LTC8871, LTC8872, LTC8874
P-1
General Description
The LTC887x family of single-, dual-, and quad- channel amplifiers features a
maximized ratio of gain bandwidth (GBW) to supply current and is ideal for a variety of
battery-powered applications that require a good balance between cost and
performance, such as audio outputs, motor phase current sensing, photodiode
amplification and white goods. Featuring rail-to-rail input and output swings, a wide
bandwidth of 20-MHz combined with low supply current (typical 1.12 mA at 5V supply per
amplifier) and low noise, the LTC887x family is an excellent choice for precision, lowcurrent, low-voltage, battery-powered applications. The low input bias current supports
these amplifiers to be used in applications with mega-ohm source impedances.
The robust design of the LTC887x amplifiers provides ease-of-use to the circuit
designer: integrated RF/EMI rejection filter, no phase reversal in overdrive conditions,
and high electro-static discharge (ESD) protection (5-kV HBM). The LTC887x amplifiers
are optimized for operation at voltages as low as +1.8 V (±0.9 V) and up to +5.5 V (±2.75
V) at the temperature range of 0 ℃ to 70 ℃, and operation at voltages from +2.0 V (±1.0
V) to +5.5 V (±2.75 V) over the extended temperature range of −40 ℃ to +125 ℃.
The LTC8871 (single) is available in both SOT23-5L and SOIC-8L packages. The LTC8872
(dual) is offered in SOIC-8L and MSOP-8L packages. The quad-channel LTC8874 is
offered in both SOIC-14L and TSSOP-14L packages.
Features and Benefits
Wide Unity-Gain Bandwidth: 20 MHz
High Slew Rate: 22 V/μs
Fast Settling: 250 ns to 0.1%
Low Noise: 8 nV/√Hz at 1 kHz
Low Input Offset Voltage: ±0.5 mV
Single 1.8 V to 5.5 V Supply Voltage Range at 0 ℃ to 70 ℃
Rail-to-Rail Input and Output
Internal RF/EMI Filter
Low Supply Current: 1.12 mA at 5 V Supply Per Amplifier
Extended Temperature Range: −40℃ to +125℃
Applications
Battery-Powered Instruments:
– Consumer, Industrial, Medical, Notebooks
Audio Outputs
Motor Phase Current Sense
Photodiode Amplification
Sensor Signal Conditioning:
– Sensor Interfaces, Loop-Powered, Active Filters
Pin Configurations (Top View)
OUT
1
–VS
2
+IN
3
LTC8871
LTC8871
LTC8872
LTC8874
SOT23-5L
SOIC-8L
SOIC-8L / MSOP-8L
SOIC-14L / TSSOP-14L
5
4
+VS
NC
1
8
–IN
2
7
–IN
NC
OUTA
1
8
+VS
OUTA
1
14
OUTD
+VS
–INA
2
7
OUTB
–INA
2
13
–IND
–INB
+INA
3
12
+IND
+INB
+VS
4
11
–VS
+INB
5
10
+INC
–INB
6
9
–INC
OUTB
7
8
OUTC
A
A
+IN
–VS
3
4
6
5
OUT
NC
+INA
–VS
3
B
4
6
5
B
CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures.
Linearin and designs are registered trademarks of Linearin Technology Corporation.
© Copyright Linearin Technology Corporation. All Rights Reserved.
All other trademarks mentioned are the property of their respective owners.
D
C
FN1617-42.0 — Data Sheet
20MHz, Low-Noise, 1.8V, RRIO CMOS Amplifiers
P-2
Pin Description
Symbol
Description
–IN
Inverting input of the amplifier. The voltage range is from (VS– – 0.1V) to (VS+ + 0.1V).
+IN
Non-inverting input of the amplifier. This pin has the same voltage range as –IN.
+VS
Positive power supply. The voltage is from 2.0V to 5.5V. Split supplies are possible
as long as the voltage between VS+ and VS– is from 2.0V to 5.5V.
–VS
Negative power supply. It is normally tied to ground. It can also be tied to a voltage
other than ground as long as the voltage between VS+ and VS– is from 2.0V to 5.5V.
OUT
Amplifier output.
