low output voltage swing Closed-loop output impedance Open-loop output impedance Short-circuit current RL = 10 kΩ RL = 10 kΩ VS+–19 VS+–11 VS–+8 f = 200kHz, G = +1 0.4 f = 1MHz, IO = 0 2.6 Source current through 10Ω 45 Sink current through 10Ω 55 mV VS–+14 mV Ω mA DYNAMIC PERFORMANCE ΦM Gain bandwidth product Phase margin SR Slew rate tS Settling time GBW tOR THD+N Overload recovery time Total harmonic distortion + noise f = 1kHz 1 MHz CL = 100pF G = +1, CL = 100pF, VO = 1.5V to 3.5V To 0.1%, G = +1, 2V step 66 ° 1.0 V/μs To 0.01%, G = +1, 2V step 1.5 VIN * Gain > VS 2 μs 0.002 % f = 1kHz, G = +1, VO = 3VPP 1.2 μs NOISE PERFORMANCE Vn Input voltage noise f = 0.1 to 10 Hz 6 μVP-P en Input voltage noise density f = 1kHz 30 nV/√Hz CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1615-34.2b — Data Sheet 1MHz General Purpose, RRIO CMOS Amplifiers LTC358H P-4 Electrical Characteristics (continued) VS = 5.0V, TA = +25℃, VCM = VS /2, VO = VS /2, and RL = 10kΩ connected to VS /2, unless otherwise noted. Boldface limits apply over the specified temperature range, TA = −40 to +125 ℃. Symbol In Parameter Input current noise density Conditions Min. f = 10kHz Typ. Max. Unit fA/√Hz 10 POWER SUPPLY VS Operating supply voltage PSRR Power supply rejection ratio IQ Quiescent current (per amplifier) 1.8 VS = 2.0 to 5.5 V, VCM < VS+ − 2V 80 TA = −40 to +125 ℃ 75 5.5 106 95 TA = −40 to +125 ℃ V dB 135 170 μA THERMAL CHARACTERISTICS TA Operating temperature range θJA Package Thermal Resistance -40 +125 SOIC-8L 125 MSOP-8L 216 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. ℃ ℃/W FN1615-34.2b — Data Sheet 1MHz General Purpose, RRIO CMOS Amplifiers LTC358H P-5 Typical Performance Characteristics At TA = +25℃, VCM = VS /2, and RL = 10kΩ connected to VS /2, unless otherwise noted. AOL (dB) 80 60 40 20 0 -20 -40 10 100 1k 10k 100k 1M 140 120 100 CMRR (dB) 100 140 120 100 80 60 40 20 0 -20 -40 -60 -80 10M Phase (deg) 120 80 60 40 20 0 1 100 Frequency (Hz) Common-mode Rejection Ratio as a function of Frequency. 1,000 120 Voltage Noise (nV/√Hz) 100 PSRR (dB) 1M Frequency (Hz) Open-loop Gain and Phase as a function of Frequency. 100 80 60 40 20 0 10 1 1 100 10k 1M 1 100 Frequency (Hz) 10k 1M Frequency (Hz) Power Supply Rejection Ratio as a function of Frequency. Input Voltage Noise Spectral Density as a function of Frequency. 150 Quiescent Current (μA) 150 Quiescent Current (μA) 10k 120 90 60 30 120 90 60 30 0 0 1.5 2 2.5 3 3.5 4 4.5 5 5.5 -50 0 25 50 75 100 125 Temperature (℃) Supply Voltage (V) Quiescent Current as a function of Supply Voltage. -25 Quiescent Current as a function of Temperature. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1615-34.2b — Data Sheet 1MHz General Purpose, RRIO CMOS Amplifiers LTC358H P-6 Typical Performance Characteristics (continued) At TA = +25℃, VCM = VS /2, and RL = 10kΩ connected to VS /2, unless otherwise noted. CL=100pF 1V/div 25mV/div CL=100pF 2μs/div 5μs/div Large Signal Step Response. Small Signal Step Response. 60 Short-circuit Current (mA) Short-circuit Current (mA) 80 60 –ISC 40 20 +ISC 0 –ISC 50 40 +ISC 30 20 2 2.5 3 3.5 4 4.5 5 5.5 -50 -25 25 50 75 100 125 Temperature (℃) Supply Voltage (V) Short-circuit Current as a function of Supply Voltage. Short-circuit Current as a function of Temperature. 5 140 Sourcing Current –40℃ 3 125℃ 25℃ 2 1 Sinking Current 0 0 10 20 30 40 50 60 70 120 Channel Separation(dB) 4 Output Voltage (V) 0 100 80 60 40 20 0 10 Output Current (mA) Output Voltage Swing as a function of Output Current. 100 1k 10k 100k 1M 10M Frequency (Hz) Channel Separation as a function of Frequency. