TCRG102012(0805)L7500BT25PPM
    SUP(美隆)
    高精度、低温漂贴片电阻 0805 750Ω ±0.1% 1/10W ±25ppm/℃
TCRG102012(0805)L7500BT25PPM 数据手册
高精密薄膜贴片电阻(TCR) Thin Film Precision Chip Resistor 信赖性试验项目 Environmental Characteristics >>> 薄膜贴片电阻(TCRG) Thin Film Chip Resistor ————————————————————————— Test Method 测试方法 Item 项目 先进的薄膜技术,阻值范围1Ω~2.49MΩ Tol.>0.05% 结构图 Construction >>> Temperature Coefficient of Resistance(T.C.R) 温度系数(T.C.R.) Short Time Overload 短时间过负载 ———————————————————————————————————————————————————— Advanced thin film technology/Wide resistance range 1Ω~2.49MΩ Requirement 条件 Tol.≤0.05% 摘要 Resume >>> As Spec. 参考规格表 —————————————————————————————————————————————— -55℃~+125℃,25℃ is the reference temperature 参考温度 ① Alumina Substrate 陶瓷基体 ② Bottom Electrode 背导电极 △R±0.05% ③ Top Electrode 正导电极 RCWV*2.5 or Max.Overload voltage whichever is lower for 5seconds 额定电压的 2.5 倍或最大负载电压 5 秒 △R±0.2% ④ Edge Electrode 侧导电极 ⑤ Barrier Layer 电镀介质层 ⑥ External Electrode 外部端电极 Insulation Resistance 绝缘阻抗 ≥1G △R±0.05% Endurance 负载寿命 Apply 100Vdc for 1 minute 施加电压 100V(DC)1 分钟 △R±0.2% >7KΩ △R±0.5% △R±0.5% for High power rating 大功率 △R±0.05% Damp Heat with Load 耐湿负荷 Bending Strength 弯折强度测试 △R±0.5% for High power rating 大功率 △R±0.05% Solderability 焊锡性 Resistance to Soldering Heat 抗焊锡热 Thermal Shock 热冲击 △R±0.2% 95% min.coverage 导体爬锡面积大于 95% △R±0.05% Dielectric Withstand Voltage 耐电压 Low Temperature Operation 低温操作 △R±0.3% △R±0.2% By type 依据型号 △R±0.05% △R±0.5% △R±0.05% ⑦ Resistor Layer 电阻层 ⑧ Overcoat 密封层 70±2℃,RCWV for 1000 hrs with 1.5 hrs”ON” and 0.5 hrs “OFF” 70±2℃温度中施加额定电压,1.5 小时"开", 0.5 小时 "关",共 1000 小时 尺寸 Dimensions >>> ————————————————————————————————————————————————— Size 规格 L W T D1 D2 0402 1.00±0.05 0.50±0.05 0.30±0.10 0.20±0.10 0.20±0.10 Bending once for 5 seconds2010,2512sizes:2mm Other sizes:3mm 产品焊在测试板上,中央施力下压5秒下压深度:2010、 2512:2毫米其他尺寸:3毫米 0603 1.60±0.10 0.80±0.10 0.45±0.10 0.30±0.20 0.30±0.20 245±5℃ for 3 seconds 245±5℃锡炉中,持续 3 秒 0805 2.00±0.15 1.25±0.15 0.50±0.10 0.30±0.20 0.40±0.20 260±5℃ for 10 seconds 260±5℃锡炉中,持续 10 秒 1206 3.10±0.15 1.55±0.15 0.55±0.10 0.42±0.20 0.35±0.25 40±2℃,90~95% R.H.,RCWV for 1000 hrs with 1.5 hrs ”ON” and 0.5 hrs “OFF” 在温度 40±2℃,相对湿度 90~95%环境中施加额定电压, 1.5 小时"开", 0.5 小时 "关",共 1000 小时 Max.Operating Voltage for 1 minute 最大操作电压*1.42 倍, 持续 1 分钟 型号名称 Part Numbering >>> —————————————————————————————————————————— △R±0.2% for High power rating 大功率 △R±0.25% 1 hour, -65℃,followed by 45 minutes of RCWV 在 45 分钟 RCWV 之后,在-65℃温度下持续 1 小时 TCRG 04 3216(1206) L1801 Product Type 产品型号 Production line code Resistor Size Resistance 阻值 D T V 50PPM -55℃ 到 +125/+150℃,100 次 Operating Voltage=√(P*R) or Max.Operating Voltage listed above,whichever is lower. Overload Voltage=2.5*√(P*R) or Max.Overload Voltage listed above,whichever is lower. RCWV(Rated Continuous Working Voltage)=√(P*R) or Max.Operating Voltage whichever is lower. Environmental conditions for electrical performance measurement,Temperature:25±5 Humidity: 25%~75%RH Reference Standards:IEC 60115-1,60068-2-58;JIS-C 5201-1 TEL:0755-82533555 / 83779968 产线代码 01 TCRG: 薄膜贴片电阻 ■RCWV(额定持续工作电压)=√(P*R)或者较小的最大操作电压. 