Ordering Information
Type Number
Package Name
Package Quantity
Marking Code
LTC8871XT5/R6
SOT23-5L
Tape and Reel, 3 000
AH5
LTC8871XS8/R8
SOIC-8L
Tape and Reel, 4 000
AH5 X
LTC8872XS8/R8
SOIC-8L
AH6 X
LTC8872XV8/R6
MSOP-8L
AH6X
LTC8874XS14/R5
SOIC-14L
Tape and Reel, 2 500
AH8 X
LTC8874XT14/R6
TSSOP-14L
AH8 X
(1) Eco Class - The planned eco-friendly classification: Pb-Free (RoHS) or Green (RoHS & Halogen Free).
(2) There may be multiple device markings, a varied marking character of “x” , or additional marking, which
relates to the logo, the lot trace code information, or the environmental category on the device.
Limiting Value
In accordance with the Absolute Maximum Rating System (IEC 60134).
Parameter
Supply Voltage, VS+ to VS–
10.0 V
Signal Input Terminals: Voltage, Current
VS– – 0.5 V to VS+ + 0.5 V, ±10 mA
Output Short-Circuit
Continuous
Storage Temperature Range, Tstg
–65 ℃ to +150 ℃
Junction Temperature, TJ
150 ℃
Lead Temperature Range (Soldering 10 sec)
260 ℃
ESD Rating
Parameter
Electrostatic
Discharge Voltage
Item
Value
Human body model (HBM), per MIL-STD-883J / Method 3015.9
±5 000
Charged device model (CDM), per ESDA/JEDEC JS-002-2014
±2 000
Machine model (MM), per JESD22-A115C
±250
Unit
V
(1) JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process.
Manufacturing with less than 500-V HBM is possible if necessary precautions are taken.
(2) JEDEC document JEP157 states that 250-V CDM allows safe manufacturing with a standard ESD control process.
Manufacturing with less than 250-V CDM is possible if necessary precautions are taken.
P-3
Electrical Characteristics
VS = 5.0V, TA = +25℃, VCM = VS /2, VO = VS /2, and RL = 10kΩ connected to VS /2, unless otherwise noted.
Boldface limits apply over the specified temperature range, TA = −40 to +125 ℃.
Symbol
Parameter
Conditions
Min.
Typ.
Max.
±0.5
±2.5
Unit
OFFSET VOLTAGE
VOS
Input offset voltage
VOS TC
Offset voltage drift
TA = −40 to +125 ℃
Power supply
rejection ratio
VS = 2.0 to 5.5 V, VCM < VS+ − 2V
75
TA = −40 to +125 ℃
71
PSRR
TA = −40 to +125 ℃
±2.8
mV
μV/℃
±1
100
dB
INPUT BIAS CURRENT
1
IB
IOS
Input bias current
TA = −40 to +85 ℃
150
TA = −40 to +125 ℃
700
Input offset current
pA
5
pA
f = 0.1 to 10 Hz
3
μVP-P
f = 1 kHz
8
nV/√Hz
f = 1 kHz
5
fA/√Hz
NOISE
Vn
en
In
Input voltage noise
Input voltage noise
density
Input current noise
density
INPUT VOLTAGE
VCM
CMRR
Common-mode
voltage range
Common-mode
rejection ratio
VS––0.1
VS = 5.5 V, VCM = −0.1 to 5.6 V
80
VCM = 0 to 5.3 V, TA = −40 to +125 ℃
75
VS = 2.0 V, VCM = −0.1 to 2.1 V
78
VCM = 0 to 1.8 V, TA = −40 to +125 ℃
72
VS++0.1
V
96
90
dB
INPUT IMPEDANCE
CIN
Input capacitance
Differential
2.0
Common mode
3.5
pF
OPEN-LOOP GAIN
AVOL
Open-loop voltage
gain
RL = 10 kΩ, VO = 0.05 to 3.5 V
90
TA = −40 to +125 ℃
85
RL = 600 Ω, VO = 0.15 to 3.5 V
85
TA = −40 to +125 ℃
80
105
100
dB
FREQUENCY RESPONSE
GBW
Gain bandwidth
product
SR
Slew rate
G = +1, CL = 100 pF, VO = 1.5 to 3.5 V
THD+N
Total harmonic
distortion + noise
G = +1, f = 1 kHz, VO = 0.5 VRMS
tS
Settling time
tOR
Overload recovery
time
MHz
22
V/μs
0.0006
To 0.1%, G = +1, 1V step
0.25
To 0.01%, G = +1, 1V step
0.33
VIN * Gain > VS
0.26
μs
μs
P-4
Electrical Characteristics (continued)
Symbol
Parameter
Conditions
Min.