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1615-34.2b — Data Sheet 1MHz General Purpose, RRIO CMOS Amplifiers LTC358H P-7 Application Notes LOW INPUT BIAS CURRENT The LTC358H device is a CMOS op-amp and features very low input bias current in pA range. The low input bias current allows the amplifiers to be used in applications with high resistance sources. Care must be taken to minimize PCB Surface Leakage. See below section on “PCB Surface Leakage” for more details. resistive loads (e.g. 100kΩ), the output voltage can typically swing to within 5mV from the supply rails. Different load conditions change the ability of the amplifier to swing close to the rails. For resistive loads up to 10-kΩ, the output swings typically to within 11-mV of the positive supply rail and within 8-mV of the negative supply rail. 6.0 PCB SURFACE LEAKAGE Guard Ring +IN –IN +VS Figure 1. Use a guard ring around sensitive pins 5.0 AMPLITUDE (V) In applications where low input bias current is critical, Printed Circuit Board (PCB) surface leakage effects need to be considered. Surface leakage is caused by humidity, dust or other contamination on the board. Under low humidity conditions, a typical resistance between nearby traces is 1012Ω. A 5V difference would cause 5pA of current to flow, which is greater than the LTC358H’s input bias current at +25℃ (±1fA, typical). It is recommended to use multi-layer PCB layout and route the op-amp’s –IN and +IN signal under the PCB surface. The effective way to reduce surface leakage is to use a guard ring around sensitive pins (or traces). The guard ring is biased at the same voltage as the sensitive pin. An example of this type of layout is shown in Figure 1 for Inverting Gain application. 1. For Non-Inverting Gain and Unity-Gain Buffer: a) Connect the non-inverting pin (+IN) to the input with a wire that does not touch the PCB surface. b) Connect the guard ring to the inverting input pin (–IN). This biases the guard ring to the Common Mode input voltage. 2. For Inverting Gain and Trans-impedance Gain Amplifiers (convert current to voltage, such as photo detectors): a) Connect the guard ring to the non-inverting input pin (+IN). This biases the guard ring to the same reference voltage as the op-amp (e.g., VS/2 or ground). b) Connect the inverting pin (–IN) to the input with a wire that does not touch the PCB surface. 4.0 3.0 2.0 1.0 0.0 -1.0 0 10 20 30 40 50 60 TIME (ms) Figure 2. No Phase Inversion with Inputs Greater Than the Power-Supply Voltage The maximum output current is a function of total supply voltage. As the supply voltage to the amplifier increases, the output current capability also increases. Attention must be paid to keep the junction temperature of the IC below 150℃ when the output is in continuous short-circuit. The output of the amplifier has reverse-biased ESD diodes connected to each supply. The output should not be forced more than 0.5V beyond either supply, otherwise current will flow through these diodes. CAPACITIVE LOAD AND STABILITY The LTC358H op-amp can directly drive 500pF in unity-gain without oscillation. The unity-gain follower (buffer) is the most sensitive configuration to capacitive loading. Direct capacitive loading reduces the phase margin of amplifiers and this results in ringing or even oscillation. Applications that require greater capacitive drive capability should use an isolation resistor between the output and the capacitive load like the circuit in Figure 3. The isolation resistor RISO and the load capacitor CL form a zero to increase stability. The bigger the RISO resistor value, the more stable VOUT will be. Note that this method results in a loss of gain accuracy because RISO forms a voltage divider with the RL. GROUND SENSING AND RAIL TO RAIL The input common-mode voltage range of the LTC358H opamp extends 100mV beyond the supply rails. This is achieved with a complementary input stage—an N-channel input differential pair in parallel with a P-channel differential pair. For normal operation, inputs should be limited to this range. The absolute maximum input voltage is 500mV beyond the supplies. Inputs greater than the input common-mode range but less than the maximum input voltage, while not valid, will not cause any damage to the op-amp. Unlike some other op-amps, if input current is limited, the inputs may go beyond the supplies without phase inversion, as shown in Figure 2. Since the input common-mode range extends from (VS− − 0.1V) to (VS+ + 0.1V), the LTC358H op-amp can easily perform ‘true ground’ sensing. A topology of class AB output stage with common-source transistors is used to achieve rail-to-rail output. For light RISO VOUT VIN CL Figure 3. Indirectly Driving Heavy Capacitive Load An improvement circuit is shown in Figure 4. It provides DC accuracy as well as AC stability. The RF provides the DC accuracy by connecting the inverting signal with the output. The CF and RISO serve to counteract the loss of phase margin by feeding the high frequency component of the output signal back to the amplifier’s inverting input, thereby preserving phase margin in the overall feedback loop. