LTP3558-33XT3
LTP3558-33XT3
    LINEARIN(先积)
    SOT23-3
    3.3V 200MA 36V
LTP3558-33XT3 数据手册
LTP3558 P-1 General Description The LTP3558 is a high voltage, low power consumption and high performance LDO. The family uses an advanced CMOS process and a P-MOSFET pass device to achieve fast start-up, with high output voltage accuracy. The LTP3558 is stable with a 1.0μF~10μF ceramic output capacitor, and uses a precision voltage reference and feedback loop to achieve a worst-case accuracy of 2% over all load, line, process, and temperature variations. Features           Wide Input Voltage Range: up to 36V Output Current: 200mA Standard Fixed Output Voltage Options: 1.8V, 2.5V, 3.0V, 3.3V, 3.6V, and 5.0V Other Output Voltage Options Available on Request Low IQ: 1.5µA Low Dropout Voltage Short current protection: 100mA Excellent Load and Line Transient Response Line Regulation: 0.01%/V Typically Available Packages: Order Information Model LTP3558 Package Ordering Number Note1 Packing Option SOT23-3L LTP3558-xxXT3 Tape and Reel, 3000 SOT23-5L LTP3558-xxXT5 Tape and Reel, 3000 DFN1x1-4L LTP3558-xxXF4 Tape and Reel, 10000 SOT89-3 LTP3558-xxXT4 Tape and Reel, 1000 Notel: xx stands for output voltage, e.g. if xx = 18, the output voltage is 1.8V; if xx = 30, the output voltage is 3.0V. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1620-2L.1a — Data Sheet 36V Input Voltage, 200-mA, Ultra-low IQ LDOs LTP3558 P-2 Pin Configuration 3 IN 1 GND 2 IN GND 3 OUT OUT 1 SOT23-3L SOT89-3 IN 1 GND 2 NC 3 2 5 OUT 4 NC SOT23-5L OUT NC 4 3 1 2 IN GND DFN1×1-4L TOP VIEW Pin Function Pin No. Pin Name Pin Function 1 GND Ground. 2 3 IN Supply input pin. Must be closely decoupled to GND with a 1μF or greater ceramic capacitor. 3 2 OUT Output pin. Bypass a 1μF or greater ceramic capacitor from this pin to ground. SOT-89 SOT23-3L 1 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1620-2L.1a — Data Sheet 36V Input Voltage, 200-mA, Ultra-low IQ LDOs LTP3558 P-3 Pin No. Pin Name Pin Function 1 IN Supply input pin. Must be closely decoupled to GND with a 1μF or greater ceramic capacitor. 2 2 GND Ground. 3 3 NC No connection. NC No connection. OUT Output pin. Bypass a 1μF or greater ceramic capacitor from this pin to ground. SOT23-5L DFN1x1-4L 1 4 5 4 Block Diagram OUT IN Short Current protection + Voltage Reference GND Functional Description Input Capacitor A 1μF-10μF ceramic capacitor is recommended to connect between Vin and GND pins to decouple input power supply glitch and noise. The amount of the capacitance may be increased without limit. This input capacitor must be located as close as possible to the device to assure input stability and less noise. For PCB layout, a wide copper trace is required for both Vin and GND. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1620-2L.1a — Data Sheet 36V Input Voltage, 200-mA, Ultra-low IQ LDOs P-4 LTP3558 Output Capacitor An output capacitor is required for the stability of the LDO. The recommended output capacitance is from 1μF to 10μF, Equivalent Series Resistance (ESR) is from 5mΩ to 100mΩ, and temperature characteristics are X7R or X5R. Higher capacitance values help to improve load/line transient response. The output capacitance may be increased to keep low undershoot/overshoot. Place output capacitor as close as possible to OUT and GND pins. Low Quiescent Current The LTP3558, consuming only around 1.5μA for all input range and output loading, provides great