Typ.
Max.
Unit
OUTPUT
VOH
High output voltage
swing
RL = 10 kΩ
VS+–12
VS+–8
RL = 600 Ω
VS+–180
VS+–125
VOL
Low output voltage
swing
RL = 10 kΩ
VS–+6
VS–+9
RL = 600 Ω
VS–+90
VS–+130
ISC
Short-circuit current
mV
+60/–90
mV
mA
POWER SUPPLY
VS
Operating supply
voltage
TA = 0 to +70 ℃
1.8
5.5
TA = −40 to +125 ℃
2.0
5.5
IQ
Quiescent current
(per amplifier)
VS = 2.0 V
0.8
0.97
VS = 5.0 V
1.12
1.36
V
mA
THERMAL CHARACTERISTICS
TA
θJA
Operating
temperature range
Package Thermal
Resistance
–40
+125
SOT23-5L
190
MSOP-8L
216
SOIC-8L
125
TSSOP-14L
112
SOIC-14L
115
℃/W
P-5
Typical Performance Characteristics
At TA = +25℃, VCM = VS /2, and RL = 10kΩ connected to VS /2, unless otherwise noted.
350
VCM = –VS
Voltage Noise (nV/√Hz)
300
Distribution (Units)
250
100
200
150
100
50
10
1
100
Offset Voltage (mV)
1M
Input Voltage Noise Spectral Density as a function of
Frequency.
Offset Voltage Production Distribution
125
125
100
100
PSRR (dB)
CMRR (dB)
10k
Frequency (Hz)
75
50
25
75
50
25
100
10k
1M
1
100
Frequency (Hz)
10k
1M
Frequency (Hz)
160
1500
90
120
60
80
30
40
-40
10
1k
100k
10M
Quiescent Current (μA)
120
Phase (deg)
Power Supply Rejection Ratio as a function of
Frequency.
AOL (dB)
Common-mode Rejection Ratio as a function of
Frequency.
1250
1000
750
500
250
2.5
3
3.5
4
4.5
5
5.5
Supply Voltage (V)
Frequency (Hz)
Open-loop Gain and Phase as a function of
Frequency.
2
Quiescent Current as a function of Supply Voltage.
P-6
Typical Performance Characteristics (continued)
1250
1,750
VS = 5V
1,500
Quiescent Current (µA)
2,000
1,250
1,000
750
500
250
VS = 5V
1000
750
500
250
-25
50
75
100
125
Temperature (℃)
3
4
5
Quiescent Current as a function of Input Commonmode Voltage.
5
Sourcing Current
–40℃
3
+125℃
2
+25℃
1
Sinking Current
60
80
Short-circuit Current (mA)
100
4
80
Sourcing, +ISC
60
40
Sinking, –ISC
1.5
2
2.5
3
3.5
4
4.5
Output Voltage Swing as a function of Output
Current.
Short-circuit Current as a function of Supply
Voltage.
125
VS = 5V
100
1 V/div
75
50
25
-25
50
75
5
Supply Voltage (V)
Output Current (mA)
6
Common-Mode Voltage (V)
Quiescent Current as a function of Temperature.
Output Voltage (V)
2
100
125
Temperature (℃)
Short-circuit Current as a function of Temperature.
250 ns/div
Large Signal Step Response.
5.5
P-7
CL = 100pF
AV = +1
25 mV/div
100 mV/div
CL = 100pF
AV = +1
100 ns/div
50 ns/div
Small Signal Step Response (500 mV).
P-8
Application Notes
The LTC887x is a family of a new generation of 20MHz bandwidth, low-power, rail-to-rail input and
output operational amplifiers specifically designed
for a variety of battery-powered applications that
current sensing, photodiode amplification and white
goods.
Featuring a maximized ratio of GBW-to-supply
current, low operating supply voltage, low input bias
current, and rail-to-rail inputs and outputs, the
or general-purpose, low-current, low-voltage,
battery-powered
applications.
These
CMOS
operational amplifiers consume an low 1.12-mA
(typically at 5-V supply voltage) supply current per
amplifier. The LTC887x family is unity-gain stable
with a 20-MHz GBW product, driving capacitive loads
up to 100-pF. The capacitive load can be increased to
500-pF when the amplifier is configured for a
greater than 5-V/V gain. DC applications are also
well served with a low input noise voltage of 8nV/√Hz, low input bias current, and an input offset
voltage of 0.5-mV typically. The typical offset voltage
drift is 1-μV/℃, over the full temperature range the
input offset voltage changes only 100-μV (0.5-mV to
0.6-mV).