操作电压=√(P*R),过负载电压=2.5*√(P*R),操作电流=√(P/R) ■电性能测量的环境条件:温度:25±5 相对湿度:25%~75%RH ■依据标准:IEC 60115-1,60068-2-58;JIS-C 5201-1 PAGE 40 ⑨ Marking 丝印 02 03 04 10 HTTP://www.szmeilong.com TEL:0755-82533555 / 83779968 电阻规格 1005(0402) Resistance Tolerance Packing Code High Power 包装形式 升功率 阻值公差 B=±0.1% 1608(0603) L1801: 1.8K Ω C=±0.25% 2012(0805) L1R30: 1.3 Ω 3216(1206) HTTP://www.szmeilong.com D=±0.5% F= ±1 % T:Taping Reel T: 编带 B:Bulk B: 散装 PPM/℃ Y:1/16W X:1/10W 25PPM W:1/8 W 50PPM V :1/4 W PAGE 41 薄膜贴片电阻(TCRG) Thin Film Chip Resistor 薄膜贴片电阻(TCRG) Thin Film Chip Resistor 标准规格表 Standard Electrical Specifications >>> Item 项目 Type 型号 Power Rating 额定功率 Max.Operating Voltage 最大工作电压 Max.Overload Voltage 最大负载电压 ————————————————————————— Resistance Range 阻值范围 ±0.1% ±0.25% ±0.5% 信赖性试验项目 Environmental Characteristics >>> Requirement 条件 TC 温度系数 (PPM/℃) ±1%及以下 50V 100V 4.7Ω-255KΩ ±25 温度系数(T.C.R.) 短时间过负载 1/10W 75V 150V 1Ω-1MΩ Insulation Resistance 1/8W 150V 300V 1Ω-2MΩ 1/4W 200V 400V 1Ω-2.49MΩ △R±0.05% ±25 ±50 0.5 hrs “OFF” 70±2℃温度中施加额定电压,1.5 小时"开", 0.5 小时 " 40±2℃,90~95% R.H.,RCWV for 1000 hrs with 1.5 耐湿负荷 ◆Operating Temp.Range 操作温度范围:0402~1206:-55~155℃ Apply 100Vdc for 1 minute 施加电压 100V(DC)1 分钟 关",共 1000 小时 Damp Heat with Load △R±0.05% hrs ”ON” and 0.5 hrs “OFF” 在温度 40±2℃,相对湿度 90~95%环境中施加额定电压, 1.5 小时"开", 0.5 小时 "关",共 1000 小时 Bending Strength 弯折强度测试 功率衰减曲线图 Derating Curve >>> ≥1G 70±2℃,RCWV for 1000 hrs with 1.5 hrs”ON” and Endurance 负载寿命 1206 lower for 5seconds 额定电压的 2.5 倍或最大负载电压 5 秒 ±25 ±50 -55℃~+125℃,25℃ is the reference temperature 参考温度 RCWV*2.5 or Max.Overload voltage whichever is △R±0.05% ±25 ±50 绝缘阻抗 0805 As Spec. 参考规格表 ±50 Short Time Overload 0603 Jumper 跳线 ±1% Temperature Coefficient of 1/16W Test Method 测试方法 Item 项目 Resistance(T.C.R) 0402 ————————————————————————— △R±0.25% —————————————————————————————————————— Bending once for 5 seconds2010,2512sizes:2mm Other sizes:3mm 产品焊在测试板上,中央施力下压5秒下压深度:2010、 2512:2毫米 其他尺寸:3毫米 Solderability 95% min.coverage 245±5℃ for 3 seconds 焊锡性 导体爬锡面积大于 95% 245±5℃锡炉中,持续 3 秒 Resistance to Soldering Heat 抗焊锡热 △R±0.5% 260±5℃ for 10 seconds 260±5℃锡炉中,持续 10 秒 Dielectric Withstand Voltage By type Max.Operating Voltage for 1 minute 耐电压 依据型号 最大操作电压*1.42 倍, 持续 1 分钟 Low Temperature Operation 低温操作 Thermal Shock 热冲击 △R±0.5% △R±0.5% 1 hour, -65℃,followed by 45 minutes of RCWV 在 45 分钟 RCWV 之后,在-65℃温度下持续 1 小时 -55℃ 到 +125/+150℃,100 次 Operating Voltage=√(P*R) or Max.Operating Voltage listed above,whichever is lower. Overload Voltage=2.5*√(P*R) or Max.Overload Voltage listed above,whichever is lower. RCWV(Rated Continuous Working Voltage)=√(P*R) or Max.Operating Voltage whichever is lower. Environmental conditions for electrical performance measurement,Temperature:25±5 Humidity: 25%~75%RH Reference Standards:IEC 60115-1,60068-2-58;JIS-C 5201-1 ■RCWV(额定持续工作电压)=√(P*R)或者较小的最大操作电压. 