power saving in portable and low power applications. Short Current Limit Protection When output current at the OUT pin is higher than current limit threshold or the OUT pin is short-circuit to GND, the short current limit protection will be triggered and clamp the output current to approximately 100mA to prevent over-current and to protect the regulator from damage due to overheating. Absolute Maximum Ratings Parameter Rating IN pin to GND pin -0.3 to 40 V OUT pin to GND pin -0.3 to 6 V Thermal Resistance (Junction to Ambient) Unit SOT23-3L 360 SOT23-5L 250 DFN1X1-4L 180 SOT-89 135 ° C/W Operating Junction Temperature -40 to 125 ° C Storage Temperature -65 to 150 ° C Lead Temperature (Soldering, 10 sec) 300 ° C ESD (HBM mode) ESDA/JEDEC JS-001-2017 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. ±2000V FN1620-2L.1a — Data Sheet 36V Input Voltage, 200-mA, Ultra-low IQ LDOs LTP3558 P-5 Electrical Characteristics (VIN= VOUT+2V, Ta= 25°C, CIN=10uF, COUT=10uF unless otherwise noted) PARAMETER SYMBOL Input Voltage Operation Range VIN Dropout Voltage VDROP DC Supply Quiescent Current IQ Regulated Output Voltage VOUT Output Voltage Line Regulation RegLINE TEST CONDITIONS MIN TYP VOUT= 5V, IOUT = 150mA 720 VOUT= 5V, IOUT = 100mA 420 VOUT= 3.3 V, IOUT = 150mA 820 VOUT= 3.3 V, IOUT = 100mA 520 1.5 IOUT=1mA VOUT X 0.98 MAX UNIT 36 V mV 3 µA VQUTX1.02 V VIN = VOUT +1V to 30V, IOUT = 10mA (△VOUT/△VIN/VOUT) 0.01 0.04 %/V IOUT from 1mA to 150mA VIN=VOUT+2V 5 20 mV IOUT from 1mA to 150mA VIN=10V 25 60 mV Output Voltage Load Regulation RegLOAD Maximum Output Current IOUT VIN = VOUT +1V Short Current Protection ISHORT OUT short to GND 100 mA Output Noise eN 10Hz to 100kHz, IOUT = 30mA, 90 µVRMS CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. 200 mA FN1620-2L.1a — Data Sheet 36V Input Voltage, 200-mA, Ultra-low IQ LDOs P-6 LTP3558 TYPICAL PERFORMANCE CHARACTERISTICS Fig1. Line-Transient Response Fig2.Load-Transient Response Fig3.StartupResponse CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1620-2L.1a — Data Sheet 36V Input Voltage, 200-mA, Ultra-low IQ LDOs LTP3558 P-7 VDROP VS. IOUT IQ VS. Temperature 10 3 1 2 IQ (μA) Dropout Voltage(V) 2.5 0.1 1.5 1 0.5 0 0.01 0 40 80 120 160 200 -40 -20 20 40 60 80 100 120 Temperature(℃) Output Current (mA) Fig4. Dropout Voltage VS Output Current 0 Fig5. DC Supply Quiescent Current VS Temperature CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1620-2L.1a — Data Sheet 36V Input Voltage, 200-mA, Ultra-low IQ LDOs LTP3558 P-8 Application Circuits VIN IN OUT 1µF to 10µF CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. VOUT 1µF to 10µF FN1620-2L.1a — Data Sheet 36V Input Voltage, 200-mA, Ultra-low IQ LDOs LTP3558 P-9 Package Dimension DFN1x1-4L 0.65BSC 0.95~1.05 0.45~0.55 0.95~1.05 0.125REF 0.15~0.35 0.00~0.05 Unit:mm PIN1 SOT23-3L 2.82~3.02 0.3~0.6 0.7 1.5~1.7 2.6~3.0 0.3~0.4 0.95 0.1~0.2 1.05~1.25 0.1max 1.8~2.0 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. Unit:mm FN1620-2L.1a — Data Sheet 36V Input Voltage, 200-mA, Ultra-low IQ LDOs LTP3558 P-10 SOT23-5L 2.82~3.02 0.3~0.6 0.7 1.6~1.7 2.6~3.0 0.35~0.5 0.95 0.08~0.2 1.05~1.25 0.1max 1.8~2.0 Unit:mm SOT-89 4.4~4.6 1.4~1.6 0.9~1.2 2.3~2.6 3.94~4.25 1.55 1.50 0.32~0.52 3.00 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. 0.35~0.44 Unit:mm FN1620-2L.1a — Data Sheet 36V Input Voltage, 200-mA, Ultra-low IQ LDOs
LTP3558-33XT3 价格&库存
很抱歉,暂时无法提供与“LTP3558-33XT3”相匹配的价格&库存,您可以联系我们找货
