GBL610
GBL610
    GOODWORK(固得沃克)
    DB-20.1X3.5MM_TM
    单相6.0安培桥式整流器 VR=1KV IR=5μA GBL
GBL610 数据手册
GBL600 5 THRU GBL 610 SINGLE PHASE 6.0 AMP BRIDGE RECTIFIERS VOLTAGE RANGE 50 to 1000 Volts CURRENT 6.0 Amperes GBL FEATURES * Ideal for printed circuit board * Low forward voltage .810(20.6) .770(19.6) .142(3.6) .133(3.4) * Low leakage current .440(11.2) .420(10.7) .095(2.4) .065(1.7) * Polarity: marked on body + AC * Mounting position: Any .043(1.1) .560(14.2) .035(0.9) .500(12.7) .055(1.4) .047(1.2) .045(1.14) .035(0.90) .020(0.51) .015(0.38) .210 .210 .210 .190 .190 .190 (5.33)(5.33)(5.33) (4.83)(4.83)(4.83) Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Rating 25 C ambient temperature uniess otherwies specified. Single phase half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. TYPE NUMBER 8 GBL610 UNITS GBL6005 GBL601 GBL602 GBL604 GBL606 GBL608 Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC Blocking Voltage Maximum Average Forward Rectified Current 50 35 50 100 70 100 200 140 200 400 280 400 600 420 600 800 560 800 1000 700 1000 V V V .375"(9.5mm) Lead Length at Ta=50 C Peak Forward Surge Current, 8.3 ms single half sine-wave 6.0 A superimposed on rated load (JEDEC method) Maximum Forward Voltage Drop per Bridge Element at 3.0A D.C. Maximum DC Reverse Current Ta=25 C 150 1.0 10 A V A 500 +150 +150 C C at Rated DC Blocking Voltage Operating Temperature Range, TJ Storage Temperature Range, TSTG Ta=100 C -65 -65 A REV 1.0 2015 JAN PAGE:1/2 RATING AND CHARACTERISTIC CURVES (GBL6005 THRU GBL610) FIG.2-MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT 6 5 4 Single Phase 3 Half Wave 60Hz Resistive Or Inductive Load 2 1 0 0 25 50 75 100 125 150 175 AMBIENT TEMPERATURE,( C) PEAK FORWARD SURGE CURRENT,(A) AVERAGE FORWARD CURRENT,(A) FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE 250 200 150 8.3ms Single Half Tj=25 C Sine Wave 100 JEDEC method 50 0 1 5 50 10 100 FIG.3-TYPICAL FORWARD FIG.4-TYPICAL REVERSE CHARACTERISTICS CHARACTERISTICS 50 50 10 10 REVERSE LEAKAGE CURRENT, ( A) INSTANTANEOUS FORWARD CURRENT,(A) NUMBER OF CYCLES AT 60Hz 3.0 1.0 Tj=25 C Pulse Width 300us 1% Duty Cycle 0.1 3.0 Tj=100 C 1.0 0.1 Tj=25 C .01 0 .2 .4 .6 .8 1.0 FORWARD VOLTAGE,(V) 1.2 1.4 .01 0 20 40 60 80 100 120 140 PERCENT OF RATED PEAK REVERSE VOLTAGE, (%) REV 1.0 2015 JAN PAGE:2/2
GBL610 价格&库存
很抱歉,暂时无法提供与“GBL610”相匹配的价格&库存,您可以联系我们找货
GBL610
  • 50+0.07473
  • 500+0.06678
  • 5000+0.06148
  • 10000+0.05883
  • 30000+0.05618
  • 50000+0.05459