操作电压=√(P*R),过负载电压=2.5*√(P*R),操作电流=√(P/R) ■电性能测量的环境条件:温度:25±5 相对湿度:25%~75%RH ■依据标准:IEC 60115-1,60068-2-58;JIS-C 5201-1 PAGE 42 TEL:0755-82533555 / 83779968 HTTP://www.szmeilong.com TEL:0755-82533555 / 83779968 HTTP://www.szmeilong.com PAGE 43 薄膜贴片电阻(TCRG) Thin Film Chip Resistor 薄膜贴片电阻(TCRG) Thin Film Chip Resistor 标准规格表 Standard Electrical Specifications >>> Item 项目 Type 型号 Power Rating 额定功率 Max.Operating Voltage 最大工作电压 Max.Overload Voltage 最大负载电压 ————————————————————————— Resistance Range 阻值范围 ±0.1% ±0.25% ±0.5% 信赖性试验项目 Environmental Characteristics >>> Requirement 条件 TC 温度系数 (PPM/℃) ±1%及以下 50V 100V 4.7Ω-255KΩ ±25 温度系数(T.C.R.) 短时间过负载 1/10W 75V 150V 1Ω-1MΩ Insulation Resistance 1/8W 150V 300V 1Ω-2MΩ 1/4W 200V 400V 1Ω-2.49MΩ △R±0.05% ±25 ±50 0.5 hrs “OFF” 70±2℃温度中施加额定电压,1.5 小时"开", 0.5 小时 " 40±2℃,90~95% R.H.,RCWV for 1000 hrs with 1.5 耐湿负荷 ◆Operating Temp.Range 操作温度范围:0402~1206:-55~155℃ Apply 100Vdc for 1 minute 施加电压 100V(DC)1 分钟 关",共 1000 小时 Damp Heat with Load △R±0.05% hrs ”ON” and 0.5 hrs “OFF” 在温度 40±2℃,相对湿度 90~95%环境中施加额定电压, 1.5 小时"开", 0.5 小时 "关",共 1000 小时 Bending Strength 弯折强度测试 功率衰减曲线图 Derating Curve >>> ≥1G 70±2℃,RCWV for 1000 hrs with 1.5 hrs”ON” and Endurance 负载寿命 1206 lower for 5seconds 额定电压的 2.5 倍或最大负载电压 5 秒 ±25 ±50 -55℃~+125℃,25℃ is the reference temperature 参考温度 RCWV*2.5 or Max.Overload voltage whichever is △R±0.05% ±25 ±50 绝缘阻抗 0805 As Spec. 参考规格表 ±50 Short Time Overload 0603 Jumper 跳线 ±1% Temperature Coefficient of 1/16W Test Method 测试方法 Item 项目 Resistance(T.C.R) 0402 ————————————————————————— △R±0.25% —————————————————————————————————————— Bending once for 5 seconds2010,2512sizes:2mm Other sizes:3mm 产品焊在测试板上,中央施力下压5秒下压深度:2010、 2512:2毫米 其他尺寸:3毫米 Solderability 95% min.coverage 245±5℃ for 3 seconds 焊锡性 导体爬锡面积大于 95% 245±5℃锡炉中,持续 3 秒 Resistance to Soldering Heat 抗焊锡热 △R±0.5% 260±5℃ for 10 seconds 260±5℃锡炉中,持续 10 秒 Dielectric Withstand Voltage By type Max.Operating Voltage for 1 minute 耐电压 依据型号 最大操作电压*1.42 倍, 持续 1 分钟 Low Temperature Operation 低温操作 Thermal Shock 热冲击 △R±0.5% △R±0.5% 1 hour, -65℃,followed by 45 minutes of RCWV 在 45 分钟 RCWV 之后,在-65℃温度下持续 1 小时 -55℃ 到 +125/+150℃,100 次 Operating Voltage=√(P*R) or Max.Operating Voltage listed above,whichever is lower. Overload Voltage=2.5*√(P*R) or Max.Overload Voltage listed above,whichever is lower. RCWV(Rated Continuous Working Voltage)=√(P*R) or Max.Operating Voltage whichever is lower. Environmental conditions for electrical performance measurement,Temperature:25±5 Humidity: 25%~75%RH Reference Standards:IEC 60115-1,60068-2-58;JIS-C 5201-1 ■RCWV(额定持续工作电压)=√(P*R)或者较小的最大操作电压. 