SL10100
10.0 AMP SCHOTTKY BARRIER RECTIFIERS
VOLTAGE RANGE
CURRENT
10.0 Ampere
0.264 (6.70)
0.248 (6.30)
1
0.073 (1.85)
0.069 (1.75)
2
3
0.028 (0.71)
0.016 (0.41)
0.216 (5.48)
0.208 (5.28)
■ Mechanical data
• Epoxy : UL94-V0 rated flame retardant.
• Case : Molded plastic, TO-277 .
• Lead : Solder plated, solderable per MIL-STD-750,
Method 2026.
• Polarity: Indicated by cathode band .
• Mounting Position : Any.
• Weight : Approximated 0.093 grams .
PIN 1
PIN 3
PIN 2
0.163 (4.13)
0.151 (3.83)
TO-277
■ Features
• Low forward voltage drop.
• Excellent high temperature stability.
• Fast switching capability.
• Suffix "G" indicates Halogen-free part, ex.CP10S45SG.
• Lead-free parts meet environmental standards of
MIL-STD-19500 /228
100 Volts
0.077 (1.96)
0.069 (1.76)
0.028 (0.71)
0.016 (0.41)
0.037 (0.95)
0.033 (0.85)
0.124 (3.15)
0.112 (2.85)
0.037 (0.95)
0.033 (0.85)
0.145 (3.69)
0.133 (3.39)
0.014 (0.35)
0.010 (0.25)
0.069 (1.74)
0.057 (1.44)
0.049 (1.25)
0.037 (0.95)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Rating 25 C ambient temperature uniess otherwies specified.
Single phase half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
TYPE NUMBER
SL10100
UNITS
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified Current
100
70
100
V
V
V
See Fig. 1
Peak Forward Surge Current, 8.3 ms single half sine-wave
10.0
A
150
A
V
A
superimposed on rated load (JEDEC method)
Maximum Instantaneous Forward Voltage at 10.0A
Maximum DC Reverse Current
Ta=25 C
at Rated DC Blocking Voltage
Ta=125 C
Typical Junction Capacitance (Note1)
Typical Thermal Resistance R JA (Note 2)
Operating Temperature Range TJ
Storage Temperature Range TSTG
0.67
100
0.70
0.85
250
60
to10+150
-55
-55 to +150
mA
pF
C/W
C
C
Note : 1.FR-4 PCB, 2oz.Copper.
2.Polymide PCB, 2oz.Copper.Cathode pad dimensions 18.8mm x 14.4mm.Anode pad dimensions 5.6mm x 14.4mm.
REV 1.0 2017 JAN
PAGE:1/2
RATING AND VHARACTERISTIC CURVES(SL10100)
REV 1.0 2017 JAN
PAGE:2/2
很抱歉,暂时无法提供与“SL10100”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.65564
- 100+0.60914
- 300+0.56264
- 500+0.51614
- 2000+0.49289
- 5000+0.47894
- 国内价格
- 5+1.53693
- 50+1.19887
- 150+1.05404
- 500+0.87325
- 2500+0.75923
- 5000+0.71092
- 国内价格
- 1+1.32000
- 100+1.01750
- 1250+0.84810
- 2500+0.77110
- 5000+0.71500