OPERATING VOLTAGE
The LTC887x family is optimized for operation at
(±2.75 V) at the temperature range of 0 ℃ to 70 ℃,
and fully specified and ensured for operation from
2.0 V to 5.5 V (±1.0 V to ±2.75 V). In addition, many
specifications apply from –40 ℃ to +125 ℃.
Parameters that vary significantly with operating
voltages or temperature are illustrated in the Typical
Characteristics graphs.
NOTE: Supply voltages (VS+ to VS–) higher than +10 V
can permanently damage the device.
RAIL-TO-RAIL INPUT
The input common-mode voltage range of the
LTC887x series extends 100-mV beyond the negative
and positive supply rails. This performance is
achieved with a complementary input stage: an Nchannel input differential pair in parallel with a Pchannel differential pair. The N-channel pair is active
for input voltages close to the positive rail, typically
VS+–1.4 V to the positive supply, whereas the Pchannel pair is active for inputs from 100-mV below
the negative supply to approximately VS+–1.4 V. There
is a small transition region, typically VS+–1.2 V to VS+–1
V, in which both pairs are on. This 200-mV transition
region can vary up to 200-mV with process variation.
Thus, the transition region (both stages on) can range
from VS+–1.4 V to VS+–1.2 V on the low end, up to VS+–1
V to VS+–0.8 V on the high end. Within this transition
region, PSRR, CMRR, offset voltage, offset drift, and
THD can be degraded compared to device operation
outside this region.
The typical input bias current of the LTC887x during
normal operation is approximately 1-pA. In
overdriven conditions, the bias current can increase
significantly. The most common cause of an
overdriven condition occurs when the operational
amplifier is outside of the linear range of operation.
When the output of the operational amplifier is driven
to one of the supply rails, the feedback loop
requirements cannot be satisfied and a differential
input voltage develops across the input pins. This
differential input voltage results in activation of
parasitic diodes inside the front-end input chopping
switches that combine with electromagnetic
interference (EMI) filter resistors to create the
equivalent circuit. Notice that the input bias current
remains within specification in the linear region.
INPUT EMI FILTER AND CLAMP CIRCUIT
Figure 1 shows the input EMI filter and clamp circuit.
The LTC887x op-amps have internal ESD protection
diodes (D1, D2, D3, and D4) that are connected
between the inputs and each supply rail. These
diodes protect the input transistors in the event of
electrostatic discharge and are reverse biased
during normal operation. This protection scheme
allows voltages as high as approximately 500-mV
beyond the rails to be applied at the input of either
terminal without causing permanent damage. These
ESD protection current-steering diodes also provide
in-circuit, input overdrive protection, as long as the
current is limited to 10-mA as stated in the Absolute
Maximum Ratings.
VS+
D1
RS1
5kΩ
IN+
D2
D3
CCM1
RS2 CDM
5kΩ
IN–
D4
CCM2
VS–
Figure 1. Input EMI Filter and Clamp Circuit
Operational amplifiers vary in susceptibility to EMI. If
conducted EMI enters the operational amplifier, the
dc offset at the amplifier output can shift from its
nominal value when EMI is present. This shift is a
result of signal rectification associated with the
internal semiconductor junctions. Although all
operational amplifier pin functions can be affected by
EMI, the input pins are likely to be the most
susceptible. The EMI filter of the LTC887x family is
P-9
Application Notes (continued)
composed of two 5-kΩ input series resistors (RS1 and
RS2), two common-mode capacitors (CCM1 and CCM2),
and a differential capacitor (CDM). These RC networks
set the −3 dB low-pass cutoff frequencies at 35-MHz
for common-mode signals, and at 22-MHz for
differential signals.
RAIL-TO-RAIL OUTPUT
Designed as a micro-power, low-noise operational
amplifier, the LTC887x delivers a robust output drive
capability. A class AB output stage with commonsource transistors is used to achieve full rail-to-rail
output swing capability. For resistive loads up to 100kΩ, the output swings typically to within 5-mV of
either supply rail regardless of the power-supply
voltage applied. Different load conditions change the
ability of the amplifier to swing close to the rails. For
resistive loads up to 600-Ω, the output swings
typically to within 125-mV of the positive supply rail
and within 90-mV of the negative supply rail.
provides the DC accuracy by connecting the inverting
signal with the output.