操作电压=√(P*R),过负载电压=2.5*√(P*R),操作电流=√(P/R) ■电性能测量的环境条件:温度:25±5 相对湿度:25%~75%RH ■依据标准:IEC 60115-1,60068-2-58;JIS-C 5201-1 PAGE 42 TEL:0755-82533555 / 83779968 HTTP://www.szmeilong.com TEL:0755-82533555 / 83779968 HTTP://www.szmeilong.com PAGE 43 普通厚膜贴片电阻(RR) Thick Automotive 汽车级防硫化贴片电阻(ASA) Film ChipGrade Resistor Anti-Sulfurated Chip Resistor 信赖性试验项目 Environmental Characteristics >>> ————————————————————————— 附表(SS) Supporting Statements Multiplier Code (for 0603 ≤±1% marking) 【指数码(0603 ≤±1% 标志)】 Code 代码 A Multiplier 指数 10 B 0 C 1 D 2 10 10 E 3 F 4 10 10 G 5 10 H 6 10 X 7 10 10 -1 Y -2 10 Z 10 -3 Standar E-96 series Resistance Value code (for 0603≤±1% marking) 【E-96 系列标准组织代码(对0603 ≤ ±1%的字码)】 Value 阻值 Code 代码 Value 阻值 Code 代码 Value 阻值 Code 代码 Value 阻值 Code 代码 Value 阻值 Code 代码 Value 阻值 Code 代码 81 100 01 147 17 215 33 316 49 464 65 681 102 02 150 18 221 34 324 50 475 66 698 82 105 03 154 19 226 35 332 51 487 67 715 83 107 04 158 20 232 36 340 52 499 68 732 84 110 05 162 21 237 37 348 53 511 69 750 85 113 06 165 22 243 38 357 54 523 70 768 86 115 07 169 23 249 39 365 55 536 71 787 87 118 08 174 24 255 40 374 56 549 72 806 88 89 121 09 178 25 261 41 383 57 562 73 825 124 10 182 26 267 42 392 58 576 74 845 90 127 11 187 27 274 43 402 59 590 75 866 91 130 12 191 28 280 44 412 60 604 76 887 92 93 133 13 196 29 287 45 422 61 619 77 909 137 14 200 30 294 46 432 62 634 78 931 94 140 15 205 31 301 47 442 63 649 79 953 95 143 16 210 32 309 48 453 64 665 80 976 96 So the resistance value are marked as the following example (阻值标识如下): -1 10X=124Ω*10 =12.4Ω Operating Voltage=√(P*R) or Max.Operating Voltage listed above,whichever is lower. Overload Voltage=2.5*√(P*R) or Max.Overload Voltage listed above,whichever is lower. RCWV(Rated Continuous Working Voltage)=√(P*R) or Max.Operating Voltage whichever is lower. Environmental conditions for electrical performance measurement,Temperature:25±5 Humidity: 25%~75%RH Reference Standards:IEC 60115-1,60068-2-58;JIS-C 5201-1 ■RCWV(额定持续工作电压)=√(P*R)或者较小的最大操作电压. 操作电压=√(P*R),过负载电压=2.5*√(P*R),操作电流=√(P/R) ■电性能测量的环境条件:温度:25±5 相对湿度:25%~75%RH ■依据标准:IEC 60115-1,60068-2-58;JIS-C 5201-1 PAGE 96 Standard E-24 and not belong to E-96 series values (≤ ±1%)of 0603 size: the marking is the same as 5% tolerance but marking as underline 0603 ±1%公差,在标准E-24系列中,但不属于E-96系列的阻值, 标示和5%的公差相同,但是在字码下多加一条线 122=1200Ω=1.2KΩ TEL:0755-82533555 / 83779968 HTTP://www.szmeilong.com TEL:0755-82533555 / 83779968 HTTP://www.szmeilong.com PAGE 97
TCRG102012(0805)L7500BT25PPM 价格&库存
很抱歉,暂时无法提供与“TCRG102012(0805)L7500BT25PPM”相匹配的价格&库存,您可以联系我们找货
  • 1+0.33510
  • 100+0.31276
  • 300+0.29042
  • 500+0.26808
  • 2000+0.25691
  • 5000+0.25021