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1615-34.2b — Data Sheet 1MHz General Purpose, RRIO CMOS Amplifiers LTC358H P-8 Application Notes (continued) CF RF RISO VOUT VIN CL RL Figure 4. Indirectly Driving Heavy Capacitive Load with DC Accuracy For no-buffer configuration, there are two others ways to increase the phase margin: (a) by increasing the amplifier’s gain, or (b) by placing a capacitor in parallel with the feedback resistor to counteract the parasitic capacitance associated with inverting node. POWER SUPPLY LAYOUT AND BYPASS The LTC358H op-amp operates from either a single +1.8V to +5.5V supply or dual ±0.9V to ±2.75V supplies. For singlesupply operation, bypass the power supply VS with a ceramic capacitor (i.e. 0.01μF to 0.1μF) which should be placed close (within 2mm for good high frequency performance) to the VS pin. For dual-supply operation, both the VS+ and the VS– supplies should be bypassed to ground with separate 0.1μF ceramic capacitors. A bulk capacitor (i.e. 2.2μF or larger tantalum capacitor) within 100mm to provide large, slow currents and better performance. This bulk capacitor can be shared with other analog parts. Good PC board layout techniques optimize performance by decreasing the amount of stray capacitance at the op-amp’s inputs and output. To decrease stray capacitance, minimize trace lengths and widths by placing external components as close to the device as possible. Use surface-mount components whenever possible. For the op-amp, soldering the part to the board directly is strongly recommended. Try to keep the high frequency big current loop area small to minimize the EMI (electromagnetic interfacing). GROUNDING A ground plane layer is important for the LTC358H circuit design. The length of the current path speed currents in an inductive ground return will create an unwanted voltage noise. Broad ground plane areas will reduce the parasitic inductance. INPUT-TO-OUTPUT COUPLING To minimize capacitive coupling, the input and output signal traces should not be parallel. This helps reduce unwanted positive feedback. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1615-34.2b — Data Sheet 1MHz General Purpose, RRIO CMOS Amplifiers LTC358H P-9 Typical Application Circuits The LTC358H op-amp has input bias current in the pA range. This is ideal in buffering high impedance chemical sensors, such as pH probes. As an example, the circuit in Figure 7 eliminates expansive low-leakage cables that that is required to connect a pH probe (general purpose combination pH probes, e.g Corning 476540) to metering ICs such as ADC, AFE and/or MCU. A LTC358H op-amp and a lithium battery are housed in the probe assembly. A conventional low-cost coaxial cable can be used to carry the op-amp’s output signal to subsequent ICs for pH reading. DIFFERENTIAL AMPLIFIER R2 R1 Vn VOUT Vp R3 R4 VREF SHUNT-BASED CURRENT SENSING AMPLIFIER Figure 5. Differential Amplifier The circuit shown in Figure 5 performs the difference function. If the resistors ratios are equal R4/R3 = R2/R1, then: VOUT = (Vp – Vn) × R2/R1 + VREF INSTRUMENTATION AMPLIFIER RG VREF R1 R2 R2 R1 VOUT V1 V2 VOUT =(V1  V2 )(1  R1 2 R1  )  VREF R2 RG Figure 6. Instrumentation Amplifier The LTC358H op-amp is well suited for conditioning sensor signals in battery-powered applications. Figure 6 shows a two op-amp instrumentation amplifier, using the LTC358H op-amp. The circuit works well for applications requiring rejection of common-mode noise at higher gains. The reference voltage (VREF) is supplied by a low-impedance source. In single voltage supply applications, the VREF is typically VS/2. The current sensing amplification shown in Figure 8 has a slew rate of 2πfVPP for the output of sine wave signal, and has a slew rate of 2fVPP for the output of triangular