The CF and RISO serve to counteract the loss of phase
margin by feeding the high frequency component of
the output signal back to the amplifier’s inverting
input, thereby preserving phase margin in the overall
feedback loop.
For no-buffer configuration, there are two others
ways to increase the phase margin: (a) by increasing
the amplifier’s gain, or (b) by placing a capacitor in
parallel with the feedback resistor to counteract the
parasitic capacitance associated with inverting node.
CF
V IN
CL
The LTC887x family can safely drive capacitive loads
of up to 100-pF in any configuration. As with most
amplifiers, driving larger capacitive loads than
specified may cause excessive overshoot and ringing,
or even oscillation. A heavy capacitive load reduces
the phase margin and causes the amplifier frequency
response to peak. Peaking corresponds to overshooting or ringing in the time domain. Therefore, it
is recommended that external compensation be used
if the LTC887x op-amps must drive a load exceeding
100-pF. This compensation is particularly important
in the unity-gain configuration, which is the worst
case for stability.
A quick and easy way to stabilize the op-amp for
capacitive load drive is by adding a series resistor,
RISO, between the amplifier output terminal and the
load capacitance, as shown in Figure 2. RISO isolates
the amplifier output and feedback network from the
capacitive load. The bigger the RISO resistor value, the
more stable VOUT will be. Note that this method
results in a loss of gain accuracy because RISO forms
a voltage divider with the RL.
RISO
V OUT
LTC 887x
CAPACITIVE LOAD AND STABILITY
LTC887x
RF
R IS O
VOUT
VIN
CL
Figure 2. Indirectly Driving Heavy Capacitive Load
An improvement circuit is shown in Figure 3. It
provides DC accuracy as well as AC stability. The RF
RL
Figure 3. Indirectly Driving Heavy Capacitive Load
with DC Accuracy
OVERLOAD RECOVERY
Overload recovery is defined as the time required for
the operational amplifier output to recover from a
saturated state to a linear state. The output devices
of the operational amplifier enter a saturation region
when the output voltage exceeds the rated operating
voltage, either because of the high input voltage or
the high gain. After the device enters the saturation
region, the charge carriers in the output devices
require time to return back to the linear state. After
the charge carriers return back to the linear state,
the device begins to slew at the specified slew rate.
Thus, the propagation delay in case of an overload
condition is the sum of the overload recovery time
and the slew time. The overload recovery time for
the LTC887x family is approximately 0.26-μs.
EMI REJECTION RATIO
Circuit performance is often adversely affected by
high frequency EMI. When the signal strength is low
and transmission lines are long, an op-amp must
accurately amplify the input signals. However, all opamp pins — the non-inverting input, inverting input,
positive supply, negative supply, and output pins —
are susceptible to EMI signals. These high frequency
signals are coupled into an op-amp by various
means, such as conduction, near field radiation, or
far field radiation. For example, wires and printed
circuit board (PCB) traces can act as antennas and
pick up high frequency EMI signals.
P-10
Amplifiers do not amplify EMI or RF signals due to
their relatively low bandwidth. However, due to the
nonlinearities of the input devices, op-amps can
rectify these out of band signals. When these high
frequency signals are rectified, they appear as a dc
offset at the output.
The LTC887x op-amps have integrated EMI filters at
their input stage. A mathematical method of
measuring EMIRR is defined as follows:
EMIRR = 20 log (VIN_PEAK / ΔVOS)
resulting in a thermal voltage error.
This thermocouple error can be reduced by using
dummy components to match the thermoelectric
error source. Placing the dummy component as
close as possible to its partner ensures both
Seebeck voltages are equal, thus canceling the
thermocouple error. Maintaining a constant ambient
temperature on the circuit board further reduces this
error. The use of a ground plane helps distribute heat
throughout the board and reduces EMI noise pickup.
INPUT-TO-OUTPUT COUPLING
To minimize capacitive coupling, the input and output
signal traces should not be parallel. This helps
reduce unwanted positive feedback.
