LTP3559A-50XT4
LTP3559A-50XT4
    LINEARIN(先积)
    SOT89-3
    350mA,45V,超低IQ,低压差LDO
LTP3559A-50XT4 数据手册
LTP3559A P-1 General Description The LTP3559A is a high voltage, low power consumption and high performance LDO. The family uses an advanced CMOS process and a P-MOSFET pass device to achieve fast start-up, with high output voltage accuracy. The LTP3559A is stable with a 1.0μF~10μF ceramic output capacitor, and uses a precision voltage reference and feedback loop to achieve a worst-case accuracy of 1% over all load, line, process, and temperature variations. Features ◼ ◼ ◼ ◼ ◼ ◼ ◼ ◼ ◼ ◼ Wide Input Voltage Range : up to 45V Output Current : 350mA Standard Fixed Output Voltage Options : 3.3V, 5.0V More Output Voltage Options Available on Request Low IQ : 2.6 μA Typically Low Dropout Voltage Short current protection:150mA Excellent Load and Line Transient Response Line Regulation : 0.01%/V Typically Package: SOT89-3 Order Information Model LTP3559A Package Ordering Number Note1 Packing Option SOT89-3 LTP3559A-33XT4 Tape and Reel, 1000 SOT89-3 LTP3559A-50XT4 Tape and Reel, 1000 SOT89-3 LTP3559A-33RXT4 Tape and Reel, 1000 SOT89-3 LTP3559A-50RXT4 Tape and Reel, 1000 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1622-12.1 — Data Sheet 350-mA, 45-V, Ultra-Low IQ , Low Dropout LDOs LTP3559A P-2 Pin Description Top View 1 GND 2 IN 1 OUT 3 OUT 2 GND 3 IN SOT89-3 SOT89-3 Pin Function Pin No. SOT89-3 SOT89-3 LTP3559A-xxXT4 LTP3559A-xxRXT4 1 Pin Name Pin Function 2 GND Ground. 2 3 IN Supply input pin. 3 1 OUT Output pin. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1622-12.1 — Data Sheet 350-mA, 45-V, Ultra-Low IQ , Low Dropout LDOs LTP3559A P-3 Block Diagram OUT IN Short Current protection + Voltage Reference GND Functional Description Input Capacitor A 1μF-10μF ceramic capacitor is recommended to connect between VIN and GND pins to decouple input power supply glitch and noise. The amount of the capacitance may be increased without limit. This input capacitor must be located as close as possible to the device to assure input stability and less noise. For PCB layout, a wide copper trace is required for both VIN and GND. Output Capacitor An output capacitor is required for the stability of the LDO. The recommended output capacitance is from 1μF to 10μF, Equivalent Series Resistance (ESR) is from 5mΩ to 100mΩ, and temperature characteristics are X7R or X5R. Higher capacitance values help to improve load/line transient response. The output capacitance may be increased to keep low undershoot/overshoot. Place output capacitor as close as possible to OUT and GND pins. Low Quiescent Current The LTP3559A, consuming only around 2.6μA for all input range and output loading, provides great power saving in portable and low power applications. Short Current Limit Protection When output current at the OUT pin is higher than current limit threshold or the OUT pin is short-circuit to GND, the short current limit protection will be triggered and clamp the output current to approximately 150mA to prevent over-current and to protect the regulator from damage due to overheating. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1622-12.1 — Data Sheet 350-mA, 45-V, Ultra-Low IQ , Low Dropout LDOs P-4 LTP3559A Absolute Maximum Ratings Parameter Rating Unit –0.3 to 48 V –0.3 to 6 V 135 ℃/W Operating Junction Temperature –40 to 125 ℃ Storage Temperature –65 to 150 ℃ IN pin to GND pin OUT pin to GND pin Thermal Resistance (Junction to Ambient) Lead Temperature (Soldering, 10 sec) ESD (HBM mode) ESDA/JEDEC JS-001-2017 300 ±2000V ℃ V Stresses exceeding those listed in the Maximum Ratings table may damage the device. If any of these limits are exceeded, device functionality should not be assumed, damage may occur and reliability may be affected. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. 04 FN1622-12.1 — Data Sheet 350-mA, 45-V, Ultra-Low IQ , Low Dropout LDOs LTP3559A P-5 Electrical Characteristics (VIN = VOUT + 2V; IOUT = 10mA, CIN = COUT = 1.0μF, unless otherwise noted. Typical values are at T A = +25°C.) Symbol Parameter Test Conditions VIN Operating Input Voltage VOUT Regulated Output Voltage IOUT=1mA LineREG Line Regulation 2.5V ≤ VIN ≤36V, IOUT = 10mA 0.01 VDROP Dropout Voltage VOUT= 3.3V, IOUT = 100mA 330 VOUT= 3.3V, IOUT = 200mA 690 LoadREG Load Regulation 1mA ≤ IOUT ≤ 300mA, VIN =VOUT+2V IOUT Maximum Output Current VIN = VOUT +2V IQ Quiescent Current IOUT = 0mA 2.6 PSRR Power Supply Rejection Ratio VIN = VOUT+1V , IOUT = 20mA f = 1 kHz 60 dB eN Output Noise Voltage VIN = VOUT+2V, IOUT = 1mA, f = 10Hz to 100KHz, (VOUT =3.3V) COUT = 1μF 100 μVrms TSD Thermal Shutdown Temperature Temperature Increasing from TA=+25°C 155 ℃ TSDH Thermal Shutdown Hysteresis Temperature Falling From TSD 20 ℃ CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. Min Typ VOUT X 0.99 Max Unit 45 V VOUT X 1.01 V 0.04 %/V mV 40 350 mV mA 4 μA FN1622-12.1 — Data Sheet 350-mA, 45-V, Ultra-Low IQ , Low Dropout LDOs P-6 LTP3559A TYPICAL PERFORMANCE CHARACTERISTICS Fig1. Line-Transient Response Fig2. Load-Transient Response Fig3. Start up Response CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. 06 FN1622-12.1 — Data Sheet 350-mA, 45-V, Ultra-Low IQ , Low Dropout LDOs LTP3559A P-7 IQ vs. Temperature VDROP VS. IOUT 3.5 1000 IQ (μA) Dropout Voltage(mV) 3.2 100 2.9 2.6 10 2.3 2 1 0 50 100 150 200 250 300 -40 -20 350 0 20 40 60 80 100 120 Temperature(℃) Output Current (mA) Fig5. IQ VS Temperature Fig4. Dropout Voltage VS Output Current Application Circuits VIN IN OUT VOUT CIN COUT 1µF 1µF GND CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1622-12.1 — Data Sheet 350-mA, 45-V, Ultra-Low IQ , Low Dropout LDOs LTP3559A P-8 Package Dimension SOT89-3/ SOT89-3R 4.4~4.6 1.4~1.6 0.9~1.2 2.3~2.6 3.94~4.25 1.55 1.50 0.32~0.52 3.00 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. 0.35~0.44 Unit:mm 08 FN1622-12.1 — Data Sheet 350-mA, 45-V, Ultra-Low IQ , Low Dropout LDOs
LTP3559A-50XT4 价格&库存
很抱歉,暂时无法提供与“LTP3559A-50XT4”相匹配的价格&库存,您可以联系我们找货