wave signal. In most of motor control systems, the PWM frequency is at 10kHz to 20kHz, and one cycle time is 100μs for a 10kHz of PWM frequency. In current shunt monitoring for a motor phase, the phase current is converted to a phase voltage signal for ADC sampling. This sampling voltage signal must be settled before entering the ADC. As the Figure 8 shown, the total settling time of a current shunt monitor circuit includes: the rising edge delay time (tSR) due to the op-amp’s slew rate, and the measurement settling time (tSET). For a 3-shunt solution in motor phase current sensing, if the smaller duty cycle of the PWM is defined at 45% (In fact, the phase with minimum PWM duty cycle, such as 5%, is not detected current directly, and it can be calculated from the other two phase currents), and the tSR is required at 20% of a total time window for a phase current monitoring, in case of a 3.3V motor control system (3.3V MCU with 12-bit ADC), the op-amp’s slew rate should be more than: 3.3V / (100μs× 45% × 20%) = 0.37 V/μs At the same time, the op-amp’s bandwidth should be much greater than the PWM frequency, like 10 time at least. tSR VBUS tSET BUFFERED CHEMICAL SENSORS High side switch R1 10MΩ 3V To ADC, AFE or MCU VM Low side switch R2 pH PROBE R1 RSHUNT R2 10MΩ tSR – Time delay due to op-amp slew rate tSET – Measurement settling time tSMP – Sampling time window To Motor Phase Coax tSMP C1 To MCU ADC pin R3 R4 R5 C2 All components contained within the pH probe Filter Figure 7. Buffered pH Probe Offset Amplification Figure 8. Current Shunt Monitor Circuit CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1615-34.2b — Data Sheet 1MHz General Purpose, RRIO CMOS Amplifiers LTC358H P-10 Package Outlines DIMENSIONS, SOIC-8L A2 A A1 D b Symbol e A A1 A2 b C D E E1 e L θ L E E1 θ Dimensions In Millimeters Min Max 1.370 1.670 0.070 0.170 1.300 1.500 0.306 0.506 0.203 TYP. 4.700 5.100 3.820 4.020 5.800 6.200 1.270 TYP. 0.450 0.750 0° 8° Dimensions In Inches Min Max 0.054 0.066 0.003 0.007 0.051 0.059 0.012 0.020 0.008 TYP. 0.185 0.201 0.150 0.158 0.228 0.244 0.050 TYP. 0.018 0.030 0° 8° C RECOMMENDED SOLDERING FOOTPRINT, SOIC-8L 8X 5.40 0.213 (1.55) MAX (0.061) (3.90) MIN (0.154) 1 (0.60) MAX 8X (0.024) PITCH 1.270 0.050 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. mm ( inches ) FN1615-34.2b — Data Sheet 1MHz General Purpose, RRIO CMOS Amplifiers LTC358H P-11 Package Outlines (continued) DIMENSIONS, MSOP-8L A2 A A1 D b Symbol e A A1 A2 b C D E E1 e L θ L E1 E Dimensions In Millimeters Min Max 0.800 1.100 Dimensions In Inches Min Max 0.031 0.043 0.050 0.150 0.750 0.950 0.290 0.380 0.150 0.200 2.900 3.100 2.900 3.100 4.700 5.100 0.650 TYP. 0.400 0.700 0° 8° 0.002 0.006 0.030 0.037 0.011 0.015 0.006 0.008 0.114 0.122 0.114 0.122 0.185 0.201 0.026 TYP. 0.016 0.028 0° 8° θ C RECOMMENDED SOLDERING FOOTPRINT, MSOP-8L 8X (0.45) MAX (0.018) (1.45) MAX (0.057) 8X 4.40 (5.85) MAX 0.173 (0.230) (2.95) MIN (0.116) 0.65 PITCH 0.026 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. mm ( inches ) FN1615-34.2b — Data Sheet 1MHz General Purpose, RRIO CMOS Amplifiers P-12 LTC358H IMPORTANT NOTICE Linearin is a global fabless semiconductor company specializing in advanced high-performance highquality analog/mixed-signal IC products and sensor solutions. The company is devoted to the innovation of high performance, analog-intensive sensor front-end products and modular sensor solutions, applied in multi-market of medical & wearable devices, smart home, sensing of IoT, and intelligent industrial & smart factory (industrie 4.0). Linearin’s product families include widely-used standard catalog products, solution-based application specific standard products (ASSPs) and sensor modules that help customers achieve faster time-to-market products. Go to http://www.linearin.com for a complete list of Linearin product families. For additional product information, or full datasheet, please contact with the Linearin’s Sales Department or Representatives. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1615-34.2b — Data Sheet 1MHz General Purpose, RRIO CMOS Amplifiers
LTC358HXV8/R6 价格&库存
很抱歉,暂时无法提供与“LTC358HXV8/R6”相匹配的价格&库存,您可以联系我们找货