MAXIMIZING PERFORMANCE THROUGH PROPER
LAYOUT
To achieve the maximum performance of the
extremely high input impedance and low offset
voltage of the LTC887x op-amps, care is needed in
laying out the circuit board. The PCB surface must
remain clean and free of moisture to avoid leakage
currents between adjacent traces. Surface coating of
the circuit board reduces surface moisture and
provides a humidity barrier, reducing parasitic
resistance on the board. The use of guard rings
around the amplifier inputs further reduces leakage
currents. Figure 4 shows proper guard ring
configuration and the top view of a surface-mount
layout. The guard ring does not need to be a specific
width, but it should form a continuous loop around
both inputs. By setting the guard ring voltage equal to
the voltage at the non-inverting input, parasitic
capacitance is minimized as well. For further
reduction of leakage currents, components can be
mounted to the PCB using Teflon standoff insulators.
Guard
Ring
+IN
–IN
+VS
Figure 4. Use a guard ring around sensitive pins
Other potential sources of offset error are
thermoelectric voltages on the circuit board. This
voltage, also called Seebeck voltage, occurs at the
junction of two dissimilar metals and is proportional
to the temperature of the junction. The most common
metallic junctions on a circuit board are solder-toboard trace and solder-to-component lead. If the
temperature of the PCB at one end of the component
is different from the temperature at the other end,
the resulting Seebeck voltages are not equal,
P-11
Typical Application Circuits
ACTIVE FILTER
MOTOR PHASE CURRENT SENSING
The LTC887x family is well-suited for active filter
applications that require a wide bandwidth, fast slew
rate, low-noise, single-supply operational amplifier.
Figure 5 shows a 500-kHz, second-order, low-pass
filter using the multiple-feedback (MFB) topology.
The components have been selected to provide a
maximally-flat Butterworth response. Beyond the
cut-off frequency, roll-off is –40 dB/dec. The
Butterworth response is ideal for applications that
require predictable gain characteristics, such as the
anti-aliasing filter used in front of an ADC.
The current sensing amplification shown in Figure 7
has a slew rate of 2πfVPP for the output of sine wave
signal, and has a slew rate of 2fVPP for the output of
triangular wave signal. In most of motor control
systems, the PWM frequency is at 10 kHz to 20 kHz,
and one cycle time is 100 μs for a 10 kHz of PWM
frequency. In current shunt monitoring for a motor
phase, the phase current is converted to a phase
voltage signal for ADC sampling. This sampling
voltage signal must be settled before entering the
ADC. As the Figure 7 shown, the total settling time of
a current shunt monitor circuit includes: the rising
edge delay time (tSR) due to the op-amp’s slew rate,
and the measurement settling time (tSET). For a 2shunt solution of motor phase current sensing, if the
minimum duty cycle of the PWM is defined at 5%, and
the tSR is required at 20% of a total time window for a
phase current monitoring, in case of a 3.3 V motor
control system (3.3 V MCU with 12-bit ADC), the opamp’s slew rate should be more than:
R3
549Ω
C2
150pF
VIN
R1
549Ω
VS+
R2
1.24kΩ
VOUT
LTC887x
C1
1nF
3.3V / (100μs× 5% × 20%) = 3.3 V/μs
At the same time, the op-amp’s bandwidth should be
much greater than the PWM frequency, like 10 time at
least.
VS–
tSR
tSET
Figure 5. Second-Order, Butterworth, 500-kHz LowPass Filter
One point to observe when considering the MFB filter
is that the output is inverted, relative to the input. If
this inversion is not required, or not desired, a noninverting output can be achieved through one of
these options:
1. adding an inverting amplifier;
2. adding an additional second-order MFB stage; or
3. using a non-inverting filter topology, such as the
Sallen-Key (shown in Figure 6).
C2
220pF
VBUS
tSR – Time delay due to op-amp slew rate
tSET – Measurement settling time
tSMP – Sampling time window
High side
switch
To Motor Phase
VM
Low side
switch
R2
R1
C1
RSHUNT
LTC887x
R3
R4
VIN
R1
1.8kΩ
R2
19.5kΩ
R3
150kΩ
1VRMS
To MCU
ADC pin
R5
C2
VS+
Filter
LTC887x
C1
3.3nF
tSMP
Offset
Amplification
VOUT
C3
47pF
VS–
Figure 6. Configured as a Three-Pole, 20-kHz, SallenKey Filter
Figure 7. Current Shunt Monitor Circuit
DIFFERENTIAL AMPLIFIER
The circuit shown in Figure 8 performs the difference
function. If the resistors ratios are equal R4/R3 = R2/R1,
then:
VOUT = (Vp – Vn) × R2/R1 + VREF
P-12
Typical Application Circuits (continued)
low-leakage cables that that is required to connect a
pH probe (general purpose combination pH probes,
e.g Corning 476540) to metering ICs such as ADC,
AFE and/or MCU. A LTC887x op-amp and a lithium
battery are housed in the probe assembly. A
conventional low-cost coaxial cable can be used to
carry the op-amp’s output signal to subsequent ICs
for pH reading.
