LTP3559-50RXT4
LTP3559-50RXT4
    LINEARIN(先积)
    SOT89-3
    350mA,45V,超低IQ,低压差LDO SOT89-3
LTP3559-50RXT4 数据手册
LTP3559 P-1 General Description The LTP3559 is a high voltage, low power consumption and high performance LDO. The family uses an advanced CMOS process and a P-MOSFET pass device to achieve fast start-up, with high output voltage accuracy. The LTP3559 is stable with a 1.0μF~10μF ceramic output capacitor, and uses a precision voltage reference and feedback loop to achieve a worst-case accuracy of 2% over all load, line, process, and temperature variations. Features            Wide Input Voltage Range : up to 45V Output Current : 350mA Standard Fixed Output Voltage Options : 1.8V, 2.5V, 3.0V, 3.3V, 3.6V, and 5.0V More Output Voltage Options Available on Request Low IQ : 2.5μA Typically Low Dropout Voltage Short current protection:150mA Excellent Load and Line Transient Response Line Regulation : 0.01%/V Typically Normal Version Available in SOT23-3L, SOT23-5L and SOT89 Packages Shutdown Version Available in SOT23-5L and Tiny DFN1×1-4L Packages Order Information Model LTP3559 Package Ordering Number Note1 Packing Option SOT23-3L LTP3559-xxXT3 Tape and Reel, 3000 SOT23-5L LTP3559-xxNXT5 Tape and Reel, 3000 SOT23-5L LTP3559-xxXT5 Tape and Reel, 3000 SOT89-3 LTP3559-xxXT4 Tape and Reel, 1000 SOT89-3R LTP3559-xxRXT4 Tape and Reel, 1000 DFN1×1-4L LTP3559-xxNXF4 Tape and Reel, 10000 Note1: xx stands for output voltage, e.g. if xx = 18, the output voltage is 1.8V; if xx = 30, the output voltage is 3.0V. The device with suffix "N" is shutdown version with enable control input. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1620-28.2 — Data Sheet 350-mA, 45-V, Ultra-Low IQ , Low Dropout LDOs LTP3559 P-2 Pin Description Normal Version Without Enable (Top View) 3 IN 1 2 GND OUT IN 1 GND 2 NC 3 SOT23-3L 5 OUT 4 NC 1 GND 2 IN 1 OUT 3 OUT SOT89-3 SOT23-5L 2 GND 3 IN SOT89-3R Shuntdown Version With Enable (Top View) IN 1 GND 2 EN 3 4 5 OUT 4 NC 1 IN EN OUT GND SOT23-5L 3 2 DFN1×1-4L Pin Function Pin No. SOT23-3L SOT23-5L SOT89-3 SOT89-3R SOT23-5L DFN1×1-4L LTP3559- LTP3559xxXT3 xxXT5 LTP3559 LTP3559-xxXT4 xxRXT4 LTP3559xxNXT5 LTP3559xxNXF4 1 2 1 2 2 2 1 2 3 3 5 3 1 3,4 Pin Name Pin Function 2 GND Ground. 1 4 IN Supply input pin. 5 1 OUT Output pin. 3 3 EN Enable control input, active high. NC No connection. 4 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1620-28.2 — Data Sheet 350-mA, 45-V, Ultra-Low IQ , Low Dropout LDOs LTP3559 P-3 Block Diagram OUT IN Short Current protection + Voltage Reference GND Functional Description Input Capacitor A 1μF-10μF ceramic capacitor is recommended to connect between VIN and GND pins to decouple input power supply glitch and noise. The amount of the capacitance may be increased without limit. This input capacitor must be located as close as possible to the device to assure input stability and less noise. For PCB layout, a wide copper trace is required for both VIN and GND. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1620-28.2 — Data Sheet 350-mA, 45-V, Ultra-Low IQ , Low Dropout LDOs P-4 LTP3559 Output Capacitor An output capacitor is required for the stability of the LDO. The recommended output capacitance is from 1μF to 10μF, Equivalent Series Resistance (ESR) is from 5mΩ to 100mΩ, and temperature characteristics are X7R or X5R. Higher capacitance values help to improve load/line transient response. The output capacitance may be increased to keep low undershoot/overshoot. Place output capacitor as close as possible to OUT and GND pins. Low Quiescent Current The LTP3559, consuming only around 2.5μA for all input range and output loading, provides great power saving in portable and low power applications. Short Current Limit Protection When output current