LTP3564-33XT3
LTP3564-33XT3
    LINEARIN(先积)
    SOT23-3
    300mA、24V、低IQ、低压差调节器
LTP3564-33XT3 数据手册
LTP3564 P-1 General Description The LTP 3564 is a high voltage, low power consumption and high performance LDO. The family uses an advanced CMOS process and a PMOSFET pass device to achieve fast start-up, with high output voltage accuracy. The LTP3564 is stable with a 1.0μF~10μF ceramic output capacitor, and uses a precision voltage reference and feedback loop to achieve a worst-case accuracy of 3% over all load, line, process, and temperature variations. Features           Wide Input Voltage Range: up to 24V Output Current: 300mA Standard Fixed Output Voltage Options: 3.0V, 3.3V, 3.6V, and 5.0V More Output Voltage Options Available on Request Low IQ : 1.8µA Typically Low Dropout Voltage Short current protection: 350mA Excellent Load/Line Transient Response Line Regulation: 0.05%/V Typically Available in SOT-89 and SOT23-3L Packages Order Information (Ordering Number) Model LTP3564 Package Ordering Number Note1 Packing Option SOT89 LTP3564-xxXT4 Tape and Reel, 1000 SOT23-3L LTP3564-xxXT3 Tape and Reel, 10000 Note1: xx stands for output voltage, e.g. if xx = 18, the output voltage is 1.8V; if xx = 30, the output voltage is 3.0V CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1620-41.1 — Data Sheet 300-mA, 24-V, Low IQ , Low Dropout Regulators LTP3564 P-2 Pin Description 3 IN 1 GND 2 IN GND 3 OUT OUT 1 SOT-89 2 SOT23-3L TOP VIEW Pin Function Pin No. Pin Name Pin Function 1 GND Ground. 2 3 IN Supply input pin. Must be closely decoupled to GND with a 1μF or greater ceramic capacitor. 3 2 OUT Output pin. Bypass a 1μF or greater ceramic capacitor from this pin to ground. SOT-89 SOT23-3L 1 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1620-41.1 — Data Sheet 300-mA, 24-V, Low IQ , Low Dropout Regulators LTP3564 P-3 Block Diagram OUT IN Short Current protection + Voltage Reference GND Functional Description Input Capacitor A 1μF-10μF ceramic capacitor is recommended to connect between VIN and GND pins to decouple input power supply glitch and noise. The amount of the capacitance may be increased without limit. This input capacitor must be located as close as possible to the device to assure input stability and less noise. For PCB layout, a wide copper trace is required for both VIN and GND. CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1620-41.1 — Data Sheet 300-mA, 24-V, Low IQ , Low Dropout Regulators P-4 LTP3564 Output Capacitor An output capacitor is required for the stability of the LDO. The recommended output capacitance is from 1μF to 10μF, Equivalent Series Resistance (ESR) is from 5mΩ to 100mΩ, and temperature characteristics are X7R or X5R. Higher capacitance values help to improve load/line transient response. The output capacitance may be increased to keep low undershoot/overshoot. Place output capacitor as close as possible to OUT and GND pins. Low Quiescent Current The LTP3559, consuming only around 1.8μA for all input range and output loading, provides great power saving in portable and low power applications. Short Current Limit Protection When output current at the OUT pin is higher than current limit threshold or the OUT pin is short-circuit to GND, the short current limit protection will be triggered and clamp the output current to approximately 70mA to prevent over-current and to protect the regulator from damage due to overheating. Absolute Maximum Ratings Parameter IN pin to GND pin Thermal Resistance (Junction to Ambient) Power Dissipation @ 25℃ Rating Unit –0.3 to 28 V SOT-89 135 SOT23-3L 360 SOT-89 750 SOT23-3L 280 ℃/W mw Operating Junction Temperature –40 to 125 ℃ Storage Temperature –65 to 150 ℃ 300 ℃ ESDA/JEDEC JS-001-2017 ±2000V Lead Temperature (Soldering, 10 sec) ESD (HBM mode) CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. FN1620-41.1 — Data Sheet 300-mA, 24-V, Low IQ , Low Dropout Regulators LTP3564 P-5 Electrical Characteristics (VIN= VOUT+2V, Ta= 25°,CIN=10uF, COUT=10uF unless otherwise noted) PARAMETER SYMBOL TEST CONDITIONS Input Voltage Operation Range VIN Dropout Voltage VDROP DC Supply Quiescent Current IQ Regulated Output Voltage VOUT IOUT=1mA Output Voltage Line Regulation RegLINE VIN = VOUT +1V to 30V, IOUT = 10mA (ΔVOUT/ΔVIN/VOUT) Output Voltage Load Regulation RegLOAD Maximum Output Current MIN TYP VOUT= 3.3V, IOUT = 50mA 160 VOUT= 3.3V, IOUT = 100mA 320 1.8 MAX UNIT 24 V mV 3 µA VOUT×1.03 V 0.05 0.2 %/V IOUT from 1mA to 50mA VIN≤35V 60 100 IOUT VIN = VOUT +1V 300 mA Short Current Protection ISHORT OUT short to GND 350 mA Power Supply Rejection Ratio PSRR IOUT=30mA Output Noise eN 10Hz to 100kHz, IOUT = 30mA, VOUT×0.97 f=100Hz 45 f=1KHz 39 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. 200 mv dB µVRMS FN1620-41.1 — Data Sheet 300-mA, 24-V, Low IQ , Low Dropout Regulators LTP3564 P-6 TYPICAL PERFORMANCE CHARACTERISTICS 350 300 250 200 150 100 50 0 -50 -100 Iout VS. Vdrop Vin VS. Iq 2.5 Vdrop Iq 2 1.5 1 0.5 0 20 40 60 80 100 120 0 0 5 Fig1. Iout VS. Vdrop 10 15 20 25 Fig2. Vin VS. Iq Fig3. Load-Transient Response Fig4. Load-Transient Response CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. 30 35 FN1620-41.1 — Data Sheet 300-mA, 24-V, Low IQ , Low Dropout Regulators LTP3564 P-7 Application Circuits VIN IN OUT 1µF to 10µF CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. VOUT 1µF to 10µF FN1620-41.1 — Data Sheet 300-mA, 24-V, Low IQ , Low Dropout Regulators LTP3564 P-8 Package Dimension SOT-89 4.4~4.6 1.4~1.6 2.3~2.6 3.94~4.25 1.55 0.9~1.2 0.35~0.44 0.32~0.52 1.50 3.00 Unit:mm SOT23-3L 2.82~3.02 0.3~0.6 0.7 1.5~1.7 2.6~3.0 0.3~0.4 0.95 0.1~0.2 1.05~1.25 0.1max 1.8~2.0 CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation. © Copyright Linearin Technology Corporation. All Rights Reserved. All other trademarks mentioned are the property of their respective owners. Unit:mm FN1620-41.1 — Data Sheet 300-mA, 24-V, Low IQ , Low Dropout Regulators
LTP3564-33XT3 价格&库存
很抱歉,暂时无法提供与“LTP3564-33XT3”相匹配的价格&库存,您可以联系我们找货