R2
R1
Vn
LTC887x
VOUT
Vp
R3
R4
VREF
Figure 8. Differential Amplifier
INSTRUMENTATION AMPLIFIER
RG
VREF
R1
R2
R2
LTC887x
R1
LTC887x
VOUT
V1
V2
VOUT =(V1 V2 )(1
R1 2R1
) VREF
R2 RG
Figure 9. Instrumentation Amplifier
The LTC887x family is well suited for conditioning
sensor signals in battery-powered applications.
Figure 9 shows a two op-amp instrumentation
amplifier, using the LTC887x op-amps. The circuit
works well for applications requiring rejection of
common-mode noise at higher gains. The reference
voltage (VREF) is supplied by a low-impedance
source. In single voltage supply applications, the VREF
is typically VS/2.
BUFFERED CHEMICAL SENSORS
Coax
LTC883x
R1
10MΩ
3V
To ADC,
AFE or MCU
pH
PROBE
R2
10MΩ
All components contained within the pH probe
Figure 10. Buffered pH Probe
The LTC887x family has input bias current in the pA
range. This is ideal in buffering high impedance
chemical sensors, such as pH probes.
As an
example, the circuit in Figure 10 eliminates expansive
P-13
Tape and Reel Information
REEL DIMENSIONS
TAPE DIMENSIONS
K0
P1
B0 W
Reel
Diameter
A0
Cavity
A0
B0
K0
W
P1
Reel
Width (W1)
Dimension designed to accommodate the component width
Dimension designed to accommodate the component length
Dimension designed to accommodate the component thickness
Overall width of the carrier tape
Pitch between successive cavity centers
QUADRANT ASSIGNMENTS FOR PIN 1 ORIETATION IN TAPE
Sprocket Holes
Q1
Q2
Q1
Q2
Q3
Q4
Q3
Q4
User Direction of Feed
Pocket Quadrants
* All dimensions are nominal
Device
LTC8871XT5/R6
Package
Pins
Type
SOT23
5
SPQ
3 000
Reel
Reel
Diameter Width W1
(mm)
(mm)
178
9.0
A0
(mm)
B0
(mm)
K0
(mm)
P1
(mm)
W
(mm)
Pin 1
Quadrant
3.3
3.2
1.5
4.0
8.0
Q3
P-14
Package Outlines
DIMENSIONS, SOT23-5L
A2
A
A1
D
e1
Symbol
A
A1
A2
b
c
D
E1
E
e
e1
L
L1
θ
θ
L
E
E1
L1
e
b
Dimensions
In Millimeters
Min
Max
1.25
0.04
0.10
1.00
1.20
0.33
0.41
0.15
0.19
2.820
3.02
1.50
1.70
2.60
3.00
0.95 BSC
1.90 BSC
0.60 REF
0.30
0.60
0°
8°
Dimensions
In Inches
Min
Max
0.049
0.002
0.004
0.039
0.047
0.013
0.016
0.006
0.007
0.111
0.119
0.059
0.067
0.102
0.118
0.037 BSC
0.075 BSC
0.024 REF
0.012
0.024
0°
8°
c
RECOMMENDED SOLDERING FOOTPRINT, SOT23-5L
1.0
0.039
0.95
0.037
0.95
0.037
0.7
0.028
2.4
0.094
mm
( inches
P-15
Package Outlines (continued)