at the OUT pin is higher than current limit threshold or the OUT pin is short-circuit to GND, the short current limit protection will be triggered and clamp the output current to approximately 150mA to prevent over-current and to protect the regulator from damage due to overheating. Absolute Maximum Ratings Parameter Rating IN pin to GND pin –0.3 to 48 V OUT pin to GND pin –0.3 to 6 V Thermal Resistance (Junction to Ambient) Unit SOT-89 135 SOT23-5L 250 SOT23-3L 360 DFN1×1-4L 250 ℃/W Operating Junction Temperature –40 to 125 ℃ Storage Temperature –65 to 150 ℃ Lead Temperature (Soldering, 10 sec) 300 ℃ ESD (HBM mode) ESDA/JEDEC JS-001-2017 ±2000V Stresses exceeding those listed in the Maximum Ratings table may damage the device. If any of these limits are exceeded, device functionality should not be assumed, damage may occur and reliability may be affected. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. 04 FN1620-28.2 — Data Sheet 350-mA, 45-V, Ultra-Low IQ , Low Dropout LDOs LTP3559 P-5 Electrical Characteristics (VIN = VOUT + 2V; IOUT = 10mA, CIN = COUT = 1.0μF, unless otherwise noted. Typical values are at T A = +25°C.) Symbol Parameter Test Conditions Min Typ VIN Operating Input Voltage LineREG Line Regulation VDROP Dropout Voltage LoadREG Load Regulation 1mA ≤ IOUT ≤ 300mA, VIN =VOUT+2V IOUT Maximum Output Current VIN = VOUT +1V IQ Quiescent Current IOUT = 0mA 2.5 4 μA IQ_OFF Standby Current VEN = 0V, TA = 25°C 0.1 1 μA VENH EN Pin Threshold Voltage EN Input Voltage “H” VENL EN Pin Threshold Voltage EN Input Voltage “L” IEN EN Pin Current VEN=0-36V PSRR Power Supply Rejection Ratio VIN = VOUT+1V IOUT = 20mA eN 2.5V ≤ VIN ≤36V, IOUT = 10mA 0.01 VOUT= 3.0V, IOUT = 100mA 330 VOUT= 3.0V, IOUT = 200mA 690 Max Unit 45 V 0.04 %/V mV 40 350 mV mA 1.2 V 0.4 V 1 μA f = 1 kHz 60 dB Output Noise Voltage VIN = VOUT+2V, IOUT = 1mA, f = 10Hz to 100KHz, (VOUT =3V) COUT = 1μF 100 μVrms TSD Thermal Shutdown Temperature Temperature Increasing from TA=+25°C 155 ℃ TSDH Thermal Shutdown Hysteresis Temperature Falling From TSD 20 ℃ CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1620-28.2 — Data Sheet 350-mA, 45-V, Ultra-Low IQ , Low Dropout LDOs P-6 LTP3559 TYPICAL PERFORMANCE CHARACTERISTICS Fig1. Line-Transient Response Fig2. Load-Transient Response Fig3. Start up Response CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. 06 FN1620-28.2 — Data Sheet 350-mA, 45-V, Ultra-Low IQ , Low Dropout LDOs LTP3559 P-7 IQ vs. Temperature VDROP VS. IOUT 3.5 1000 IQ (μA) Dropout Voltage(mV) 3.2 100 2.9 2.6 10 2.3 2 1 0 50 100 150 200 250 300 -40 -20 350 0 20 40 60 80 100 120 Temperature(℃) Output Current (mA) Fig5. IQ VS Temperature Fig4. Dropout Voltage VS Output Current Application Circuits VIN VDD OUT VOUT CIN COUT 1µF 1µF Enable OFF ON EN GND CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1620-28.2 — Data Sheet 350-mA, 45-V, Ultra-Low IQ , Low Dropout LDOs LTP3559 P-8 Package Dimension SOT-89 4.4~4.6 1.4~1.6 2.3~2.6 3.94~4.25 1.55 0.9~1.2 0.35~0.44 0.32~0.52 1.50 3.00 Unit:mm SOT23-5L 2.82~3.02 0.3~0.6 0.7 1.5~1.7 2.65~3.05 0.35~0.5 0.95 0.08~0.2 1.05~1.25 0.03~0.15 1.8~2.0 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. Unit:mm 08 FN1620-28.2 — Data Sheet 350-mA, 45-V, Ultra-Low IQ , Low Dropout LDOs LTP3559 P-9 SOT23-3L 2.82~3.02 0.3~0.6 0.7 1.5~1.7 2.6~3.0 0.3~0.4 0.95 0.1~0.2 1.05~1.25 0.1max 1.8~2.0 Unit:mm DFN1×1-4 0.65BSC 0.15~0.35 0.95~1.05 0.5Max 0.95~1.05 Detail A 0.125REF 0.00~0.05 Unit:mm Detail A:PIN1 shape) CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1620-28.2 — Data Sheet 350-mA, 45-V, Ultra-Low IQ , Low Dropout LDOs
LTP3559-50RXT4 价格&库存
很抱歉,暂时无法提供与“LTP3559-50RXT4”相匹配的价格&库存,您可以联系我们找货
LTP3559-50RXT4
  • 1+1.45000
  • 30+1.40000
  • 100+1.30000
  • 500+1.20000
  • 1000+1.15000
