KBU1510
KBU1510
    GOODWORK(固得沃克)
    DB-23.2X6.75MM_TM
    单相15.0安培桥式整流器 VR=1KV IR=10μA KBU
KBU1510 数据手册
KBU15005THRU KBU1510 SINGLE PHASE 15.0 AMP BRIDGE RECTIFIERS VOLTAGE RANGE 50 to 1000 Volts CURRENT 15 Amperes KBU FEATURES * Ideal for printed circuit board .15 X.23L (3.8 X5.7L) HOLE THRU .935(23.7) .895(22.7) * Low forward voltage .700(17.8) .660(16.8) * Low leakage current .780(19.8) .740(18.8) * Polarity: marked on body AC * Mounting position: Any + 1.00 MIN. (25.4) .052(1.3) .048(1.2) DIA. .220(5.6) SPACING .180(4.6) .078 (2.0) .276(7.0) .256(6.5) Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Rating 25 C ambient temperature uniess otherwies specified. Single phase half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. KBU15005 KBU1501 KBU1502 KBU1504 KBU1506 KBU15088 KBU1510 UNITS TYPE NUMBER Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC Blocking Voltage Maximum Average Forward Rectified Current 50 35 50 100 70 100 200 140 200 400 280 400 .375"(9.5mm) Lead Length at Ta=55 C Peak Forward Surge Current, 8.3 ms single half sine-wave superimposed on rated load (JEDEC method) Maximum Forward Voltage Drop per Bridge Element at 7.5A D.C. Maximum DC Reverse Current Ta=25 C at Rated DC Blocking Voltage Operating Temperature Range, TJ Storage Temperature Range, TSTG Ta=100 C -65 -65 600 420 600 800 560 800 1000 700 1000 V V V 15 A 240 1.05 10 A V A 500 +150 +150 C C A REV 1.0 2015 JAN PAGE:1/2 RATING AND CHARACTERISTIC CURVES (KBU15005 THRU KBU1510) FIG.2-MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT PEAK FORWARD SURGE CURRENT,(A) 12 10 8 6 Single Phase 4 Half Wave 60Hz Resistive Or Inductive Load 2 0.375"(9.5mm) Lead Length 0 0 50 100 150 250 200 150 8.3ms Single Half Tj=25 C Sine Wave 100 JEDEC method 50 0 1 AMBIENT TEMPERATURE,( C) 5 50 10 100 NUMBER OF CYCLES AT 60Hz FIG.3-TYPICAL FORWARD FIG.4-TYPICAL REVERSE CHARACTERISTICS CHARACTERISTICS 50 50 10 10 REVERSE LEAKAGE CURRENT, ( A) INSTANTANEOUS FORWARD CURRENT,(A) AVERAGE FORWARD CURRENT,(A) FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE 3.0 1.0 Tj=25 C Pulse Width 300us 1% Duty Cycle 0.1 3.0 Tj=100 C 1.0 0.1 Tj=25 C .01 0 .2 .4 .6 .8 1.0 FORWARD VOLTAGE,(V) 1.2 1.4 .01 0 20 40 60 80 100 120 140 PERCENT OF RATED PEAK REVERSE VOLTAGE, (%) REV 1.0 2015 JAN PAGE:2/2
KBU1510 价格&库存
很抱歉,暂时无法提供与“KBU1510”相匹配的价格&库存,您可以联系我们找货
KBU1510
  • 1+1.27070
  • 30+1.22220
  • 100+1.17370
  • 500+1.07670
  • 1000+1.02820
  • 2000+0.99910
库存:30