DIMENSIONS, SOIC-8L
A2
A
A1
D
b
Symbol
e
A
A1
A2
b
C
D
E
E1
e
L
θ
L
E
E1
θ
Dimensions
In Millimeters
Min
Max
1.370
1.670
0.070
0.170
1.300
1.500
0.306
0.506
0.203 TYP.
4.700
5.100
3.820
4.020
5.800
6.200
1.270 TYP.
0.450
0.750
0°
8°
Dimensions
In Inches
Min
Max
0.054
0.066
0.003
0.007
0.051
0.059
0.012
0.020
0.008 TYP.
0.185
0.201
0.150
0.158
0.228
0.244
0.050 TYP.
0.018
0.030
0°
8°
C
RECOMMENDED SOLDERING FOOTPRINT, SOIC-8L
8X
5.40
0.213
(1.55)
MAX
(0.061)
(3.90)
MIN
(0.154)
1
(0.60)
MAX 8X
(0.024)
PITCH
1.270
0.050
mm
( inches
P-16
DIMENSIONS, MSOP-8L
A2
A
A1
D
b
Symbol
e
A
A1
A2
b
C
D
E
E1
e
L
θ
L
E1
E
Dimensions
In Millimeters
Min
Max
0.800
1.100
Dimensions
In Inches
Min
Max
0.031
0.043
0.050
0.150
0.750
0.950
0.290
0.380
0.150
0.200
2.900
3.100
2.900
3.100
4.700
5.100
0.650 TYP.
0.400
0.700
0°
8°
0.002
0.006
0.030
0.037
0.011
0.015
0.006
0.008
0.114
0.122
0.114
0.122
0.185
0.201
0.026 TYP.
0.016
0.028
0°
8°
θ
C
RECOMMENDED SOLDERING FOOTPRINT, MSOP-8L
8X
(0.45)
MAX
(0.018)
(1.45)
MAX
(0.057)
8X
4.40
(5.85)
MAX
0.173
(0.230)
(2.95)
MIN
(0.116)
0.65
PITCH
0.026
mm
( inches
P-17
DIMENSIONS, SOIC-14L
A3
A2
A
A1
D
b
C
e
L1 L
E
Symbol
E1
A
A1
A2
A3
b
C
D
E
E1
e
L1
L
θ
Dimensions
In Millimeters
Min
Max
1.450
1.850
0.100
0.300
1.350
1.550
0.550
0.750
0.406 TYP.
0.203 TYP.
8.630
8.830
5.840
6.240
3.850
4.050
1.270 TYP.
1.040 REF.
0.350
0.750
2°
8°
Dimensions
In Inches
Min
Max
0.057
0.073
0.004
0.012
0.053
0.061
0.022
0.030
0.016 TYP.
0.008 TYP.
0.340
0.348
0.230
0.246
0.152
0.159
0.050 TYP.
0.041 REF.
0.014
0.030
2°
8°
θ
RECOMMENDED SOLDERING FOOTPRINT, SOIC-14L
14X
5.40
0.213
(1.50)
MAX
(0.059)
(3.90)
MIN
(0.154)
1
(0.60)
MAX 14X
(0.024)
PITCH
1.270
0.050
mm
( inches
P-18
DIMENSIONS, TSSOP-14L
A3 A2
A
Symbol
A1
D
b
e
C
L1 L
E
E1
A
A1
A2
A3
b
C
D
E
E1
e
L1
L
θ
Dimensions
In Millimeters
Min
Max
1.200
0.050
0.150
0.900
1.050
0.390
0.490
0.200
0.290
0.130
0.180
4.860
5.060
6.200
6.600
4.300
4.500
0.650 TYP.
1.000 REF.
0.450
0.750
0°
8°
Dimensions
In Inches
Min
Max
0.047
0.002
0.006
0.035
0.041
0.015
0.019
0.008
0.011
0.005
0.007
0.191
0.199
0.244
0.260
0.169
0.177
0.026 TYP.
0.039 REF.
0.018
0.030
0°
8°
θ
RECOMMENDED SOLDERING FOOTPRINT, TSSOP-14L
14X
(1.45)
MAX
(0.057)
(4.40)
MIN
(0.173)
PITCH
0.65
0.026
1
5.90
0.232
14X
(0.45)
MAX
(0.018)
mm
( inches
P-19
IMPORTANT NOTICE
Linearin is a global fabless semiconductor company specializing in advanced high-performance highquality analog/mixed-signal IC products and sensor solutions. The company is devoted to the innovation
of high performance, analog-intensive sensor front-end products and modular sensor solutions, applied
in multi-market of medical & wearable devices, smart home, sensing of IoT, and intelligent industrial &
smart factory (industrie 4.0). Linearin’s product families include widely-used standard catalog products,
solution-based application specific standard products (ASSPs) and sensor modules that help customers
achieve faster time-to-market products. Go to http://www.linearin.com for a complete list of Linearin
product families.
For additional product information, or full datasheet, please contact with the Linearin’s Sales Department
or Representatives.
